[Mapbender-commits] r8468 - in trunk/mapbender: http/javascripts http/plugins resources/locale/de_DE/LC_MESSAGES
svn_mapbender at osgeo.org
Wed Aug 22 03:41:06 PDT 2012
Author: armin11
Date: 2012-08-22 03:41:05 -0700 (Wed, 22 Aug 2012)
New Revision: 8468
trunk/mapbender/http/javascripts/mb_downloadFeedClient.js
trunk/mapbender/http/plugins/mb_downloadFeedClient.php
trunk/mapbender/http/plugins/mb_downloadFeedServer.php
trunk/mapbender/resources/locale/de_DE/LC_MESSAGES/Mapbender.po
Bugfixes for INSPIRE ATOM Download Feed V1.0
Modified: trunk/mapbender/http/javascripts/mb_downloadFeedClient.js
--- trunk/mapbender/http/javascripts/mb_downloadFeedClient.js 2012-08-22 10:34:01 UTC (rev 8467)
+++ trunk/mapbender/http/javascripts/mb_downloadFeedClient.js 2012-08-22 10:41:05 UTC (rev 8468)
@@ -53,6 +53,8 @@
mapframe_file_list = new OpenLayers.Map('mapframe_file_list');
var wms1 = new OpenLayers.Layer.WMS( "OpenLayers WMS",
"http://www.gdi-rp-dienste2.rlp.de/cgi-bin/mapserv.fcgi?map=/data/umn/geoportal/karte_rp/rheinland-pfalz-gesamt2.map&", {layers: 'ATKIS-Praes'}, {singleTile: true});
+ //var wms_osm = new OpenLayers.Layer.WMS( "OpenLayers WMS",
+ // "http://osm.omniscale.net/proxy/service?", {layers: 'osm'}, {singleTile: true});
var wms2 = new OpenLayers.Layer.WMS( "OpenLayers WMS",
//Vector layer for the georss polygons of the service feed - maybe more than one
@@ -90,6 +92,7 @@
//central function to call server by ajax, result is a featureCollection which is generated by mapbenders server component
function callServer(data,method,id) {
if (id === undefined) id = 0;
+ //alert("ajax call begin");
$.ajax({
url: '../plugins/mb_downloadFeedServer.php',
type: "post",
@@ -105,6 +108,7 @@
if (method == "getDatasetFeedObjectFromUrl") {
//function to draw bboxes of single link to data tile and the corresponding list of tiles
+ //alert("ajax datasetfeed read!");
showDatasetEntryList(result, id);
@@ -120,7 +124,7 @@
$("#representation_select").css("display","none");
$("#representation_info").css("display","none");
//change size of outer fieldset
- $("#client").css("height","400px");
+ $("#client").css("height","450px");
@@ -166,6 +170,7 @@
//call second feed with first entry for default
data = featureCollection.features[0].properties.datasetFeedLink;
datasetFeedObject = callServer(data,method);
+ //alert("ajax call started");
@@ -175,6 +180,7 @@
alert("No parseable content found");
return false;
+ //alert("test");
//remove select element for the different possible representations (formats, crs, ...)
$('#dataset_representation_select').remove();
//generate new select element
@@ -207,7 +213,7 @@
//count number of links in representation
var numberOfLinks = featureCollection.features[0].properties.entry[k].link.length;
//alert("number of links: "+numberOfLinks);
- if (numberOfLinks > 1) {
+ if (numberOfLinks >= 1) {
//show list
$("#representation_select").css("display","block");
//deactivate mapframe2 by default
@@ -216,13 +222,6 @@
$("#representation_info").css("display","block");
//extent size of outer fieldset
$("#client").css("height","730px");
- //test if the bbox attribute of the first link is set
- if (featureCollection.features[0].properties.entry[k].link[0]['@attributes'].bbox != '') {
- //show mapframe
- $("#mapframe_file_list").css("display","block");
- //extent size of outer fieldset
- $("#client").css("height","900px");
} else {
/*if (numberOfLinks == 1) {
//open single link for download!
