[Mapbender-commits] r7435 - trunk/mapbender/resources/db
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Mon Jan 10 11:42:39 EST 2011
Author: armin11
Date: 2011-01-10 08:42:38 -0800 (Mon, 10 Jan 2011)
New Revision: 7435
   trunk/mapbender/resources/db/new_admin_gui.sql
some more content for new administration gui
Modified: trunk/mapbender/resources/db/new_admin_gui.sql
--- trunk/mapbender/resources/db/new_admin_gui.sql	2011-01-10 15:02:47 UTC (rev 7434)
+++ trunk/mapbender/resources/db/new_admin_gui.sql	2011-01-10 16:42:38 UTC (rev 7435)
@@ -1,74 +1,148 @@
 INSERT INTO gui (gui_id, gui_name, gui_description, gui_public) VALUES ('Administration','Administration','Dienstadmin',1);
 -- give root access to admin_wms_metadata
-INSERT INTO gui_mb_user (fkey_gui_id, fkey_mb_user_id, mb_user_type) VALUES ('Admin_Dienste', 1, 'owner');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration','i18n',1,1,'Internationalization module, collects data from all elements and sends them to the server in a single POST request. The strings are translated via gettext only.','Internationalization','div','','',NULL ,NULL,NULL ,NULL,NULL ,'','','div','../plugins/mb_i18n.js','','','','http://www.mapbender.org/Gettext');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration','jq_datatables',1,0,'Includes the jQuery plugin datatables, use like this
-$(selector).datatables(options)','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','../plugins/jq_datatables.js','../extensions/dataTables-1.5/media/js/jquery.dataTables.min.js','','','http://www.datatables.net/');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Administration','jq_datatables','defaultCss','../extensions/dataTables-1.5/media/css/demo_table_jui.css','','file/css');
+INSERT INTO gui_mb_user (fkey_gui_id, fkey_mb_user_id, mb_user_type) VALUES ('Administration', 1, 'owner');
+-- set category to administration guis
+INSERT into gui_gui_category VALUES ('Administration', 1);
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration','jq_ui',1,0,'The jQuery UI core','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.1.custom/development-bundle/ui/jquery.ui.core.js','','','');
 INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Administration','jq_ui','css','../extensions/jquery-ui-1.7.2.custom/css/ui-lightness/jquery-ui-1.7.2.custom.css','','file/css');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration','jq_upload',1,0,'','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../plugins/jq_upload.js','','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration','jq_ui_widget',1,0,'jQuery UI widget','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.1.custom/development-bundle/ui/jquery.ui.widget.js','','','');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration','globalWindowOpener',1,1,'Globel handler for an administration window','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','../javascripts/mod_windowOpener.js','','','','');
 INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Administration','globalWindowOpener','windowHeight','100','','var');
 INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Administration','globalWindowOpener','windowWidth','300','','var');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration','body',1,1,'Navigation','','body','','',0,0,200,40,NULL ,'','','','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration','body',1,1,'Navigation','','body','','',0,0,200,40,NULL ,'','','','../geoportal/mod_revertGuiSessionSettings.php','','','','');
 INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Administration','body','favicon','../img/favicon.png','favicon','php_var');
 INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Administration','body','includeWhileLoading','','show splash screen while the application is loading','php_var');
 INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Administration','body','popupcss','../css/popup.css','file css','file/css');
 INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Administration','body','tablesortercss','../css/tablesorter.css','file css','file/css');
 INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Administration','body','use_load_message','true','show splash screen while the application is loading','php_var');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration','owsproxy_collection',2,1,'Put existing divs in new div object. List the elements comma-separated under target, and make sure they have a title.','','div','','',0,160,200,30,NULL ,'','','div','../plugins/mb_div_collection.js','','owsproxy,owsproxy_icon','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration','i18n',1,1,'Internationalization module, collects data from all elements and sends them to the server in a single POST request. The strings are translated via gettext only.','Internationalization','div','','',NULL ,NULL,NULL ,NULL,NULL ,'','','div','../plugins/mb_i18n.js','','','','http://www.mapbender.org/Gettext');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration','jq_datatables',1,0,'Includes the jQuery plugin datatables, use like this
+$(selector).datatables(options)','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','../plugins/jq_datatables.js','../extensions/dataTables-1.5/media/js/jquery.dataTables.min.js','','','http://www.datatables.net/');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Administration','jq_datatables','defaultCss','../extensions/dataTables-1.5/media/css/demo_table_jui.css','','file/css');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration','jq_upload',1,0,'','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../plugins/jq_upload.js','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration','jq_ui_widget',1,0,'jQuery UI widget','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.1.custom/development-bundle/ui/jquery.ui.widget.js','','','');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration','wms_metadata_collection',2,1,'Put existing divs in new div object. List the elements comma-separated under target, and make sure they have a title.','','div','','',150,0,200,30,NULL ,'','','div','../plugins/mb_div_collection.js','','wms_metadata,wms_metadata_icon','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration','updateWMSs',2,1,'edit the elements of the gui','','a','','href="../php/mod_updateWMS.php?sessionID"''
