[Mapbender-commits] r7989 - branches/2.7/resources/db
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Fri Jul 22 09:44:34 EDT 2011
Author: astrid_emde
Date: 2011-07-22 06:44:34 -0700 (Fri, 22 Jul 2011)
New Revision: 7989
   branches/2.7/resources/db/install.sh
 set defaults for continue, answer to abort script
Modified: branches/2.7/resources/db/install.sh
--- branches/2.7/resources/db/install.sh	2011-07-21 11:50:14 UTC (rev 7988)
+++ branches/2.7/resources/db/install.sh	2011-07-22 13:44:34 UTC (rev 7989)
@@ -187,6 +187,7 @@
     then
           echo "Do you want that all files are owned by the apache webserver? (y)es or (n)o"
           read setowner
+		: ${setowner:="n"}
           if test $setowner != "n"
           then
 	        echo "Please specify the webserver user (on Debian Linux typically www-data)"
@@ -227,6 +228,7 @@
 then
 	echo "Continue? (y)es or (n)o"
 	read disclaimer
+		: ${disclaimer:="n"}
 	if test $disclaimer != "y"
 	then
 		exit 1
@@ -237,6 +239,7 @@
 	show_db_config;
 	echo "Look ok? Start Install? (y)es or (n)o"
 	read ANSWER
+		: ${ANSWER:="n"}
 	if test $ANSWER != "y"
 	then
 	    exec $0
More information about the Mapbender_commits mailing list
