[Mapbender-commits] r7972 - branches/2.7/http/php
svn_mapbender at osgeo.org
Tue Jul 19 09:04:37 EDT 2011
Author: astrid_emde
Date: 2011-07-19 06:04:37 -0700 (Tue, 19 Jul 2011)
New Revision: 7972
Added:
branches/2.7/http/php/mod_dataISOMetadata.php
branches/2.7/http/php/mod_exportISOMetadata.php
branches/2.7/http/php/mod_deleteWMS.php
branches/2.7/http/php/mod_digitize_splitLine.php
branches/2.7/http/php/mod_editElements.php
branches/2.7/http/php/mod_layerISOMetadata.php
branches/2.7/http/php/mod_savewmc_server.php
branches/2.7/http/php/mod_showMetadata.php
branches/2.7/http/php/mod_updateWMS.php
branches/2.7/http/php/mod_wmc2ol.php
branches/2.7/http/php/wms.php
merged with trunk
Copied: branches/2.7/http/php/mod_dataISOMetadata.php (from rev 7962, trunk/mapbender/http/php/mod_dataISOMetadata.php)
--- branches/2.7/http/php/mod_dataISOMetadata.php (rev 0)
+++ branches/2.7/http/php/mod_dataISOMetadata.php 2011-07-19 13:04:37 UTC (rev 7972)
@@ -0,0 +1,1425 @@
+<?php
+#http://www.geoportal.rlp.de/mapbender/php/mod_dataISOMetadata.php?outputFormat=iso19139&Id=uuid
+#http://localhost/mapbender/php/mod_dataISOMetadata.php?outputFormat=iso19139&ID=cb567df4-57da-449a-be74-821903a59d45
+# $Id: mod_dataISOMetadata.php 235
+# http://www.mapbender.org/index.php/Inspire_Metadata_Editor
+# Copyright (C) 2002 CCGIS
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+//function to pull out information from mapbenders md_metadata table
+//the information is pulled out by uuid cause the uuid is not changed
+//there are 3 ways to access the information:
+//1. read a link out from database and give the link content back to the requesting client
+//2. read the metadata addon information and fill the rest from the wms/mb_user/mb_group/layer table
+//3. give back the harvested content of the column data - if conform?
+require_once(dirname(__FILE__) . "/../../core/globalSettings.php");
+require_once(dirname(__FILE__) . "/../classes/class_connector.php");
+require_once(dirname(__FILE__) . "/../classes/class_administration.php");
+require_once(dirname(__FILE__) . "/../classes/class_Uuid.php");
+$con = db_connect(DBSERVER,OWNER,PW);
+db_select_db(DB,$con);
+$admin = new administration();
+$wmsView = '';
+//parse request parameter
+//make all parameters available as upper case
+foreach($_REQUEST as $key => $val) {
+ $_REQUEST[strtoupper($key)] = $val;
+//example mapbender uuid: 2494d033-ccdd-cdd7-71c6-3e3c195e1d85
+//cb567df4-57da-449a-be74-821903a59d45
+//validate request params
+if (isset($_REQUEST['ID']) & $_REQUEST['ID'] != "") {
+ //validate uuid
+ $testMatch = $_REQUEST["ID"];
+ $uuid = new Uuid($testMatch);
+ $isUuid = $uuid->isValid();
+ if (!$isUuid) {
+ echo 'Id: <b>'.$testMatch.'</b> is not a valid mapbender uuid.<br/>';
+ die();
+ $recordId = $testMatch;
+ $testMatch = NULL;
+if ($_REQUEST['OUTPUTFORMAT'] == "iso19139") {
+ //Initialize XML document
+ $iso19139Doc = new DOMDocument('1.0');
+ $iso19139Doc->encoding = 'UTF-8';
+} else {
+ echo 'outputFormat: <b>'.$_REQUEST['OUTPUTFORMAT'].'</b> is not set or valid.<br/>';
+ die();
+//if validation is requested
+if (isset($_REQUEST['VALIDATE']) and $_REQUEST['VALIDATE'] != "true") {
+ echo 'validate: <b>'.$_REQUEST['VALIDATE'].'</b> is not valid.<br/>';
+ die();
+ //get record from mb_metadata and prohibit duplicates:
+ $sql = <<<SQL
+SELECT * FROM mb_metadata WHERE uuid = $1 ORDER BY lastchanged DESC LIMIT 1
+SQL;
+ $v = array($uuid);
+ $t = array('s');
+ $res = db_prep_query($sql,$v,$t);
+ if (!$res) {
+ echo "No record with uuid ".$recordId." found in mapbender database!";
+ die();
+ $row = db_fetch_assoc($res);
+ $mb_metadata = $row;
+ //convert dates to timestamps
+ $mb_metadata['createdate'] = strtotime($mb_metadata['createdate']);
+ $mb_metadata['changedate'] = strtotime($mb_metadata['changedate']);
+ $mb_metadata['lastchanged'] = strtotime($mb_metadata['lastchanged']);
+ //check which kind of metadata was found:
+ switch ($mb_metadata['origin']) {
+ case 'metador':
+ //generate the xml on the fly - there is no need to store it as xml in the database
+ //do the things which had to be done ;-)
+ if ($_REQUEST['VALIDATE'] == "true"){
+ validateInspireMetadata($iso19139Doc, $recordId); //calls fillISO19139 to!
+ } else {
+ pushISO19139($iso19139Doc, $recordId); //throw it out!
+ break;
+ case 'external':
+ if ($mb_metadata['export2csw']) { //the metadata must have been harvested before!
+ if ($mb_metadata['harvestresult'] == 1) {
+ if ($_REQUEST['VALIDATE'] != "true") {
+ header("Content-type: text/xml");
+ echo $mb_metadata['data'];
+ die();
+ } else {
+ validateInspireMetadataFromData($row['data']);
+ die();
+ } else {
+ //send error report - metadata has not been harvested - maybe
+ $errMsg = "Metadata should have been harvested, but some unkown error occured";
+ $errMsg .= "<br>Please use following URL directly: <a href='".$mb_metadata['link']."'>".$row['link']."</a><br>";
+ echo $errMsg;
+ die();
+ } else {
+ //load metadata, from url and send it to requesting client
+ $metadataUrlObject = new connector($mb_metadata['link']);
+ $metadataXml = $metadataUrlObject->file;
+ echo $metadataXml;
+ die();
+ } else {
+ validateInspireMetadataFromData($metadataXml);
+ die();
+ //if xml has been harvested - push this xml from database, if not just harvest it and push the result
+ break;
+ case 'upload':
+ die();
+ } else {
+ die();
+ } else {
+ echo $errMsg;
+ die();
+ break;
+ case 'capabilities':
+ //do the same as for the external case but all from caps should be harvested
+ die();
+ } else {
+ validateInspireMetadataFromData($mb_metadata['data']);
+ die();
+ } else {
+ $errMsg .= "<br>Please use following URL directly: <a href='".$mb_metadata['link']."'>".$mb_metadata['link']."</a><br>";
+ echo $errMsg;
+ die();
+ default:
+ break;
+//function to give away the xml data
+function pushISO19139($iso19139Doc, $recordId) {
+ //echo $recordId;
+ header("Content-type: application/xhtml+xml; charset=UTF-8");
+ $xml = fillISO19139($iso19139Doc, $recordId);
+ echo $xml;
+ die();
+//some needfull functions to pull metadata out of the database!
+function fillISO19139($iso19139, $recordId) {
+ global $admin;
+ global $mb_metadata;
+ //read out relevant information from mapbender database:
+ //layer and service information:
+ $sql = <<<SQL
+SELECT layer_id, fkey_wms_id FROM layer INNER JOIN ows_relation_metadata ON
+(ows_relation_metadata.fkey_layer_id=layer.layer_id) WHERE ows_relation_metadata.fkey_metadata_id = $1
+SQL;
+ //TODO: Problem - the metadata may be used for more than one service - not often but sometimes - does one get the right contact data?
+ $e = new mb_exception("used metadata id: ".$mb_metadata['metadata_id']);
+ $v = array($mb_metadata['metadata_id']);
+ $t = array('i');
+ if (!$res) {
+ $exception = "<exception>No coupled resource found in database!</exception>";
+ return $exception;
+ } else {
+ $mb_metadata_coupling = db_fetch_array($res);
+ $layerId = $mb_metadata_coupling['layer_id'];
+ $wmsId = $mb_metadata_coupling['wms_id'];
+ $e = new mb_notice("mod_dataISOMetadata.php: Found coupled layer with id: ".$layerId);
+ if ($wmsView != '') {
+ $sql = "SELECT * ";
+ $sql .= "FROM ".$wmsView." WHERE layer_id = $1";
+ else {
+ //next function is for normal mapbender installations and read the info directly from the wms and layer tables
+ $sql = "SELECT ";
+ $sql .= "layer.layer_id,layer.layer_name, layer.layer_title, layer.layer_abstract, layer.layer_pos, layer.layer_parent, layer.layer_minscale, layer.layer_maxscale, layer.uuid,";
+ $sql .= "wms.wms_title, wms.wms_abstract, wms.wms_id, wms.fees, wms.accessconstraints, wms.contactperson, ";
+ $sql .= "wms.contactposition, wms.contactorganization, wms.address, wms.city, wms_timestamp, wms_owner, ";
+ $sql .= "wms.stateorprovince, wms.postcode, wms.contactvoicetelephone, wms.contactfacsimiletelephone, wms.wms_owsproxy,";
+ $sql .= "wms.contactelectronicmailaddress, wms.country, wms.fkey_mb_group_id, ";
+ $sql .= "layer_epsg.minx || ',' || layer_epsg.miny || ',' || layer_epsg.maxx || ',' || layer_epsg.maxy as bbox ";
+ $sql .= "FROM wms, layer, layer_epsg WHERE layer_id = $1 and layer.fkey_wms_id = wms.wms_id";
+ $sql .= " and layer_epsg.fkey_layer_id=layer.layer_id and layer_epsg.epsg='EPSG:4326'";
+ $v = array((integer)$layerId);
+ $t = array('i');
+ $mapbenderMetadata = db_fetch_array($res);
+ //infos about the registrating department, check first if a special metadata point of contact is defined in the service table - function from mod_showMetadata - TODO: should be defined in admin class
+ if (!isset($mapbenderMetadata['fkey_mb_group_id']) or is_null($mapbenderMetadata['fkey_mb_group_id']) or $mapbenderMetadata['fkey_mb_group_id'] == 0){
+ $e = new mb_exception("mod_dataISOMetadata.php: fkey_mb_group_id not found!");
+ //Get information about owning user of the relation mb_user_mb_group - alternatively the defined fkey_mb_group_id from the service must be used!
+ $sqlDep = "SELECT mb_group_name, mb_group_title, mb_group_id, mb_group_logo_path, mb_group_address, mb_group_email, mb_group_postcode, mb_group_city, mb_group_voicetelephone, mb_group_facsimiletelephone FROM mb_group AS a, mb_user AS b, mb_user_mb_group AS c WHERE b.mb_user_id = $1 AND b.mb_user_id = c.fkey_mb_user_id AND c.fkey_mb_group_id = a.mb_group_id AND c.mb_user_mb_group_type=2 LIMIT 1";
+ $vDep = array($mapbenderMetadata['wms_owner']);
+ $tDep = array('i');
+ $resDep = db_prep_query($sqlDep, $vDep, $tDep);
+ $departmentMetadata = db_fetch_array($resDep);
+ } else {
+ $e = new mb_exception("mod_dataISOMetadata.php: fkey_mb_group_id found!");
+ $sqlDep = "SELECT mb_group_name , mb_group_title, mb_group_id, mb_group_logo_path , mb_group_address, mb_group_email, mb_group_postcode, mb_group_city, mb_group_voicetelephone, mb_group_facsimiletelephone FROM mb_group WHERE mb_group_id = $1 LIMIT 1";
+ $vDep = array($mapbenderMetadata['fkey_mb_group_id']);
+ //infos about the owner of the service - he is the man who administrate the metadata - register the service
+ $sql = "SELECT mb_user_email ";
+ $sql .= "FROM mb_user WHERE mb_user_id = $1";
+ $v = array((integer)$mapbenderMetadata['wms_owner']);
+ $t = array('i');
+ $userMetadata = db_fetch_array($res);
+ //check if resource is freely available to anonymous user - which are all users who search thru metadata catalogues:
+ $hasPermission=$admin->getLayerPermission($mapbenderMetadata['wms_id'],$mapbenderMetadata['layer_name'],PUBLIC_USER);
+ //Creating the "MD_Metadata" node
+ $MD_Metadata = $iso19139->createElementNS('http://www.isotc211.org/2005/gmd', 'gmd:MD_Metadata');
+ $MD_Metadata = $iso19139->appendChild($MD_Metadata);
+ $MD_Metadata->setAttribute("xmlns:srv", "http://www.isotc211.org/2005/srv");
+ $MD_Metadata->setAttribute("xmlns:gml", "http://www.opengis.net/gml");
+ $MD_Metadata->setAttribute("xmlns:gco", "http://www.isotc211.org/2005/gco");
+ $MD_Metadata->setAttribute("xmlns:xlink", "http://www.w3.org/1999/xlink");
+ $MD_Metadata->setAttribute("xmlns:xsi", "http://www.w3.org/2001/XMLSchema-instance");
+ $MD_Metadata->setAttribute("xsi:schemaLocation", "http://www.isotc211.org/2005/gmd ./xsd/gmd/gmd.xsd://www.isotc211.org/2005/srv ./xsd/srv/srv.xsd");
+ //generate fileidentifier part (metadata record identification)
+ $identifier = $iso19139->createElement("gmd:fileIdentifier");
+ $identifierString = $iso19139->createElement("gco:CharacterString");
+ if (isset($mb_metadata['uuid'])) {
+ $identifierText = $iso19139->createTextNode($mb_metadata['uuid']);
+ else {
+ $identifierText = $iso19139->createTextNode("no id found");
+ $identifierString->appendChild($identifierText);
+ $identifier->appendChild($identifierString);
+ $MD_Metadata->appendChild($identifier);
+ //generate language part B 10.3 (if available) of the inspire metadata regulation
+ $language = $iso19139->createElement("gmd:language");
+ $languagecode = $iso19139->createElement("gmd:LanguageCode");
+ $languagecode->setAttribute("codeList", "http://standards.iso.org/ittf/PubliclyAvailableStandards/ISO_19139_Schemas/resources/Codelist/ML_gmxCodelists.xml#LanguageCode");
