[Mapbender-commits] r8172 - trunk/mapbender/http/plugins
svn_mapbender at osgeo.org
Wed Sep 28 09:47:25 EDT 2011
Author: verenadiewald
Date: 2011-09-28 06:47:25 -0700 (Wed, 28 Sep 2011)
New Revision: 8172
trunk/mapbender/http/plugins/mb_handleStartUpWmsParams.php
check if module setBackground is set
Modified: trunk/mapbender/http/plugins/mb_handleStartUpWmsParams.php
--- trunk/mapbender/http/plugins/mb_handleStartUpWmsParams.php 2011-09-28 13:46:42 UTC (rev 8171)
+++ trunk/mapbender/http/plugins/mb_handleStartUpWmsParams.php 2011-09-28 13:47:25 UTC (rev 8172)
@@ -1,40 +1,40 @@
-<?php
+<?php
* Package: handleStartUpWmsParams
* Description:
- * Mapbender is initialized with params for visibility and queryability of layers
+ * Mapbender is initialized with params for visibility and queryability of layers
* given as parameters visiblelayers and querylayers (comma-separated lists of layer names) or
* visiblelayers_regexpr and querylayers_regexpr (regular expressions that match layer names)
* Files:
* - http/plugins/mb_handleStartUpWmsParams.php
* SQL:
- * > INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment,
- * > e_title, e_element, e_src, e_attributes, e_left, e_top, e_width,
- * > e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file,
+ * > INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment,
+ * > e_title, e_element, e_src, e_attributes, e_left, e_top, e_width,
+ * > e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file,
* > e_mb_mod, e_target, e_requires, e_url) VALUES('<appId>','handleStartUpWmsParams',
* > 2,1,'handle wms params given in startup URL','handleStartUpWmsParams','div','','',1,1,2,2,5,'','',
* > 'div','../plugins/mb_handleStartUpWmsParams.php','',
* > 'mapframe1','','http://www.mapbender.org/index.php/HandleStartUpWmsParams');
- * > INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context,
- * > var_type) VALUES('<appId>', 'handleStartUpWmsParams', 'errormessages',
+ * > INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context,
+ * > var_type) VALUES('<appId>', 'handleStartUpWmsParams', 'errormessages',
* > 'log', 'log or alert if layer are not present, default is log' ,'var');
* Help:
* http://www.mapbender.org/HandleStartUpWmsParams
* Maintainer:
* http://www.mapbender.org/User:Verena_Diewald
* License:
* Copyright (c) 2009, Open Source Geospatial Foundation
- * This program is dual licensed under the GNU General Public License
- * and Simplified BSD license.
+ * This program is dual licensed under the GNU General Public License
+ * and Simplified BSD license.
* http://svn.osgeo.org/mapbender/trunk/mapbender/license/license.txt
require_once(dirname(__FILE__)."/../php/mb_validateSession.php");
@@ -82,143 +82,157 @@
var errormessages = options.errormessages;
// set background WMS
-Mapbender.events.setBackgroundIsReady.register(function () {
- if (apiBackgroundWms !== '') {
- var newBackgroundWms = parseInt(apiBackgroundWms);
- if (mod_setBackground_active !== false && wms[mod_setBackground_active]) {
- wms[mod_setBackground_active].gui_wms_visible = 0;
- wms[newBackgroundWms].gui_wms_visible = 2;
- mod_setBackground_active = newBackgroundWms;
- $("#setBackground > *").get(0).value = newBackgroundWms;
- zoom(mod_setBackground_target, true, 1.0);
+if(typeof Mapbender.events.setBackgroundIsReady != "undefined") {
+ Mapbender.events.setBackgroundIsReady.register(function () {
+ if (apiBackgroundWms !== '') {
+ var newBackgroundWms = parseInt(apiBackgroundWms);
+ if (mod_setBackground_active !== false && wms[mod_setBackground_active]) {
+ wms[mod_setBackground_active].gui_wms_visible = 0;
+ wms[newBackgroundWms].gui_wms_visible = 2;
+ mod_setBackground_active = newBackgroundWms;
+ $("#setBackground > *").get(0).value = newBackgroundWms;
+ zoom(mod_setBackground_target, true, 1.0);
+else {