-target="Mapbender Administration"  onclick="windowOpen(this.href,''Mapbender Administration'')"',80,15,NULL ,NULL,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','UPDATE WMS','a','','','','','http://www.mapbender.org/index.php/UpdateWMS');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration','updateWMSs_collection',2,1,'Put existing divs in new div object. List the elements comma-separated under target, and make sure they have a title.','','div','','',0,40,200,30,NULL ,'','','div','../plugins/mb_div_collection.js','','updateWMSs,updateWMSs_icon','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration','wmc_metadata',2,1,'wmc metadata editor','','a','','href = "../frames/index.php?guiID=admin_wmc_metadata"
-target="Mapbender Administration"   onclick="windowOpen(this.href,''Mapbender Administration'')"',80,15,NULL ,NULL,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','METADATA EDITOR','a','','','','','http://www.mapbender.org/index.php/DeleteWMS');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration','wmc_metadata_collection',2,1,'Put existing divs in new div object. List the elements comma-separated under target, and make sure they have a title.','','div','','',0,0,200,30,NULL ,'','','div','../plugins/mb_div_collection.js','','wmc_metadata,wmc_metadata_icon','','');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration','menu_wmc',2,1,'WMC admin menu','Admin WMC','div','','',NULL ,NULL,NULL ,NULL,NULL ,'','','div','../plugins/mb_div_collection.js','','wmc_metadata_collection','','');
 INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Administration','menu_wmc','css','../extensions/jquery-ui-1.7.2.custom/css/ui-lightness/jquery-ui-1.7.2.custom.css','','file/css');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration','menu_wfs',2,1,'WFS admin menu','Admin WFS','div','','',NULL ,NULL,NULL ,NULL,NULL ,'','','div','../plugins/mb_div_collection.js','','loadWFS_collection','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration','loadWFS',2,1,'load capabilities in a gui','','a','','href = "../php/mod_loadWFSCapabilities.php?sessionID" target="Mapbender Administration"  onclick="windowOpen(this.href,''Mapbender Administration'')"',80,15,NULL ,NULL,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','LOAD WFS','a','','','','','http://www.mapbender.org/index.php/WFS_Konfiguration');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration','menu_user',2,1,'User admin menu','Admin User','div','','',NULL ,NULL,NULL ,NULL,NULL ,'','','div','../plugins/mb_div_collection.js','','','','');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration','monitor_results_collection',2,1,'Put existing divs in new div object. List the elements comma-separated under target, and make sure they have a title.','','div','','',0,200,200,30,NULL ,'','','div','../plugins/mb_div_collection.js','','monitor_results,monitor_results_icon','','');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration','monitor_results_icon',2,1,'icon','','img','../img/gnome/preferences-desktop-remote-desktop.png','',0,0,NULL ,NULL,2,'','','','','','','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration','deleteWMS',2,1,'delete wms','','a','','href = "../php/mod_deleteWMS.php?sessionID"
-target="Mapbender Administration"   onclick="windowOpen(this.href,''Mapbender Administration'')"',80,15,NULL ,NULL,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','DELETE WMS','a','','','','','http://www.mapbender.org/index.php/DeleteWMS');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration','loadWMS',2,1,'load capabilities in a gui','','a','','href = "../php/mod_loadCapabilities.php?sessionID" target="Mapbender Administration"
-onclick="windowOpen(this.href,''Mapbender Administration'')"',80,15,NULL ,NULL,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','LOAD WMS','a','','','','','http://www.mapbender.org/index.php/Add_new_maps_to_Mapbender');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration','editGUI_WMS',2,1,'edit the elements of the gui','','a','','href="../php/mod_editGuiWms.php?sessionID"''
-target="Mapbender Administration"  onclick="windowOpen(this.href,''Mapbender Administration'')"',80,15,NULL ,NULL,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','EDIT GUI-WMS','a','','','','','http://www.mapbender.org/index.php/Edit_GUI_WMS');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Administration','editGUI_WMS','file_css','../css/edit_gui.css','','file/css');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration','monitor_results',2,1,'','Monitoring results','a','','href = "../php/mod_monitorCapabilities_read.php?sessionID"  target="Mapbender Administration"
-onclick="windowOpen(this.href,''Mapbender Administration'')"',80,15,NULL ,NULL,2,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','MONITORING RESULTS','a','','','','','http://www.mapbender.org/');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration','owsproxy',2,1,'secure services','','a','','href="../php/mod_owsproxy_conf.php?sessionID"'' target="Mapbender Administration" onclick="windowOpen(this.href,''Mapbender Administration'')"',80,15,NULL ,NULL,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','OWSPROXY','a','','','','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration','wms_metadata_icon',2,1,'icon','','img','../img/gnome/preferences-desktop-personal.png','',0,0,NULL ,NULL,2,'','','','','','','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration','wms_metadata',2,1,'wms metadata editor','','a','','href = "../frames/index.php?guiID=admin_wms_metadata"
