[Mapbender-commits] r8328 - trunk/mapbender/http/classes
svn_mapbender at osgeo.org
Thu Apr 26 10:00:54 EDT 2012
Author: verenadiewald
Date: 2012-04-26 07:00:53 -0700 (Thu, 26 Apr 2012)
New Revision: 8328
trunk/mapbender/http/classes/class_twitter.php
trunk/mapbender/http/classes/class_wms.php
changes to enable control options for twitter and georss from scheduler
Modified: trunk/mapbender/http/classes/class_twitter.php
--- trunk/mapbender/http/classes/class_twitter.php 2012-04-26 13:58:03 UTC (rev 8327)
+++ trunk/mapbender/http/classes/class_twitter.php 2012-04-26 14:00:53 UTC (rev 8328)
@@ -1,8 +1,6 @@
<?php
require_once(dirname(__FILE__)."/../../core/globalSettings.php");
-if (TWITTER_NEWS) {
- require_once(dirname(__FILE__)."/../../conf/twitter.conf");
+require_once(dirname(__FILE__)."/../../conf/twitter.conf");
require_once(dirname(__FILE__)."/../extensions/tmhOAuth/tmhOAuth.php");
Modified: trunk/mapbender/http/classes/class_wms.php
--- trunk/mapbender/http/classes/class_wms.php 2012-04-26 13:58:03 UTC (rev 8327)
+++ trunk/mapbender/http/classes/class_wms.php 2012-04-26 14:00:53 UTC (rev 8328)
@@ -12,7 +12,6 @@
require_once dirname(__FILE__) . "/class_administration.php";
require_once dirname(__FILE__) . "/class_georss_factory.php";
require_once dirname(__FILE__) . "/class_mb_exception.php";
-require_once dirname(__FILE__) . "/class_twitter.php";
require_once dirname(__FILE__) . "/../classes/class_universal_wms_factory.php";
class wms {
@@ -66,14 +65,10 @@
var $default_epsg = 0;
var $overwrite = true;
- //GeoRSS feed
+ var $twitterNews = false;
+ var $setGeoRss = false;
+ var $geoRss;
var $geoRssFactory; // = new GeoRssFactory();
- var $geoRss; //= $this->geoRssFactory->loadOrCreate(GEO_RSS_FILE);
- // write a GeoRSS feed?
const GEORSS = true;
// append items to the feed when a new WMS is inserted?
const GEORSS_APPEND_ON_INSERT = true;
@@ -83,7 +78,16 @@
// and new layers have been added?
const GEORSS_APPEND_ON_UPDATE_NEWLAYERS = true;
- function wms() {
+ function _construct() {
+ if (TWITTER_NEWS) {
+ $this->twitterNews = true;
+ require_once dirname(__FILE__) . "/class_twitter.php";
+ if(GEO_RSS_FILE && GEO_RSS_FILE != "") {
+ //GeoRSS feed
+ $this->setGeoRss = true;
@@ -973,8 +977,8 @@
* private function
- function optimizeWMS() {
- /*define defaults for wms-version 1.0.0*/
+ function optimizeWMS($layerSearchable = null) {
+ /*define defaults for wms-version 1.0.0*/
$map_default_ok = false;
$featureinfo_default_ok = false;
$exception_default_ok = false;
@@ -1038,7 +1042,12 @@
$this->objLayer[$i]->gui_layer_minscale = $this->objLayer[$i]->layer_minscale;
$this->objLayer[$i]->gui_layer_maxscale = $this->objLayer[$i]->layer_maxscale;
- $this->objLayer[$i]->layer_searchable = 1;
+ if($layerSearchable != "") {
+ $this->objLayer[$i]->layer_searchable = $layerSearchable;
+ else {
+ $this->objLayer[$i]->layer_searchable = 1;
for($i=0;$i<count($this->data_format);$i++){
if(mb_strtolower($this->data_type[$i]) == 'map' && mb_strtoupper($this->data_format[$i]) == mb_strtoupper($map_default)){
@@ -1543,8 +1552,11 @@
$admin = new administration();
$uuid = new Uuid();
$this->checkObj();
- $this->geoRssFactory = new GeoRssFactory();
- $this->geoRss = $this->geoRssFactory->loadOrCreate(GEO_RSS_FILE);
+ if($this->setGeoRss == true){
+ $this->geoRssFactory = new GeoRssFactory();
+ $this->geoRss = $this->geoRssFactory->loadOrCreate(GEO_RSS_FILE);
db_begin();
# TABLE wms
@@ -1661,7 +1673,7 @@
//$geoRssFactory = new GeoRssFactory();
//$geoRss = $geoRssFactory->loadOrCreate(GEO_RSS_FILE);
$e = new mb_notice("class_wms.php: writeObjInDB: test if geoRss maybe null!");
- if (!is_null($this->geoRss)) {
