[Mapbender-commits] r7488 -
trunk/mapbender/resources/db/pgsql/UTF-8/update
svn_mapbender at osgeo.org
Fri Jan 28 11:38:39 EST 2011
Author: astrid_emde
Date: 2011-01-28 08:38:39 -0800 (Fri, 28 Jan 2011)
New Revision: 7488
trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.7rc1_to_2.7rc2_pgsql_UTF-8.sql
Grant options deleted, drop view
Modified: trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.7rc1_to_2.7rc2_pgsql_UTF-8.sql
--- trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.7rc1_to_2.7rc2_pgsql_UTF-8.sql 2011-01-28 13:53:27 UTC (rev 7487)
+++ trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.7rc1_to_2.7rc2_pgsql_UTF-8.sql 2011-01-28 16:38:39 UTC (rev 7488)
@@ -2,13 +2,12 @@
--bugfix for template_openlayers #759
UPDATE gui_element set e_pos='2' WHERE e_id='jq_ui_position';
--new function to get the load_count of wmc which are stored in the mapbender database
-- Function: f_wmc_load_count(integer)
--- DROP FUNCTION f_wmc_load_count(integer);
CREATE OR REPLACE FUNCTION f_wmc_load_count(integer)
RETURNS integer AS
$BODY$
@@ -25,13 +24,14 @@
$BODY$
LANGUAGE 'plpgsql' VOLATILE
COST 100;
-ALTER FUNCTION f_wmc_load_count(integer) OWNER TO postgres;
-- change view for search wmc to include the load_count
-- View: search_wmc_view
--- DROP VIEW search_wmc_view;
+DROP VIEW search_wmc_view;
CREATE OR REPLACE VIEW search_wmc_view AS
SELECT wmc_dep.fkey_user_id AS user_id, wmc_dep.wmc_id, wmc_dep.srs AS wmc_srs, wmc_dep.wmc_title, wmc_dep.abstract AS wmc_abstract, f_collect_searchtext_wmc(wmc_dep.wmc_id) AS searchtext, wmc_dep.wmc_timestamp, wmc_dep.department, wmc_dep.mb_group_name, wmc_dep.mb_group_title, wmc_dep.mb_group_country, wmc_dep.wmc_serial_id, f_wmc_load_count(wmc_dep.wmc_serial_id) as load_count, wmc_dep.mb_group_stateorprovince, f_collect_inspire_cat_wmc(wmc_dep.wmc_serial_id) AS md_inspire_cats, f_collect_custom_cat_wmc(wmc_dep.wmc_serial_id) AS md_custom_cats, f_collect_topic_cat_wmc(wmc_dep.wmc_id) AS md_topic_cats, transform(geometryfromtext(((((((((((((((((((('POLYGON(('::text || wmc_dep.minx::text) || ' '::text) || wmc_dep.miny::text) || ','::text) || wmc_dep.minx::text) || ' '::text) || wmc_dep.maxy::text) || ','::text) || wmc_dep.maxx::text) || ' '::text) || wmc_dep.maxy::text) || ','::text) || wmc_dep.maxx::text) || ' '::text) || wmc_dep.miny::text) || ','::text) || wmc_dep.minx::
text) || ' '::text) || wmc_dep.miny::text) || '))'::text, regexp_replace(upper(wmc_dep.srs::text), 'EPSG:'::text, ''::text)::integer), 4326) AS the_geom, (((((wmc_dep.minx::text || ','::text) || wmc_dep.miny::text) || ','::text) || wmc_dep.maxx::text) || ','::text) || wmc_dep.maxy::text AS bbox, wmc_dep.mb_group_logo_path
@@ -43,7 +43,6 @@
WHERE wmc_dep.wmc_public = 1
ORDER BY wmc_dep.wmc_id;
-ALTER TABLE search_wmc_view OWNER TO postgres;
-- Bugfix for normalize searchtext of wmc docs
@@ -75,7 +74,6 @@
$BODY$
COST 100;
-ALTER FUNCTION f_collect_searchtext_wmc(integer) OWNER TO postgres;
--Bugfix in integral monitoring table
@@ -118,7 +116,6 @@
END;
$BODY$
LANGUAGE 'plpgsql' VOLATILE;
-ALTER FUNCTION mb_monitor_after() OWNER TO postgres;
--new columns with uuids for resources wms, layer, wfs, featuretype - is needed to generate konsistent metadatasets
--you need a postgres >= 8.3 cause the new datatype uuid is used!
More information about the Mapbender_commits
