[Mapbender-commits] r7921 - in trunk/metador/mapbender:
http/MeTaDor resources
svn_mapbender at osgeo.org
Fri Jul 8 03:41:15 EDT 2011
Author: astrid_emde
Date: 2011-07-08 00:41:15 -0700 (Fri, 08 Jul 2011)
New Revision: 7921
trunk/metador/mapbender/http/MeTaDor/class_MdMetadata.php
trunk/metador/mapbender/http/MeTaDor/inspirevalidate.php
trunk/metador/mapbender/http/MeTaDor/mb_md_editor_search_data_server.php
trunk/metador/mapbender/http/MeTaDor/xmlexport.php
trunk/metador/mapbender/http/MeTaDor/xmlprint.php
trunk/metador/mapbender/resources/update_2.7_metador_pgsql_UTF-8.sql
* change GUI Abstract to 'Application to edit metadata'
* changed SQLs in the scripts to store the data in table mb_metadata instead of mb_metadta_data
** changed columns
*** metadata_id (instead of id),
*** data (instead of xml),
*** lastchanged (instead of date)
** changed view to view_mb_metadata instead of view_mb_metadta_data
**** view contains metadata_id as id as an additional column
Store origin 'MeTaDor-full' to know where the metadata came from
Modified: trunk/metador/mapbender/http/MeTaDor/class_MdMetadata.php
--- trunk/metador/mapbender/http/MeTaDor/class_MdMetadata.php 2011-07-08 07:40:54 UTC (rev 7920)
+++ trunk/metador/mapbender/http/MeTaDor/class_MdMetadata.php 2011-07-08 07:41:15 UTC (rev 7921)
@@ -14,7 +14,7 @@
class MdMetadata implements RPCObject {
- private $id;
+ private $metadata_id;
var $uuid;
var $copyof;
var $title;
@@ -56,12 +56,12 @@
- * Returns $id.
- * @see MdMetadata::$id
+ * Returns $metadata_id.
+ * @see MdMetadata::$metadata_id
public function getId()
- return intval($this->id);
+ return intval($this->metadata_id);
@@ -94,11 +94,11 @@
public function __construct () {
if (func_num_args() === 1) {
- $this->id = intval(func_get_arg(0));
+ $this->metadata_id = intval(func_get_arg(0));
try{
- if (!is_null($this->id)) {
+ if (!is_null($this->metadata_id)) {
$this->load();
@@ -108,7 +108,7 @@
public static function byUUID($uuid){
- $sql = "SELECT id FROM view_mb_metadata_data";
+ $sql = "SELECT metadata_id FROM view_mb_metadata";
$filter = new Filter("AND", array(
new Filter("=", "uuid", $uuid),
@@ -122,7 +122,7 @@
$res = db_prep_query($sql, $v, $t);
$row = db_fetch_assoc($res);
if ($row) {
- return new self($row['id']);
+ return new self($row['metadata_id']);
else {
throw new Exception("Trying to load Record with invalid UUID: $uuid, $sql");
@@ -290,12 +290,12 @@
public function load () {
- $sql = "SELECT id, uuid, copyof, title, status, responsible_party,responsible_party_name, responsible_party_id,
-fkey_mb_user_id, individual_name,individual_name_id, date, xml, visibility, type
-FROM view_mb_metadata_data";
+ $sql = "SELECT metadata_id, uuid, copyof, title, status, responsible_party,responsible_party_name, responsible_party_id,
+fkey_mb_user_id, individual_name,individual_name_id, lastchanged, data, visibility, type
+FROM view_mb_metadata";
- new Filter("=", "id", $this->getId()),
+ new Filter("=", "metadata_id", $this->getId()),
self::getReadAccessFilter()
$sqlObject = $filter->toSql();
@@ -319,13 +319,13 @@
$this->fkey_mb_user_id = $row["fkey_mb_user_id"];
$this->individual_name = $row["individual_name_id"];
$this->individual_name_name = $row["individual_name"];
- $this->date = $row["date"];
- $this->xml = new MdMetadataXml($row["xml"]);
+ $this->date = $row["lastchanged"];
+ $this->xml = new MdMetadataXml($row["data"]);
$this->type = $row["type"];
$this->visibility = $row["visibility"];
else {
- $this->id = null;
+ $this->metadata_id = null;
@@ -341,7 +341,7 @@
return false;
- $sql = "SELECT uuid from mb_metadata_data where uuid = $1";
+ $sql = "SELECT uuid from mb_metadata where uuid = $1";
$v = array($uuid);
$t = array('s');
$res = db_prep_query($sql,$v,$t);
@@ -352,7 +352,7 @@
public static function getCount ($aFilter) {
