[Mapbender-commits] r7490 -
trunk/mapbender/resources/db/pgsql/UTF-8/update
svn_mapbender at osgeo.org
Fri Jan 28 15:00:32 EST 2011
Author: astrid_emde
Date: 2011-01-28 12:00:32 -0800 (Fri, 28 Jan 2011)
New Revision: 7490
trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.6.2_to_2.7rc1_pgsql_UTF-8.sql
atributes for print e_element div
Modified: trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.6.2_to_2.7rc1_pgsql_UTF-8.sql
--- trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.6.2_to_2.7rc1_pgsql_UTF-8.sql 2011-01-28 16:39:26 UTC (rev 7489)
+++ trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.6.2_to_2.7rc1_pgsql_UTF-8.sql 2011-01-28 20:00:32 UTC (rev 7490)
@@ -564,7 +564,7 @@
UPDATE gui_element SET e_content = '<span>Ma</span><span style="color: blue;">P</span><span style="color: red;">b</span><span>ender</span><script type="text/javascript"> mb_registerSubFunctions("mod_mapbender()"); function mod_mapbender(){ document.getElementById("mapbender").style.left = parseInt(document.getElementById("mapframe1").style.left) + parseInt(document.getElementById("mapframe1").style.width) - 90; document.getElementById("mapbender").style.top = parseInt(document.getElementById("mapframe1").style.top) + parseInt(document.getElementById("mapframe1").style.height) -1; } </script>' WHERE e_id = 'mapbender';
-- correct URL encoding
-UPDATE gui_element SET e_attributes = E'onclick="printWindow = window.open(\'../print/mod_printPDF.php?target=mapframe1&sessionID&conf=printPDF_b.conf\',\'printWin\',\'width=260, height=380, resizable=yes\');printWindow.focus();" onmouseover="this.src = this.src.replace(/_off/,\'_over\');" onmouseout="this.src = this.src.replace(/_over/, \'_off\');"' WHERE e_id = 'printPDF';
+UPDATE gui_element SET e_attributes = E'onclick="printWindow = window.open(\'../print/mod_printPDF.php?target=mapframe1&sessionID&conf=printPDF_b.conf\',\'printWin\',\'width=260, height=380, resizable=yes\');printWindow.focus();" onmouseover="this.src = this.src.replace(/_off/,\'_over\');" onmouseout="this.src = this.src.replace(/_over/, \'_off\');"' WHERE e_id = 'printPDF' AND e_element = 'img';
-- added mandatory action attribute
UPDATE gui_element SET e_attributes = 'action="window.location.href"' WHERE e_id = 'setBackground';
@@ -572,7 +572,7 @@
UPDATE gui_element SET e_content = '<form id="form_switch_locale" action="window.location.href" name="form_switch_locale" target="parent"><select id="language" name="language" onchange="validate_locale()"></select></form>' WHERE e_id = 'switchLocale_noreload';
-- attributes only valid for printPDF button (img)
-UPDATE gui_element SET e_attributes = '' WHERE e_id = 'printPDF' AND e_element = 'iframe';
+UPDATE gui_element SET e_attributes = '' WHERE e_id = 'printPDF' AND e_element IN ('iframe','div');
More information about the Mapbender_commits