+ if ($this->setGeoRss == true && !is_null($this->geoRss)) {
$e = new mb_notice("class_wms.php: writeObjInDB: geoRss was not NULL!");
$geoRssItem = new GeoRssItem();
$geoRssItem->setTitle("NEW WMS: " . $this->wms_title." (".$myWMS.")");
@@ -1686,8 +1698,8 @@
$this->geoRss->appendTop($geoRssItem);
$this->geoRss->saveAsFile();
- if (TWITTER_NEWS == true) {
- //new WMS
+ if ($this->twitterNews == true) {
+ //new WMS
$twitter_wms = new twitter();
$twUuid = new Uuid();
//combine text for tweet
@@ -1752,8 +1764,9 @@
$this->insertLayerMetadataUrls($i);
//update messages for twitter and georss
$currentLayer = $this->objLayer[$i];
- $geoRssItemNewLayer = new GeoRssItem();
+ $geoRssItemNewLayer = new GeoRssItem();
$geoRssItemNewLayer->setTitle("NEW LAYER: " . $currentLayer->layer_title." (".$currentLayer->db_id.")");
$geoRssItemNewLayer->setDescription($currentLayer->layer_abstract);
$geoRssItemNewLayer->setUrl(self::getLayerMetadataUrl($currentLayer->db_id));
@@ -1774,7 +1787,7 @@
$this->geoRss->appendTop($geoRssItemNewLayer);
//new LAYER
$twitter_layer = new twitter();
@@ -2546,8 +2559,12 @@
if (!isset($this->wms_network_access) || ($this->wms_network_access == '')) {
$this->wms_network_access = intval('0');
+ if ($this->setGeoRss == true) {
db_begin();
@@ -2559,23 +2576,23 @@
$sql .= "wms_getlegendurl = $5 ,";
$sql .= "wms_getcapabilities_doc = $6 ,";
$sql .= "wms_upload_url = $7, ";
- $sql .= "wms_owner = $8, ";
- $sql .= "wms_timestamp = $9, ";
- $sql .= "wms_supportsld = $10, ";
- $sql .= "wms_userlayer = $11, ";
- $sql .= "wms_userstyle = $12, ";
- $sql .= "wms_remotewfs = $13, ";
- $sql .= "wms_network_access = $14, ";
- $sql .= "fkey_mb_group_id = $15, ";
- $sql .= "uuid = $16 ";
- $sql .= " WHERE wms_id = $17";
+ #$sql .= "wms_owner = $8, ";
+ $sql .= "wms_timestamp = $8, ";
+ $sql .= "wms_supportsld = $9, ";
+ $sql .= "wms_userlayer = $10, ";
+ $sql .= "wms_userstyle = $11, ";
+ $sql .= "wms_remotewfs = $12, ";
+ $sql .= "wms_network_access = $13, ";
+ $sql .= "fkey_mb_group_id = $14, ";
+ $sql .= "uuid = $15 ";
+ $sql .= " WHERE wms_id = $16";
$v = array($this->wms_version,$this->wms_getcapabilities,
$this->wms_getmap,$this->wms_getfeatureinfo,$this->wms_getlegendurl,
- $admin->char_encode($this->wms_getcapabilities_doc),$this->wms_upload_url,Mapbender::session()->get("mb_user_id"),strtotime("now"),
+ $admin->char_encode($this->wms_getcapabilities_doc),$this->wms_upload_url,strtotime("now"),
$this->wms_supportsld,$this->wms_userlayer,$this->wms_userstyle,$this->wms_remotewfs,$this->wms_network_access, $this->fkey_mb_group_id ,$this->uuid ,$myWMS);
- $t = array('s','s','s','s','s','s','s','i','i','s','s','s','s','i','i','s','i');
+ $t = array('s','s','s','s','s','s','s','i','s','s','s','s','i','i','s','i');
$res = db_prep_query($sql,$v,$t);
if(!$res){
db_rollback();
@@ -2602,7 +2619,6 @@
$sql .= "fkey_mb_group_id = $17, ";
$sql .= "uuid = $18 ";
$sql .= " WHERE wms_id = $19";
$v = array($this->wms_title,$this->wms_abstract,$this->fees,$this->accessconstraints,
$this->contactperson,$this->contactposition,$this->contactorganization,$this->address,
$this->city,$this->stateorprovince,$this->postcode,$this->country,$this->contactvoicetelephone,
@@ -2761,8 +2777,7 @@
$geoRssItem->setTitle("UPDATED WMS: " . $this->wms_title." (".$myWMS.")");
$geoRssItem->setDescription($this->wms_abstract);
@@ -2793,10 +2808,10 @@
// $geoRssItem->setUrl();
$this->geoRss->appendTop($geoRssItemOldLayer);
+ $this->geoRss->saveAsFile();
//twitter out changes
//updated WMS
@@ -2818,8 +2833,8 @@
- $this->geoRss->saveAsFile();
- return;
+ return true;
function updateGuiLayer($i,$myWMS,$gui_id){
More information about the Mapbender_commits