+ if (isset($mapbenderMetadata['metadata_language'])) {
+ $languageText = $iso19139->createTextNode($mapbenderMetadata['metadata_language']);
+ $languagecode->setAttribute("codeListValue", $mapbenderMetadata['metadata_language']);
+ else {
+ $languageText = $iso19139->createTextNode("ger");
+ $languagecode->setAttribute("codeListValue", "ger");
+ $languagecode->appendChild($languageText);
+ $language ->appendChild($languagecode);
+ $language = $MD_Metadata->appendChild($language);
+ //generate Characterset
+ $characterSet = $iso19139->createElement("gmd:characterSet");
+ $characterSetCode = $iso19139->createElement("gmd:MD_CharacterSetCode");
+ $characterSetCode->setAttribute("codeList", "./resources/codeList.xml#MD_CharacterSetCode");
+ $characterSetCode->setAttribute("codeListValue", $mb_metadata['inspire_charset']);
+ $characterSet->appendChild($characterSetCode);
+ $characterSet = $MD_Metadata->appendChild($characterSet);
+ #generate MD_Scope part B 1.3 (if available)
+ $hierarchyLevel = $iso19139->createElement("gmd:hierarchyLevel");
+ $scopecode = $iso19139->createElement("gmd:MD_ScopeCode");
+ $scopecode->setAttribute("codeList", "http://standards.iso.org/ittf/PubliclyAvailableStandards/ISO_19139_Schemas/resources/Codelist/ML_gmxCodelists.xml#MD_ScopeCode");
+ if (isset($mb_metadata['type'])) {
+ $scopecode->setAttribute("codeListValue", $mb_metadata['type']);
+ $scopeText = $iso19139->createTextNode($mb_metadata['type']);
+ else {
+ $scopecode->setAttribute("codeListValue", "dataset");
+ $scopeText = $iso19139->createTextNode("dataset");
+ $scopecode->appendChild($scopeText);
+ $hierarchyLevel->appendChild($scopecode);
+ $hierarchyLevel=$MD_Metadata->appendChild($hierarchyLevel);
+ #Part B 10.1 responsible party for the resource
+ $contact=$iso19139->createElement("gmd:contact");
+ $CI_ResponsibleParty=$iso19139->createElement("gmd:CI_ResponsibleParty");
+ $organisationName=$iso19139->createElement("gmd:organisationName");
+ $organisationName_cs=$iso19139->createElement("gco:CharacterString");
+ if (isset($departmentMetadata['mb_group_name'])) {
+ $organisationNameText = $iso19139->createTextNode($departmentMetadata['mb_group_name']);
+ else
+ $organisationNameText=$iso19139->createTextNode('department not known');
+ $contactInfo=$iso19139->createElement("gmd:contactInfo");
+ $CI_Contact=$iso19139->createElement("gmd:CI_Contact");
+ $address=$iso19139->createElement("gmd:address");
+ $CI_Address=$iso19139->createElement("gmd:CI_Address");
+ $electronicMailAddress=$iso19139->createElement("gmd:electronicMailAddress");
+ $electronicMailAddress_cs=$iso19139->createElement("gco:CharacterString");
+ if (isset($userMetadata['mb_user_email']) && $userMetadata['mb_user_email'] != '') {
+ //get email address from ows service metadata out of mapbender database
+ $electronicMailAddressText=$iso19139->createTextNode($userMetadata['mb_user_email']);
+ else
+ $electronicMailAddressText=$iso19139->createTextNode('kontakt at geoportal.rlp.de');
+ $role=$iso19139->createElement("gmd:role");
+ $CI_RoleCode=$iso19139->createElement("gmd:CI_RoleCode");
+ $CI_RoleCode->setAttribute("codeList", "http://standards.iso.org/ittf/PubliclyAvailableStandards/ISO_19139_Schemas/resources/Codelist/ML_gmxCodelists.xml#CI_RoleCode");
+ $CI_RoleCode->setAttribute("codeListValue", "pointOfContact");
+ $CI_RoleCodeText=$iso19139->createTextNode("pointOfContact");
+ $organisationName_cs->appendChild($organisationNameText);
+ $organisationName->appendChild($organisationName_cs);
+ $CI_ResponsibleParty->appendChild($organisationName);
+ $electronicMailAddress_cs->appendChild($electronicMailAddressText);
+ $electronicMailAddress->appendChild($electronicMailAddress_cs);
+ $CI_Address->appendChild($electronicMailAddress);
+ $address->appendChild($CI_Address);
+ $CI_Contact->appendChild($address);
+ $contactInfo->appendChild($CI_Contact);
+ $CI_RoleCode->appendChild($CI_RoleCodeText);
+ $role->appendChild($CI_RoleCode);
+ $CI_ResponsibleParty->appendChild($contactInfo);
+ $CI_ResponsibleParty->appendChild($role);
+ $contact->appendChild($CI_ResponsibleParty);
+ $MD_Metadata->appendChild($contact);
+ #generate dateStamp part B 10.2 (if available)
+ $dateStamp = $iso19139->createElement("gmd:dateStamp");
+ $mddate = $iso19139->createElement("gco:Date");
+ if (isset($mb_metadata['lastchanged'])) {
+ $mddateText = $iso19139->createTextNode(date("Y-m-d h:i:s",$mb_metadata['lastchanged']));
+ else {
+ $mddateText = $iso19139->createTextNode("2000-01-01");
+ $mddate->appendChild($mddateText);
+ $dateStamp->appendChild($mddate);
+ $dateStamp=$MD_Metadata->appendChild($dateStamp);
+ //standard definition - everytime the same
+ $metadataStandardName = $iso19139->createElement("gmd:metadataStandardName");
+ $metadataStandardVersion = $iso19139->createElement("gmd:metadataStandardVersion");
+ $metadataStandardNameText = $iso19139->createElement("gco:CharacterString");
+ $metadataStandardVersionText = $iso19139->createElement("gco:CharacterString");
+ $metadataStandardNameTextString = $iso19139->createTextNode("ISO19115");
+ $metadataStandardVersionTextString = $iso19139->createTextNode("2003/Cor.1:2006");
+ $metadataStandardNameText->appendChild($metadataStandardNameTextString);
+ $metadataStandardVersionText->appendChild($metadataStandardVersionTextString);
+ $metadataStandardName->appendChild($metadataStandardNameText);
+ $metadataStandardVersion->appendChild($metadataStandardVersionText);
+ $MD_Metadata->appendChild($metadataStandardName);
+ $MD_Metadata->appendChild($metadataStandardVersion);
+ #do the things for identification
+ $identificationInfo=$iso19139->createElement("gmd:identificationInfo");
+ $MD_DataIdentification=$iso19139->createElement("gmd:MD_DataIdentification");
+ $citation=$iso19139->createElement("gmd:citation");
+ $CI_Citation=$iso19139->createElement("gmd:CI_Citation");
+ #create nodes for things which are defined
+ #Create Resource title element B 1.1
+ $title=$iso19139->createElement("gmd:title");
+ $title_cs=$iso19139->createElement("gco:CharacterString");
+ if (isset($mb_metadata['title'])) {
+ $titleText = $iso19139->createTextNode($mb_metadata['title']);
+ else {
+ $titleText = $iso19139->createTextNode("title not given");
+ $title_cs->appendChild($titleText);
+ $title->appendChild($title_cs);
+ $CI_Citation->appendChild($title);
+ #Create date elements B5.2-5.4
+ #Do things for B 5.2 date of publication - maybe the date when the first metadata was generated or it should not be available at all
+ if (isset($mb_metadata['createdate'])) {
+ $date1=$iso19139->createElement("gmd:date");
+ $CI_Date=$iso19139->createElement("gmd:CI_Date");
+ $date2=$iso19139->createElement("gmd:date");
+ $gcoDate=$iso19139->createElement("gco:Date");
+ $dateType=$iso19139->createElement("gmd:dateType");
+ $dateTypeCode=$iso19139->createElement("gmd:CI_DateTypeCode");
+ $dateTypeCode->setAttribute("codeList", "http://standards.iso.org/ittf/PubliclyAvailableStandards/ISO_19139_Schemas/resources/Codelist/ML_gmxCodelists.xml#CI_DateTypeCode");
+ $dateTypeCode->setAttribute("codeListValue", "publication");
+ $dateTypeCodeText=$iso19139->createTextNode('publication');
+ $dateText= $iso19139->createTextNode(date("Y-m-d h:i:s",$mb_metadata['createdate']));
+ $dateTypeCode->appendChild($dateTypeCodeText);
+ $dateType->appendChild($dateTypeCode);
+ $gcoDate->appendChild($dateText);
+ $date2->appendChild($gcoDate);
+ $CI_Date->appendChild($date2);
+ $CI_Date->appendChild($dateType);
+ $date1->appendChild($CI_Date);
+ $CI_Citation->appendChild($date1);
+ #Do things for B 5.3 date of revision
+ //this should be created from the information of maintenance if available
+ //some initialization for the temporal extent:
+ $beginPositionValue = $mb_metadata['tmp_reference_1'];
+ $endPositionValue = $mb_metadata['tmp_reference_2'];
+ $dateOfLastRevision = date('Y-m-d h:i:s');
+ if (isset($mb_metadata['update_frequency']) && $mb_metadata['update_frequency'] != "") {
+ switch ($mb_metadata['update_frequency']) {
+ case ('continual'):
+ //set value to now
+ $endPositionValue = date('Y-m-d h:i:s');
+ $dateOfLastRevision = $endPositionValue;
+ break;
+ case ('daily'):
+ //set value to now - one day
+ $endPositionValue = date('Y-m-d h:i:s', mktime(0, 0, 0, date("m"), date("d")-1, date("Y")));
+ break;
+ case ('weekly'):
+ //set value to now - one week
+ $endPositionValue = date('Y-m-d h:i:s', mktime(0, 0, 0, date("m"), date("d")-7, date("Y")));
+ break;
+ case ('fortnightly'):
+ //set value to now - two weeks
+ $endPositionValue = date('Y-m-d h:i:s', mktime(0, 0, 0, date("m"), date("d")-14, date("Y")));
+ break;
+ case ('monthly'):
+ //set value to now - one month
+ $endPositionValue = date('Y-m-d h:i:s', mktime(0, 0, 0, date("m")-1, date("d"), date("Y")));
+ break;
+ case ('quarterly'):
+ //set value to now - 3 months
+ $endPositionValue = date('Y-m-d h:i:s', mktime(0, 0, 0, date("m")-3, date("d"), date("Y")));
+ break;
+ case ('biannually'):
+ //set value to now - half a year
+ $endPositionValue = date('Y-m-d h:i:s', mktime(0, 0, 0, date("m")-6, date("d"), date("Y")));
+ break;
+ case ('annually'):
+ //set value to now - one year
+ $endPositionValue = date('Y-m-d h:i:s', mktime(0, 0, 0, date("m"), date("d"), date("Y")-1));
+ break;
+ default:
+ break;
+ $dateTypeCode->setAttribute("codeListValue", "revision");
+ $dateTypeCodeText=$iso19139->createTextNode('revision');
+ $dateText= $iso19139->createTextNode($dateOfLastRevision);
+/* #Do things for B 5.4 date of creation not applicable cause it cannot be edited
+ if (isset($mb_metadata['changedate']) || isset($mb_metadata['lastchanged'])) {
+ $dateTypeCode->setAttribute("codeListValue", "creation");
+ $dateTypeCodeText=$iso19139->createTextNode('creation');
+ if (!isset($mb_metadata['changedate'])) {
+ $dateText= $iso19139->createTextNode($mb_metadata['lastchanged']);
+ } else {
+ $dateText= $iso19139->createTextNode($mb_metadata['changedate']);
+ #Do things for B 1.5 Resource unique identifier NOTE: not applicable for services
+//example from INSPIRE Guidance Metadata
+//The main problem will be, that this entry is the identifier for the service data coupling
+//to make it easy, we will use the same identifier as for fileidentifier! In case of external datasets, the right data identifier must be harvested!
+/*<gmd:identifier><gmd:RS_Identifier><gmd:code><gco:CharacterString>gdi-rp</gco:CharacterString></gmd:code><gmd:codeSpace><gco:CharacterString>gdi-rp</gco:CharacterString></gmd:codeSpace></gmd:RS_Identifier></gmd:identifier>*/
+ $identifier=$iso19139->createElement("gmd:identifier");
+ $rs_identifier=$iso19139->createElement("gmd:RS_Identifier");
+ $code=$iso19139->createElement("gmd:code");
+ $code_cs=$iso19139->createElement("gco:CharacterString");
+ $codeText=$iso19139->createTextNode($mb_metadata['uuid']); //in case of the mapbender addon!
+ $codeSpace=$iso19139->createElement("gmd:codeSpace");
+ $codeSpace_cs=$iso19139->createElement("gco:CharacterString");
+ $codeSpaceText=$iso19139->createTextNode("http://www.geoportal.rlp.de"); //in case of the mapbender addon!
+ $code_cs->appendChild($codeText);
+ $code->appendChild($code_cs);
+ $rs_identifier->appendChild($code);
+ $codeSpace_cs->appendChild($codeSpaceText);
+ $codeSpace->appendChild($codeSpace_cs);
+ $rs_identifier->appendChild($codeSpace);
+ $identifier->appendChild($rs_identifier);
+ $CI_Citation->appendChild($identifier);
+ $citation->appendChild($CI_Citation);
+ $MD_DataIdentification->appendChild($citation);
+ #Create part for abstract B 1.2
+ $abstract=$iso19139->createElement("gmd:abstract");
+ $abstract_cs=$iso19139->createElement("gco:CharacterString");
+ if (isset($mb_metadata['abstract'])) {
+ $abstractText = $iso19139->createTextNode($mb_metadata['abstract']);
+ else {
+ $abstractText = $iso19139->createTextNode("not yet defined");
+ $abstract_cs->appendChild($abstractText);
+ $abstract->appendChild($abstract_cs);
+ $MD_DataIdentification->appendChild($abstract);
+ #Create part for point of contact for data identification - use contact from service provider!