- $sql = "SELECT COUNT(id) FROM view_mb_metadata_data";
+ $sql = "SELECT COUNT(metadata_id) FROM view_mb_metadata";
self::getReadAccessFilter(),
@@ -378,7 +378,7 @@
$limit = func_num_args() >= 3 ? func_get_arg(2) : null;
$offset = func_num_args() >= 4 ? func_get_arg(3) : null;
@@ -397,8 +397,8 @@
$metadataArray = array();
while ($row = db_fetch_assoc($res)) {
- $id = intval($row["id"]);
- $metadata = new MdMetadata($id);
+ $metadata_id = intval($row["metadata_id"]);
+ $metadata = new MdMetadata($metadata_id);
if ($metadata->isValid()) {
$metadataArray[]= $metadata;
@@ -407,7 +407,7 @@
public function isValid () {
return true;
return false;
@@ -422,9 +422,9 @@
$this->date = date("Y-m-d");
$sql = <<<SQL
-UPDATE mb_metadata_data SET
-fkey_mb_user_id = $1, date = $2, status = $3, xml = $4, title = $5,
-responsible_party = $6, individual_name = $7, type = $8, visibility = $9,copyof = $10, uuid= $11, responsible_party_name = $12
+UPDATE mb_metadata SET
+fkey_mb_user_id = $1, lastchanged = $2, status = $3, data = $4, title = $5,
+responsible_party = $6, individual_name = $7, type = $8, visibility = $9,copyof = $10, uuid= $11, responsible_party_name = $12, origin = $13
SQL;
$v = array(
Mapbender::session()->get('mb_user_id'),
@@ -438,17 +438,18 @@
$this->visibility,
$this->copyof,
$this->uuid,
- $this->responsible_party_name
+ $this->responsible_party_name,
+ 'MeTaDoR-full'
- $t = array('i', 's', 's', 's', 's', 'i', 'i', 's', 's', 's','s','s');
- if($this->id){
+ $t = array('i', 's', 's', 's', 's', 'i', 'i', 's', 's', 's','s','s','s');
+ if($this->metadata_id){
- $sql .= " WHERE id = $13";
- $v[] = $this->id;
+ $sql .= " WHERE metadata_id = $14";
+ $v[] = $this->metadata_id;
$t[] = 'i';
}else{
- $sql .= " WHERE uuid = $13";
+ $sql .= " WHERE uuid = $14";
$v[] = $this->uuid;
$t[] = 's';
@@ -473,9 +474,9 @@
throw new Exception (_mb("Not allowed to remove metadata record."));
- $sql = "DELETE FROM mb_metadata_data";
+ $sql = "DELETE FROM mb_metadata";
- $filter = new Filter("=", "id", $this->getId());
+ $filter = new Filter("=", "metadata_id", $this->getId());
$sql .= " WHERE " . $sqlObject->sql;
@@ -506,7 +507,7 @@
db_begin();
- $sql_group_create = "INSERT INTO mb_metadata_data (uuid) VALUES ($1)";
+ $sql_group_create = "INSERT INTO mb_metadata (uuid) VALUES ($1)";
$v = array($this->uuid);
$t = array("s");
$insert_result = db_prep_query($sql_group_create, $v, $t);
@@ -516,9 +517,9 @@
throw new Exception (_mb("Could not insert new metadata record."));
- $id = db_insertid($insert_result,'mb_metadata_data', 'id');
- if ($id != 0) {
- $this->id = intval($id);
+ $metadata_id = db_insertid($insert_result,'mb_metadata', 'metadata_id');
+ if ($metadata_id != 0) {
+ $this->metadata_id = intval($metadata_id);
try {
Modified: trunk/metador/mapbender/http/MeTaDor/inspirevalidate.php
--- trunk/metador/mapbender/http/MeTaDor/inspirevalidate.php 2011-07-08 07:40:54 UTC (rev 7920)
+++ trunk/metador/mapbender/http/MeTaDor/inspirevalidate.php 2011-07-08 07:41:15 UTC (rev 7921)
@@ -21,12 +21,12 @@
$path = tempnam("/tmp","mb_inspireval");
-$recordSQL = "SELECT xml from mb_metadata_data WHERE id = $1;";
+$recordSQL = "SELECT data from mb_metadata WHERE metadata_id = $1;";
$result = db_prep_query($recordSQL,array($id),array(i));
$row = db_fetch_array($result);
if($row){
- file_put_contents($path,$row['xml']);
+ file_put_contents($path,$row['data']);
}else{
die("invalid id");
Modified: trunk/metador/mapbender/http/MeTaDor/mb_md_editor_search_data_server.php
--- trunk/metador/mapbender/http/MeTaDor/mb_md_editor_search_data_server.php 2011-07-08 07:40:54 UTC (rev 7920)
+++ trunk/metador/mapbender/http/MeTaDor/mb_md_editor_search_data_server.php 2011-07-08 07:41:15 UTC (rev 7921)
@@ -43,7 +43,7 @@
$v[]= $reg->getId();
$t[]= "i";
- $sql = "SELECT DISTINCT mb_group_name FROM mb_group, mb_metadata_data " .
