[Mapbender-commits] r8105 - branches/2.7/lib
svn_mapbender at osgeo.org
Tue Sep 6 06:45:23 EDT 2011
Author: verenadiewald
Date: 2011-09-06 03:45:23 -0700 (Tue, 06 Sep 2011)
New Revision: 8105
branches/2.7/lib/printbox.js
don't use a filledPolygon any more to move the print box, because IE can't display the filled opacity, use instead a center point for moving print box
Modified: branches/2.7/lib/printbox.js
--- branches/2.7/lib/printbox.js 2011-09-06 06:51:25 UTC (rev 8104)
+++ branches/2.7/lib/printbox.js 2011-09-06 10:45:23 UTC (rev 8105)
@@ -22,7 +22,7 @@
var afterChangeSize = options.afterChangeSize || function (obj) {};
// styles
- var opacity = options.boxOpacity || 0.6;
+ var opacity = options.boxOpacity || 1;
var boxColour = options.boxColour || "#9999FF";
var frameColour = options.frameColour || "#000000";
var pointColour = options.pointColour || "#DD0000";
@@ -588,23 +588,36 @@
circleCanvas.paint();
boxCanvas.clear();
- if (!boxTooBig()) {
- boxCanvas.fillPolygon([
+ //don't use a filledPolygon any more to move the print box, because
+ //IE can't display the fill opacity, use instead a center point for moving print box
+ //if (!boxTooBig()) {
+ /*boxCanvas.fillPolygon([
pointArray[0].x + c.x,
pointArray[1].x + c.x,
pointArray[2].x + c.x,
pointArray[3].x + c.x
pointArray[0].y + c.y,
pointArray[1].y + c.y,
pointArray[2].y + c.y,
pointArray[3].y + c.y
- else {
- new Mb_warning("The print box is too big. The box is not filled.");
+ boxCanvas.setColor(pointColour);
+ boxCanvas.fillEllipse(
+ c.x - 4,
+ c.y - 4,
+ 10,
+ 10
+ //else {
+ // new Mb_warning("The print box is too big. The box is not filled.");
// frame
boxCanvas.setColor(frameColour);
@@ -677,7 +690,8 @@
$boxCanvas = $("#" + canvasName[0]);
$boxCanvas.css({
"opacity" : opacity,
- "filter" : "alpha(opacity=" + (opacity * 100) + ")"
+ "filter" : "alpha(opacity=" + (opacity * 100) + ")",
+ "cursor" : "move"
var boxCanvas = jg[0];
More information about the Mapbender_commits