+ #Define relevant objects
+ $pointOfContact=$iso19139->createElement("gmd:pointOfContact");
+ $orgaName_cs=$iso19139->createElement("gco:CharacterString");
+ $address_1=$iso19139->createElement("gmd:address");
+ $email_cs=$iso19139->createElement("gco:CharacterString");
+ $CI_RoleCode->setAttribute("codeListValue", "publisher");
+ if (isset($mapbenderMetadata['contactorganization'])) {
+ $resOrgaText = $iso19139->createTextNode($mapbenderMetadata['contactorganization']);
+ else {
+ $resOrgaText= $iso19139->createTextNode("not yet defined");
+ if (isset($mapbenderMetadata['contactelectronicmailaddress']) && $mapbenderMetadata['contactelectronicmailaddress'] != '') {
+ $resMailText = $iso19139->createTextNode($mapbenderMetadata['contactelectronicmailaddress']);
+ else {
+ $resMailText = $iso19139->createTextNode("kontakt at geoportal.rlp.de");
+ $resRoleText = $iso19139->createTextNode("publisher");
+ $orgaName_cs->appendChild($resOrgaText);
+ $organisationName->appendChild($orgaName_cs);
+ $email_cs->appendChild($resMailText);
+ $electronicMailAddress->appendChild($email_cs);
+ $address_1->appendChild($CI_Address);
+ $CI_Contact->appendChild($address_1);
+ $CI_RoleCode->appendChild($resRoleText);
+ $pointOfContact->appendChild($CI_ResponsibleParty);
+ $MD_DataIdentification->appendChild($pointOfContact);
+ //Part for maintenance if given
+ /* example
+<gmd:resourceMaintenance>
+ <gmd:MD_MaintenanceInformation>
+ <gmd:maintenanceAndUpdateFrequency>
+ <gmd:MD_MaintenanceFrequencyCode codeListValue="asNeeded" codeList="http://www.isotc211.org/2005/resources/codeList.xml#MD_MaintenanceFrequencyCode"/>
+ </gmd:maintenanceAndUpdateFrequency>
+ </gmd:MD_MaintenanceInformation>
+</gmd:resourceMaintenance>
+ $resourceMaintenance=$iso19139->createElement("gmd:resourceMaintenance");
+ $MD_MaintenanceInformation=$iso19139->createElement("gmd:MD_MaintenanceInformation");
+ $maintenanceAndUpdateFrequency=$iso19139->createElement("gmd:maintenanceAndUpdateFrequency");
+ $MD_MaintenanceFrequencyCode=$iso19139->createElement("gmd:MD_MaintenanceFrequencyCode");
+ $MD_MaintenanceFrequencyCode->setAttribute("codeListValue", $mb_metadata['update_frequency']);
+ $MD_MaintenanceFrequencyCode->setAttribute("codeList", "http://www.isotc211.org/2005/resources/codeList.xml#MD_MaintenanceFrequencyCode");
+ $maintenanceAndUpdateFrequency->appendChild($MD_MaintenanceFrequencyCode);
+ $MD_MaintenanceInformation->appendChild($maintenanceAndUpdateFrequency);
+ $resourceMaintenance->appendChild($MD_MaintenanceInformation);
+ $MD_DataIdentification->appendChild($resourceMaintenance);
+ //generate keyword part - for services the inspire themes are not applicable!!!**********
+ //read keywords for resource out of the database:
+ $sql = "SELECT keyword.keyword FROM keyword, layer_keyword WHERE layer_keyword.fkey_layer_id=$1 AND layer_keyword.fkey_keyword_id=keyword.keyword_id";
+ $t = array('i');
+ $descriptiveKeywords=$iso19139->createElement("gmd:descriptiveKeywords");
+ $MD_Keywords=$iso19139->createElement("gmd:MD_Keywords");
+ //push in keywords without thesaurus
+ while ($row = db_fetch_array($res)) {
+ $keyword=$iso19139->createElement("gmd:keyword");
+ $keyword_cs=$iso19139->createElement("gco:CharacterString");
+ $keywordText = $iso19139->createTextNode($row['keyword']);
+ $keyword_cs->appendChild($keywordText);
+ $keyword->appendChild($keyword_cs);
+ $MD_Keywords->appendChild($keyword);
+ //pull special keywords from custom categories:
+ $e = new mb_notice("layer: ".$layerId);
+ $sql = "SELECT custom_category.custom_category_key FROM custom_category, layer_custom_category WHERE layer_custom_category.fkey_layer_id = $1 AND layer_custom_category.fkey_custom_category_id = custom_category.custom_category_id AND custom_category_hidden = 0";
+ $t = array('i');
+ $e = new mb_notice("look for custom categories: ");
+ $countCustom = 0;
+ $keywordText = $iso19139->createTextNode($row['custom_category_key']);
+ $countCustom++;
+ $e = new mb_notice("count custom categories: ".$countCustom);
+ //close decriptive keywords and generate a new entry for inspire themes:
+ $descriptiveKeywords->appendChild($MD_Keywords);
+ $MD_DataIdentification->appendChild($descriptiveKeywords);
+ //new entry - with gemet thesaurus referenced
+ //read out the inspire categories and push them in as controlled keywords
+/* example
+<gmd:keyword><gco:CharacterString>Geographical names</gco:CharacterString></gmd:keyword><gmd:thesaurusName><gmd:CI_Citation><gmd:title><gco:CharacterString>GEMET - INSPIRE themes, version 1.0</gco:CharacterString></gmd:title><gmd:date><gmd:CI_Date><gmd:date><gco:Date>2008-06-01</gco:Date></gmd:date><gmd:dateType><gmd:CI_DateTypeCode codeList="http://standards.iso.org/ittf/PubliclyAvailableStandards/ISO_19139_Schemas/resources/Codelist/ML_gmxCodelists.xml#CI_DateTypeCode" codeListValue="publication">publication</gmd:CI_DateTypeCode></gmd:dateType></gmd:CI_Date></gmd:date></gmd:CI_Citation></gmd:thesaurusName></gmd:MD_Keywords></gmd:descriptiveKeywords><gmd:descriptiveKeywords><gmd:MD_Keywords><gmd:keyword><gco:CharacterString>BasisDLM</gco:CharacterString></gmd:keyword>
+ $sql = "SELECT inspire_category.inspire_category_code_en FROM inspire_category, layer_inspire_category WHERE layer_inspire_category.fkey_layer_id=$1 AND layer_inspire_category.fkey_inspire_category_id=inspire_category.inspire_category_id";
+ $t = array('i');
+ //part for the name of the inspire category
+ $keywordText = $iso19139->createTextNode($row['inspire_category_code_en']);
+ //part for the vocabulary
+ $thesaurusName = $iso19139->createElement("gmd:thesaurusName");
+ $CI_Citation = $iso19139->createElement("gmd:CI_Citation");
+ $title = $iso19139->createElement("gmd:title");
+ $title_cs = $iso19139->createElement("gco:CharacterString");
+ $titleText = $iso19139->createTextNode("GEMET - INSPIRE themes, version 1.0");
+ $dateText= $iso19139->createTextNode('2008-06-01');
+ $thesaurusName->appendChild($CI_Citation);
+ $MD_Keywords->appendChild($thesaurusName);
+ //add the keyword part to the right leaf
+ //End of keyword part **********
+ //generate constraints part
+ //generate service type part
+ //generate extent part
+ //generate coupling part
+ //end of service identification
+ //generate distribution part
+ //generate data quality part
+ #Part B 3 INSPIRE Category
+ #do this only if an INSPIRE keyword (Annex I-III) is set
+ #Resource Constraints B 8
+ $resourceConstraints=$iso19139->createElement("gmd:resourceConstraints");
+ $MD_LegalConstraints=$iso19139->createElement("gmd:MD_Constraints");
+ $useLimitation=$iso19139->createElement("gmd:useLimitation");
+ $useLimitation_cs=$iso19139->createElement("gco:CharacterString");
+ if(isset($mapbenderMetadata['accessconstraints'])){
+ $useLimitationText=$iso19139->createTextNode($mapbenderMetadata['accessconstraints']);
+ else
+ $useLimitationText=$iso19139->createTextNode("no conditions apply");
+ //TODO: Mapping of constraints between OWS/registry and INSPIRE
+ $useLimitation_cs->appendChild($useLimitationText);
+ $useLimitation->appendChild($useLimitation_cs);
+ $MD_LegalConstraints->appendChild($useLimitation);
+ $resourceConstraints->appendChild($MD_LegalConstraints);
+ $MD_DataIdentification->appendChild($resourceConstraints);
+ $MD_LegalConstraints=$iso19139->createElement("gmd:MD_LegalConstraints");
+ $accessConstraints=$iso19139->createElement("gmd:accessConstraints");
+ $MD_RestrictionCode=$iso19139->createElement("gmd:MD_RestrictionCode");
+ $MD_RestrictionCode->setAttribute("codeList", "http://standards.iso.org/ittf/PubliclyAvailableStandards/ISO_19139_Schemas/resources/Codelist/ML_gmxCodelists.xml#MD_RetrictionCode");
+ $MD_RestrictionCode->setAttribute("codeListValue", "otherRestrictions");
+ $MD_RestrictionCodeText=$iso19139->createTextNode("otherRestrictions");
+ $otherConstraints=$iso19139->createElement("gmd:otherConstraints");
+ $otherConstraints_cs=$iso19139->createElement("gco:CharacterString");
+ if (isset($mapbenderMetadata['accessconstraints']) & strtoupper($mapbenderMetadata['accessconstraints']) != 'NONE'){
+ $otherConstraintsText=$iso19139->createTextNode($mapbenderMetadata['accessconstraints']);
+ else {
+ $otherConstraintsText=$iso19139->createTextNode("no constraints");
+ $otherConstraints_cs->appendChild($otherConstraintsText);
+ $otherConstraints->appendChild($otherConstraints_cs);
+ $MD_RestrictionCode->appendChild($MD_RestrictionCodeText);
+ $accessConstraints->appendChild($MD_RestrictionCode);
+ $MD_LegalConstraints->appendChild($accessConstraints);
+ $MD_LegalConstraints->appendChild($otherConstraints);
+ //Spatial Resolution
+/* Example
+<gmd:spatialResolution><gmd:MD_Resolution><gmd:distance><gco:Distance uom="m">3.0</gco:Distance></gmd:distance></gmd:MD_Resolution></gmd:spatialResolution>
+ $spatialResolution=$iso19139->createElement("spatialResolution");
+ $MD_Resolution=$iso19139->createElement("gmd:MD_Resolution");
+ if ($mb_metadata['spatial_res_type'] == 'groundDistance') {
+ $distance = $iso19139->createElement("gmd:distance");
+ $Distance = $iso19139->createElement("gmd:Distance");
+ $Distance->setAttribute("uom", "http://standards.iso.org/ittf/PubliclyAvailableStandards/ISO_19139_Schemas/resources/uom/ML_gmxUom.xml#m");
+ $DistanceText=$iso19139->createTextNode($mb_metadata['spatial_res_value']);
+ $Distance->appendChild($DistanceText);
+ $distance->appendChild($Distance);
+ $MD_Resolution->appendChild($distance);
+ } else { //will be scaleDenominator
+ /*<gmd:equivalentScale>
+ <gmd:MD_RepresentativeFraction>
+ <gmd:denominator>
+ <gco:Integer>50000</gco:Integer>
+ </gmd:denominator>
+ </gmd:MD_RepresentativeFraction>
+ </gmd:equivalentScale>*/
+ $equivalentScale = $iso19139->createElement("gmd:equivalentScale");
+ $MD_RepresentativeFraction = $iso19139->createElement("gmd:MD_RepresentativeFraction");
+ $denominator = $iso19139->createElement("gmd:denominator");
+ $Integer = $iso19139->createElement("gco:Integer");
+ $IntegerText=$iso19139->createTextNode($mb_metadata['spatial_res_value']);
+ $Integer->appendChild($IntegerText);
+ $denominator->appendChild($Integer);
+ $MD_RepresentativeFraction->appendChild($denominator);
+ $equivalentScale->appendChild($MD_RepresentativeFraction);
+ $MD_Resolution->appendChild($equivalentScale);
+ $spatialResolution->appendChild($MD_Resolution);
+ $MD_DataIdentification->appendChild($spatialResolution);
+ #Part B 1.7 Dataset Language
+ $language=$iso19139->createElement("gmd:language");
+ $LanguageCode=$iso19139->createElement("gmd:LanguageCode");
+ $LanguageCodeText=$iso19139->createTextNode('ger');
+ $LanguageCode->setAttribute("codeListValue", "ger");
+ $LanguageCode->setAttribute("codeList", "http://standards.iso.org/ittf/PubliclyAvailableStandards/ISO_19139_Schemas/resources/Codelist/ML_gmxCodelists.xml#LanguageCode");
+ $LanguageCode->appendChild($LanguageCodeText);
+ $language->appendChild($LanguageCode);
+ $MD_DataIdentification->appendChild($language);
+<gmd:topicCategory>
+<gmd:MD_TopicCategoryCode>imageryBaseMapsEarthCover</gmd:MD_TopicCategoryCode>
+</gmd:topicCategory>
+ #Topic Category B 2.1 - not needed for services
+ $sql = "SELECT md_topic_category.md_topic_category_code_en FROM md_topic_category, layer_md_topic_category WHERE layer_md_topic_category.fkey_layer_id = $1 AND layer_md_topic_category.fkey_md_topic_category_id=md_topic_category.md_topic_category_id";
+ $t = array('i');
+ $e = new mb_notice("look for topic: ");
+ $countTopic = 0;
+ $e = new mb_exception("topic cat found!");
+ $topicCategory=$iso19139->createElement("gmd:topicCategory");
+ $MD_TopicCategoryCode=$iso19139->createElement("gmd:MD_TopicCategoryCode");
+ $MD_TopicCategoryText=$iso19139->createTextNode($row['md_topic_category_code_en']);
+ $MD_TopicCategoryCode->appendChild($MD_TopicCategoryText);
+ $topicCategory->appendChild($MD_TopicCategoryCode);
+ $MD_DataIdentification->appendChild($topicCategory);
+ $countTopic++;
+ $e = new mb_exception("count topic: ".$countTopic);
+ if ($countTopic == 0) {
+ $e = new mb_exception("no topic cat found!");
+ $MD_TopicCategoryText=$iso19139->createTextNode("no category defined till now!");
+ #Geographical Extent
+ $bbox = array();
+ //initialize if no extent is defined in the database
+ $bbox[0] = -180;
+ $bbox[1] = -90;
+ $bbox[2] = 180;
+ $bbox[3] = 90;
+ if (isset($mapbenderMetadata['bbox']) & ($mapbenderMetadata['bbox'] != '')) {
+ $bbox = explode(',',$mapbenderMetadata['bbox']);
+ $extent=$iso19139->createElement("gmd:extent");
+ $EX_Extent=$iso19139->createElement("gmd:EX_Extent");
+ $geographicElement=$iso19139->createElement("gmd:geographicElement");
+ $EX_GeographicBoundingBox=$iso19139->createElement("gmd:EX_GeographicBoundingBox");
+ $westBoundLongitude=$iso19139->createElement("gmd:westBoundLongitude");
+ $wb_dec=$iso19139->createElement("gco:Decimal");
+ $wb_text=$iso19139->createTextNode($bbox[0]);
+ $eastBoundLongitude=$iso19139->createElement("gmd:eastBoundLongitude");
+ $eb_dec=$iso19139->createElement("gco:Decimal");
+ $eb_text=$iso19139->createTextNode($bbox[2]);
+ $southBoundLatitude=$iso19139->createElement("gmd:southBoundLatitude");
+ $sb_dec=$iso19139->createElement("gco:Decimal");
+ $sb_text=$iso19139->createTextNode($bbox[1]);
+ $northBoundLatitude=$iso19139->createElement("gmd:northBoundLatitude");
+ $nb_dec=$iso19139->createElement("gco:Decimal");
+ $nb_text=$iso19139->createTextNode($bbox[3]);
+ $wb_dec->appendChild($wb_text);
+ $westBoundLongitude->appendChild($wb_dec);
+ $EX_GeographicBoundingBox->appendChild($westBoundLongitude);
+ $eb_dec->appendChild($eb_text);
+ $eastBoundLongitude->appendChild($eb_dec);
+ $EX_GeographicBoundingBox->appendChild($eastBoundLongitude);
+ $sb_dec->appendChild($sb_text);
+ $southBoundLatitude->appendChild($sb_dec);
+ $EX_GeographicBoundingBox->appendChild($southBoundLatitude);
+ $nb_dec->appendChild($nb_text);
+ $northBoundLatitude->appendChild($nb_dec);
+ $EX_GeographicBoundingBox->appendChild($northBoundLatitude);
+ $geographicElement->appendChild($EX_GeographicBoundingBox);
+ $EX_Extent->appendChild($geographicElement);
+ $extent->appendChild($EX_Extent);
+ $MD_DataIdentification->appendChild($extent);
+ //generate temporal extent from begin and end positions
+<gmd:extent>
+<gmd:EX_Extent>
+<gmd:temporalElement>
+<gmd:EX_TemporalExtent>
+<gmd:extent>
+<gml:TimePeriod gml:id="extent">
+<gml:beginPosition>1977-03-
+10T11:45:30</gml:beginPosition>
+<gml:endPosition>2005-01-
+15T09:10:00</gml:endPosition>
+</gml:TimePeriod>
+</gmd:extent>
+</gmd:EX_TemporalExtent>
+</gmd:temporalElement>
+</gmd:EX_Extent>
+</gmd:extent>
+ //check if maintenance is set and adopt the last time - both times are always set, cause the editor demands this!!!!
+ $temporalElement=$iso19139->createElement("gmd:temporalElement");
+ $EX_TemporalExtent=$iso19139->createElement("gmd:EX_TemporalExtent");
+ $extent2=$iso19139->createElement("gmd:extent");
+ $TimePeriod=$iso19139->createElement("gml:TimePeriod");
+ $TimePeriod->setAttribute("gml:id", "temporalextent"); //maybe exchange thru uuid?