@@ -231,19 +230,25 @@
for (var i = 0; i < featureCollection.features[0].properties.entry[k].link.length; i++) {
- ext = featureCollection.features[0].properties.entry[k].link[i]['@attributes'].bbox;
- extArrayNew = new Array();
- extArray = ext.split(",");
- //sort array to lat lon
- extArrayNew[0] = extArray[1];
- extArrayNew[1] = extArray[0];
- extArrayNew[2] = extArray[3];
- extArrayNew[3] = extArray[2];
- bound = OpenLayers.Bounds.fromArray(extArrayNew);
- attributes = {id: i, url:featureCollection.features[0].properties.entry[k].link[i]['@attributes'].href};
- box = new OpenLayers.Feature.Vector(bound.toGeometry(),attributes);
- bboxFiles.addFeatures(box);
- selectFOptions = selectFOptions+"<option value='"+i+"' url='"+featureCollection.features[0].properties.entry[k].link[i]['@attributes'].href+"' title='"+featureCollection.features[0].properties.entry[k].link[i]['@attributes'].title+"' onclick='highlightFeatureIndexById("+i+",true);' onmouseover='highlightFeatureIndexById("+i+",false);'>"+featureCollection.features[0].properties.entry[k].link[i]['@attributes'].title+"</option>";
+ if (featureCollection.features[0].properties.entry[k].link[i]['@attributes'].bbox == '' || featureCollection.features[0].properties.entry[k].link[i]['@attributes'].bbox === undefined) {
+ selectFOptions = selectFOptions+"<option value='"+i+"' url='"+featureCollection.features[0].properties.entry[k].link[i]['@attributes'].href+"' title='"+featureCollection.features[0].properties.entry[k].link[i]['@attributes'].title+"' onclick='window.open(\""+featureCollection.features[0].properties.entry[k].link[i]['@attributes'].href+"\");'>"+featureCollection.features[0].properties.entry[k].link[i]['@attributes'].title+"</option>";
+ } else {
+ ext = featureCollection.features[0].properties.entry[k].link[i]['@attributes'].bbox;
+ extArrayNew = new Array();
+ extArray = ext.split(",");
+ //sort array to lat lon
+ extArrayNew[0] = extArray[1];
+ extArrayNew[1] = extArray[0];
+ extArrayNew[2] = extArray[3];
+ extArrayNew[3] = extArray[2];
+ bound = OpenLayers.Bounds.fromArray(extArrayNew);
+ attributes = {id: i, url:featureCollection.features[0].properties.entry[k].link[i]['@attributes'].href};
+ box = new OpenLayers.Feature.Vector(bound.toGeometry(),attributes);
+ bboxFiles.addFeatures(box);
+ selectFOptions = selectFOptions+"<option value='"+i+"' url='"+featureCollection.features[0].properties.entry[k].link[i]['@attributes'].href+"' title='"+featureCollection.features[0].properties.entry[k].link[i]['@attributes'].title+"' onclick='highlightFeatureIndexById("+i+",true);' onmouseover='highlightFeatureIndexById("+i+",false);'>"+featureCollection.features[0].properties.entry[k].link[i]['@attributes'].title+"</option>";
//count features of bboxFiles
//bboxFiles if not available show error message
@@ -253,29 +258,36 @@
//add options
selectFOptionsObject = $('#section_option').append(selectFOptions);
selectFOptionsObject.attr({'width': 300});
- bound = bboxFiles.getDataExtent();
- mapframe_file_list.zoomToExtent(bound);
- bboxFiles.events.on({
- featureselected: function(event) {
- var feature = event.feature;
- var id = feature.attributes.id;
- var url = feature.attributes.url;
- $('#section_option option').removeAttr('selected')
- $("#section_option option[value='"+id+"']").attr('selected',true);
- //window.open(url,'download_window');
+ //alert(bboxFiles.features.length);
+ if (bboxFiles.features.length >= 1) {//TODO
+ //show mapframe
+ $("#mapframe_file_list").css("display","block");
+ //extent size of outer fieldset
