[Mapbender-commits] r8098 - in trunk/mapbender: http/javascripts
resources/locale/de_DE/LC_MESSAGES
svn_mapbender at osgeo.org
Mon Sep 5 05:53:18 EDT 2011
Author: armin11
Date: 2011-09-05 02:53:18 -0700 (Mon, 05 Sep 2011)
New Revision: 8098
trunk/mapbender/http/javascripts/mod_displayWmc.php
trunk/mapbender/http/javascripts/mod_loadwmc.js
trunk/mapbender/resources/locale/de_DE/LC_MESSAGES/Mapbender.po
Extent loadWMC with function to download the wmc xml.
Modified: trunk/mapbender/http/javascripts/mod_displayWmc.php
--- trunk/mapbender/http/javascripts/mod_displayWmc.php 2011-09-05 09:51:13 UTC (rev 8097)
+++ trunk/mapbender/http/javascripts/mod_displayWmc.php 2011-09-05 09:53:18 UTC (rev 8098)
@@ -20,6 +20,7 @@
require_once(dirname(__FILE__)."/../php/mb_validateSession.php");
$wmc_id = $_GET["wmc_id"];
+$download = $_GET["download"];
if ($wmc_id){
require_once(dirname(__FILE__)."/../classes/class_wmc.php");
@@ -28,16 +29,21 @@
if ($wmc_gml){
//Display WMC
- // if "short open tags" is activated, the xml output is interpreted
+ // if "short open tags" is activated, the xml output is interpreted
// as php, because the XML begins with "<?xml "
if (ini_get("short_open_tag") == 1) {
echo htmlentities($wmc_gml);
$e = new mb_warning("'Allow short open tags' is 'On' in php.ini...you might want to turn it off to allow proper WMC display.'");
else {
- header("Content-type: application/xhtml+xml; charset=".CHARSET);
- echo $wmc_gml;
+ if ($download == 'true') {
+ header('Content-disposition: attachment; filename=mapbender_wmc.xml');
+ header("Content-type: application/xhtml+xml; charset=".CHARSET);
+ echo $wmc_gml;
+ } else {
+ echo $wmc_gml;
else{
Modified: trunk/mapbender/http/javascripts/mod_loadwmc.js
--- trunk/mapbender/http/javascripts/mod_loadwmc.js 2011-09-05 09:51:13 UTC (rev 8097)
+++ trunk/mapbender/http/javascripts/mod_loadwmc.js 2011-09-05 09:53:18 UTC (rev 8098)
@@ -46,7 +46,7 @@
"labelMerge": "merge",
"labelAppend": "append",
"labelPublic": "public",
- "labelShow": "show",
+ "labelShow": "show/save",
"labelDelete": "delete",
"labelEditWmc": "edit",
"labelOpenLayers": "OpenLayers",
@@ -196,7 +196,7 @@
this.showWmcXml = function (id) {
this.hideWmcXml();
var url = "../javascripts/mod_displayWmc.php?wmc_id=" + id + "&" + mb_session_name + "=" + mb_nr;
- var $wmcDisplayPopup = $('<div class="wmcDisplayPopup"><iframe style="width:99%;height:99%;" src="' + url + '"></iframe></div>');
+ var $wmcDisplayPopup = $('<div class="wmcDisplayPopup"><a href="'+ url + '&download=true' +'"><h3>Download</h3><img src="../img/gnome/document-save.png"/></a><br><br><iframe style="width:99%;height:99%;" src="' + url + '"></iframe></div>');
$wmcDisplayPopup.dialog({
title: translatedI18nObject.labelWmcDocument,
bgiframe: true,
@@ -239,7 +239,7 @@
this.hideOpenLayersUrl();
var url = Mapbender.loginUrl;
url = url.replace("frames/login.php", "");
- url = url.replace("http/frames/login.php", "");
+ url = Mapbender.baseUrl + "/mapbender/";
url = url + "php/mod_wmc2ol.php?wmc_id=" + id ;
var $wmcOpenLayersUrlPopup = $('<div><input size="35" type="text" value="' + url + '"/></div>');
$wmcOpenLayersUrlPopup.dialog({
Modified: trunk/mapbender/resources/locale/de_DE/LC_MESSAGES/Mapbender.po
--- trunk/mapbender/resources/locale/de_DE/LC_MESSAGES/Mapbender.po 2011-09-05 09:51:13 UTC (rev 8097)
+++ trunk/mapbender/resources/locale/de_DE/LC_MESSAGES/Mapbender.po 2011-09-05 09:53:18 UTC (rev 8098)
@@ -1068,8 +1068,8 @@
msgstr "öffentlich"
#: ../http/javascripts/mod_loadwmc.js:87
-msgid "show"
-msgstr "anzeigen"
+msgid "show/save"
+msgstr "anzeigen/speichern"
#: ../http/javascripts/mod_loadwmc.js:88
#: ../http/javascripts/mod_loadwmc.js:294
More information about the Mapbender_commits
