[Mapbender-commits] r7499 - branches/2.7/conf
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Mon Jan 31 02:02:34 EST 2011
Author: armin11
Date: 2011-01-30 23:02:34 -0800 (Sun, 30 Jan 2011)
New Revision: 7499
   branches/2.7/conf/mapbender.conf-dist
Some explainations for the new conf parameters.
Modified: branches/2.7/conf/mapbender.conf-dist
--- branches/2.7/conf/mapbender.conf-dist	2011-01-30 18:17:27 UTC (rev 7498)
+++ branches/2.7/conf/mapbender.conf-dist	2011-01-31 07:02:34 UTC (rev 7499)
@@ -124,11 +124,17 @@
 # RSS
+# Mapbender > 2.7 generates a GeoRSS file which shows the changes in the mapbender service database. The
+# GeoRSS file get entries when wms are uploaded, updated or deleted. The RSS file can be used to show the positions
+# of new layers and services on in the own mapframe or in other applications.
 define("GEO_RSS_FILE", "../tmp/georss.xml");
 # PREVIEW
+# This path is defined to allow a saving of preview pictures for the content of wms/layers and
+# wmc docs. The preview can generated with the wms and wmc metadata editor guis and the previews are used
+# by the metadata module and are distributed with the iso19139 files which can be generated by mapbender.
 define("PREVIEW_DIR", "../geoportal/preview");
@@ -147,16 +153,25 @@
 # define a public user
+# This user is a typical anonymous user which don't need to authenticate itself.
+# Some functions of the portal framework not allowed for this user.
 define("PUBLIC_USER", "");
-# define a session name (useful for )
+# Define a session name (useful for installations when more than one mapbender is installed on one server.
+# These installations won't share the session but will share probably one database. When the user switch from one
+# to another installation - and there are different session names - the configuration from the session will be forgotten. There is a new environment.)
 #define("SESSION_NAME", "MAPBENDER");
-# calculate bboxes for all supported SRS (Postgis needed)
+# Calculate bboxes for all supported SRS (Postgis needed)
+# This module will compute bboxes for all srs which will be found in the service capabilities and which are defined
+# in the array below. Normaly mapbender only uses bbox's which are given thru the service caps. In many use cases it is
+# needfull to have more than one bbox given (e.g. metadata). The array is defined to supress the calculation of to many
+# srs like e.g. geoserver offers. The array should include all the srs which are used in the mapbender installation and
+# which are usefull for the special community for which the installation was done (local-sdi, INSPIRE, ...)
 #define("SRS_ARRAY", "4326, 31466, 31467, 31468, 25832");
More information about the Mapbender_commits mailing list
