[Mapbender-commits] r7792 -
	trunk/mapbender/resources/db/pgsql/UTF-8/update
    svn_mapbender at osgeo.org
    Wed May  4 03:32:07 EDT 2011
Author: armin11
Date: 2011-05-04 00:32:07 -0700 (Wed, 04 May 2011)
New Revision: 7792
   trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.7rc1_to_2.7rc2_pgsql_UTF-8.sql
Added flag to indicate if an added metadataurl link should harvested and published via csw (geonetwork).
Modified: trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.7rc1_to_2.7rc2_pgsql_UTF-8.sql
--- trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.7rc1_to_2.7rc2_pgsql_UTF-8.sql	2011-05-03 19:17:35 UTC (rev 7791)
+++ trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.7rc1_to_2.7rc2_pgsql_UTF-8.sql	2011-05-04 07:32:07 UTC (rev 7792)
@@ -1804,6 +1804,7 @@
   "type" character varying(50), --from iso19115 - service/dataset/application ...
   harvestresult integer, --when getting information from caps
   harvestexception text, --if mimetype from link result is not the expected format
+  export2csw boolean, -- can be set to show if an added link should be harvested and this metadata should be published again
   tmp_reference_1 timestamp, --metadata
   tmp_reference_2 timestamp, --metadata
   spatial_res_type integer, --metadata
@@ -1817,7 +1818,7 @@
   individual_name integer, --what is this?
   visibility character varying(12), --from metador
   locked boolean DEFAULT false, --from metador
-  copyof character varying(100),--from metador
+  copyof character varying(100), --from metador
  -- fkey_metadata_id integer,
  -- fkey_layer_id integer,
  -- fkey_featuretype_id integer,
More information about the Mapbender_commits