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration','menu_wms',2,1,'WMS admin menu','Admin WMS','div','','',NULL ,NULL,NULL ,NULL,NULL ,'','','div','../plugins/mb_div_collection.js','','loadWMS_collection,updateWMSs_collection,deleteWMS_collection,editGUI_WMS_collection,owsproxy_collection,monitor_results_collection,wms_metadata_collection','','');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Administration','menu_wms','css','../extensions/jquery-ui-1.7.2.custom/css/ui-lightness/jquery-ui-1.7.2.custom.css','','file/css');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration','wmc_metadata_icon',2,1,'icon','','img','../img/gnome/preferences-desktop-personal.png','',0,0,NULL ,NULL,2,'','','','','','','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration','loadWFS_collection',2,1,'Put existing divs in new div object. List the elements comma-separated under target, and make sure they have a title.','','div','','',0,0,200,30,NULL ,'','','div','../plugins/mb_div_collection.js','','loadWFS,loadWFS_icon','','');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration','loadWFS_icon',2,1,'icon','','img','../img/gnome/document-save.png','',0,0,NULL ,NULL,2,'','','','','','','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration','menu_gui',2,1,'GUI admin menu','Admin GUI','div','','',NULL ,NULL,NULL ,NULL,NULL ,'','','div','../plugins/mb_div_collection.js','','','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration','loadWMS_collection',2,1,'Put existing divs in new div object. List the elements comma-separated under target, and make sure they have a title.','','div','','',0,0,200,30,NULL ,'','','div','../plugins/mb_div_collection.js','','loadWMS,loadWMS_icon','','');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration','updateWMSs_icon',2,1,'icon','','img','../img/gnome/view-refresh.png','',0,0,NULL ,NULL,2,'','','','','','','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration','mb_horizontal_accordion',2,1,'Put existing divs in new horizontal accordion div object. List the elements comma-separated under target, and make sure they have a title.','','div','','',0,0,NULL ,NULL,NULL ,'','<dl></dl>','div','../plugins/mb_horizontal_accordion.js','../../extensions/jqueryEasyAccordion/jquery.easyAccordion.js','menu_wms,menu_wfs,menu_wmc,menu_user,menu_gui','','');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Administration','mb_horizontal_accordion','Accordion css file','../extensions/jqueryEasyAccordion/mb_jquery.easyAccordion.css','','file/css');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration','jq_ui_mouse',2,0,'jQuery UI mouse','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.1.custom/development-bundle/ui/jquery.ui.mouse.js','','jq_ui_widget','');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration','jq_ui_position',2,0,'jQuery UI position','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.1.custom/development-bundle/ui/jquery.ui.position.js','','','');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration','jq_ui_mouse',2,0,'jQuery UI mouse','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.1.custom/development-bundle/ui/jquery.ui.mouse.js','','jq_ui_widget','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration','wms_metadata',2,1,'wms metadata editor','','a','','href = "../frames/index.php?guiID=admin_wms_metadata"
+target="Mapbender Administration"   onclick="window.parent.document.getElementById(''AdminFrame'').parentNode.removeChild(window.parent.document.getElementById(''AdminFrame''));windowOpen(this.href,''Mapbender Administration'')" ',80,15,NULL ,NULL,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','METADATA EDITOR','a','','','','','http://www.mapbender.org/index.php/DeleteWMS');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration','loadWMS_icon',2,1,'icon','','img','../img/gnome/document-save.png','',0,0,NULL ,NULL,2,'','','','','','','','');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration','editGUI_WMS_collection',2,1,'Put existing divs in new div object. List the elements comma-separated under target, and make sure they have a title.','','div','','',0,120,200,30,NULL ,'','','div','../plugins/mb_div_collection.js','','editGUI_WMS,editGUI_WMS_icon','','');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration','deleteWMS_icon',2,1,'icon','','img','../img/gnome/edit-delete.png','',0,0,NULL ,NULL,2,'','','','','','','','');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration','editGUI_WMS_icon',2,1,'icon','','img','../img/gnome/preferences-other.png','',0,0,NULL ,NULL,2,'','','','','','','','');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration','deleteWMS_collection',2,1,'Put existing divs in new div object. List the elements comma-separated under target, and make sure they have a title.','','div','','',0,80,200,30,NULL ,'','','div','../plugins/mb_div_collection.js','','deleteWMS,deleteWMS_icon','','');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration','owsproxy_icon',2,1,'icon','','img','../img/gnome/emblem-readonly.png','',0,0,NULL ,NULL,2,'','','','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration','updateWMSs',2,1,'edit the elements of the gui','','a','','href="../php/mod_updateWMS.php?sessionID"''
