[Mapbender-commits] r8135 - branches/2.7/http/print/classes
svn_mapbender at osgeo.org
Mon Sep 12 05:05:17 EDT 2011
Author: kmq
Date: 2011-09-12 02:05:17 -0700 (Mon, 12 Sep 2011)
New Revision: 8135
branches/2.7/http/print/classes/mbPermanentImgDecorator.php
small fixup concerning image size calculations
Modified: branches/2.7/http/print/classes/mbPermanentImgDecorator.php
--- branches/2.7/http/print/classes/mbPermanentImgDecorator.php 2011-09-12 08:59:01 UTC (rev 8134)
+++ branches/2.7/http/print/classes/mbPermanentImgDecorator.php 2011-09-12 09:05:17 UTC (rev 8135)
@@ -34,8 +34,8 @@
$markers = json_decode($permanentImage);
- //only works if dpi is set to 72
- $_REQUEST['dpi'] = 72;
+ // If images are printed use the $_REQUEST['dpi'] setting they get too small at hight dpi values
+ $imagedpi = 72;
foreach( $markers as $marker){
@@ -65,13 +65,13 @@
// add the marker offset to the left
- $pdf_marker_off_x = ($marker->offset_x * 25.4)/$_REQUEST['dpi']; //unit: mm
+ $pdf_marker_off_x = ($marker->offset_x * 25.4)/$imagedpi; //unit: mm
// left edge of the image on the pdf
$pdf_img_off_x = ($pdf_map_x1 + $img_off_x * ($pdf_map_dx/$map_dx)) - $pdf_marker_off_x ; //unit: mm
// width of the image on the pdf
- $pdf_img_dx = ($marker->width * 25.4)/$_REQUEST['dpi']; //unit: mm
+ $pdf_img_dx = ($marker->width * 25.4)/$imagedpi; //unit: mm
// top edge of the map on pdf
@@ -98,13 +98,13 @@
// add the marker offset to the top
- $pdf_marker_off_y = ($marker->offset_y * 25.4)/$_REQUEST['dpi']; //unit: mm
+ $pdf_marker_off_y = ($marker->offset_y * 25.4)/$imagedpi; //unit: mm
// top edge of the image on the pdf
$pdf_img_off_y = $pdf_map_dy - ($pdf_map_y1 + $img_off_y * ($pdf_map_dy/$map_dy)) + $pdf_marker_off_y; //unit: mm
- $pdf_img_dy = ($marker->width * 25.4)/$_REQUEST['dpi']; //unit: mm
+ $pdf_img_dy = ($marker->width * 25.4)/$imagedpi; //unit: mm
$left = $pdf_img_off_x;
More information about the Mapbender_commits