// set queryability and visibility
Mapbender.events.afterInit.register(function () {
- if(apiVisibleLayers != '' || apiQueryLayers != '' ||
+ if(apiVisibleLayers != '' || apiQueryLayers != '' ||
apiVisibleLayersRegExpr != '' || apiQueryLayersRegExpr != '' ||
- apiDisableLayers != '' || apiDisableQueryLayers != '' ||
+ apiDisableLayers != '' || apiDisableQueryLayers != '' ||
apiDisableLayersRegExpr != '' || apiDisableQueryLayersRegExpr != ''
var currentVisibleLayerMatchTrue = false;
var currentQueryLayerMatchTrue = false;
var currentDisableLayerMatchTrue = false;
- var currentDisableQueryLayerMatchTrue = false;
+ var currentDisableQueryLayerMatchTrue = false;
var mapObject = Mapbender.modules[options.target[0]];
var wmsArray = mapObject.wms;
for (var i in wmsArray) {
var currentWms = wmsArray[i];
for (var j in currentWms.objLayer) {
var currentLayer = currentWms.objLayer[j];
// parameter apiDisableLayers
for (var k in apiDisableLayerArray) {
var disableLayer = apiDisableLayerArray[k];
- if (disableLayer == currentLayer.layer_name && currentLayer.gui_layer_status == '1' &&
+ if (disableLayer == currentLayer.layer_name && currentLayer.gui_layer_status == '1' &&
(currentLayer.gui_layer_selectable == 1 || currentLayer.gui_layer_visible == 1)
currentLayer.gui_layer_visible = 0;
checkForDisableLayerArray.push(currentLayer.layer_name);
// parameter apiDisableQueryLayers
for (var k in apiDisableQueryLayerArray) {
var disableQueryLayer = apiDisableQueryLayerArray[k];
if (disableQueryLayer == currentLayer.layer_name && currentLayer.gui_layer_queryable) {
currentLayer.gui_layer_querylayer = 0;
checkForDisableQueryLayerArray.push(currentLayer.layer_name);
// parameter apiVisibleLayers
for (var k in apiVisibleLayerArray) {
var visibleLayer = apiVisibleLayerArray[k];
- if (visibleLayer == currentLayer.layer_name && currentLayer.gui_layer_status == '1' &&
+ if (visibleLayer == currentLayer.layer_name && currentLayer.gui_layer_status == '1' &&
currentLayer.gui_layer_visible = 1;
checkForVisibleLayerArray.push(currentLayer.layer_name);
// parameter apiQueryLayers
for (var k in apiQueryLayerArray) {
var queryLayer = apiQueryLayerArray[k];
if (queryLayer == currentLayer.layer_name && currentLayer.gui_layer_queryable) {
currentLayer.gui_layer_querylayer = 1;
checkForQueryLayerArray.push(currentLayer.layer_name);
// parameter apiDisableLayersRegExpr
- if(apiDisableLayersRegExpr !== "") {
+ if(apiDisableLayersRegExpr !== "") {
var pattern = new RegExp(apiDisableLayersRegExpr);
var currentDisableLayerMatch = currentLayer.layer_name.match(pattern);
- if (currentDisableLayerMatch && currentLayer.gui_layer_status == '1' &&
+ if (currentDisableLayerMatch && currentLayer.gui_layer_status == '1' &&
currentDisableLayerMatchTrue = true;
// parameter apiDisableQueryLayersRegExpr
if (apiDisableQueryLayersRegExpr !== "") {
var pattern = new RegExp(apiDisableQueryLayersRegExpr);
var currentDisableQueryLayerMatch = currentLayer.layer_name.match(pattern);
if (currentDisableQueryLayerMatch && currentLayer.gui_layer_queryable) {
currentDisableQueryLayerMatchTrue = true;
// parameter apiVisibleLayersRegExpr
- if(apiVisibleLayersRegExpr !== "") {
+ if(apiVisibleLayersRegExpr !== "") {
var pattern = new RegExp(apiVisibleLayersRegExpr);
var currentVisibleLayerMatch = currentLayer.layer_name.match(pattern);
- if (currentVisibleLayerMatch && currentLayer.gui_layer_status == '1' &&
+ if (currentVisibleLayerMatch && currentLayer.gui_layer_status == '1' &&
currentVisibleLayerMatchTrue = true;
// parameter apiQueryLayersRegExpr
if (apiQueryLayersRegExpr !== "") {
var pattern = new RegExp(apiQueryLayersRegExpr);
var currentQueryLayerMatch = currentLayer.layer_name.match(pattern);
if (currentQueryLayerMatch && currentLayer.gui_layer_queryable) {
currentQueryLayerMatchTrue = true;