+target="Mapbender Administration"  onclick="window.parent.document.getElementById(''AdminFrame'').parentNode.removeChild(window.parent.document.getElementById(''AdminFrame''));windowOpen(this.href,''Mapbender Administration'')" ',80,15,NULL ,NULL,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','UPDATE WMS','a','','','','','http://www.mapbender.org/index.php/UpdateWMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration','wfs_metadata',2,1,'wfs metadata editor','','a','','href = "../frames/index.php?guiID=admin_wfs_metadata"
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration','wmc_metadata',2,1,'wmc metadata editor','','a','','href = "../frames/index.php?guiID=admin_wmc_metadata"
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration','wms_mail_abo',2,1,'send mail to user which have abos','','a','','href = "../php/mod_abo_show.php?sessionID"
+target="Mapbender Administration"   onclick="window.parent.document.getElementById(''AdminFrame'').parentNode.removeChild(window.parent.document.getElementById(''AdminFrame''));windowOpen(this.href,''Mapbender Administration'')" ',80,15,NULL ,NULL,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','MAIL ABO','a','','','','','http://www.mapbender.org/index.php/DeleteWMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration','wfs_metadata_icon',2,1,'icon','','img','../img/gnome/preferences-desktop-personal.png','',0,0,NULL ,NULL,2,'','','','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration','wfs_metadata_collection',2,1,'Put existing divs in new div object. List the elements comma-separated under target, and make sure they have a title.','','div','','',150,0,200,30,NULL ,'','','div','../plugins/mb_div_collection.js','','wfs_metadata,wfs_metadata_icon','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration','wms_metadata_icon',2,1,'icon','','img','../img/gnome/preferences-desktop-personal.png','',0,0,NULL ,NULL,2,'','','','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration','wms_mail_abo_icon',2,1,'icon','','img','../img/gnome/mail-message-new.png','',0,0,NULL ,NULL,2,'','','','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration','menu_wms',2,1,'WMS admin menu','Admin WMS','div','','',NULL ,NULL,NULL ,NULL,NULL ,'','','div','../plugins/mb_div_collection.js','','loadWMS_collection,updateWMSs_collection,deleteWMS_collection,editGUI_WMS_collection,owsproxy_collection,monitor_results_collection,wms_metadata_collection,wms_mail_abo_collection','','');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Administration','menu_wms','css','../extensions/jquery-ui-1.7.2.custom/css/ui-lightness/jquery-ui-1.7.2.custom.css','','file/css');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration','wms_mail_abo_collection',2,1,'Put existing divs in new div object. List the elements comma-separated under target, and make sure they have a title.','','div','','',150,40,200,30,NULL ,'','','div','../plugins/mb_div_collection.js','','wms_mail_abo,wms_mail_abo_icon','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration','updateWFS_icon',2,1,'icon','','img','../img/gnome/view-refresh.png','',0,0,NULL ,NULL,2,'','','','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration','updateWFS_collection',2,1,'Put existing divs in new div object. List the elements comma-separated under target, and make sure they have a title.','','div','','',0,40,200,30,NULL ,'','','div','../plugins/mb_div_collection.js','','updateWFS,updateWFS_icon','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration','deleteWFS_icon',2,1,'icon','','img','../img/gnome/edit-delete.png','',0,0,NULL ,NULL,2,'','','','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration','deleteWFS_collection',2,1,'Put existing divs in new div object. List the elements comma-separated under target, and make sure they have a title.','','div','','',0,80,200,30,NULL ,'','','div','../plugins/mb_div_collection.js','','deleteWFS,deleteWFS_icon','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration','editGUI_WFS_icon',2,1,'icon','','img','../img/gnome/preferences-other.png','',0,0,NULL ,NULL,2,'','','','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration','editGUI_WFS_collection',2,1,'Put existing divs in new div object. List the elements comma-separated under target, and make sure they have a title.','','div','','',0,120,200,30,NULL ,'','','div','../plugins/mb_div_collection.js','','editGUI_WFS,editGUI_WFS_icon','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration','owsproxy_collection',2,1,'Put existing divs in new div object. List the elements comma-separated under target, and make sure they have a title.','','div','','',0,160,200,30,NULL ,'','','div','../plugins/mb_div_collection.js','','owsproxy,owsproxy_icon','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration','owsproxy_wfs_collection',2,1,'Put existing divs in new div object. List the elements comma-separated under target, and make sure they have a title.','','div','','',0,160,200,30,NULL ,'','','div','../plugins/mb_div_collection.js','','owsproxy_wfs,owsproxy_wfs_icon','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration','owsproxy_wfs_icon',2,1,'icon','','img','../img/gnome/emblem-readonly.png','',0,0,NULL ,NULL,2,'','','','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration','wfs_conf_icon',2,1,'icon','','img','../img/gnome/preferences-other.png','',0,0,NULL ,NULL,2,'','','','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration','wfs_conf_collection',2,1,'Put existing divs in new div object. List the elements comma-separated under target, and make sure they have a title.','','div','','',150,80,200,30,NULL ,'','','div','../plugins/mb_div_collection.js','','wfs_conf,wfs_conf_icon','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration','wfs_conf',2,1,'configure wfs','','a','','href = "../php/mod_wfs_conf_client.php"
