[Mapbender-commits] r8203 - trunk/mapbender/conf
svn_mapbender at osgeo.org
Thu Nov 17 02:30:30 EST 2011
Author: armin11
Date: 2011-11-16 23:30:30 -0800 (Wed, 16 Nov 2011)
New Revision: 8203
Added:
trunk/mapbender/conf/twitter.conf-dist
trunk/mapbender/conf/mapbender.conf-dist
Enhancement to push update information of mapbenders database to twitter account.
Modified: trunk/mapbender/conf/mapbender.conf-dist
--- trunk/mapbender/conf/mapbender.conf-dist 2011-11-17 07:29:40 UTC (rev 8202)
+++ trunk/mapbender/conf/mapbender.conf-dist 2011-11-17 07:30:30 UTC (rev 8203)
@@ -151,6 +151,14 @@
define("GEO_RSS_FILE", "../tmp/georss.xml");
+# TWITTER
+# This need a twitter.conf file with the keys and tokens for the twitter account. See conf/twitter.conf-dist.
+define("TWITTER_NEWS", false);
# PREVIEW
# This path is defined to allow a saving of preview pictures for the content of wms/layers and
@@ -167,6 +175,12 @@
define("METADATA_DIR", "../../metadata");
+# METADATA CODESPACE
+# This path is used as a default codespace of metadatasets which are administrated thru the simple mapbender layer metadata editor
+#define("METADATA_DEFAULT_CODESPACE", "http://www.mapbender.org");
# UPLOAD
@@ -195,7 +209,6 @@
#define("SESSION_NAME", "MAPBENDER");
# HOSTNAME WHITELIST
# The whitelist is used for some modules who generate urls from a given hostName GET parameter. In such a case it is usefull to give a whitelist for security reasons! If no hostName is given, the parameter $_SERVER['HTTP_HOST'] is used for the urls!
Added: trunk/mapbender/conf/twitter.conf-dist
--- trunk/mapbender/conf/twitter.conf-dist (rev 0)
+++ trunk/mapbender/conf/twitter.conf-dist 2011-11-17 07:30:30 UTC (rev 8203)
@@ -0,0 +1,15 @@
+<?php
+//twitter.conf
+//documentation see: http://140dev.com/twitter-api-programming-tutorials/hello-twitter-oauth-php/
+// twitter keys
+define("TWITTER_CONSUMER_KEY", "");
+define("TWITTER_CONSUMER_SECRET", "");
+define("TWITTER_ACCESS_TOKEN", "");
+define("TWITTER_ACCESS_TOKEN_SECRET", "");
More information about the Mapbender_commits
