[Mapbender-commits] r7429 - trunk/mapbender/http/javascripts
svn_mapbender at osgeo.org
Fri Jan 7 09:58:50 EST 2011
Author: kmq
Date: 2011-01-07 06:58:50 -0800 (Fri, 07 Jan 2011)
New Revision: 7429
trunk/mapbender/http/javascripts/mod_wfsGazetteerEditor_client.php
use resultList instead for displaying results
Modified: trunk/mapbender/http/javascripts/mod_wfsGazetteerEditor_client.php
--- trunk/mapbender/http/javascripts/mod_wfsGazetteerEditor_client.php 2011-01-07 14:41:00 UTC (rev 7428)
+++ trunk/mapbender/http/javascripts/mod_wfsGazetteerEditor_client.php 2011-01-07 14:58:50 UTC (rev 7429)
@@ -865,9 +865,10 @@
// empty the result geometry
- if(geomArray != null && geomArray.count()>0){
- geomArray.empty();
+// geomArray not used any more
+// if(geomArray != null && geomArray.count()>0){
+// geomArray.empty();
// set the Highlight object for the result geometry
var styleProperties = {"position":"absolute", "top":"0px", "left":"0px", "z-index":100};
@@ -912,9 +913,7 @@
if (!exportToShape) {
if (jsCode) {
if (typeof(geoObj) == 'object') {
- geomArray = new parent.GeometryArray();
- geomArray.importGeoJSON(geoObj);
- displayPopup(geomArray);
+ displayPopup(geoObj);
else {
displayPopup();
@@ -958,9 +957,7 @@
if (jsCode) {
else {
displayPopup();
@@ -1041,6 +1038,17 @@
function displayPopup(geom){
geomArray = geom;
+ if(!parent.$("#resultList")){
+ return;
+ var resultList = parent.$('#resultList').mapbender();
+ resultList.clear();
+ resultList.setTitle(global_wfsConfObj[global_selectedWfsConfId].wfs_conf_abstract);
+ resultList.setWFSconf(global_wfsConfObj[global_selectedWfsConfId]);
+ resultList.addFeatureCollection(geom);
+ resultList.show();
+ return;
var contentHtml = "Kein Ergebnis";
if (geomArray != null && geomArray.count() > 0){
contentHtml = createListOfGeometries();
More information about the Mapbender_commits
