[Mapbender-commits] r7497 - in trunk/mapbender/resources/db/pgsql:
. UTF-8/update
svn_mapbender at osgeo.org
Sun Jan 30 13:05:34 EST 2011
Author: astrid_emde
Date: 2011-01-30 10:05:34 -0800 (Sun, 30 Jan 2011)
New Revision: 7497
trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.6.2_to_2.7rc1_pgsql_UTF-8.sql
trunk/mapbender/resources/db/pgsql/gui_digitize.sql
gui_digitize featureInfoPopupWidth and Height to 320
Modified: trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.6.2_to_2.7rc1_pgsql_UTF-8.sql
--- trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.6.2_to_2.7rc1_pgsql_UTF-8.sql 2011-01-30 17:57:46 UTC (rev 7496)
+++ trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.6.2_to_2.7rc1_pgsql_UTF-8.sql 2011-01-30 18:05:34 UTC (rev 7497)
@@ -3129,9 +3129,9 @@
.button {height:18px; width:32px;}', 'text css', 'text/css');
INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'digitize', 'wfsCssUrl', '../css/mapbender.css', 'var', 'var');
INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'featureInfoTunnel', 'featureInfoLayerPopup', 'true', '', 'var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'featureInfoTunnel', 'featureInfoPopupHeight', '200', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'featureInfoTunnel', 'featureInfoPopupHeight', '320', '', 'var');
INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'featureInfoTunnel', 'featureInfoPopupPosition', '[100,100]', 'position of the featureInfoPopup', 'var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'featureInfoTunnel', 'featureInfoPopupWidth', '270', '', 'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'featureInfoTunnel', 'featureInfoPopupWidth', '320', '', 'var');
INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'gazetteerWFS', 'enableSearchWithoutParams', '0', 'define that search can be started without any search params', 'var');
INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'gazetteerWFS', 'initializeOnLoad', '0', 'start gazetteer onload', 'var');
INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('gui_digitize', 'gazetteerWFS', 'removeSpatialRequestHighlight', '0', 'remove spatialrequest highlighting when firing search', 'var');
Modified: trunk/mapbender/resources/db/pgsql/gui_digitize.sql
--- trunk/mapbender/resources/db/pgsql/gui_digitize.sql 2011-01-30 17:57:46 UTC (rev 7496)
+++ trunk/mapbender/resources/db/pgsql/gui_digitize.sql 2011-01-30 18:05:34 UTC (rev 7497)
@@ -108,9 +108,9 @@
More information about the Mapbender_commits