+target="AdminFrame"',80,15,NULL ,NULL,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','FEATURETYPE-CONF','a','','','','AdminFrame','http://www.mapbender.org/index.php/DeleteWMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration','updateWFS',2,1,'edit the elements of the gui','','a','','href="../javascripts/mod_wfs_client.html"
+target="AdminFrame"',80,15,NULL ,NULL,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','UPDATE WFS','a','','','','AdminFrame','http://www.mapbender.org/index.php/UpdateWMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration','AdminFrame',2,1,'the frame for administration modules','','iframe','','frameborder = "0"',0,320,900,1000,NULL ,'','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration','editGUI_WFS',2,1,'edit the elements of the gui','','a','','href="../javascripts/mod_wfs_client.html"
+target="AdminFrame"',80,15,NULL ,NULL,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','EDIT GUI-WFS','a','','','','AdminFrame','http://www.mapbender.org/index.php/Edit_GUI_WMS');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Administration','editGUI_WFS','file_css','../css/edit_gui.css','','file/css');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration','owsproxy_wfs',2,1,'secure services','','a','','href="../javascripts/mod_wfs_client.html" target="AdminFrame"',80,15,NULL ,NULL,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','OWSPROXY WFS','a','','','','AdminFrame','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration','deleteWFSConf_collection',2,1,'Put existing divs in new div object. List the elements comma-separated under target, and make sure they have a title.','','div','','',150,120,200,30,NULL ,'','','div','../plugins/mb_div_collection.js','','deleteWFSConf,deleteWFSConf_icon','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration','deleteWFSConf',2,1,'delete wfs conf','','a','','href = "../javascripts/mod_deleteWfsConf_client.html" target="AdminFrame"',80,15,250,20,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','DELETE FEATURETYPE-CONF','a','','','','AdminFrame','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration','menu_wfs',2,1,'WFS admin menu','Admin WFS','div','','',NULL ,NULL,NULL ,NULL,NULL ,'','','div','../plugins/mb_div_collection.js','','loadWFS_collection,updateWFS_collection,editGUI_WFS_collection,deleteWFS_collection,wfs_metadata_collection,owsproxy_wfs_collection,wfs_conf_collection,deleteWFSConf_collection','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration','editFilteredGroup_collection',2,1,'Put existing divs in new div object. List the elements comma-separated under target, and make sure they have a title.','','div','','',0,40,200,30,NULL ,'','','div','../plugins/mb_div_collection.js','','editFilteredGroup,editFilteredGroup_icon','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration','menu_user',2,1,'User admin menu','Admin User','div','','',NULL ,NULL,NULL ,NULL,NULL ,'','','div','../plugins/mb_div_collection.js','','editFilteredUser_collection,editFilteredGroup_collection,filteredGroup_User_collection','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration','filteredGroup_User_collection',2,1,'Put existing divs in new div object. List the elements comma-separated under target, and make sure they have a title.','','div','','',0,80,200,30,NULL ,'','','div','../plugins/mb_div_collection.js','','filteredGroup_User,filteredGroup_User_icon','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration','editFilteredGroup_icon',2,1,'icon','','img','../img/gnome/editMyGroup.png','',0,0,NULL ,NULL,2,'','','','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration','newGui_collection',2,1,'Put existing divs in new div object. List the elements comma-separated under target, and make sure they have a title.','','div','','',0,0,200,30,NULL ,'','','div','../plugins/mb_div_collection.js','','newGui,newGui_icon','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration','loadWMS_collection',2,1,'Put existing divs in new div object. List the elements comma-separated under target, and make sure they have a title.','','div','','',0,0,200,30,NULL ,'','','div','../plugins/mb_div_collection.js','','loadWMS,loadWMS_icon','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration','loadWFS_collection',2,1,'Put existing divs in new div object. List the elements comma-separated under target, and make sure they have a title.','','div','','',0,0,200,30,NULL ,'','','div','../plugins/mb_div_collection.js','','loadWFS,loadWFS_icon','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration','newGui_icon',2,1,'icon','','img','../img/gnome/newGui.png','',0,0,NULL ,NULL,2,'','','','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration','rename_copy_gui_icon',2,1,'icon','','img','../img/gnome/edit-copy.png','',0,0,NULL ,NULL,2,'','','','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration','rename_copy_gui_collection',2,1,'Put existing divs in new div object. List the elements comma-separated under target, and make sure they have a title.','','div','','',0,40,200,30,NULL ,'','','div','../plugins/mb_div_collection.js','','rename_copy_Gui,rename_copy_gui_icon','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration','deleteWFSConf_icon',2,1,'icon','','img','../img/gnome/edit-delete.png','',0,0,NULL ,NULL,2,'','','','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration','editElements_icon',2,1,'icon','','img','../img/gnome/editGuiElements.png','',0,0,NULL ,NULL,2,'','','','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration','editElements_collection',2,1,'Put existing divs in new div object. List the elements comma-separated under target, and make sure they have a title.','','div','','',0,120,200,30,NULL ,'','','div','../plugins/mb_div_collection.js','','editElements,editElements_icon','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration','delete_filteredGui_collection',2,1,'Put existing divs in new div object. List the elements comma-separated under target, and make sure they have a title.','','div','','',0,80,200,30,NULL ,'','','div','../plugins/mb_div_collection.js','','delete_filteredGui,delete_filteredGui_icon','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration','delete_filteredGui_icon',2,1,'icon','','img','../img/gnome/deleteGui.png','',0,0,NULL ,NULL,2,'','','','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration','deleteGui_icon',2,0,'icon','','img','../img/gnome/deleteGui.png','',0,0,NULL ,NULL,2,'','','','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration','deleteGui',2,0,'delete gui','','a','','href = "../php/mod_deleteGUI.php?sessionID" target="Mapbender Administration"