+ $beginPosition=$iso19139->createElement("gml:beginPosition");
+ $beginPositionText=$iso19139->createTextNode($beginPositionValue);
+ $endPosition=$iso19139->createElement("gml:endPosition");
+ $endPositionText=$iso19139->createTextNode($endPositionValue);
+ //generate xml
+ $endPosition->appendChild($endPositionText);
+ $beginPosition->appendChild($beginPositionText);
+ $TimePeriod->appendChild($beginPosition);
+ $TimePeriod->appendChild($endPosition);
+ $extent2->appendChild($TimePeriod);
+ $EX_TemporalExtent->appendChild($extent2);
+ $temporalElement->appendChild($EX_TemporalExtent);
+ $EX_Extent->appendChild($temporalElement);
+//reference system
+https://geo-ide.noaa.gov/wiki/index.php?title=ISO_Boilerplate
+<gmd:referenceSystemInfo>
+ <gmd:MD_ReferenceSystem>
+ <gmd:referenceSystemIdentifier>
+ <gmd:RS_Identifier>
+ <gmd:authority>
+ <gmd:CI_Citation>
+ <gmd:title>
+ <gco:CharacterString>European Petroleum Survey Group (EPSG) Geodetic Parameter Registry</gco:CharacterString>
+ </gmd:title>
+ <gmd:date>
+ <gmd:CI_Date>
+ <gmd:date>
+ <gco:Date>2008-11-12</gco:Date>
+ </gmd:date>
+ <gmd:dateType>
+ <gmd:CI_DateTypeCode codeList="http://www.isotc211.org/2005/resources/Codelist/gmxCodelists.xml#CI_DateTypeCode" codeListValue="publication">publication</gmd:CI_DateTypeCode>
+ </gmd:dateType>
+ </gmd:CI_Date>
+ </gmd:date>
+ <gmd:citedResponsibleParty>
+ <gmd:CI_ResponsibleParty>
+ <gmd:organisationName>
+ <gco:CharacterString>European Petroleum Survey Group</gco:CharacterString>
+ </gmd:organisationName>
+ <gmd:contactInfo>
+ <gmd:CI_Contact>
+ <gmd:onlineResource>
+ <gmd:CI_OnlineResource>
+ <gmd:linkage>
+ <gmd:URL>http://www.epsg-registry.org/</gmd:URL>
+ </gmd:linkage>
+ </gmd:CI_OnlineResource>
+ </gmd:onlineResource>
+ </gmd:CI_Contact>
+ </gmd:contactInfo>
+ <gmd:role gco:nilReason="missing"/>
+ </gmd:CI_ResponsibleParty>
+ </gmd:citedResponsibleParty>
+ </gmd:CI_Citation>
+ </gmd:authority>
+ <gmd:code>
+ <gco:CharacterString>urn:ogc:def:crs:EPSG:4326</gco:CharacterString>
+ </gmd:code>
+ <gmd:version>
+ <gco:CharacterString>6.18.3</gco:CharacterString>
+ </gmd:version>
+ </gmd:RS_Identifier>
+ </gmd:referenceSystemIdentifier>
+ </gmd:MD_ReferenceSystem>
+</gmd:referenceSystemInfo>
+ $gmd_referenceSystemInfo=$iso19139->createElement("gmd:referenceSystemInfo");
+ $gmd_MD_ReferenceSystem=$iso19139->createElement("gmd:MD_ReferenceSystem");
+ $gmd_referenceSystemIdentifier=$iso19139->createElement("gmd:referenceSystemIdentifier");
+ $gmd_RS_Identifier=$iso19139->createElement("gmd:RS_Identifier");
+ $gmd_authority=$iso19139->createElement("gmd:authority");
+ $gmd_CI_Citation=$iso19139->createElement("gmd:CI_Citation");
+ $gmd_title=$iso19139->createElement("gmd:title");
+ $gmd_title_cs=$iso19139->createElement("gco:CharacterString");
+ $gmd_title_Text=$iso19139->createTextNode("European Petroleum Survey Group (EPSG) Geodetic Parameter Registry");
+ $gmd_title_cs->appendChild($gmd_title_Text);
+ $gmd_title->appendChild($gmd_title_cs);
+ $gmd_CI_Citation->appendChild($gmd_title);
+ $gmd_date=$iso19139->createElement("gmd:date");
+ $gmd_CI_Date=$iso19139->createElement("gmd:CI_Date");
+ $gmd_date2=$iso19139->createElement("gmd:date");
+ $gco_Date=$iso19139->createElement("gco:Date");
+ $gmd_dateType=$iso19139->createElement("gmd:dateType");
+ $gmd_CI_DateTypeCode=$iso19139->createElement("gmd:CI_DateTypeCode");
+ $gmd_CI_DateTypeCode_Text=$iso19139->createTextNode("publication");
+ $gmd_CI_DateTypeCode->setAttribute("codeList", "http://www.isotc211.org/2005/resources/Codelist/gmxCodelists.xml#CI_DateTypeCode");
+ $gmd_CI_DateTypeCode->setAttribute("codeListValue", "publication");
+ $gmd_CI_DateTypeCode->appendChild($gmd_CI_DateTypeCode_Text);
+ $gmd_dateType->appendChild($gmd_CI_DateTypeCode);
+ $gco_Date->appendChild($gmd_dateType);
+ $gmd_date2->appendChild($gco_Date);
+ $gmd_CI_Date->appendChild($gmd_date2);
+ $gmd_date->appendChild($gmd_CI_Date);
+ $gmd_CI_Citation->appendChild($gmd_date);
+ $gmd_citedResponsibleParty=$iso19139->createElement("gmd:citedResponsibleParty");
+ $gmd_CI_ResponsibleParty=$iso19139->createElement("gmd:CI_ResponsibleParty");
+ $gmd_organisationName=$iso19139->createElement("gmd:organisationName");
+ $gmd_organisationName_cs=$iso19139->createElement("gco:CharacterString");
+ $gmd_organisationName_Text=$iso19139->createTextNode("European Petroleum Survey Group");
+ $gmd_organisationName_cs->appendChild($gmd_organisationName_Text);
+ $gmd_organisationName->appendChild($gmd_organisationName_cs);
+ $gmd_CI_ResponsibleParty->appendChild($gmd_organisationName);
+ $gmd_contactInfo=$iso19139->createElement("gmd:contactInfo");
+ $gmd_CI_Contact=$iso19139->createElement("gmd:CI_Contact");
+ $gmd_onlineResource=$iso19139->createElement("gmd:onlineResource");
+ $gmd_CI_OnlineResource=$iso19139->createElement("gmd:CI_OnlineResource");
+ $gmd_linkage=$iso19139->createElement("gmd:linkage");
+ $gmd_URL=$iso19139->createElement("gmd:URL");
+ $gmd_URL_Text=$iso19139->createTextNode("http://www.epsg-registry.org/");
+ $gmd_URL->appendChild($gmd_URL_Text);
+ $gmd_linkage->appendChild($gmd_URL);
+ $gmd_CI_OnlineResource->appendChild($gmd_linkage);
+ $gmd_onlineResource->appendChild($gmd_CI_OnlineResource);
+ $gmd_CI_Contact->appendChild($gmd_onlineResource);
+ $gmd_contactInfo->appendChild($gmd_CI_Contact);
+ $gmd_CI_ResponsibleParty->appendChild($gmd_contactInfo);
+ $gmd_role=$iso19139->createElement("gmd:role");
+ $gmd_role->setAttribute("gco:nilReason", "missing");
+ $gmd_CI_ResponsibleParty->appendChild($gmd_role);
+ $gmd_citedResponsibleParty->appendChild($gmd_CI_ResponsibleParty);
+ $gmd_CI_Citation->appendChild($gmd_citedResponsibleParty);
+ $gmd_authority->appendChild($gmd_CI_Citation);
+ $gmd_RS_Identifier->appendChild($gmd_authority);
+ $gmd_code=$iso19139->createElement("gmd:code");
+ $gmd_code_cs=$iso19139->createElement("gco:CharacterString");
+ $gmd_code_text=$iso19139->createTextNode("urn:ogc:def:crs:".$mb_metadata['ref_system']);
+ $gmd_code_cs->appendChild($gmd_code_text);
+ $gmd_code->appendChild($gmd_code_cs);
+ $gmd_RS_Identifier->appendChild($gmd_code);
+ $gmd_version=$iso19139->createElement("gmd:version");
+ $gmd_version_cs=$iso19139->createElement("gco:CharacterString");
+ $gmd_version_text=$iso19139->createTextNode("6.18.3");
+ $gmd_version_cs->appendChild($gmd_version_text);
+ $gmd_version->appendChild($gmd_version_cs);
+ $gmd_RS_Identifier->appendChild($gmd_version);
+ $gmd_referenceSystemIdentifier->appendChild($gmd_RS_Identifier);
+ $gmd_MD_ReferenceSystem->appendChild($gmd_referenceSystemIdentifier);
+ $gmd_referenceSystemInfo->appendChild($gmd_MD_ReferenceSystem);
+ $MD_DataIdentification->appendChild($gmd_referenceSystemInfo);
+ $identificationInfo->appendChild($MD_DataIdentification);
+//distributionInfo
+ $gmd_distributionInfo=$iso19139->createElement("gmd:distributionInfo");
+ $MD_Distribution=$iso19139->createElement("gmd:MD_Distribution");
+ $gmd_distributionFormat=$iso19139->createElement("gmd:distributionFormat");
+ $MD_Format=$iso19139->createElement("gmd:MD_Format");
+ $gmd_name=$iso19139->createElement("gmd:name");
+ $MD_FormatName_cs=$iso19139->createElement("gco:CharacterString");
+ $MD_FormatNameText=$iso19139->createTextNode($mb_metadata['format']);
+ $MD_FormatVersion_cs=$iso19139->createElement("gco:CharacterString");
+ $MD_FormatVersionText=$iso19139->createTextNode("unkown");
+ $MD_FormatName_cs->appendChild($MD_FormatNameText);
+ $MD_FormatVersion_cs->appendChild($MD_FormatVersionText);
+ $gmd_name->appendChild($MD_FormatName_cs);
+ $gmd_version->appendChild($MD_FormatVersion_cs);
+ //$gmd_name->setAttribute("gco:nilReason", "inapplicable");
+ //$gmd_version->setAttribute("gco:nilReason", "inapplicable");
+ $gmd_transferOptions=$iso19139->createElement("gmd:transferOptions");
+ $MD_DigitalTransferOptions=$iso19139->createElement("gmd:MD_DigitalTransferOptions");
+ $gmd_onLine=$iso19139->createElement("gmd:onLine");
+ $CI_OnlineResource=$iso19139->createElement("gmd:CI_OnlineResource");
+ //Check if anonymous user has rights to access this layer - if not ? which resource should be advertised? TODO
+ if ($hasPermission) {
+ $gmd_URLText=$iso19139->createTextNode("http://".$_SERVER['HTTP_HOST']."/mapbender/php/wms.php?inspire=1&layer_id=".$mapbenderMetadata['layer_id']."");
+ else {
+ $gmd_URLText=$iso19139->createTextNode("https://".$_SERVER['HTTP_HOST']."/http_auth/".$mapbenderMetadata['layer_id']."?");
+ $gmd_URL->appendChild($gmd_URLText);
+ $CI_OnlineResource->appendChild($gmd_linkage);
+ $gmd_onLine->appendChild($CI_OnlineResource);
+ $MD_DigitalTransferOptions->appendChild($gmd_onLine);
+ $gmd_transferOptions->appendChild($MD_DigitalTransferOptions);
+ $MD_Format->appendChild($gmd_name);
+ $MD_Format->appendChild($gmd_version);
+ $gmd_distributionFormat->appendChild($MD_Format);
+ $MD_Distribution->appendChild($gmd_distributionFormat);
+ $MD_Distribution->appendChild($gmd_transferOptions);
+ $gmd_distributionInfo->appendChild($MD_Distribution);
+ //dataQualityInfo
+ $gmd_dataQualityInfo=$iso19139->createElement("gmd:dataQualityInfo");
+ $DQ_DataQuality=$iso19139->createElement("gmd:DQ_DataQuality");
+ $gmd_scope=$iso19139->createElement("gmd:scope");
+ $DQ_Scope=$iso19139->createElement("gmd:DQ_Scope");
+ $gmd_level=$iso19139->createElement("gmd:level");
+ $MD_ScopeCode=$iso19139->createElement("gmd:MD_ScopeCode");
+ $MD_ScopeCodeText=$iso19139->createTextNode("dataset");
+ $MD_ScopeCode->setAttribute("codeList", "http://standards.iso.org/ittf/PubliclyAvailableStandards/ISO_19139_Schemas/resources/Codelist/ML_gmxCodelists.xml#MD_RestrictionCode");
+ $MD_ScopeCode->setAttribute("codeListValue", "dataset");
+ $MD_ScopeCode->appendChild($MD_ScopeCodeText);
+ $gmd_level->appendChild($MD_ScopeCode);
+ $DQ_Scope->appendChild($gmd_level);
+ $gmd_scope->appendChild($DQ_Scope);
+ $DQ_DataQuality->appendChild($gmd_scope);
+<gmd:lineage>
+<gmd:LI_Lineage>
+<gmd:statement>
+<gco:CharacterString>test</gco:CharacterString>
+</gmd:statement>
+</gmd:LI_Lineage>
+</gmd:lineage>
+ $lineage=$iso19139->createElement("gmd:lineage");
+ $LI_Lineage=$iso19139->createElement("gmd:LI_Lineage");
+ $statement=$iso19139->createElement("gmd:statement");
+ $statement_cs=$iso19139->createElement("gco:CharacterString");
+ $statementText=$iso19139->createTextNode($mb_metadata['lineage']);
+ $lineage->appendChild($LI_Lineage);
+ $LI_Lineage->appendChild($statement);
+ $statement->appendChild($statement_cs);
+ $statement_cs->appendChild($statementText);
+ $DQ_DataQuality->appendChild($lineage);
+ //gmd:report in dataQualityInfo
+ $gmd_report=$iso19139->createElement("gmd:report");
+ $DQ_DomainConsistency=$iso19139->createElement("gmd:DQ_DomainConsistency");
+ $gmd_result=$iso19139->createElement("gmd:result");
+ $DQ_ConformanceResult=$iso19139->createElement("gmd:DQ_ConformanceResult");
+ $gmd_specification=$iso19139->createElement("gmd:specification");
+ $gmd_titleText=$iso19139->createTextNode("INSPIRE Metadata Regulation"); //TODO put in the inspire test suites from mb database!
+ $gmd_date_2=$iso19139->createElement("gmd:date");
+ $gco_DateText=$iso19139->createTextNode("2008-12-03"); //TODO put in the info from database
+ $CI_DateTypeCode=$iso19139->createElement("gmd:CI_DateTypeCode");
+ $CI_DateTypeCode->setAttribute("codeList","http://standards.iso.org/ittf/PubliclyAvailableStandards/ISO_19139_Schemas/resources/Codelist/ML_gmxCodelists.xml#CI_DateTypeCode");
+ $CI_DateTypeCode->setAttribute("codeListValue","publication");
+ $CI_DateTypeCodeText=$iso19139->createTextNode("publication");
+ $gmd_explanation=$iso19139->createElement("gmd:explanation");
+ $gmd_explanation_cs=$iso19139->createElement("gco:CharacterString");
+ $gmd_explanationText=$iso19139->createTextNode("No explanation available");
+ $gmd_pass=$iso19139->createElement("gmd:pass");
+ $gco_Boolean=$iso19139->createElement("gco:Boolean");
+ $gco_BooleanText=$iso19139->createTextNode("true"); //TODO maybe set here a string cause it can be unevaluated!! See Implementing Rules
+ //generate XML objects
+ $gco_Date->appendChild($gco_DateText);
+ $gmd_date->appendChild($gco_Date);
+ $CI_DateTypeCode->appendChild($CI_DateTypeCodeText);
+ $gmd_dateType->appendChild($CI_DateTypeCode);
+ $CI_Date->appendChild($gmd_date);
+ $CI_Date->appendChild($gmd_dateType);
+ $gmd_date_2->appendChild($CI_Date);
+ $gmd_title_cs->appendChild($gmd_titleText);
+ $CI_Citation->appendChild($gmd_title);
+ $CI_Citation->appendChild($gmd_date_2);
+ $gmd_specification->appendChild($CI_Citation);
+ $gmd_explanation_cs->appendChild($gmd_explanationText);
+ $gmd_explanation->appendChild($gmd_explanation_cs);
+ $gco_Boolean->appendChild($gco_BooleanText);
+ $gmd_pass->appendChild($gco_Boolean);
+ $DQ_ConformanceResult->appendChild($gmd_specification);
+ $DQ_ConformanceResult->appendChild($gmd_explanation);
+ $DQ_ConformanceResult->appendChild($gmd_pass);
+ $gmd_result->appendChild($DQ_ConformanceResult);
+ $DQ_DomainConsistency->appendChild($gmd_result);
+ $gmd_report->appendChild($DQ_DomainConsistency);
+ $DQ_DataQuality->appendChild($gmd_report);
+ $gmd_dataQualityInfo->appendChild($DQ_DataQuality);
+ //$MD_ScopeCode->setAttribute("codeListValue", "service");
+ $MD_Metadata->appendChild($identificationInfo);
+ $MD_Metadata->appendChild($gmd_distributionInfo);
+ $MD_Metadata->appendChild($gmd_dataQualityInfo);
+ return $iso19139->saveXML();
+ //function to validate against the inspire validation service
+ function validateInspireMetadata($iso19139Doc, $recordId){
+ $validatorUrl = 'http://www.inspire-geoportal.eu/INSPIREValidatorService/resources/validation/inspire';
+ #$validatorUrl2 = 'http://localhost/mapbender/x_geoportal/log_requests.php';
+ //send inspire xml to validator and push the result to requesting user
+ $validatorInterfaceObject = new connector();
+ $validatorInterfaceObject->set('httpType','POST');
+ #$validatorInterfaceObject->set('httpContentType','application/xml');
+ $validatorInterfaceObject->set('httpContentType','multipart/form-data'); # maybe given automatically
+ //first test with data from ram - doesn't function
+ $fields = array(
+ 'dataFile'=>urlencode($xml)
+ //generate file identifier:
+ $fileId = guid();
+ //generate temporary file under tmp
+ if($h = fopen(TMPDIR."/".$fileId."iso19139_validate_tmp.xml","w")){
+ if(!fwrite($h,$xml)){
+ $e = new mb_exception("mod_layerISOMetadata: cannot write to file: ".TMPDIR."iso19139_validate_tmp.xml");
+ fclose($h);
+ //send file as post like described under http://www.tecbrat.com/?itemid=13&catid=1
+ $fields['dataFile']='@'.TMPDIR.'/'.$fileId.'iso19139_validate_tmp.xml';
+ #if we give a string with parameters
+ #foreach($fields as $key=>$value) { $fields_string .= $key.'='.$value.'&'; }
+ #rtrim($fields_string,'&');
+ #$postData = $fields_string;
+ $postData = $fields;
+ #$e = new mb_exception("mod_layerISOMetadata: postData: ".$postData['dataFile']);
+ //number of post fields:
+ //curl_setopt($ch,CURLOPT_POST,count($fields));
+ $validatorInterfaceObject->set('httpPostFieldsNumber',count($postData));
+ $validatorInterfaceObject->set('curlSendCustomHeaders',false);
+ //$validatorInterfaceObject->set('httpPostData', $postData);
+ $validatorInterfaceObject->set('httpPostData', $postData); #give an array
+ $validatorInterfaceObject->load($validatorUrl);
+ header("Content-type: text/html; charset=UTF-8");
+ echo $validatorInterfaceObject->file;
+ //delete file in tmp
+ //TODO - this normally done by a cronjob
+ die();
+ function validateInspireMetadataFromData($iso19139Xml){
+ $fields = array(
+ 'dataFile'=>urlencode($iso19139Xml)
+ $fileId = guid();
+ if(!fwrite($h,$iso19139Xml)){
+ fclose($h);
+ die();
+function getEpsgByLayerId ($layer_id) { // from merge_layer.php
+ $epsg_list = "";
+ $sql = "SELECT DISTINCT epsg FROM layer_epsg WHERE fkey_layer_id = $1";
+ $v = array($layer_id);
+ $t = array('i');
+ $res = db_prep_query($sql, $v, $t);
+ while($row = db_fetch_array($res)){
+ $epsg_list .= $row['epsg'] . " ";
+ return trim($epsg_list);
+function getEpsgArrayByLayerId ($layer_id) { // from merge_layer.php
+ //$epsg_list = "";
+ $epsg_array=array();
+ $t = array('i');
+ $cnt=0;
+ $epsg_array[$cnt] = $row['epsg'];
+ $cnt++;
+ return $epsg_array;
+function guid(){
+ if (function_exists('com_create_guid')){
+ return com_create_guid();
+ }else{
+ mt_srand((double)microtime()*10000);//optional for php 4.2.0 and up.
