[Mapbender-commits] r7978 - branches/2.7/http/php
svn_mapbender at osgeo.org
Tue Jul 19 09:21:38 EDT 2011
Author: astrid_emde
Date: 2011-07-19 06:21:38 -0700 (Tue, 19 Jul 2011)
New Revision: 7978
Removed:
branches/2.7/http/php/mod_layerISOMetadataWriteToFolder.php
merged
Deleted: branches/2.7/http/php/mod_layerISOMetadataWriteToFolder.php
--- branches/2.7/http/php/mod_layerISOMetadataWriteToFolder.php 2011-07-19 13:21:23 UTC (rev 7977)
+++ branches/2.7/http/php/mod_layerISOMetadataWriteToFolder.php 2011-07-19 13:21:38 UTC (rev 7978)
@@ -1,97 +0,0 @@
-<?php
-#http://www.geoportal.rlp.de/mapbender/php/mod_layerISOMetadataWriteToFolder.php?SERVICE=WMS&outputFormat=iso19139&Id=24356
-# $Id: mod_layerISOMetadata.php 235
-# http://www.mapbender.org/index.php/Inspire_Metadata_Editor
-# Copyright (C) 2002 CCGIS
-# This program is free software; you can redistribute it and/or modify
-# it under the terms of the GNU General Public License as published by
-# the Free Software Foundation; either version 2, or (at your option)
-# any later version.
-# This program is distributed in the hope that it will be useful,
-# but WITHOUT ANY WARRANTY; without even the implied warranty of
-# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
-# GNU General Public License for more details.
-# You should have received a copy of the GNU General Public License
-# along with this program; if not, write to the Free Software
-# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
-require_once(dirname(__FILE__) . "/../../core/globalSettings.php");
-require_once(dirname(__FILE__) . "/../classes/class_connector.php");
-$con = db_connect(DBSERVER,OWNER,PW);
-db_select_db(DB,$con);
-//define the view or table where to read out the layer ids for which metadatafiles should be generated
-$wmsView = "wms_search_table";
-//$wmsView = '';
-//parse request parameter
-//make all parameters available as upper case
-foreach($_REQUEST as $key => $val) {
- $_REQUEST[strtoupper($key)] = $val;
-//validate request params
-if (!isset($_REQUEST['TYPE'])) {
- echo 'GET Parameter Type lacks';
- die();
-if (isset($_REQUEST['TYPE']) and $_REQUEST['TYPE'] != "ALL") {
- echo 'validate: <b>'.$_REQUEST['TYPE'].'</b> is not valid.<br/>';
- die();
-$sql = "SELECT layer_id ";
-$sql .= "FROM ".$wmsView;
-$v = array();
-$t = array();
-$res = db_prep_query($sql,$v,$t);
-$generatorScript = '/mapbender/php/mod_layerISOMetadata.php?';
-$generatorBaseUrl = 'http://'.$_SERVER['HTTP_HOST'].$generatorScript;
-echo $generatorBaseUrl."<br>";
-while($row = db_fetch_array($res)){
- $generatorUrl = $generatorBaseUrl."SERVICE=WMS&outputFormat=iso19139&id=".$row['layer_id'];
- echo "URL requested : ".$generatorUrl."<br>";
- $generatorInterfaceObject = new connector($generatorUrl);
- $ISOFile = $generatorInterfaceObject->file;
- #echo "Returned value: ".$ISOFile."<br>";
- //generate file identifier:
- $fileId = guid();
- echo "File ID ".$fileId." generated<br>";
- //generate temporary files under tmp
- if($h = fopen(TMPDIR."/metadata/mapbenderLayerMetadata_".$row['layer_id']."_".$fileId."_iso19139.xml","w")){
- if(!fwrite($h,$ISOFile)){
- $e = new mb_exception("mod_layerISOMetadata: cannot write to file: ".TMPDIR."/mapbenderLayerMetadata_".$row['layer_id']."_".$fileId."_iso19139.xml");
- echo "File for ID ".$fileId." written to TMP<br>";
- fclose($h);
-function guid(){
- if (function_exists('com_create_guid')){
- return com_create_guid();
- }else{
- mt_srand((double)microtime()*10000);//optional for php 4.2.0 and up.
- $charid = strtoupper(md5(uniqid(rand(), true)));
- $hyphen = chr(45);// "-"
- $uuid = chr(123)// "{"
- .substr($charid, 0, 8).$hyphen
- .substr($charid, 8, 4).$hyphen
- .substr($charid,12, 4).$hyphen
- .substr($charid,16, 4).$hyphen
- .substr($charid,20,12)
- .chr(125);// "}"
- return $uuid;
More information about the Mapbender_commits
