[Mapbender-commits] r7818 - trunk/mapbender/http/classes
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Tue May 17 06:03:36 EDT 2011
Author: armin11
Date: 2011-05-17 03:03:36 -0700 (Tue, 17 May 2011)
New Revision: 7818
   trunk/mapbender/http/classes/class_connector.php
Bugfixes
Modified: trunk/mapbender/http/classes/class_connector.php
--- trunk/mapbender/http/classes/class_connector.php	2011-05-17 10:02:55 UTC (rev 7817)
+++ trunk/mapbender/http/classes/class_connector.php	2011-05-17 10:03:36 UTC (rev 7818)
@@ -28,15 +28,15 @@
 	var $file;
 	private $connectionType;
+	private $timeOut = 20;
 	private $httpType = "get";
 	private $httpVersion = "1.0";
 	private $httpPostData;
 	private $httpContentType;
 	private $httpPostFieldsNumber;
 	private $curlSendCustomHeaders = true; //decide to send own headers or not
 	 * @constructor
 	 * @param String url the URL that will be loaded (optional)
@@ -155,6 +155,10 @@
 			case "curlSendCustomHeaders":
 				$this->curlSendCustomHeaders = $value;
+				break;
+			case "timeOut":
+				$this->timeOut = (integer)$value;
 				break;
 			case "httpContentType":
@@ -206,6 +210,7 @@
 		//allow https connections and handle certificates quite simply ;-)
 		curl_setopt($ch,CURLOPT_SSL_VERIFYHOST,0);
 		curl_setopt($ch, CURLOPT_SSL_VERIFYPEER, 0);
+		curl_setopt($ch, CURLOPT_CONNECTTIMEOUT, $this->timeOut);
 		//$e = new mb_notice("connector: test1:");
 		//get hostname/ip out of url
 		//$host = parse_url($url,PHP_URL_HOST);
More information about the Mapbender_commits mailing list