+onclick="windowOpen(this.href,''Mapbender Administration'')"',80,15,200,20,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','DELETE GUI','a','','','','','http://www.mapbender.org/index.php/DeleteGUI');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration','menu_gui',2,1,'GUI admin menu','Admin GUI','div','','',NULL ,NULL,NULL ,NULL,NULL ,'','','div','../plugins/mb_div_collection.js','','newGui_collection,rename_copy_gui_collection,delete_filteredGui_collection,editElements_collection,category_filteredGui_collection','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration','category_filteredGui_icon',2,1,'icon','','img','../img/gnome/myGuiCategories.png','',0,0,NULL ,NULL,2,'','','','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration','category_filteredGui_collection',2,1,'Put existing divs in new div object. List the elements comma-separated under target, and make sure they have a title.','','div','','',0,160,200,30,NULL ,'','','div','../plugins/mb_div_collection.js','','category_filteredGUI,category_filteredGui_icon','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration','mb_horizontal_accordion',2,1,'Put existing divs in new horizontal accordion div object. List the elements comma-separated under target, and make sure they have a title.','','div','','',0,0,NULL ,NULL,NULL ,'','<dl></dl>','div','../plugins/mb_horizontal_accordion.js','../../extensions/jqueryEasyAccordion/jquery.easyAccordion.js','menu_wms,menu_wfs,menu_wmc,menu_user,menu_gui,menu_auth','','');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Administration','mb_horizontal_accordion','Accordion css file','../extensions/jqueryEasyAccordion/mb_jquery.easyAccordion.css','','file/css');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration','filteredGui_user_collection',2,1,'Put existing divs in new div object. List the elements comma-separated under target, and make sure they have a title.','','div','','',0,0,200,30,NULL ,'','','div','../plugins/mb_div_collection.js','','filteredGui_user,filteredGui_user_icon','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration','filteredGui_user_icon',2,1,'icon','','img','../img/gnome/myGuiUser.png','',0,0,NULL ,NULL,2,'','','','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration','filteredGui_group_icon',2,1,'icon','','img','../img/gnome/myGuiGroup.png','',0,0,NULL ,NULL,2,'','','','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration','filteredGui_group_collection',2,1,'Put existing divs in new div object. List the elements comma-separated under target, and make sure they have a title.','','div','','',0,40,200,30,NULL ,'','','div','../plugins/mb_div_collection.js','','filteredGui_Group,filteredGui_group_icon','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration','editFilteredUser_icon',2,0,'icon','','img','../img/gnome/editMyUser.png','',0,0,NULL ,NULL,2,'','','','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration','editFilteredUser_collection',2,0,'Put existing divs in new div object. List the elements comma-separated under target, and make sure they have a title.','','div','','',0,0,200,30,NULL ,'','','div','../plugins/mb_div_collection.js','','editFilteredUser,editFilteredUser_icon','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration','editFilteredUser',2,0,'save, edit, delete user where this admin is owner','','a','','href = "../php/mod_editFilteredUser.php?sessionID" target="Mapbender Administration"
+onclick="windowOpen(this.href,''Mapbender Administration'')"',80,15,200,20,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','EDIT myUSER','a','','','','','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Administration','editFilteredUser','withPasswordInsertion','true','define if admin can set the new user','php_var');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration','filteredGroup_User_icon',2,1,'icon','','img','../img/gnome/myGroupUser.png','',0,0,NULL ,NULL,2,'','','','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration','filteredGui_filteredGroup_icon',2,1,'icon','','img','../img/gnome/myGuiMyGroup.png','',0,0,NULL ,NULL,2,'','','','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration','filteredGui_filteredGroup_collection',2,1,'Put existing divs in new div object. List the elements comma-separated under target, and make sure they have a title.','','div','','',0,80,200,30,NULL ,'','','div','../plugins/mb_div_collection.js','','filteredGui_filteredGroup,filteredGui_filteredGroup_icon','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration','menu_auth',2,1,'GUI admin menu','Authentication','div','','',NULL ,NULL,NULL ,NULL,NULL ,'','','div','../plugins/mb_div_collection.js','','filteredGui_user_collection,filteredGui_group_collection,filteredGui_filteredGroup_collection','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration','filteredGui_filteredGroup',2,1,'allocate guis of this admin to groups where this admin is