[Mapbender-commits] r8156 -
trunk/mapbender/resources/db/pgsql/UTF-8/update
svn_mapbender at osgeo.org
Mon Sep 19 07:24:23 EDT 2011
Author: verenadiewald
Date: 2011-09-19 04:24:23 -0700 (Mon, 19 Sep 2011)
New Revision: 8156
trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.7.2_to_2.7.3_pgsql_UTF-8.sql
changed sql for inserting raphael.js into body element
Modified: trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.7.2_to_2.7.3_pgsql_UTF-8.sql
--- trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.7.2_to_2.7.3_pgsql_UTF-8.sql 2011-09-19 11:23:21 UTC (rev 8155)
+++ trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.7.2_to_2.7.3_pgsql_UTF-8.sql 2011-09-19 11:24:23 UTC (rev 8156)
@@ -54,8 +54,7 @@
-- update all body elements for guis containing wz_jsgraphics.js
---> otherwise new wz_jsgraphics version leads to an error
UPDATE gui_element set
-e_mb_mod = '../extensions/RaphaelJS/raphael-1.4.7.min.js'
-where e_id = 'body' and fkey_gui_id IN (SELECT DISTINCT fkey_gui_id FROM gui_element where e_js_file LIKE '%wz_jsgraphics%' OR e_mb_mod LIKE '%wz_jsgraphics%');
+e_mb_mod = CASE WHEN e_mb_mod IS NULL THEN '../extensions/RaphaelJS/raphael-1.4.7.min.js' ELSE e_mb_mod::text ||',../extensions/RaphaelJS/raphael-1.4.7.min.js' END where e_id = 'body' and fkey_gui_id IN (SELECT DISTINCT fkey_gui_id FROM gui_element where e_js_file LIKE '%wz_jsgraphics%' OR e_mb_mod LIKE '%wz_jsgraphics%');
--update all gui elements using jquery-ui version 1.8.1 to 1.8.16
update gui_element set e_mb_mod = replace(e_mb_mod, 'jquery-ui-1.8.1.custom', 'jquery-ui-1.8.16.custom') where e_mb_mod LIKE '%jquery-ui-1.8.1.custom%';
More information about the Mapbender_commits