+ $sql = "SELECT DISTINCT mb_group_name FROM mb_group, mb_metadata " .
"WHERE mb_group_id = responsible_party AND " .
"responsible_party IN (" . implode(",", $vars) . ")";
@@ -91,7 +91,7 @@
$v[]= $user->id;
$t[]= "i";
- $sql = "SELECT DISTINCT mb_user_name FROM mb_user, mb_metadata_data " .
+ $sql = "SELECT DISTINCT mb_user_name FROM mb_user, mb_metadata " .
"WHERE mb_user_id = individual_name AND " .
"individual_name IN (" . implode(",", $vars) . ")";
@@ -137,7 +137,7 @@
$v[]= $user->id;
$t[]= "i";
"WHERE mb_user_id = fkey_mb_user_id AND " .
"fkey_mb_user_id IN (" . implode(",", $vars) . ")";
Modified: trunk/metador/mapbender/http/MeTaDor/xmlexport.php
--- trunk/metador/mapbender/http/MeTaDor/xmlexport.php 2011-07-08 07:40:54 UTC (rev 7920)
+++ trunk/metador/mapbender/http/MeTaDor/xmlexport.php 2011-07-08 07:41:15 UTC (rev 7921)
@@ -21,15 +21,15 @@
-$recordSQL = "SELECT uuid,xml from mb_metadata_data WHERE id = $1;";
+$recordSQL = "SELECT uuid, data from mb_metadata WHERE metadata_id = $1;";
if($row = db_fetch_array($result)){
header("Content-Type: application/xml");
header("Content-Disposition: attachment; filename=metador_".$row['uuid'].".xml");
- echo $row['xml'];
+ echo $row['data'];
exit;
}else{
- die("invalid id");
+ die("invalid metadata_id");
Modified: trunk/metador/mapbender/http/MeTaDor/xmlprint.php
--- trunk/metador/mapbender/http/MeTaDor/xmlprint.php 2011-07-08 07:40:54 UTC (rev 7920)
+++ trunk/metador/mapbender/http/MeTaDor/xmlprint.php 2011-07-08 07:41:15 UTC (rev 7921)
@@ -11,7 +11,7 @@
if(is_numeric($_GET["id"])) {
- $recordSQL = "SELECT uuid,xml from mb_metadata_data WHERE id = $1;";
+ $recordSQL = "SELECT uuid, data from mb_metadata WHERE metadata_id = $1;";
$result = db_prep_query($recordSQL,array($_GET["id"]),array(i));
@@ -20,7 +20,7 @@
// GET TYPE
$tmp = new DOMDocument();
- if(!$tmp->loadXML($row['xml'])) {
+ if(!$tmp->loadXML($row[data])) {
Throw new Exception(__FILE__." : could not load xml.");
@@ -45,7 +45,7 @@
default : $filename = "metadata_data.json";
- $metadataPrint = new MetadataPrint($row['xml'],$pathJson.$filename);
+ $metadataPrint = new MetadataPrint($row['data'],$pathJson.$filename);
// LOAD TEMPLATE CLASS AND SET PATH
$template = new Template($pathTemplates);
Modified: trunk/metador/mapbender/resources/update_2.7_metador_pgsql_UTF-8.sql
--- trunk/metador/mapbender/resources/update_2.7_metador_pgsql_UTF-8.sql 2011-07-08 07:40:54 UTC (rev 7920)
+++ trunk/metador/mapbender/resources/update_2.7_metador_pgsql_UTF-8.sql 2011-07-08 07:41:15 UTC (rev 7921)
@@ -1,7 +1,7 @@
--- METADOR GUI
+-- METADOR Application
-INSERT INTO gui (gui_id, gui_name, gui_description, gui_public) VALUES ('MeTaDor','MeTaDor','application_metadata_editor',1);
+INSERT INTO gui (gui_id, gui_name, gui_description, gui_public) VALUES ('MeTaDor','MeTaDor','Application to edit metadata',1);
INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('MeTaDor','jq_ui',1,1,'The jQuery UI core','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.14.custom/js/jquery-ui-1.8.14.custom.min.js','','','');
INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('MeTaDor','jq_ui','css','../extensions/jquery-ui-1.7.2.custom/css/ui-lightness/jquery-ui-1.7.2.custom.css','','file/css');
INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('MeTaDor','mb_md_selectAction',1,1,'','Metadateneditorstartseite','div','','data="{path:''#mb_md_selectAction''}"',0,0,NULL ,NULL,NULL ,'','','div','../MeTaDor/mb_md_selectAction.js','','','','');
@@ -517,34 +517,50 @@
-- METADATA TABLE
+-- Umschreiben auf die Tabelle mb_metadata
+--CREATE TABLE mb_metadata_data (
+-- id serial NOT NULL, -- metadata_id
+-- uuid character varying(100), -- uuid
+-- title character varying(250), -- t
+-- keywords text, -- ?
+-- date date, -- einfügedatum ? createdate lastchanged changedate --> lastchanged
+-- status character varying(50), -- status
+-- "type" character varying(50),--type
+-- "xml" text, --- data
+-- fkey_mb_user_id integer NOT NULL DEFAULT 1, -- wie
+-- responsible_party integer, --wie
+-- individual_name integer, -- wie
+-- visibility character varying(12), -- wie
+-- locked boolean DEFAULT false, -- wie
+-- copyof character varying(100), -- wie
+-- responsible_party_name character varying(100) -- neu
+-- noch: origin MeTaDoR-full
- keywords text,
- date date,
- "xml" text,
-- ADD VIEW
+-- new -- view on table mb_metadata
+DROP VIEW view_mb_metadata ;
+CREATE OR REPLACE VIEW view_mb_metadata AS
+ SELECT mb_metadata.metadata_id,
+mb_metadata.metadata_id as id,
+mb_metadata.uuid,
+ mb_metadata.copyof, mb_metadata.title,
+ mb_metadata.createdate, --date,
+lastchanged,
+changedate,
+ mb_group.mb_group_name AS responsible_party,
+mb_metadata.responsible_party_name, -- neu
+ mb_group.mb_group_id AS responsible_party_id,
+ kontakt.mb_user_name AS individual_name,
+ kontakt.mb_user_id AS individual_name_id,
+ mb_metadata.status, mb_metadata.visibility,
+ mb_metadata.fkey_mb_user_id,
+ mb_metadata.data, --xml,
+ mb_metadata.type
+ FROM mb_user erfasser, mb_metadata
+ LEFT JOIN mb_group ON mb_metadata.responsible_party = mb_group.mb_group_id
+ LEFT JOIN mb_user kontakt ON mb_metadata.individual_name = kontakt.mb_user_id
+WHERE mb_metadata.fkey_mb_user_id = erfasser.mb_user_id;
-CREATE OR REPLACE VIEW view_mb_metadata_data AS
- SELECT mb_metadata_data.id, mb_metadata_data.uuid, mb_metadata_data.copyof, mb_metadata_data.title, mb_metadata_data.date, mb_group.mb_group_name AS responsible_party, mb_metadata_data.responsible_party_name, mb_group.mb_group_id AS responsible_party_id, kontakt.mb_user_name AS individual_name, kontakt.mb_user_id AS individual_name_id, mb_metadata_data.status, mb_metadata_data.visibility, mb_metadata_data.fkey_mb_user_id, mb_metadata_data.xml, mb_metadata_data.type
- FROM mb_user erfasser, mb_metadata_data
- LEFT JOIN mb_group ON mb_metadata_data.responsible_party = mb_group.mb_group_id
- LEFT JOIN mb_user kontakt ON mb_metadata_data.individual_name = kontakt.mb_user_id
-WHERE mb_metadata_data.fkey_mb_user_id = erfasser.mb_user_id;
+ALTER TABLE mb_metadata ADD COLUMN responsible_party_name character varying(100);
More information about the Mapbender_commits