+ $charid = strtoupper(md5(uniqid(rand(), true)));
+ $hyphen = chr(45);// "-"
+ $uuid = chr(123)// "{"
+ .substr($charid, 0, 8).$hyphen
+ .substr($charid, 8, 4).$hyphen
+ .substr($charid,12, 4).$hyphen
+ .substr($charid,16, 4).$hyphen
+ .substr($charid,20,12)
+ .chr(125);// "}"
+ return $uuid;
Modified: branches/2.7/http/php/mod_deleteWMS.php
--- branches/2.7/http/php/mod_deleteWMS.php 2011-07-19 13:04:13 UTC (rev 7971)
+++ branches/2.7/http/php/mod_deleteWMS.php 2011-07-19 13:04:37 UTC (rev 7972)
@@ -201,7 +201,19 @@
$wms_abstract = $row["wms_abstract"];
+ //Before the wms will be deleted, the metadataUrls from the Layers must be deleted!
+ //The other things will be done by class_wms!
+ $sql = "DELETE FROM mb_metadata WHERE metadata_id IN (SELECT metadata_id FROM mb_metadata INNER JOIN";
+ $sql .= " (SELECT * from ows_relation_metadata WHERE fkey_layer_id IN ";
+ $sql .= " (SELECT layer_id FROM layer WHERE fkey_wms_id = $1) )";
+ $sql .= " as relation ON ";
+ $sql .= " mb_metadata.metadata_id = relation.fkey_metadata_id AND mb_metadata.origin = 'capabilities')";
+ $v = array($wmsList);
+ $t = array('i');
$sql = "DELETE FROM wms WHERE wms_id = $1";
$t = array('i');
Modified: branches/2.7/http/php/mod_digitize_splitLine.php
--- branches/2.7/http/php/mod_digitize_splitLine.php 2011-07-19 13:04:13 UTC (rev 7971)
+++ branches/2.7/http/php/mod_digitize_splitLine.php 2011-07-19 13:04:37 UTC (rev 7972)
@@ -1,4 +1,5 @@
<?php
# License:
# Copyright (c) 2009, Open Source Geospatial Foundation
# This program is dual licensed under the GNU General Public License
@@ -9,50 +10,55 @@
require_once(dirname(__FILE__) . "/../classes/class_json.php");
$json = new Mapbender_JSON();
+$startPoint = null;
+$endPoint = null;
+$points = array();
+$lineArray = array();
-$line1Text = $_REQUEST["line1"];
-$line2Text = $_REQUEST["line2"];
+function isLinestring($string) {
+ $floatPattern = "-?\d+(\.\d+)?";
+ $pointPattern = $floatPattern . " " . $floatPattern;
+ $linePattern = "LINESTRING \(" . $pointPattern . ",( )*" . $pointPattern . "(,( )*" . $pointPattern . ")*\)";
+ if(preg_match("/" . $linePattern . "/", $string)) {
+ return true;
+ return false;
-$floatPattern = "-?\d+(\.\d+)?";
-$pointPattern = $floatPattern . " " . $floatPattern;
-$linePattern = "LINESTRING \(" . $pointPattern . ",( )*" . $pointPattern . "(,( )*" . $pointPattern . ")*\)";
-$pattern = "/" . $linePattern . "/";
-if (!preg_match($pattern, $line1Text)) {
- echo "not a line.";
- die();
+if(!isLinestring($_REQUEST["line1"]) OR !isLinestring($_REQUEST["line2"])) {
+ die("not a line.");
-if (!preg_match($pattern, $line2Text)) {
- die();
+$line1Text = $_REQUEST["line1"];
+$line2Text = $_REQUEST["line2"];
// find intersection points
$intersection_sql = sprintf("SELECT ST_AsText(multipoint.geom) as point, "
." ST_AsText(ST_StartPoint('%s'::geometry)) AS startpoint,"
." ST_AsText(ST_EndPoint('%s'::geometry)) AS endpoint "
- ." FROM ST_Dump((SELECT ST_AsText(ST_Intersection('%s'::geometry,'%s'::geometry)))) AS multipoint;",
- $line1Text,$line1Text,$line1Text,$line2Text);
+ ." FROM ST_Dump((SELECT ST_AsText(ST_Intersection('%s'::geometry,'%s'::geometry)))) AS multipoint"
+ ." ORDER BY ST_Line_Locate_Point('%s'::geometry,ST_AsText(multipoint.geom)::geometry) ASC;"
+ ,$line1Text,$line1Text,$line1Text,$line2Text,$line1Text);
$res = db_query($intersection_sql);
// add first and last points to the array of intersectionpoints
-$points = array();
-$lineArray = array();
- $points[0] = $row['startpoint'];
- $endpoint = $row['endpoint'];
+ $startPoint = $row['startpoint'];
+ $endPoint = $row['endpoint'];
$points[] = $row['point'];
// if the two lines don't intersect, we just do nothing, and return the first line
if(count($points) == 0){
$lineArray[] = $line1Text;
}else{
- $points[] = $endpoint;
+ $points = array_merge(array($startPoint),$points,array($endPoint));
// go through the point array in pairs, cut into segment, and add each segment onto resultArray
for($i = 0; $i < count($points)-1; $i++){
@@ -60,21 +66,33 @@
$pointStartText = $points[$i];
$pointEndText = $points[$i+1];
- $nthSegment_sql = sprintf("SELECT ST_AsText(ST_multi(geom)) AS substring FROM "
- ." ST_Dump((SELECT ST_AsText(ST_FORCE_COLLECTION(ST_Line_Substring("
- ."'%s'::geometry,"
- ."ST_Line_Locate_Point('%s'::geometry,'%s'::geometry),"
- ."ST_Line_Locate_Point('%s'::geometry,'%s'::geometry)"
- $line1Text,$line1Text,$pointStartText,$line1Text,$pointEndText);
+ if($i == count($points) -2 && $startPoint == $endPoint) {
+ $nthSegment_sql = sprintf("SELECT ST_AsText(ST_multi(geom)) AS substring FROM "
+ ." ST_Dump((SELECT ST_AsText(ST_FORCE_COLLECTION(ST_Line_Substring("
+ ."'%s'::geometry,"
+ ."ST_Line_Locate_Point('%s'::geometry,'%s'::geometry),"
+ ."1.0"
+ $line1Text,$line1Text,$pointStartText);
+ } else {
+ ."ST_Line_Locate_Point('%s'::geometry,'%s'::geometry)"
+ $line1Text,$line1Text,$pointStartText,$line1Text,$pointEndText);
$res = db_query($nthSegment_sql);
- if($row = db_fetch_array($res)){
+ if($row = db_fetch_array($res)) {
$lineArray[] = $row['substring'];
-$data = array("geometries" => $lineArray);
-$output = $json->encode($data);
+// OUTPUT
header("Content-type:application/x-json; charset=utf-8");
-echo $output;
+echo $json->encode(array("geometries" => $lineArray));
Modified: branches/2.7/http/php/mod_editElements.php
--- branches/2.7/http/php/mod_editElements.php 2011-07-19 13:04:13 UTC (rev 7971)
+++ branches/2.7/http/php/mod_editElements.php 2011-07-19 13:04:37 UTC (rev 7972)
@@ -612,7 +612,7 @@
echo "></td>\n";
echo "<td>";
if(is_file($row["e_src"]) && getimagesize($row["e_src"])){
- echo "<img src='".$row["e_src"]."' width='28px' height='28pxcdsvn '>";
+ echo "<img src='".$row["e_src"]."' width='28px' height='28px'>";
echo "</td>";
echo "<td class='myTable'>";
Copied: branches/2.7/http/php/mod_exportISOMetadata.php (from rev 7962, trunk/mapbender/http/php/mod_exportISOMetadata.php)
--- branches/2.7/http/php/mod_exportISOMetadata.php (rev 0)
+++ branches/2.7/http/php/mod_exportISOMetadata.php 2011-07-19 13:04:37 UTC (rev 7972)
@@ -0,0 +1,128 @@
+<?php
+#http://www.geoportal.rlp.de/mapbender/php/mod_exportISOMetadata.php?
+# $Id: mod_exportISOMetadata.php 235
+# http://www.mapbender.org/index.php/Inspire_Metadata_Editor
+# Copyright (C) 2002 CCGIS
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+require_once(dirname(__FILE__) . "/../../core/globalSettings.php");
+require_once(dirname(__FILE__) . "/../classes/class_connector.php");
+$con = db_connect(DBSERVER,OWNER,PW);
+db_select_db(DB,$con);
+//define the view or table where to read out the layer ids for which metadatafiles should be generated
+$wmsView = "search_wms_view";
+//would have been called from web
+//parse request parameter
+//make all parameters available as upper case
+foreach($_REQUEST as $key => $val) {
+ $_REQUEST[strtoupper($key)] = $val;
+//validate request params
+if (!isset($_REQUEST['TYPE'])) {
+ echo 'GET Parameter Type lacks';
+ die();
+if (isset($_REQUEST['TYPE']) and $_REQUEST['TYPE'] != "ALL") {
+ echo 'validate: <b>'.$_REQUEST['TYPE'].'</b> is not valid.<br/>';
+ die();
+$sql = "SELECT layer_id ";
+$sql .= "FROM ".$wmsView;
+//$sql .= "FROM layer WHERE layer_id IN (20203,20202)";
+$v = array();
+$t = array();
+$res = db_prep_query($sql,$v,$t);
+$generatorScript = '/mapbender/php/mod_layerISOMetadata.php?';
+$generatorScriptMetadata = '/mapbender/php/mod_dataISOMetadata.php?';
+$generatorBaseUrl = 'http://'.$_SERVER['HTTP_HOST'].$generatorScript;
+$generatorBaseUrlMetadata = 'http://'.$_SERVER['HTTP_HOST'].$generatorScriptMetadata;
+$countLayer = 0;
+$countMetadataURL = 0;
+echo date('Y-m-d - H:i:s', time())."<br>";
+//remove files from METADATA_DIR!
+if ($handle = opendir(METADATA_DIR)) {
+ echo "Delete files from temporary metadata folder:<br>";
+ /* This is the correct way to loop over the directory. */
+ while (false !== ($file = readdir($handle))) {
+ //check if file name begin with "mapbender";
+ $pos = strpos($file, "mapbender");
+ if ($pos !== false) {
+ //delete file with unlink
+ unlink(METADATA_DIR."/".$file);
+ echo METADATA_DIR."/".$file." has been deleted!<br>";
+ } else {
+ echo "$file will not be deleted!<br>";
+ closedir($handle);
+echo "Begin to create new metadata: ".date('Y-m-d - H:i:s', time())."<br>";
+while($row = db_fetch_array($res)){
+ $generatorUrl = $generatorBaseUrl."SERVICE=WMS&outputFormat=iso19139&id=".$row['layer_id'];
+ echo "URL requested : ".$generatorUrl."<br>";
+ $generatorInterfaceObject = new connector($generatorUrl);
+ $ISOFile = $generatorInterfaceObject->file;
+ $layerId = $row['layer_id'];
+ echo "File for layer ".$layerId." will be generated<br>";
+ //generate temporary files under tmp
+ if($h = fopen(METADATA_DIR."/mapbenderServiceMetadata_".$layerId."_iso19139.xml","w")){
+ if(!fwrite($h,$ISOFile)){
+ $e = new mb_exception("mod_exportISOMetadata.php: cannot write to file: ".METADATA_DIR."/mapbenderLayerMetadata_".$row['layer_id']."_iso19139.xml");
+ echo "Service metadata file for layer ".$layerId." written to ".METADATA_DIR."<br>";
+ fclose($h);
+ //get all connected metadata for this layer and save it too
+ $sql = <<<SQL
+SELECT metadata_id, uuid, link, linktype, md_format, origin FROM mb_metadata
+INNER JOIN (SELECT * from ows_relation_metadata
+WHERE fkey_layer_id = $layerId ) as relation ON
+mb_metadata.metadata_id = relation.fkey_metadata_id WHERE mb_metadata.export2csw = TRUE
+SQL;
+ $res_metadata = db_query($sql);
+ while ($row_metadata = db_fetch_array($res_metadata)) {
+ $generatorUrlMetadata = $generatorBaseUrlMetadata."outputFormat=iso19139&id=".$row_metadata['uuid'];
+ echo "<BLOCKQUOTE>URL requested : ".$generatorUrlMetadata."<br>";
+ $generatorInterfaceObject = new connector($generatorUrlMetadata);
+ echo "Metadata uuid: ".$row_metadata['uuid']."<br>";
+ if($h = fopen(METADATA_DIR."/mapbenderDataMetadata_".$layerId."_".$row_metadata['uuid']."_iso19139.xml","w")){
+ $e = new mb_exception("mod_exportISOMetadata.php: cannot write to file: ".METADATA_DIR."/metadata/mapbenderMetadata_".$layerId."_".$row_metadata['uuid']."_iso19139.xml");
+ echo "Data metadate file for layer ".$row['layer_id']." and metadata ".$row_metadata['uuid']." written to ".METADATA_DIR."</BLOCKQUOTE><br>";
+ fclose($h);
+ $countMetadataURL++;
+ $countLayer++;
+echo "Number of generated Service Metadata Records (one for each layer): ".$countLayer."<br>";
+echo "Number of generated Data Metadata Records (multiple for each layer): ".$countMetadataURL."<br>";
Modified: branches/2.7/http/php/mod_layerISOMetadata.php
--- branches/2.7/http/php/mod_layerISOMetadata.php 2011-07-19 13:04:13 UTC (rev 7971)
+++ branches/2.7/http/php/mod_layerISOMetadata.php 2011-07-19 13:04:37 UTC (rev 7972)
@@ -18,6 +18,8 @@
+//Script to generate a conformant ISO19139 service metadata record for a wms layer which is registrated in the mapbender database. It works as a webservice
+//The record will be fulfill the demands of the INSPIRE metadata regulation from 03.12.2008
require_once(dirname(__FILE__) . "/../classes/class_administration.php");
@@ -27,7 +29,7 @@
$admin = new administration();
-//define the view or table to use as input for metadata generation if this is wished. If not the data will be directly read from the database tables
+//define the view or table to use as input for metadata generation if this is wished. If not, the data will be directly read from the database tables
$wmsView = "wms_search_table";
$wmsView = '';
@@ -116,6 +118,7 @@
@@ -123,12 +126,12 @@
$t = array('i');
- $hasPermission=$admin->getLayerPermission($mapbenderMetadata['wms_id'],$mapbenderMetadata['layer_name'],ANONYMOUS_USER);
- //Creating the "MD_Metadata" node
+ //Creating the central "MD_Metadata" node
- //$MD_Metadata=$iso19139->registerNamespace('srv','http://www.iso211.org/2005/srv');
- //$wmt_ms_capabilities->setAttribute("updateSequence", $wms_row["wms_timestamp"]);
@@ -136,11 +139,12 @@
//generate identifier part
if (isset($mapbenderMetadata['uuid'])) {
- $identifierText = $iso19139->createTextNode($mapbenderMetadata['uuid']);//TODO: generate an uuid?