owner','','a','','href = "../php/mod_filteredGui_filteredGroup.php?sessionID&e_id_css=filteredGui_filteredGroup" target="Mapbender Administration"   onclick="window.parent.document.getElementById(''AdminFrame'').parentNode.removeChild(window.parent.document.getElementById(''AdminFrame''));windowOpen(this.href,''Mapbender Administration'')"',80,15,200,20,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','myGUI -> myGROUP','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Administration','filteredGui_filteredGroup','file css','../css/administration_alloc.css','file css','file/css');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration','category_filteredGUI',2,1,'add Gui to Category','','a','','href = "../php/mod_category_filteredGUI.php?sessionID&e_id_css=filteredUser_filteredGroup" target="Mapbender Administration"  onclick="window.parent.document.getElementById(''AdminFrame'').parentNode.removeChild(window.parent.document.getElementById(''AdminFrame''));windowOpen(this.href,''Mapbender Administration'')" ',80,15,190,20,10,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','add GUI to Category','a','','','','','http://www.mapbender.org/GUI_Category');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Administration','category_filteredGUI','cssfile','../css/administration_alloc.css','css file for admin module','file/css');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration','deleteWFS',2,1,'delete wfs','','a','','href = "../php/mod_deleteWFS.php?sessionID"
+target="Mapbender Administration"  onclick="window.parent.document.getElementById(''AdminFrame'').parentNode.removeChild(window.parent.document.getElementById(''AdminFrame''));windowOpen(this.href,''Mapbender Administration'')" ',80,15,NULL ,NULL,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','DELETE WFS','a','','','','','http://www.mapbender.org/index.php/DeleteWMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration','deleteWMS',2,1,'delete wms','','a','','href = "../php/mod_deleteWMS.php?sessionID"
+target="Mapbender Administration"   onclick="window.parent.document.getElementById(''AdminFrame'').parentNode.removeChild(window.parent.document.getElementById(''AdminFrame''));windowOpen(this.href,''Mapbender Administration'')"',80,15,NULL ,NULL,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','DELETE WMS','a','','','','','http://www.mapbender.org/index.php/DeleteWMS');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration','delete_filteredGui',2,1,'delete guis of this admin','','a','','href = "../php/mod_deleteFilteredGUI.php?sessionID"  target="Mapbender Administration" onclick="window.parent.document.getElementById(''AdminFrame'').parentNode.removeChild(window.parent.document.getElementById(''AdminFrame''));windowOpen(this.href,''Mapbender Administration'')"',80,15,200,20,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','DELETE myGUI','a','','','','','http://www.mapbender.org/index.php/DeleteGUI');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration','editElements',2,1,'edit gui elements','','a','','href = "../php/mod_editElements.php?sessionID" target="Mapbender Administration" onclick="window.parent.document.getElementById(''AdminFrame'').parentNode.removeChild(window.parent.document.getElementById(''AdminFrame''));windowOpen(this.href,''Mapbender Administration'')"
+',80,15,200,20,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none;color: #808080;','EDIT GUI-ELEMENTS','a','','','','','http://www.mapbender.org/index.php/Edit_GUI_Elements');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration','editFilteredGroup',2,1,'edit group of this admin','','a','','href = "../php/mod_editFilteredGroup.php?sessionID" target="Mapbender Administration" onclick="window.parent.document.getElementById(''AdminFrame'').parentNode.removeChild(window.parent.document.getElementById(''AdminFrame''));windowOpen(this.href,''Mapbender Administration'')"',80,15,200,20,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','EDIT myGROUP','a','','','','','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration','editGUI_WMS',2,1,'edit the elements of the gui','','a','','href="../php/mod_editGuiWms.php?sessionID"
+target="Mapbender Administration" onclick="window.parent.document.getElementById(''AdminFrame'').parentNode.removeChild(window.parent.document.getElementById(''AdminFrame''));windowOpen(this.href,''Mapbender Administration'')"',80,15,NULL ,NULL,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','EDIT GUI-WMS','a','','','','','http://www.mapbender.org/index.php/Edit_GUI_WMS');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Administration','editGUI_WMS','file_css','../css/edit_gui.css','','file/css');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration','filteredGroup_User',2,1,'allocate groups of this admin to user','','a','','href = "../php/mod_filteredGroup_User.php?sessionID&e_id_css=filteredGroup_User" target="Mapbender Administration" onclick="window.parent.document.getElementById(''AdminFrame'').parentNode.removeChild(window.parent.document.getElementById(''AdminFrame''));windowOpen(this.href,''Mapbender Administration'')"',80,15,200,20,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','myGROUP -> USER','a','','','','','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Administration','filteredGroup_User','file css','../css/administration_alloc.css','file css','file/css');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration','filteredGui_Group',2,1,'allocate guis to groups','','a','','href = "../php/mod_filteredGui_group.php?sessionID&e_id_css=filteredGui_Group" target="Mapbender Administration"  onclick="window.parent.document.getElementById(''AdminFrame'').parentNode.removeChild(window.parent.document.getElementById(''AdminFrame''));windowOpen(this.href,''Mapbender