[Mapbender-commits] r7805 - in trunk/mapbender/http: php plugins
svn_mapbender at osgeo.org
Tue May 10 08:45:57 EDT 2011
Author: armin11
Date: 2011-05-10 05:45:57 -0700 (Tue, 10 May 2011)
New Revision: 7805
trunk/mapbender/http/php/mod_dataISOMetadata.php
trunk/mapbender/http/plugins/mb_metadata_server.php
Bugfix
Modified: trunk/mapbender/http/php/mod_dataISOMetadata.php
--- trunk/mapbender/http/php/mod_dataISOMetadata.php 2011-05-10 11:38:28 UTC (rev 7804)
+++ trunk/mapbender/http/php/mod_dataISOMetadata.php 2011-05-10 12:45:57 UTC (rev 7805)
@@ -565,6 +565,25 @@
$keyword->appendChild($keyword_cs);
$MD_Keywords->appendChild($keyword);
+ //pull special keywords from custom categories:
+ $e = new mb_exception("layer: ".$layerId);
+ $sql = "SELECT custom_category.custom_category_key FROM custom_category, layer_custom_category WHERE layer_custom_category.fkey_layer_id = $1 AND layer_custom_category.fkey_custom_category_id = custom_category.custom_category_id AND (custom_category_hidden <> 1 OR custom_category_hidden ISNULL)";
+ $v = array((integer)$layerId);
+ $t = array('i');
+ $res = db_prep_query($sql,$v,$t);
+ $e = new mb_notice("look for custom categories: ");
+ $countCustom = 0;
+ while ($row = db_fetch_array($res)) {
+ $keyword=$iso19139->createElement("gmd:keyword");
+ $keyword_cs=$iso19139->createElement("gco:CharacterString");
+ $keywordText = $iso19139->createTextNode($row['custom_category_key']);
+ $keyword_cs->appendChild($keywordText);
+ $keyword->appendChild($keyword_cs);
+ $MD_Keywords->appendChild($keyword);
+ $countCustom++;
+ $e = new mb_exception("count custom categories: ".$countCustom);
//read out the inspire categories and push them in as controlled keywords
/* example
<gmd:keyword><gco:CharacterString>Geographical names</gco:CharacterString></gmd:keyword><gmd:thesaurusName><gmd:CI_Citation><gmd:title><gco:CharacterString>GEMET - INSPIRE themes, version 1.0</gco:CharacterString></gmd:title><gmd:date><gmd:CI_Date><gmd:date><gco:Date>2008-06-01</gco:Date></gmd:date><gmd:dateType><gmd:CI_DateTypeCode codeList="http://standards.iso.org/ittf/PubliclyAvailableStandards/ISO_19139_Schemas/resources/Codelist/ML_gmxCodelists.xml#CI_DateTypeCode" codeListValue="publication">publication</gmd:CI_DateTypeCode></gmd:dateType></gmd:CI_Date></gmd:date></gmd:CI_Citation></gmd:thesaurusName></gmd:MD_Keywords></gmd:descriptiveKeywords><gmd:descriptiveKeywords><gmd:MD_Keywords><gmd:keyword><gco:CharacterString>BasisDLM</gco:CharacterString></gmd:keyword>
@@ -730,7 +749,7 @@
#Topic Category B 2.1 - not needed for services
//read keywords for resource out of the database:
- $sql = "SELECT md_topic_category.md_topic_category_code_en FROM md_topic_category, layer_md_topic_category WHERE layer_md_topic_category.fkey_layer_id=$1 AND layer_md_topic_category.fkey_md_topic_category_id=md_topic_category.md_topic_category_id";
+ $sql = "SELECT md_topic_category.md_topic_category_code_en FROM md_topic_category, layer_md_topic_category WHERE layer_md_topic_category.fkey_layer_id = $1 AND layer_md_topic_category.fkey_md_topic_category_id=md_topic_category.md_topic_category_id";
$t = array('i');
Modified: trunk/mapbender/http/plugins/mb_metadata_server.php
--- trunk/mapbender/http/plugins/mb_metadata_server.php 2011-05-10 11:38:28 UTC (rev 7804)
+++ trunk/mapbender/http/plugins/mb_metadata_server.php 2011-05-10 12:45:57 UTC (rev 7805)
@@ -739,10 +739,7 @@
SQL;
$v = array($link, $uuid, $origin, $title, $abstract, $format, $ref_system, $export2csw,$inspire_top_consistence,$tmp_reference_1,$tmp_reference_2,$lineage,$spatial_res_type,$spatial_res_value,$inspire_charset);
$t = array('s','s','s','s','s','s','s','b','b','s','s','s','s','s','s');
- $res = db_prep_query($sql,$v,$t);
- if (db_error()) {
- $test = new mb_exception("test");
try {
More information about the Mapbender_commits