+ $identifierText = $iso19139->createTextNode($mapbenderMetadata['uuid']);
else {
@@ -148,6 +152,7 @@
@@ -171,8 +176,6 @@
@@ -188,6 +191,7 @@
@@ -219,6 +223,7 @@
#create xml tree
@@ -235,6 +240,7 @@
@@ -247,6 +253,7 @@
@@ -260,20 +267,21 @@
- #do the things for identification
- #create nodes
+ //do the things for identification
+ //create nodes
$SV_ServiceIdentification=$iso19139->createElement("srv:SV_ServiceIdentification");
- #add attribut
+ //TODO: add attribut
//$SV_ServiceIdentification->setAttribute("id", "dataId");
#create nodes for things which are defined - howto do the multiplicities? Ask Martin!
- #Create Resource title element B 1.1
+ //Create Resource title element B 1.1
if (isset($mapbenderMetadata['wms_title'])) {
- $titleText = $iso19139->createTextNode($mapbenderMetadata['wms_title']);
+ $titleText = $iso19139->createTextNode($mapbenderMetadata['wms_title']." - ".$mapbenderMetadata['layer_title']);
else {
@@ -281,6 +289,7 @@
if (isset($mapbenderMetadata['wms_timestamp_create'])) {
@@ -345,20 +354,9 @@
- #Do things for B 1.5 Resource unique identifier NOTE: not applicable for services
- //$identifier=$iso19139->createElement("gmd:identifier");
- //$rs_identifier=$iso19139->createElement("gmd:RS_Identifier");
- //$code=$iso19139->createElement("gmd:code");
- //$code_cs=$iso19139->createElement("gco:CharacterString");
- //$codeText=$iso19139->createTextNode($detail_array['t01_object.obj_id']);
- //$code_cs->appendChild($codeText);
- //$code->appendChild($code_cs);
- //$rs_identifier->appendChild($code);
- //$identifier->appendChild($rs_identifier);
- //$CI_Citation->appendChild($identifier);
- #create tree
$SV_ServiceIdentification->appendChild($citation);
@@ -371,6 +369,7 @@
$SV_ServiceIdentification->appendChild($abstract);
#Create part for point of contact for service identification
@@ -415,6 +414,7 @@
$SV_ServiceIdentification->appendChild($pointOfContact);
//generate graphical overview part
$sql = "SELECT layer_preview.layer_map_preview_filename FROM layer_preview WHERE layer_preview.fkey_layer_id=$1";
$v = array((integer)$mapbenderMetadata["layer_id"]);
@@ -471,12 +471,9 @@
$SV_ServiceIdentification->appendChild($graphicOverview);
- /*<gmd:graphicOverview>
+ /*example:
+ <gmd:graphicOverview>
<gmd:MD_BrowseGraphic>
<gmd:fileName>
<gco:CharacterString>http://goesr.noaa.gov/browse/datasetIdentifier</gco:CharacterString>
@@ -501,45 +498,55 @@
- //a special keyword for service type wms ;-)
+ //a special keyword for service type wms as INSPIRE likes it ;-)
$keywordText = $iso19139->createTextNode("humanGeographicViewer");
+ $v = array((integer)$recordId);
+ $t = array('i');
+ $res = db_prep_query($sql,$v,$t);
+ $countCustom = 0;
+ $countCustom++;
$SV_ServiceIdentification->appendChild($descriptiveKeywords);
- //generate constraints part
- //generate service type part
- //generate extent part
- //generate coupling part
- //end of service identification
- //generate distribution part
- //generate data quality part
- //if(isset($mapbenderMetadata['accessconstraints'])){
- $resourceConstraints=$iso19139->createElement("gmd:resourceConstraints");
- $MD_LegalConstraints=$iso19139->createElement("gmd:MD_Constraints");
- $useLimitation=$iso19139->createElement("gmd:useLimitation");
- $useLimitation_cs=$iso19139->createElement("gco:CharacterString");
- if(isset($mapbenderMetadata['accessconstraints'])){
- $useLimitationText=$iso19139->createTextNode($mapbenderMetadata['accessconstraints']);
- else
- $useLimitationText=$iso19139->createTextNode("no conditions apply");
- //TODO: Mapping of constraints between OWS/registry and INSPIRE
- $useLimitation_cs->appendChild($useLimitationText);
- $useLimitation->appendChild($useLimitation_cs);
- $MD_LegalConstraints->appendChild($useLimitation);
- $resourceConstraints->appendChild($MD_LegalConstraints);
- $SV_ServiceIdentification->appendChild($resourceConstraints);
+ else
+ //TODO: Mapping of constraints between OWS/registry and INSPIRE see View Service Guidance
+ $SV_ServiceIdentification->appendChild($resourceConstraints);
@@ -565,10 +572,11 @@
- //service type
- //<srv:serviceType>
- // <gco:LocalName>view</gco:LocalName>
- //</srv:serviceType>
+/* example
+ <srv:serviceType>
+ <gco:LocalName>view</gco:LocalName>
+ </srv:serviceType>*/
$serviceType=$iso19139->createElement("srv:serviceType");
$localName=$iso19139->createElement("gco:LocalName");
$serviceTypeText=$iso19139->createTextNode("view");
@@ -576,8 +584,6 @@
$serviceType->appendChild($localName);
$SV_ServiceIdentification->appendChild($serviceType);
$serviceTypeVersion=$iso19139->createElement("srv:serviceTypeVersion");
$serviceTypeVersion_cs=$iso19139->createElement("gco:CharacterString");
$serviceTypeVersionText=$iso19139->createTextNode("1.1.1");
@@ -586,25 +592,6 @@
$serviceTypeVersion->appendChild($serviceTypeVersion_cs);
$SV_ServiceIdentification->appendChild($serviceTypeVersion);
- # Part B 1.7 Dataset Language
- #if(isset($detail_array['t01_object.data_language'])){
- #$language=$iso19139->createElement("gmd:language");
- #$LanguageCode=$iso19139->createElement("gmd:LanguageCode");
- #$LanguageCodeText=$iso19139->createTextNode($detail_array['t01_object.data_language']);
- #$LanguageCode->appendChild($LanguageCodeText);
- #$language->appendChild($LanguageCode);
- #$SV_ServiceIdentification->appendChild($language);
- #Topic Category B 2.1 - not needed for services
- #if(isset($detail_array['t011_obj_geo_topic_cat.topic_category'])){
- #$topicCategory=$iso19139->createElement("gmd:topicCategory");
- #$MD_TopicCategoryCode=$iso19139->createElement("gmd:MD_TopicCategoryCode");
- #$MD_TopicCategoryText=$iso19139->createTextNode($detail_array['t011_obj_geo_topic_cat.topic_category']);
- #$MD_TopicCategoryCode->appendChild($MD_TopicCategoryText);
- #$topicCategory->appendChild($MD_TopicCategoryCode);
- #$SV_ServiceIdentification->appendChild($topicCategory);
$bbox = array();
@@ -658,13 +645,41 @@
$SV_ServiceIdentification->appendChild($extent);
+ //read all metadata entries:
+ $i=0;
+ $sql = <<<SQL
-#to the things which have to be done for integrating the service into a client like portalu ... they have defined another location to put the GetCap URL than INSPIRE does it
+SELECT metadata_id, uuid, link, linktype, md_format, origin, datasetid FROM mb_metadata
+WHERE fkey_layer_id = $recordId ) as relation ON
+mb_metadata.metadata_id = relation.fkey_metadata_id WHERE mb_metadata.origin IN ('capabilities','external','metador')
+SQL;
+ $res_metadataurl = db_query($sql);
+ if ($res_metadataurl != false) {
+ $couplingType=$iso19139->createElement("srv:couplingType");
+ $SV_CouplingType=$iso19139->createElement("srv:SV_CouplingType");
+ $SV_CouplingType->setAttribute("codeList", "SV_CouplingType");
+ $SV_CouplingType->setAttribute("codeListValue", "tight");
+ $couplingType->appendChild($SV_CouplingType);
+ $SV_ServiceIdentification->appendChild($couplingType);
+ //declare coupling type:
+ /*example from guidance paper:
+<srv:couplingType>
+ <srv:SV_CouplingType codeList="SV_CouplingType" codeListValue="tight"/>
+</srv:couplingType>
+<srv:couplingType gco:nilReason="missing"/>
+<srv:containsOperations gco:nilReason="missing"/>
+<srv:operatesOn xlink:href="http://image2000.jrc.it#image2000_1_nl2_multi"/>*/
+ #to the things which have to be done for integrating the service into a client like portalu ... they have defined another location to put the GetCap URL than INSPIRE does it
$containsOperation=$iso19139->createElement("srv:containsOperations");
$SV_OperationMetadata=$iso19139->createElement("srv:SV_OperationMetadata");
$operationName=$iso19139->createElement("srv:operationName");
$operationName_cs=$iso19139->createElement("gco:CharacterString");
@@ -679,7 +694,6 @@
$DCPList->setAttribute("codeList", "DCPList");
$DCPList->setAttribute("codeListValue", "WebService");
$DCP->appendChild($DCPList);
//connectPoint **********************************
@@ -691,7 +705,7 @@
- $gmd_URLText=$iso19139->createTextNode("http://".$_SERVER['HTTP_HOST']."/mapbender/php/wms.php?layer_id=".$mapbenderMetadata['layer_id']."");
else {
@@ -708,6 +722,30 @@
$containsOperation->appendChild($SV_OperationMetadata);
$SV_ServiceIdentification->appendChild($containsOperation);
+ //fill in operatesOn fields with datasetid if given
+ /*<srv:operatesOn xlink:href="http://image2000.jrc.it#image2000_1_nl2_multi"/>*/
+ while ($row_metadata = db_fetch_array($res_metadataurl)) {
+ switch ($row_metadata['origin']) {
+ case 'capabilities':
+ $operatesOn=$iso19139->createElement("srv:operatesOn");
+ $operatesOn->setAttribute("xlink:href", $row_metadata['datasetid']);
+ $SV_ServiceIdentification->appendChild($operatesOn);
+ break;
+ case 'metador':
+ $operatesOn->setAttribute("xlink:href", "http://www.geoportal.rlp.de#".$row_metadata['uuid']);
+ break;
+ case 'external':
+ $operatesOn->setAttribute("xlink:href", $row_metadata['uuid']);
+ break;
+ default:
+ break;
$serviceTypeVersion_cs->appendChild($serviceTypeVersionText);
@@ -715,7 +753,8 @@
$identificationInfo->appendChild($SV_ServiceIdentification);
-//distributionInfo
+ //distributionInfo
@@ -732,9 +771,10 @@
else {
@@ -761,8 +801,6 @@
$gmdProtocol->appendChild($gmdProtocol_cs);
$CI_OnlineResource->appendChild($gmdProtocol);
$gmdName_cs->appendChild($gmdNameText);
$gmdName->appendChild($gmdName_cs);
$CI_OnlineResource->appendChild($gmdName);
@@ -959,7 +997,7 @@
if ($_REQUEST['VALIDATE'] == "true"){
validateInspireMetadata($iso19139Doc, $recordId);
} else {
- pushISO19139($iso19139Doc, $recordId); //throw it out!
+ pushISO19139($iso19139Doc, $recordId); //throw it out to world!
Modified: branches/2.7/http/php/mod_savewmc_server.php
--- branches/2.7/http/php/mod_savewmc_server.php 2011-07-19 13:04:13 UTC (rev 7971)
+++ branches/2.7/http/php/mod_savewmc_server.php 2011-07-19 13:04:37 UTC (rev 7972)
@@ -61,32 +61,40 @@
if ($saveInSession === 1) {
- // CLEAN SESSION WMC FILES
- //do this by cronjob!
- //$tmp = scandir(TMPDIR);
- // get all files from tmp folder
- /*for($p = 0; $p < count($tmp); $p++) {
- // match timestamp on begin of the filename
- if(preg_match("/^([\d]+).*$/i", $tmp[$p],$timestamp)) {
- // if file older than 24h, remove it.
- if((time() - $timestamp[1]) >= 86400) { // 86400 = 24h
- unlink(TMPDIR."/wmc/".$tmp[$p]);
- // store XML in tmp folder
- if(Mapbender::session()->get("mb_wmc")) {
- $filename = Mapbender::session()->get("mb_wmc");
- } else {
- $filename = TMPDIR."/wmc/".time()."_".uniqid();//will be set to new one cause ?
- file_put_contents($filename, $wmc->xml);
- Mapbender::session()->set("mb_wmc",$filename);
+ // CLEAN SESSION WMC FILES
+ //do this by cronjob!
+ //$tmp = scandir(TMPDIR);
+ // get all files from tmp folder
+ /*for($p = 0; $p < count($tmp); $p++) {
+ // match timestamp on begin of the filename
+ if(preg_match("/^([\d]+).*$/i", $tmp[$p],$timestamp)) {
+ // if file older than 24h, remove it.
+ if((time() - $timestamp[1]) >= 86400) { // 86400 = 24h
+ unlink(TMPDIR."/wmc/".$tmp[$p]);
+ // store XML in tmp folder
+ if(Mapbender::session()->get("mb_wmc")) {
+ $filename = Mapbender::session()->get("mb_wmc");
+ } else {
+ $filename = TMPDIR."/wmc/".time()."_".uniqid();//will be set to new one cause ?