mb_restateLayers(options.target[0], currentWms.wms_id);
- if(apiVisibleLayers !== "") {
+ if(apiVisibleLayers !== "") {
var visibleLayerNotFound = array_diff(apiVisibleLayerArray, checkForVisibleLayerArray);
if(visibleLayerNotFound.length > 0) {
var visibleLayerString = visibleLayerNotFound.join(",");
- var visibleLayerNotFoundMsg = "Visible layer " + visibleLayerString + " not found.";
+ var visibleLayerNotFoundMsg = "Visible layer " + visibleLayerString + " not found.";
if(errormessages == 'alert'){
alert(visibleLayerNotFoundMsg);
}else{
@@ -226,12 +240,12 @@
- if(apiQueryLayers !== "") {
+ if(apiQueryLayers !== "") {
var queryLayerNotFound = array_diff(apiQueryLayerArray, checkForQueryLayerArray);
if(queryLayerNotFound.length > 0) {
var queryLayerString = queryLayerNotFound.join(",");
- var queryLayerNotFoundMsg = "Query layer " + queryLayerString + " not found.";
+ var queryLayerNotFoundMsg = "Query layer " + queryLayerString + " not found.";
alert(queryLayerNotFoundMsg);
}else{
@@ -239,10 +253,10 @@
if (apiVisibleLayersRegExpr !== "") {
- if(currentVisibleLayerMatchTrue === false) {
- var visibleLayerNotFoundMsg = "No visible layer matches the given regular expression.";
+ if(currentVisibleLayerMatchTrue === false) {
+ var visibleLayerNotFoundMsg = "No visible layer matches the given regular expression.";
}else{
@@ -250,10 +264,10 @@
if(currentQueryLayerMatchTrue === false) {
- var queryLayerNotFoundMsg = "No queryable layer matches the given regular expression.";
+ var queryLayerNotFoundMsg = "No queryable layer matches the given regular expression.";
}else{
@@ -261,12 +275,12 @@
- if(apiDisableLayers !== "") {
+ if(apiDisableLayers !== "") {
var disableLayerNotFound = array_diff(apiDisableLayerArray, checkForDisableLayerArray);
if(disableLayerNotFound.length > 0) {
var disableLayerString = disableLayerNotFound.join(",");
- var disableLayerNotFoundMsg = "Disable Layer: Disable layer " + disableLayerString + " not found.";
+ var disableLayerNotFoundMsg = "Disable Layer: Disable layer " + disableLayerString + " not found.";
alert(disableLayerNotFoundMsg);
}else{
@@ -274,43 +288,43 @@
- if(apiDisableQueryLayers !== "") {
+ if(apiDisableQueryLayers !== "") {
var disableQueryLayerNotFound = array_diff(apiDisableQueryLayerArray, checkForDisableQueryLayerArray);
if(disableQueryLayerNotFound.length > 0) {
var disableQueryLayerString = disableQueryLayerNotFound.join(",");
- var disableQueryLayerNotFoundMsg = "Disable Query Layer: Query layer " + disableQueryLayerString + " not found.";
+ var disableQueryLayerNotFoundMsg = "Disable Query Layer: Query layer " + disableQueryLayerString + " not found.";
alert(disableQueryLayerNotFoundMsg);
}else{
new Mapbender.Exception(disableQueryLayerNotFoundMsg);
if (apiDisableLayersRegExpr !== "") {
- if(currentDisableLayerMatchTrue === false) {
- var disableLayerNotFoundMsg = "Disable Layer: No visible layer matches the given regular expression.";
+ if(currentDisableLayerMatchTrue === false) {
+ var disableLayerNotFoundMsg = "Disable Layer: No visible layer matches the given regular expression.";
- }else{
+ }else{
new Mapbender.Exception(disableLayerNotFoundMsg);
if(currentDisableQueryLayerMatchTrue === false) {
- var disableQueryLayerNotFoundMsg = "Disable Query Layer: No queryable layer matches the given regular expression.";
+ var disableQueryLayerNotFoundMsg = "Disable Query Layer: No queryable layer matches the given regular expression.";
}else{
eventAfterMapRequest.trigger({
map: mapObject
@@ -321,8 +335,8 @@
var a=[], diff=[];
for(var i=0;i < a1.length;i++) {
a[a1[i]]=true;
for(var i=0;i < a2.length;i++) {
if(a[a2[i]]) {
delete a[a2[i]];
@@ -331,9 +345,9 @@
a[a2[i]]=true;
for(var k in a) {
- diff.push(k);
+ diff.push(k);
return diff;
\ No newline at end of file
More information about the Mapbender_commits
