[Mapbender-commits] r8000 - branches/2.7
svn_mapbender at osgeo.org
Tue Jul 26 05:22:03 EDT 2011
Author: astrid_emde
Date: 2011-07-26 02:22:03 -0700 (Tue, 26 Jul 2011)
New Revision: 8000
branches/2.7/Changes.txt
Changes 2.7.1 and 2.7.2 added
Modified: branches/2.7/Changes.txt
--- branches/2.7/Changes.txt 2011-07-26 08:57:07 UTC (rev 7999)
+++ branches/2.7/Changes.txt 2011-07-26 09:22:03 UTC (rev 8000)
@@ -4,6 +4,107 @@
The mapbender trac provides different reports. The reports give detailed information about the enhancements
+Changelog 2.7.2
+http://trac.osgeo.org/mapbender/query?status=closed&group=resolution&milestone=2.7.2+release
+790 Mapbender StartUpParams are not handled
+840 IE: WFS featureType configuration - popup helptext ok button not displayed size incorrect
+765 jquery ui dialog (jumps)
+786 savewms and loadwmc in my updated guis
+807 mod_usemap divs um_img and um_draw are missing
+816 Digitize: Wrong mouse position in scrolled page in IE
+817 New Constant in mapbender.conf
+818 Digitize: Does not work properly in scrolled IE page
+819 WMC Update to 2.7
+821 Mod_digitize_splitline don't intersect closed lines.
+827 Dynamic print frame: provide possibility to cancel a running print
+828 Dynamic print frame: delete temporary files after pdf creation
+829 Dynamic print frame: log WMS request in mb_log table in Mapbender db
+830 Dynamic print frame: avoid reload with ie
+831 Dynamic print frame: scale modification
+834 administration - remove application from category does not work
+836 admin2_de fails to load with IE8
+838 wrong entry new at the top of the treeGDE
+839 login.php application overview - change switch on mouseover to click
+841 IE: WFS featureType configuration - attribute columns - wrong number of header columns and columns
+846 layer with sld settings not displayed...
+852 scaleSelect has to refer to ../plugins/mb_selectScale.js and does not need e_attributes
+853 update script overwrites the user defined EPSG options
+854 open Legend with a button in a dialog
+858 integration of new applications PortalAdmin and PortalAdmin_DE
+859 french translation update in table translation for textes with '
+796 mismatching i18-Strings de
+808 mb_background doesn't work in 2.7
+812 Wrong Value in SQL-Update-Script
+813 Clean 'layer_load_count'
+814 URL of OL-Link to WMC
+815 Title of OL-Link from WMC
+844 guis looses Category when renamed
+848 2.7.x: Count of failure-login by users is not counted
+851 initial icon for Layer-Group wrong
+823 Show Icons in real Size
+833 Picture for showCoords not transparent (blue_red)
+782 table mb_meetingpoint does not exist
+842 add createCategory to Administzration and Administration_DE
+811 spatial search and digitize conflict
+850 FeatureInfo Dialog jumping arround
+527 HTTP authentication for OWS Proxy
+837 function getAvailableWfsForGeom(geom wfsConf) does not check for gml:MultiPolygonPropertyType and other element_types gml:* (with GeoServer 2.1.0)
+Changelog 2.7.1
+http://trac.osgeo.org/mapbender/query?status=closed&group=resolution&milestone=2.7.1+release
+778 WFS administration
+791 copy application - gui_lyer_title are not copied to new application
+799 gui_digitize update of a geometry does not work
+801 setbackground - background wms is not displayed
+806 load wfs doesn't load describeFeatureType information
+506 Use WMS monitor from www.geoportal.rlp.de
+661 Northarrow Print Overview
+715 Cutting two lines does not work as expected when
+720 login.php creates a session even if the user is not logged in
+734 temporary load GeoRSS and KML
+743 reloadTree triggers a single map request for every layer
+746 Layertree for GeoRSS and KML files GeoRSS
+747 WFS conf Layertree for selection
+749 setbackground - mb_background
+773 senseful description for new metadata applications
+774 admin_wmc_metadata does not load when no wmc is in the database
+776 slippy map (Browser overflow)
+777 change application description does not work
+784 WMS Metadata fails to start - authentication issue?
+787 Monitoring runs on database errors
+788 some scripts refer to x_geoportal instead of geoportal
+789 create and edit user - filter for users does not filter correctly
+792 featureInfoResults in dialog windows are displayed at the same position
+793 Can't insert Basepoint
+794 Digitize/update feature shows all configured Featuretypes
+800 resizeMapsize does not work on start
+802 slider in template_print is not displayed correctly
+699 wms status in treGDE
+739 Installation from script
+756 enhanced Metadatainformations for service and layer - check Abo alert a notice
+780 slippy map in Internet Explorer ...
+781 MousewheelZoom and selArea
+795 undefined targets of toogelModule after upgrade
+775 translation mistake in AdWMSFromFilteredListAjax
+503 Digitize module pop-ups
+810 WFS update has problem with updating featuretypes
+316 Mapbender treeGDE Observations
+451 select tool problem
+454 polish translation for Mapbender
+459 Administration Interface - TranslationBuilder
+485 Update Governance pages
+476 scale parameter for getlegendgraphic dropped by owsproxy
+785 setBBOX doesn't work
+500 Bug in WFS-Update
+779 Digitizing
+803 Administration_DE and Administration: Delete WFS Conf module does not load
Changelog 2.7
http://trac.osgeo.org/mapbender/report/48
20 addWMS beim Login
More information about the Mapbender_commits