+ file_put_contents($filename, $wmc->xml);
+ Mapbender::session()->set("mb_wmc",$filename);
// store XML in session
- //Mapbender::session()->set("mb_wmc",$wmc->xml);
- Mapbender::session()->set("epsg",$mapObject->epsg);
+ //Mapbender::session()->set("mb_wmc",$wmc->xml);
+ //$epsgTest=$wmc->mainMap->extent->toJavaScript();
+ $epsgString = $wmc->mainMap->extentToJavascript();
+ // get epsg code from jquery string
+ preg_match('/EPSG:\d{4,5}/',$epsgString, $matches);
+ $epsgString = $matches[0];
+ if (preg_match('/EPSG:\d{4,5}/',$epsgString, $matches)) {
+ $e = new mb_notice("epsg: ".$epsgString);
+ $epsg = str_replace("EPSG:", "", $epsgString);
+ Mapbender::session()->set("epsg",$epsg);
Mapbender::session()->set("previous_gui", Mapbender::session()->get("mb_user_gui"));
$e = new mb_notice("mod_insertWMCIntoDB: save WMC in session succeeded.");
Modified: branches/2.7/http/php/mod_showMetadata.php
--- branches/2.7/http/php/mod_showMetadata.php 2011-07-19 13:04:13 UTC (rev 7971)
+++ branches/2.7/http/php/mod_showMetadata.php 2011-07-19 13:04:37 UTC (rev 7972)
@@ -20,7 +20,10 @@
require_once dirname(__FILE__) . "/../../core/globalSettings.php";
require_once dirname(__FILE__)."/../classes/class_connector.php";
require_once dirname(__FILE__) . "/../classes/class_user.php";
+require_once dirname(__FILE__) . "/../classes/class_wms.php";
+require_once dirname(__FILE__) . "/../classes/class_Uuid.php";
require_once dirname(__FILE__) . "/../../tools/wms_extent/extent_service.conf";
+require_once dirname(__FILE__) . "/../extensions/phpqrcode/phpqrcode.php";
//GET:
//resource: wms, layer, wfs, featuretype, wfs-conf, wmc
@@ -163,7 +166,7 @@
$translation['crs'] = 'Koordinatenreferenzsysteme (mit BBOX)';
$translation['wmccrs'] = 'Eingestelltes Koordinatenreferenzsystem';
$translation['wgs84Bbox'] = 'Eckpunkte in geogr. Koordinaten';
- $translation['wgs84BboxGraphic'] = 'Kartenübersicht';
+ $translation['wgs84BboxGraphic'] = 'Ausdehnung';
$translation['mapbenderCapabilities'] = 'Geoportal Capabilities';
$translation['originalCapabilities'] = 'Original Capabilities';
$translation['describeFeaturetype'] = 'Link zum Datenschema';
@@ -171,6 +174,7 @@
$translation['inspireMetadata'] = 'INSPIRE Service Metadaten';
$translation['showInspireMetadata'] = 'Metadatendatei';
$translation['securedCapabilities'] = 'Secured Capabilities URL';
+ $translation['inspireCapabilities'] = 'INSPIRE Capabilities URL';
$translation['capabilities'] = 'Link zum Capabilities Dokument';
$translation['inspireMetadataValidation'] = 'Validierung gegen INSPIRE Geoportal';
$translation['showInspireMetadataValidation'] = 'Validierung starten';
@@ -183,6 +187,15 @@
$translation['notMonitored'] = 'Informationen über die Qualität sind nur verfügbar, wenn das Service Monitoring aktiv ist!';
$translation['wmcQualityText'] = 'Für Web Map Context Dokumente entfällt die Angabe zur Qualität!';
$translation['noTouInformation'] = 'Es sind keine Informationen über Nutzungsbedingungen verfügbar!';
+ $translation['loadWmc'] = 'Link um Anwendung mit WMC zu starten';
+ $translation['validate'] = "Validierung";
+ $translation['uploaded metadata'] = "Hochgeladene Metadaten";
+ $translation['linked metadata'] = "Verlinkte Metadaten";
+ $translation['metadata from capabilities'] = "Metadaten von Service Capabilities";
+ $translation['added from registry'] = "Metadaten über Registry angereichert";
+ $translation['Coupled Metadata'] = "Verknüpfte Metadaten";
+ $translation['addLayerToMap'] = "Karte im eigenen Viewer anzeigen";
+ $translation['showMap'] = "Karte anzeigen";
break;
case "en":
$translation['overview'] = 'Overview';
@@ -227,9 +240,10 @@
$translation['crs'] = 'Coordinate Reference System';
$translation['wmccrs'] = 'Used Coordinate Reference System';
$translation['wgs84Bbox'] = 'Corner in geographic Coordinates';
- $translation['wgs84BboxGraphic'] = 'Map View';
+ $translation['wgs84BboxGraphic'] = 'Spatial Extent';
$translation['describeFeaturetype'] = 'Dataschema';
$translation['kml'] = 'KML';
$translation['inspireMetadata'] = 'INSPIRE Service Metadata';
@@ -247,6 +261,15 @@
$translation['notMonitored'] = 'Information about Quality is only available if the service monitoring is activated!';
$translation['wmcQualityText'] = 'In case of Web Map Context Documents the Quality part is not applicable!';
$translation['noTouInformation'] = 'No informations about terms of use are available!';
+ $translation['loadWmc'] = 'Link to start application with WMC';
+ $translation['validate'] = "validate";
+ $translation['uploaded metadata'] = "uploaded metadata";
+ $translation['linked metadata'] = "linked metadata";
+ $translation['metadata from capabilities'] = "metadata from capabilities";
+ $translation['added from registry'] = "added from registry";
+ $translation['Coupled Metadata'] = "Coupled Metadata";
+ $translation['addLayerToMap'] = "Show map in own viewer";
+ $translation['showMap'] = "Show map";
break;
default: #to english
@@ -291,7 +314,7 @@
@@ -299,6 +322,7 @@
$translation['inspireMetadataValidation'] = 'Validation against INSPIRE Geoportal';
$translation['showInspireMetadataValidation'] = 'Start Validation';
@@ -311,6 +335,15 @@
//Array with infos about the different elements which are shown in the tabs
@@ -570,8 +603,32 @@
$html .= '<link type="text/css" href="../extensions/jquery-ui-1.8.1.custom/css/custom-theme/jquery-ui-1.8.5.custom.css" rel="Stylesheet" />';
$html .= '<script type="text/javascript" src="../extensions/jquery-ui-1.8.1.custom/js/jquery-1.4.2.min.js"></script>';
$html .= '<script type="text/javascript" src="../extensions/jquery-ui-1.8.1.custom/js/jquery-ui-1.8.1.custom.min.js"></script>';
+//some js for dialog
+ //following is added to give a window with an interated link which can be included in external applications
+ $html .= '<script type="text/javascript">';
+ $html .= 'showCapabilitiesUrl = function (url,title) {';
+ $html .= 'hideCapabilitiesUrl();';
+ $html .= 'var $capabilitiesUrlPopup = $(\'<div><input size="40" type="text" value="\' + url + \'"/></div>\');';
+ $html .= '$capabilitiesUrlPopup.dialog({';
+ $html .= 'title: title,';
+ $html .= 'bgiframe: true,';
+ $html .= 'autoOpen: true,';
+ $html .= 'resizable: false,';
+ $html .= 'modal: true,';
+ $html .= 'width: 400,';
+ $html .= 'height: 90,';
+ $html .= 'pos: [600,40]';
+ $html .= '});';
+ $html .= '};';
+ $html .= 'hideCapabilitiesUrl = function () {';
+ $html .= 'if($(\'capabilitiesUrl.Popup\').size() > 0) {';
+ $html .= '$(\'capabilitiesUrl.Popup\').dialog(\'destroy\');';
+ $html .= '}';
+ $html .= '};';
+ $html .= '</script>';
/*if ($metadataContactGroup['metadatapointofcontactorglogo'] != '') {
$html .= "<img src='".$metadataContactGroup['metadatapointofcontactorglogo']."' height='30'>";
@@ -703,13 +760,17 @@
$user = new User();
+$layerAccessibility = $user->isLayerAccessible ($layerId);
// Monitoring is only available if the user is allowed to access this service
if ($resource == 'wms' or $resource == 'layer'){
- if ($user->isLayerAccessible($layerId)) {
+ if ($layerAccessibility) {
$is_public = $user->isPublic();
//show abo function to registred and authorized users
if (!$is_public) {
@@ -733,6 +794,27 @@
$html .= $aboStr;
+if ($layerAccessibility && WRAPPER_PATH != '' && ($resource == 'layer' or $resource == 'wms' )) {
+ $showMapUrl = $mapbenderBaseUrl.WRAPPER_PATH."?LAYER[zoom]=1&LAYER[id]=".$resourceMetadata['contentid'];
+ //$html .= $t_a.$translation['addLayerToMap'].$t_b."<a href='".$showMapUrl."' target='_blank'><img src='../img/osgeo_graphics/layer-wms-add.png'></a>".$t_c;
+ $html .= $t_a."<button onclick='window.open(\"".$showMapUrl."\",
+ \"windowname1\",
+ \"width=1024, height=768\");'
+ return false;><img src='../img/osgeo_graphics/layer-wms-add.png'>".$translation['showMap']."</button>".$t_b."".$t_c;
+if (WRAPPER_PATH != '' && $resource == 'wmc') {
+ $showMapUrl = $mapbenderBaseUrl.WRAPPER_PATH."?WMC=".$resourceMetadata['contentid'];
+ \"windowname1\",
$html .= $tableEnd;
$html .= '</p>';
$html .= '</div>';
@@ -825,27 +907,75 @@
$html .= $tableEnd;
$html .= $tableBegin;
//Scales
if ((isset($resourceMetadata['contentminscale']) & $resourceMetadata['contentminscale'] != '0') or (isset($resourceMetadata['contentmaxscale']) & $resourceMetadata['contentmaxscale'] != '0')){
- $html .= '<h4>'.$translation['restrictedScale'].'</h4>';
- if (isset($resourceMetadata['contentminscale']) & $resourceMetadata['contentminscale'] != '0' ) {
+ $html .= $t_a.$translation['restrictedScale'].$t_b.$t_c;
+ if (isset($resourceMetadata['contentminscale']) & $resourceMetadata['contentminscale'] != '0' & $resourceMetadata['contentminscale'] != "") {
$html .= $t_a.$translation['maxscale'].$t_b. "1 : ".$resourceMetadata['contentminscale'].$t_c;
- if (isset($resourceMetadata['contentmaxscale']) & $resourceMetadata['contentmaxscale'] != '0') {
+ if (isset($resourceMetadata['contentmaxscale']) & $resourceMetadata['contentmaxscale'] != '0' & $resourceMetadata['contentmaxscale'] != "") {
$html .= $t_a.$translation['minscale'].$t_b. "1 : ".$resourceMetadata['contentmaxscale'].$t_c;
+ //$html .= '</fieldset>';
+$html .= $tableEnd;
if (isset($resourceMetadata['wfs_describefeaturetype']) && ($resourceMetadata['wfs_describefeaturetype'] != '')) {
$html .= $t_a.$translation['describeFeaturetype'].$t_b."<a href='".$resourceMetadata['wfs_describefeaturetype']."SERVICE=WFS&VERSION=".$resourceMetadata['serviceversion']."&REQUEST=DescribeFeaturetype&typename=".$resourceMetadata['contentname']."' >Link</a>".$t_c;
#$html .= $t_a.$translation['describeFeaturetype'].$t_b."<a href='".$resourceMetadata['wfs_describefeaturetype']."&REQUEST=DescribeFeaturetype&typename=".$resourceMetadata['contentname']."' >Link</a>".$t_c;
if (isset($resourceMetadata['featuretype_geomType']) && ($resourceMetadata['featuretype_geomType'] != '')) {
$html .= $t_a.$translation['geomtype'].$t_b.$resourceMetadata['featuretype_geomType'].$t_c;
+if ($resource == 'wms' or $resource == 'layer'){
+ $html .= $tableBegin;
+ //part for coupled resources - if they exists (first this is realized only for layers):
+ //get metadata entries
+ //get MetadataURLs from md_metadata table
+ $sql = <<<SQL
+ SELECT metadata_id, uuid, link, linktype, md_format, origin FROM mb_metadata
+ INNER JOIN (SELECT * from ows_relation_metadata
+ WHERE fkey_layer_id = $layerId ) as relation ON
+ mb_metadata.metadata_id = relation.fkey_metadata_id WHERE mb_metadata.origin
+ IN('capabilities','external','metador','upload')
+SQL;
+ $res = db_query($sql);
+ $i = 0;
+ $metadataList = "";
+ while ($row = db_fetch_assoc($res)) {
+ //$html .= "<li>";
+ switch ($row["origin"]) {
+ case "capabilities" :
+ $metadataList .= "<img src='../img/osgeo_graphics/geosilk/server_map.png' title='".$translation['metadata from capabilities']."'/>";
+ break;
+ case "external" :
+ $metadataList .= "<img src='../img/osgeo_graphics/geosilk/link.png' title='".$translation['linked metadata']."'/>";
+ break;
+ case "upload" :
+ $metadataList .= "<img src='../img/button_blue_red/up.png' title='".$translation['uploaded metadata']."'/>";
+ break;
+ case "metador" :
+ $metadataList .= "<img src='../img/gnome/edit-select-all.png' title='".$translation['added from registry']."'/>";
+ break;
+ default:
+ break;
+ $metadataList .= "<a href='../php/mod_dataISOMetadata.php?outputFormat=iso19139&id=".$row["uuid"]."'>".$row["uuid"]."</a> <a href='../php/mod_dataISOMetadata.php?outputFormat=iso19139&id=".$row["uuid"]."&validate=true'>".$translation['validate']."</a><br>";
+ $i++;
+ if ($i != 0) {
+ $html .= $t_a.$translation['Coupled Metadata'].$t_b;
+ $html .= $metadataList;
+ $html .= $t_c;
+ $html .= $tableEnd;
$html .= $tableEnd;
$html .= '</p>';
$html .= '</div>';
@@ -985,21 +1115,43 @@
if ($resource == 'wmc') {
$html .= $t_a.$translation['wmc'].$t_b."XML".$t_c;
+ //show qr for link
+ //create uuid for qr graphic
+ $uuid = new Uuid;
+ $filename = "qr_wmc_".$uuid.".png";
+ //generate qr on the fly in tmp folder
+ //link to invoke wmc per get api if wrapper path isset
+ if (WRAPPER_PATH != "") {
+ $invokeLink = $mapbenderBaseUrl."".WRAPPER_PATH."?WMC=".$resourceMetadata['contentid'];
+ QRcode::png($invokeLink,TMPDIR."/".$filename);
+ $html .= $t_a.$translation['loadWmc'].$t_b."<img src='".TMPDIR."/".$filename."'>".$t_c;
if ($resource == 'wfs') {
- $html .= $t_a.$translation['mapbenderCapabilities'].$t_b."<a href = '../php/wms.php?layer_id=".$layerId."&PHPSESSID=".session_id()."&REQUEST=GetCapabilities&VERSION=1.1.1&SERVICE=WMS' target=_blank>".$translation['capabilities']."</a>".$t_c;
- $html .= $t_a.$translation['originalCapabilities'].$t_b."<a href = '".$resourceMetadata['wms_getcapabilities']."&REQUEST=GetCapabilities&VERSION=1.1.1&SERVICE=WMS' target=_blank>".$translation['capabilities']."</a>".$t_c;
+ $html .= $t_a.$translation['mapbenderCapabilities'].$t_b."<a href = '../php/wms.php?layer_id=".$layerId."&PHPSESSID=".session_id()."&REQUEST=GetCapabilities&VERSION=1.1.1&SERVICE=WMS' target=_blank>".$translation['capabilities']."</a> <img src='../img/osgeo_graphics/geosilk/link.png' onclick='showCapabilitiesUrl(\"".$mapbenderBaseUrl.$_SERVER['PHP_SELF']."/../wms.php?layer_id=".$layerId."&PHPSESSID=".session_id()."&REQUEST=GetCapabilities&VERSION=1.1.1&SERVICE=WMS"."\",\"".$translation['mapbenderCapabilities']."\");'>".$t_c;
+$capUrl = $resourceMetadata['wms_getcapabilities'].getConjunctionCharacter($resourceMetadata['wms_getcapabilities']).'REQUEST=GetCapabilities&VERSION=1.1.1&SERVICE=WMS';
+ //show only original url if the resource is not secured!
