[Mapbender-commits] r7929 - trunk/mapbender/lib
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Tue Jul 12 09:29:21 EDT 2011
Author: verenadiewald
Date: 2011-07-12 06:29:21 -0700 (Tue, 12 Jul 2011)
New Revision: 7929
   trunk/mapbender/lib/printbox.js
calculate center pos of printbox using map.getWidth() and map.getHeight()
Modified: trunk/mapbender/lib/printbox.js
--- trunk/mapbender/lib/printbox.js	2011-07-12 13:28:33 UTC (rev 7928)
+++ trunk/mapbender/lib/printbox.js	2011-07-12 13:29:21 UTC (rev 7929)
@@ -40,7 +40,8 @@
 	// The pointArray is moved by the center vector.
 	// default: place box in the center of the map
-	var center = options.center || new Point(map.width/2,map.height/2);
+	//var center = options.center || new Point(map.width/2,map.height/2);
+        var center = options.center || new Point(map.getWidth()/2,map.getHeight()/2);
 	// the center in real world coordinates
 	var centerMap = null;
More information about the Mapbender_commits mailing list