Administration'')"',80,15,200,20,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','myGUI -> GROUP ','a','','','','AdminFrame','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Administration','filteredGui_Group','file css','../css/administration_alloc.css','file css','file/css');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration','filteredGui_user',2,1,'allocate the guis of this admin to a user','','a','','href = "../php/mod_filteredGui_User.php?sessionID&e_id_css=filteredGui_user" target="Mapbender Administration" onclick="window.parent.document.getElementById(''AdminFrame'').parentNode.removeChild(window.parent.document.getElementById(''AdminFrame''));windowOpen(this.href,''Mapbender Administration'')"',80,15,200,20,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','myGUI -> USER ','a','','','','','http://www.mapbender.org/index.php/user');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Administration','filteredGui_user','file css','../css/administration_alloc.css','a file css','file/css');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration','loadWFS',2,1,'load capabilities in a gui','','a','','href = "../php/mod_loadWFSCapabilities.php?sessionID" target="Mapbender Administration"  onclick="window.parent.document.getElementById(''AdminFrame'').parentNode.removeChild(window.parent.document.getElementById(''AdminFrame''));windowOpen(this.href,''Mapbender Administration'')"',80,15,NULL ,NULL,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','LOAD WFS','a','','','','','http://www.mapbender.org/index.php/WFS_Konfiguration');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration','loadWMS',2,1,'load capabilities in a gui','','a','','href = "../php/mod_loadCapabilities.php?sessionID" target="Mapbender Administration" onclick="window.parent.document.getElementById(''AdminFrame'').parentNode.removeChild(window.parent.document.getElementById(''AdminFrame''));windowOpen(this.href,''Mapbender Administration'')" ',80,15,NULL ,NULL,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','LOAD WMS','a','','','','','http://www.mapbender.org/index.php/Add_new_maps_to_Mapbender');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration','monitor_results',2,1,'','Monitoring results','a','','href = "../php/mod_monitorCapabilities_read.php?sessionID"  target="Mapbender Administration" onclick="window.parent.document.getElementById(''AdminFrame'').parentNode.removeChild(window.parent.document.getElementById(''AdminFrame''));windowOpen(this.href,''Mapbender Administration'')" ',80,15,NULL ,NULL,2,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','MONITORING RESULTS','a','','','','','http://www.mapbender.org/');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration','newGui',2,1,'create a new gui','','a','','href = "../php/mod_newGui.php?sessionID" target="Mapbender Administration" onclick="window.parent.document.getElementById(''AdminFrame'').parentNode.removeChild(window.parent.document.getElementById(''AdminFrame''));windowOpen(this.href,''Mapbender Administration'')" ',80,15,200,20,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none;color: #808080;','NEW GUI','a','','','','','http://www.mapbender.org/index.php/newGUI');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration','owsproxy',2,1,'secure services','','a','','href="../php/mod_owsproxy_conf.php?sessionID"'' target="Mapbender Administration" onclick="window.parent.document.getElementById(''AdminFrame'').parentNode.removeChild(window.parent.document.getElementById(''AdminFrame''));windowOpen(this.href,''Mapbender Administration'')" ',80,15,NULL ,NULL,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','OWSPROXY','a','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration','rename_copy_Gui',2,1,'rename and copy gui','','a','','href = "../php/mod_renameGUI.php?sessionID" target="Mapbender Administration"  onclick="window.parent.document.getElementById(''AdminFrame'').parentNode.removeChild(window.parent.document.getElementById(''AdminFrame''));windowOpen(this.href,''Mapbender Administration'')" ',80,15,200,20,NULL ,'font-family: Arial, Helvetica, sans-serif; font-size : 12px; text-decoration : none; color: #808080;','RENAME COPY GUI','a','','','','','');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration','jq_ui_droppable',4,0,'jQuery UI droppable','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.1.custom/development-bundle/ui/jquery.ui.droppable.js','','jq_ui,jq_ui_widget,jq_ui_mouse,jq_ui_draggable','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration','jq_ui_tabs',5,0,'horizontal tabs from the jQuery UI framework','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.1.custom/development-bundle/ui/jquery.ui.tabs.js','','jq_ui,jq_ui_widget','');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration','jq_ui_resizable',5,0,'Resizable from the jQuery UI framework','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','../plugins/jq_ui_resizable.js','../extensions/jquery-ui-1.8.1.custom/development-bundle/ui/jquery.ui.resizable.js','','jq_ui,jq_ui_mouse,jq_ui_widget','http://jqueryui.com/demos/resizable/');
-INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration','jq_ui_tabs',5,0,'horizontal tabs from the jQuery UI framework','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.1.custom/development-bundle/ui/jquery.ui.tabs.js','','jq_ui,jq_ui_widget','');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Administration','jq_ui_draggable',5,0,'Draggable from the jQuery UI framework','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.1.custom/development-bundle/ui/jquery.ui.draggable.js','','jq_ui,jq_ui_mouse,jq_ui_widget','http://jqueryui.com/demos/draggable/');
More information about the Mapbender_commits mailing list