+ if (!$resourceSecured) {
+ $html .= $t_a.$translation['originalCapabilities'].$t_b."<a href = '".$capUrl."' target=_blank>".$translation['capabilities']."</a>".$t_c;
+ $html .= $t_a.$translation['inspireCapabilities'].$t_b."<a href = '../php/wms.php?layer_id=".$layerId."&PHPSESSID=".session_id()."&INSPIRE=1&REQUEST=GetCapabilities&VERSION=1.1.1&SERVICE=WMS' target=_blank>".$translation['capabilities']."</a> <img src='../img/osgeo_graphics/geosilk/link.png' onclick='showCapabilitiesUrl(\"".$mapbenderBaseUrl.$_SERVER['PHP_SELF']."/../wms.php?layer_id=".$layerId."&PHPSESSID=".session_id()."&INSPIRE=1&REQUEST=GetCapabilities&VERSION=1.1.1&SERVICE=WMS"."\",\"".$translation['inspireCapabilities']."\");'>".$t_c;
$html .= $t_a.$translation['inspireMetadata'].$t_b."<a href='../php/mod_layerISOMetadata.php?SERVICE=WMS&outputFormat=iso19139&Id=". $layerId."' target=_blank ><img style='border: none;' src='../img/inspire_tr_36.png' title='".$translation['inspireMetadata']."' style='width:34px;height:34px' alt='' /></a>".$t_c;
$html .= $t_a.$translation['inspireMetadataValidation'].$t_b."<a href='../php/mod_layerISOMetadata.php?SERVICE=WMS&outputFormat=iso19139&Id=".$layerId."&validate=true' target=_blank title='".$translation['inspireMetadataValidation']."'>".$translation['showInspireMetadataValidation']."</a>".$t_c;
//if service is secured and http_auth is adjusted show secured url
if ($resourceSecured) {
$securedLink = HTTP_AUTH_PROXY."/".$layerId."?REQUEST=GetCapabilities&VERSION=1.1.1&SERVICE=WMS";
- $html .= $t_a.$translation['securedCapabilities'].$t_b."<a href = '".$securedLink."' target=_blank>".$translation['capabilities']."</a>".$t_c;
+ $html .= $t_a.$translation['securedCapabilities'].$t_b."<a href = '".$securedLink."' target=_blank>".$translation['capabilities']."</a> <img src='../img/osgeo_graphics/geosilk/link.png' onclick='showCapabilitiesUrl(\"".$securedLink."\",\"".$translation['securedCapabilities']."\");'>".$t_c;
//kml
$html .= $t_a.$translation['kml'].$t_b."<a href='../php/mod_interfaceWms4Kml.php?id=".$layerId."'><img style='border: none;' src='../img/misc/kml_icon.gif' title='".$translation['kml']."' style='width:34px;height:34px' alt='' /></a>".$t_c;
@@ -1079,6 +1231,23 @@
return array("x" => $minx, "y" => $miny);
+function getConjunctionCharacter ($url) {
+ if (mb_strpos($url, "?") !== false) {
+ if (mb_substr($url, mb_strlen($url)-1, 1) == "?") {
+ return "";
+ else if (mb_substr($url, mb_strlen($url)-1, 1) == "&"){
+ return "";
+ else {
+ return "&";
+ else {
+ return "?";
+ return "";
Modified: branches/2.7/http/php/mod_updateWMS.php
--- branches/2.7/http/php/mod_updateWMS.php 2011-07-19 13:04:13 UTC (rev 7971)
+++ branches/2.7/http/php/mod_updateWMS.php 2011-07-19 13:04:37 UTC (rev 7972)
@@ -129,7 +129,9 @@
$mywms->createObjFromXML($myURL);
$mywms->optimizeWMS();
echo "<br />";
- //$mywms->overwrite=false; //TODO:this handling is used if the information should not be overwritten in the mapbender database. The owner has to explicitly overwrite them in the metadata editor - like geoportal.rlp
+ if (!MD_OVERWRITE) {
+ $mywms->overwrite=false;
$mywms->updateObjInDB($myWMS);
$mywms->displayWMS();
@@ -182,4 +184,4 @@
echo "There are no wms available for this user.<br>";
-</html>
\ No newline at end of file
+</html>
Modified: branches/2.7/http/php/mod_wmc2ol.php
--- branches/2.7/http/php/mod_wmc2ol.php 2011-07-19 13:04:13 UTC (rev 7971)
+++ branches/2.7/http/php/mod_wmc2ol.php 2011-07-19 13:04:37 UTC (rev 7972)
@@ -173,7 +173,7 @@
$html.="<title>".$xml->General->Title."</title>\n";
//include OL libs from local source - must be minimized, for new functions use the newest openlayers lib - directly from ol site
- $e = new mb_exception('georss request : '.$_REQUEST['GEORSS']);
+ $e = new mb_notice('georss request : '.$_REQUEST['GEORSS']);
if(isset($_REQUEST["withDigitize"]) or isset($_REQUEST["GEORSS"])){
if(($_REQUEST["withDigitize"]=='1') or ($_REQUEST["GEORSS"]!='')){
#$html.="<script src='http://".$_SERVER['HTTP_HOST']."/mapbender/extensions/OpenLayers-2.8/OpenLayers.js'></script>\n";
@@ -592,7 +592,25 @@
$georssElements = $georssXml->entry[$i]->children('http://www.georss.org/georss');
$gmlElements = $georssElements->children('http://www.opengis.net/gml');
$coords = explode(" ", $gmlElements->Point->pos);
+ $geoRssEpsg = $gmlElements->Point->attributes()->srsName;
+ $geoRssEpsgId = str_replace('EPSG:','',$geoRssEpsg);
+ //transform coordinates if other epsg was choosen
+ if ($geoRssEpsgId != $xml_epsg){
+ //coords have to be transformed
+ $sql= "select asewkt(transform(GeometryFromText ( 'POINT ( ";
+ $sql .= $coords[0]." ".$coords[1]." )',". $geoRssEpsgId ."),".intval($xml_epsg)."))";
+ //select asewkt(transform(GeometryFromText ( 'POINT ( 7 50 )', 4326 ),31466));
+ $e = new mb_notice("mod_wms2ol.php: sql (transform)=".$sql);
+ //read out result
+ $pointNew = db_fetch_row($res);
+ $e = new mb_notice("mod_wms2ol.php: pointNew=".$pointNew[0]);
+ $pattern = '~POINT\((.*)\)~i';
+ preg_match($pattern, $pointNew[0], $subpattern);
+ $e = new mb_notice("mod_wms2ol.php: subpattern=".$subpattern[1]);
+ $coords = explode(' ',$subpattern[1]);
$html.=" var point = new OpenLayers.Geometry.Point(";
$html.="".$coords[0].",".$coords[1].");\n";
$html.=" pointFeatures[".$i."] = new OpenLayers.Feature.Vector(point, {title: \"".$georssXml->entry[$i]->title."\", description : \"".str_replace("\"", "'",$georssXml->entry[$i]->content)."\", link : \"".$georssXml->entry[$i]->link->attributes()->href."\"});\n";
Modified: branches/2.7/http/php/wms.php
--- branches/2.7/http/php/wms.php 2011-07-19 13:04:13 UTC (rev 7971)
+++ branches/2.7/http/php/wms.php 2011-07-19 13:04:37 UTC (rev 7972)
@@ -1,6 +1,6 @@
<?php
-# $Id: mb_listGUIs.php 11 2006-07-31 16:22:36Z rothstein $
-# http://www.mapbender.org/index.php/mb_listGUIs.php
+# $Id: wms.php
+# http://www.mapbender.org/index.php/wms.php
@@ -20,7 +20,6 @@
require_once(dirname(__FILE__)."/../../core/globalSettings.php");
require_once(dirname(__FILE__)."/../classes/class_layer_monitor.php");
// make all parameters available as upper case
@@ -33,14 +32,25 @@
$service = strtoupper($_GET["SERVICE"]);
$layerId = $_GET["LAYER_ID"];
$updateSequence = intval($_GET["UPDATESEQUENCE"]);
+$inspire = $_GET["INSPIRE"];
+if (isset($inspire) && $inspire === 1 ) {
+ $inspire = true;
$mapbenderMetadaUrl = $_SERVER['HTTP_HOST']."/mapbender/php/mod_showMetadata.php?resource=layer&id=";
+$inspireServiceMetadataUrl = $_SERVER['HTTP_HOST']."/mapbender/php/mod_layerISOMetadata.php?SERVICE=WMS&outputFormat=iso19139&Id=";
+$mapbenderMetadataUrlUrl = $_SERVER['HTTP_HOST']."/mapbender/php/mod_dataISOMetadata.php?outputFormat=iso19139&id=";
+//http://www.geoportal.rlp.de/mapbender/php/mod_layerISOMetadata.php?SERVICE=WMS&outputFormat=iso19139&Id=24615
if (isset($_SERVER["HTTPS"])){
$urlPrefix = "https://";
} else {
$urlPrefix = "http://";
$mapbenderMetadataUrl = $urlPrefix.$mapbenderMetadataUrl;
+$inspireServiceMetadataUrl = $urlPrefix.$inspireServiceMetadataUrl;
+$mapbenderMetadataUrlUrl = $urlPrefix.$mapbenderMetadataUrlUrl;
@@ -164,8 +174,6 @@
$doc->encoding = 'UTF-8';
$doc->standalone = false;
#Check for existing content in database
#to be adopted TODO armin
function validate ($contactInformation_column) {
@@ -177,11 +185,14 @@
return $contactinformationcheck;
#Creating the "WMT_MS_Capabilities" node
$wmt_ms_capabilities = $doc->createElement("WMT_MS_Capabilities");
+if ($inspire){
+ $wmt_ms_capabilities->setAttribute("xmlns:inspire_common", "http://inspire.ec.europa.eu/schemas/inspire/1.0");
+ $wmt_ms_capabilities->setAttribute("xmlns:inspire_vs", "http://inspire.ec.europa.eu/schemas/inspire_vs/1.0");
$wmt_ms_capabilities = $doc->appendChild($wmt_ms_capabilities);
$wmt_ms_capabilities->setAttribute('version', '1.1.1');
@@ -246,7 +257,7 @@
validate($wms_row['address']) &&
validate($wms_row['city']) &&
validate($wms_row['stateorprovince']) &&
- validate($wms_row['postcode']) /*AND validate($wms_row['country'])*/ &&
+ validate($wms_row['postcode']) && //AND validate($wms_row['country']) &&
validate($wms_row['contactvoicetelephone']) &&
validate($wms_row['contactfacsimiletelephone']) &&
validate($wms_row['contactelectronicmailaddress']))
@@ -395,7 +406,7 @@
-#Creatig the "Capability" node
+#Creating the "Capability" node
$capability = $doc->createElement("Capability");
$capability = $wmt_ms_capabilities->appendChild($capability);
@@ -601,8 +612,62 @@
$formatText = $doc->createTextNode($wms_format_row['data_format']);
$formatText = $format->appendChild($formatText);
+#INSPIRE
+if ($inspire) {
+ #generating the vendor specific node
+ $vendorSpecificCapabilities = $doc->createElement("VendorSpecificCapabilities");
+ $vendorSpecificCapabilities = $capability->appendChild($vendorSpecificCapabilities);
+ #generate inspire_vs:ExtendedCapabilities node
+ $inspire_vs_ExtendedCapabilities = $doc->createElement("inspire_vs:ExtendedCapabilities");
+ $inspire_vs_ExtendedCapabilities->setAttribute("xmlns:inspire_common", "http://inspire.ec.europa.eu/schemas/common/1.0");
+ $inspire_vs_ExtendedCapabilities = $vendorSpecificCapabilities->appendChild($inspire_vs_ExtendedCapabilities);
+ #generate inspire_vs: node
+ #$inspire_vs_ExtendedCapabilities = $doc->createElement("inspire_vs:ExtendedCapabilities");
+ #$inspire_vs_ExtendedCapabilities = $vendorSpecificCapabilities->appendChild($inspire_vs_ExtendedCapabilities);
+ #MetadataUrl to inspire service metadata
+ $inspire_common_MetadataUrl = $doc->createElement("inspire_common:MetadataUrl");
+ $inspire_common_MetadataUrl = $inspire_vs_ExtendedCapabilities->appendChild($inspire_common_MetadataUrl);
+ #URL
+ $inspire_common_URL = $doc->createElement("inspire_common:URL");
+ $inspire_common_URLText = $doc->createTextNode($inspireServiceMetadataUrl.$layerId);
+ $inspire_common_URL->appendChild($inspire_common_URLText);
+ $inspire_common_URL = $inspire_common_MetadataUrl->appendChild($inspire_common_URL);
+ #MediaType
+ $inspire_common_MediaType = $doc->createElement("inspire_common:MediaType");
+ $inspire_common_MediaTypeText = $doc->createTextNode('application/vnd.iso.19139+xml');#from http://inspire.ec.europa.eu/schemas/inspire_vs/1.0/examples/WMS_Image2000GetCapabilities_InspireSchema.xml
+ $inspire_common_MediaType->appendChild($inspire_common_MediaTypeText);
+ $inspire_common_MediaType = $inspire_common_MetadataUrl->appendChild($inspire_common_MediaType);
+ #Language Part
+ #SupportedLanguages
+ $inspire_common_SupportedLanguages = $doc->createElement("inspire_common:SupportedLanguages");
+ $inspire_common_SupportedLanguages = $inspire_vs_ExtendedCapabilities->appendChild($inspire_common_SupportedLanguages);
+ #DefaultLanguage
+ $inspire_common_DefaultLanguage = $doc->createElement("inspire_common:DefaultLanguage");
+ $inspire_common_DefaultLanguage = $inspire_common_SupportedLanguages->appendChild($inspire_common_DefaultLanguage);
+ #Language
+ $inspire_common_Language = $doc->createElement("inspire_common:Language");
+ $inspire_common_LanguageText = $doc->createTextNode('ger');
+ $inspire_common_Language->appendChild($inspire_common_LanguageText);
+ $inspire_common_Language = $inspire_common_DefaultLanguage->appendChild($inspire_common_Language);
+ $inspire_common_SupportedLanguage = $doc->createElement("inspire_common:SupportedLanguage");
+ $inspire_common_SupportedLanguage = $inspire_common_SupportedLanguages->appendChild($inspire_common_SupportedLanguage);
+ #Language
+ $inspire_common_Language = $inspire_common_SupportedLanguage->appendChild($inspire_common_Language);
+ #ResponseLanguage
+ $inspire_common_ResponseLanguage = $doc->createElement("inspire_common:ResponseLanguage");
+ $inspire_common_ResponseLanguage = $inspire_vs_ExtendedCapabilities->appendChild($inspire_common_ResponseLanguage);
+ #Language
+ $inspire_common_Language = $inspire_common_ResponseLanguage->appendChild($inspire_common_Language);
#Querying layer table
$layer_sql = "SELECT * FROM layer WHERE layer.fkey_wms_id = $1 AND layer.layer_parent = ''";
$v = array($wms_row['wms_id']);
@@ -953,57 +1018,113 @@
# Creating Metadata Node
- $metadataUrl = $doc->createElement("MetadataURL");
- $metadataUrl = $sub_layer->appendChild($metadataUrl);
- $metadataUrl->setAttribute('type', "TC211");
- $format = $doc->createElement("Format");
- $format = $metadataUrl->appendChild($format);
- $formatText = $doc->createTextNode('text/html');
- $formatText = $format->appendChild($formatText);
+ //read out all metadata entries for specific layer
- if ($wms_row['wms_owsproxy'] <> "" AND $wms_row['wms_owsproxy'] <> NULL) {
- $onlineResource = $doc->createElement("OnlineResource");
- $onlineResource = $metadataUrl->appendChild($onlineResource);
- $onlineResource->setAttribute("xmlns:xlink", "http://www.w3.org/1999/xlink" );
- $onlineResource->setAttribute("xlink:href", OWSPROXY."/".session_id()."/".$wms_row["wms_owsproxy"]."?");
- $onlineResource->setAttribute("xlink:type", "simple");
- else {
- if ($sub_layer_row['layer_metadataurl'] <> "" AND $sub_layer_row['layer_metadataurl'] <> NULL) {
- $onlineResource->setAttribute("xlink:href", $sub_layer_row['layer_metadataurl']);
- //TODO set metadataUrl from mb_database
-else
- //$onlineResource->setAttribute("xlink:href", "http://www.geoportal.rlp.de/mapbender/x_geoportal/mod_layerMetadata.php?id=".$sub_layer_row['layer_id']);
- $onlineResource->setAttribute("xlink:href", $mapbenderMetadaUrl.$sub_layer_row['layer_id']);
+ $subLayerId = $sub_layer_row['layer_id'];
+ $sql = <<<SQL
+WHERE fkey_layer_id = $subLayerId ) as relation ON
+mb_metadata.metadata_id = relation.fkey_metadata_id WHERE mb_metadata.origin IN ('capabilities','external','metador','upload')
+SQL;
+ $e = new mb_notice("layerid: ".$sub_layer_row['layer_id']);
+ $i = 0;
+ $e = new mb_notice("row size: ".count($row_metadata));
+ $e = new mb_exception("i: ".$i);
+ //push entries into xml structure
+ //check for kind of link - push the right one into the link field
+ $metadataUrl = $doc->createElement("MetadataURL");
+ $metadataUrl = $sub_layer->appendChild($metadataUrl);
+ $metadataUrl->setAttribute('type', $row_metadata['linktype']);
+ $format = $doc->createElement("Format");
+ $format = $metadataUrl->appendChild($format);
+ $formatText = $doc->createTextNode($row_metadata['md_format']);
+ $formatText = $format->appendChild($formatText);
+ $onlineResource = $doc->createElement("OnlineResource");
+ $onlineResource = $metadataUrl->appendChild($onlineResource);
+ $onlineResource->setAttribute("xmlns:xlink", "http://www.w3.org/1999/xlink" );
+ $onlineResource->setAttribute("xlink:href", $row_metadata['link']);
+ break;
+ case 'external':
+ $metadataUrl->setAttribute('type', 'ISO19115:2003');
+ $formatText = $doc->createTextNode("text/xml");
+ $onlineResource->setAttribute("xlink:href", $mapbenderMetadataUrlUrl.$row_metadata['uuid']);
+ break;
+ case 'upload':
+ break;
+ case 'metador':
+ break;
+ default:
+ $onlineResource->setAttribute("xlink:href", $row['link']);
+ $onlineResource->setAttribute("xlink:href", "Url not given - please check your registry!");
+ break;
+ $onlineResource->setAttribute("xlink:type", "simple");
+ //Add linkage to Capabilities
+ $i++;
# Creating DataURL Node
$dataUrl = $doc->createElement("DataURL");
$dataUrl = $sub_layer->appendChild($dataUrl);
- $format = $dataUrl->appendChild($format);
+ $format = $dataUrl->appendChild($format);
+ $formatText = $doc->createTextNode('text/html');
if($wms_row['wms_owsproxy'] <> "" AND $wms_row['wms_owsproxy'] <> NULL)
More information about the Mapbender_commits
