[Mapbender-commits] r8141 - in trunk/mapbender: . http/extensions
http/extensions/FirePHP-0.3 http/javascripts http/plugins
http/print resources/db/pgsql/UTF-8/update
svn_mapbender at osgeo.org
Mon Sep 12 08:23:56 EDT 2011
Author: kmq
Date: 2011-09-12 05:23:56 -0700 (Mon, 12 Sep 2011)
New Revision: 8141
trunk/mapbender/
trunk/mapbender/http/extensions/FirePHP-0.3/FirePHP.class.php
trunk/mapbender/http/extensions/FirePHP-0.3/fb.php
trunk/mapbender/http/extensions/jqjson.min.js
trunk/mapbender/http/javascripts/mod_sandclock.js
trunk/mapbender/http/plugins/mb_selectScale.js
trunk/mapbender/http/print/A4_portrait_template.json
trunk/mapbender/http/print/mapbender_template.json
trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.6rc1_to_2.6_pgsql_UTF-8.sql
merging from branch/2.7
Property changes on: trunk/mapbender
___________________________________________________________________
Modified: svn:mergeinfo
- /branches/kmq_dev:4021-4487,7677
+ /branches/2.7:8140
Property changes on: trunk/mapbender/http/extensions/FirePHP-0.3/FirePHP.class.php
- /branches/kmq_dev/http/extensions/FirePHP-0.3/FirePHP.class.php:7677
/branches/kmq_dev/http/extensions/FirePHP.class.php:4021-4487
+ /branches/2.7/http/extensions/FirePHP-0.3/FirePHP.class.php:8140
Property changes on: trunk/mapbender/http/extensions/FirePHP-0.3/fb.php
- /branches/kmq_dev/http/extensions/FirePHP-0.3/fb.php:7677
/branches/kmq_dev/http/extensions/fb.php:4021-4487
+ /branches/2.7/http/extensions/FirePHP-0.3/fb.php:8140
Property changes on: trunk/mapbender/http/extensions/jqjson.min.js
- /branches/kmq_dev/http/extensions/jqjson.min.js:7677
+ /branches/2.7/http/extensions/jqjson.min.js:8140
Property changes on: trunk/mapbender/http/javascripts/mod_sandclock.js
- /branches/kmq_dev/http/javascripts/mod_sandclock.js:7677
+ /branches/2.7/http/javascripts/mod_sandclock.js:8140
Modified: trunk/mapbender/http/plugins/mb_selectScale.js
--- trunk/mapbender/http/plugins/mb_selectScale.js 2011-09-12 12:21:40 UTC (rev 8140)
+++ trunk/mapbender/http/plugins/mb_selectScale.js 2011-09-12 12:23:56 UTC (rev 8141)
@@ -4,9 +4,9 @@
var that = this;
this.set = function (scale) {
- options.$target.mapbender(function () {
- this.repaintScale(null, null, scale);
+ // IE call this with empty scale for some convoluted reason
+ if(!scale){ return; }
+ options.$target.mapbender().repaintScale(null,null,scale);
var init = function () {
Modified: trunk/mapbender/http/print/A4_portrait_template.json
--- trunk/mapbender/http/print/A4_portrait_template.json 2011-09-12 12:21:40 UTC (rev 8140)
+++ trunk/mapbender/http/print/A4_portrait_template.json 2011-09-12 12:23:56 UTC (rev 8141)
@@ -93,6 +93,9 @@
"coords_font_family" : "Arial",
"coords_font_size" : 8
+ "permanentImage":{
+ "type":"permanentImage"
"messung" : {
"type" : "measure",
"do_fill" : 0,
Property changes on: trunk/mapbender/http/print/mapbender_template.json
- /branches/kmq_dev/http/print/mapbender_template.json:7677
+ /branches/2.7/http/print/mapbender_template.json:8140
Property changes on: trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.6rc1_to_2.6_pgsql_UTF-8.sql
- /branches/kmq_dev/resources/db/pgsql/UTF-8/update/update_2.6rc1_to_2.6_pgsql_UTF-8.sql:7677
/branches/kmq_dev/resources/db/pgsql/UTF-8/update/update_2.6rc1_to_2.6rc2_pgsql_UTF-8.sql:4021-4487
+ /branches/2.7/resources/db/pgsql/UTF-8/update/update_2.6rc1_to_2.6_pgsql_UTF-8.sql:8140
More information about the Mapbender_commits
