[Mapbender-commits] r7976 - branches/2.7/http/plugins
svn_mapbender at osgeo.org
Tue Jul 19 09:20:06 EDT 2011
Author: astrid_emde
Date: 2011-07-19 06:20:06 -0700 (Tue, 19 Jul 2011)
New Revision: 7976
branches/2.7/http/plugins/mb_print.php
merged
Modified: branches/2.7/http/plugins/mb_print.php
--- branches/2.7/http/plugins/mb_print.php 2011-07-19 13:07:06 UTC (rev 7975)
+++ branches/2.7/http/plugins/mb_print.php 2011-07-19 13:20:06 UTC (rev 7976)
@@ -19,7 +19,7 @@
* > 2,1,'pdf print','Print','div','','',1,1,2,2,5,'',
* > '<div id="printPDF_working_bg"></div><div id="printPDF_working"><img src="../img/indicator_wheel.gif" style="padding:10px 0 0 10px">Generating PDF</div><div id="printPDF_input"><form id="printPDF_form" action="../print/printFactory.php"><div id="printPDF_selector"></div><div class="print_option"><input type="hidden" id="map_url" name="map_url" value=""/><input type="hidden" id="legend_url" name="legend_url" value=""/><input type="hidden" id="overview_url" name="overview_url" value=""/><input type="hidden" id="map_scale" name="map_scale" value=""/><input type="hidden" name="measured_x_values" /><input type="hidden" name="measured_y_values" /><br /></div><div class="print_option" id="printPDF_formsubmit"><input id="submit" type="submit" value="Print"><br /></div></form><div id="printPDF_result"></div></div>',
* > 'div','../plugins/mb_print.php',
- * > '../../lib/printbox.js,../extensions/jquery-ui-1.7.2.custom/development-bundle/external/bgiframe/jquery.bgiframe.min.js,../extensions/jquery.form.min.js',
+ * > '../../lib/printbox.js,../extensions/jquery-ui-1.7.2.custom/development-bundle/external/bgiframe/jquery.bgiframe.js,../extensions/jquery.form.min.js',
* > 'mapframe1','','http://www.mapbender.org/index.php/Print');
* > INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name,
@@ -42,8 +42,8 @@
* > var_value, context, var_type) VALUES('<appId>', 'printPDF',
* > 'timeout', '90000', 'define maximum milliseconds to wait for print request finished' ,'var');
- * > INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name,
- * > var_value, context, var_type) VALUES('<appId>', 'body',
+ * > INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name,
+ * > var_value, context, var_type) VALUES('<appId>', 'body',
* > 'print_css', '../css/print_div.css', '' ,'file/css');
* Help:
@@ -126,7 +126,7 @@
printBox.repaint();
* Method: createPrintBox
* creates a printBox in the current view, calculates the scale
@@ -232,7 +232,7 @@
$("."+myId+"-dialog").bind("dialogclose", function () {
destroyPrintBox();
* Method: loadConfig
@@ -244,7 +244,7 @@
// either json or a string, which trips up $.parseJSON which was being used in the callback
$.get(mbPrintConfigPath + configFilename, function(json, status){
actualConfig = json;
- buildForm();
+ buildForm();
hookForm();
if (typeof callback === "function") {
printBox = null;
@@ -260,7 +260,7 @@
* utility method to connect the form plugin to the print form.
var hookForm = function () {
- var o = {
+ var o = {
url: '../print/printFactory.php?e_id='+myId,
type: 'post',
dataType: 'json',
@@ -273,7 +273,6 @@
destroyPrintBox();
$("#"+myId+"_form").ajaxForm(o);
@@ -412,7 +411,7 @@
layerLegendObj.name = currentLayer.layer_name;
layerLegendObj.title = currentWms.getTitleByLayerName(currentLayer.layer_name);
var layerStyle = currentWms.getCurrentStyleByLayerName(currentLayer.layer_name);
- if (layerStyle === false) {
+ if (layerStyle === false || layerStyle === "") {
layerStyle = "default";
layerLegendObj.legendUrl = currentWms.getLegendUrlByGuiLayerStyle(currentLayer.layer_name, layerStyle);
@@ -425,11 +424,13 @@
var tmpObj = {};
tmpObj[currentWms.wms_currentTitle] = wmsLegendObj;
legendUrlArray.push(tmpObj);
- updateFormField(formData, "legend_url", $.toJSON(legendUrlArray));
+ var legendUrlArrayJson = $.toJSON(legendUrlArray));
+ updateFormField(formData, "legend_url", legendUrlArrayJson);
updateFormField(formData, "map_url", f.map_url.value);
updateFormField(formData, "scale", scale);
@@ -563,7 +564,7 @@
return false;
var scale = parseInt(this.value, 10);
- if (isNaN(scale) || typeof printBox === "undefined") {
+ if (isNaN(scale) || typeof printBox === "undefined") {
return true;
printBox.setScale(scale);
More information about the Mapbender_commits
