[Mapbender-commits] r7465 - trunk/mapbender/http/php
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Fri Jan 21 01:26:57 EST 2011
Author: armin11
Date: 2011-01-20 22:26:57 -0800 (Thu, 20 Jan 2011)
New Revision: 7465
   trunk/mapbender/http/php/mod_callMetadata.php
Give titles for orderBy and maxResults to show them as header for the resultList auf a metadata search
Modified: trunk/mapbender/http/php/mod_callMetadata.php
--- trunk/mapbender/http/php/mod_callMetadata.php	2011-01-20 16:29:20 UTC (rev 7464)
+++ trunk/mapbender/http/php/mod_callMetadata.php	2011-01-21 06:26:57 UTC (rev 7465)
@@ -42,7 +42,7 @@
 #$searchResources = "wms";
 $searchPages = "1";
 $resultTarget = "debug";
-$preDefinedMaxResults = array(5,10,15,20);
+$preDefinedMaxResults = array(5,10,15,20,25,30);
 $searchEPSG = "EPSG:31466";
 $classJSON = new Mapbender_JSON;
 #$tempFolder = "/tmp";
@@ -716,6 +716,7 @@
 //generate filter for different maxResults entries
 //$preDefinedMaxResults
 if ($_REQUEST["maxResults"] == '') {
+	$queryJSON->searchFilter->maxResults->header = $maxResultsTitle['header'];
 	$queryJSON->searchFilter->maxResults->title = $preDefinedMaxResults[0];
 	for ($i=0; $i<(count($preDefinedMaxResults)-1); $i++) {
 		$queryJSON->searchFilter->maxResults->item[$i]->title = $preDefinedMaxResults[$i+1];
@@ -723,6 +724,7 @@
 } else {
 	if (in_array($maxResults, $preDefinedMaxResults)) { //is part of preDefined array
 		$queryJSON->searchFilter->maxResults->title = $maxResults;
 		//delete entry from array
 		//$preDefinedMaxResultsRed = deleteEntry($preDefinedMaxResults, $maxResults);
@@ -731,6 +733,7 @@
 			$queryJSON->searchFilter->maxResults->item[$i]->url = $searchURL."&maxResults=".$preDefinedMaxResults[$i];
 	} else { // is some other value
 		for ($i=0; $i<(count($preDefinedMaxResults)); $i++) {
 			$queryJSON->searchFilter->maxResults->item[$i]->title = $preDefinedMaxResults[$i];
@@ -749,6 +752,7 @@
 //$queryJSON->searchFilter = (object) array();
 if ($_REQUEST["orderBy"] == '') {
 //echo "<br>orderBy:>".$_REQUEST["orderBy"]."<<br>";
+	$queryJSON->searchFilter->orderFilter->header = $orderByTitle['header'];
 	$queryJSON->searchFilter->orderFilter->title = $orderByTitle['rank'];
 	$queryJSON->searchFilter->orderFilter->item[0]->title = $orderByTitle['title'];
 	$queryJSON->searchFilter->orderFilter->item[0]->url = $searchURL."&orderBy=title";
@@ -760,6 +764,7 @@
 } else {
 //read out actual order filter
 switch ($orderBy) {
 					case "rank":
More information about the Mapbender_commits mailing list