+ $("#client").css("height","900px");
+ bound = bboxFiles.getDataExtent();
+ mapframe_file_list.zoomToExtent(bound);
+ bboxFiles.events.on({
+ featureselected: function(event) {
+ var feature = event.feature;
+ var id = feature.attributes.id;
+ var url = feature.attributes.url;
+ $('#section_option option').removeAttr('selected')
+ $("#section_option option[value='"+id+"']").attr('selected',true);
+ //window.open(url,'download_window');
- /*if ($('#multi_select').is(':checked')) {
- alert("checked");
- } else {
- alert("un-checked");
- alert(url);*/
+ /*if ($('#multi_select').is(':checked')) {
+ alert("checked");
+ } else {
+ alert("un-checked");
+ alert(url);*/
- sf = new OpenLayers.Control.SelectFeature(bboxFiles);
- mapframe_file_list.addControl(sf);
- sf.activate();
+ sf = new OpenLayers.Control.SelectFeature(bboxFiles);
+ mapframe_file_list.addControl(sf);
+ sf.activate();
function drawMetadataPolygons(featureCollection) {
Modified: trunk/mapbender/http/plugins/mb_downloadFeedClient.php
--- trunk/mapbender/http/plugins/mb_downloadFeedClient.php 2012-08-22 10:34:01 UTC (rev 8467)
+++ trunk/mapbender/http/plugins/mb_downloadFeedClient.php 2012-08-22 10:41:05 UTC (rev 8468)
@@ -111,7 +111,7 @@
<body onload="init()">
<fieldset id="client">
- <legend><?php echo _mb("INSPIRE Download Service ATOM Feed Client");?><!--<img class="help-dialog" title="<?php echo _mb("Help");?>" help="{text:'<?php echo _mb("Client to download INSPIRE data on an easy way.");?>'}" src="../img/questionmark.png" alt="" />--></legend>
+ <legend><?php echo _mb("INSPIRE Download Service ATOM Feed Client");?><img src="../img/inspire_tr_36.png" /><!--<img class="help-dialog" title="<?php echo _mb("Help");?>" help="{text:'<?php echo _mb("Client to download INSPIRE data on an easy way.");?>'}" src="../img/questionmark.png" alt="" />--></legend>
<div id="input_feed_url">
<p>
<form id="service_feed_form">
Modified: trunk/mapbender/http/plugins/mb_downloadFeedServer.php
--- trunk/mapbender/http/plugins/mb_downloadFeedServer.php 2012-08-22 10:34:01 UTC (rev 8467)
+++ trunk/mapbender/http/plugins/mb_downloadFeedServer.php 2012-08-22 10:41:05 UTC (rev 8468)
@@ -189,12 +189,20 @@
$link = $feedXML->xpath('/defaultns:feed/defaultns:entry/defaultns:link[contains(@rel,\'section\')]/@bbox');
$feature->geometry = new geoRSSPolygon();
- $feature->geometry->parsePolygon($bboxArray[0]);
+ $e = new mb_notice("mod_downloadFeedServer.php: bboxArray[0]: ".$bboxArray[0]);
+ if (!isset($bboxArray[0]) || $bboxArray[0] == "") {
+ $feature->geometry = null;
+ } else {
+ $feature->geometry->parsePolygon($bboxArray[0]);
//$feature->geometry->targetEPSG = "EPSG:4326";
- if (isset($feature->geometry) && $feature->geometry!==false) {
- $featureCollection->addFeature($feature);
- $e = new mb_notice("Feature added to collection!");
+ //set geometry to null if geometry is not given!
+ //if (isset($feature->geometry) && $feature->geometry!==false) {
+ $featureCollection->addFeature($feature);
+ $e = new mb_notice("Feature added to collection!");
/*$titleArray = (array)$title[$i];
$linkArray = (array)$link[$i];
$linkArray = $linkArray["@attributes"];
Modified: trunk/mapbender/resources/locale/de_DE/LC_MESSAGES/Mapbender.po
--- trunk/mapbender/resources/locale/de_DE/LC_MESSAGES/Mapbender.po 2012-08-22 10:34:01 UTC (rev 8467)
+++ trunk/mapbender/resources/locale/de_DE/LC_MESSAGES/Mapbender.po 2012-08-22 10:41:05 UTC (rev 8468)
@@ -3561,3 +3561,27 @@
msgid "Search for addresses"
msgstr "Suche nach Adressen"
+#plugins/mod_downloadFeedClient.php
+msgid "INSPIRE ATOM Feed Client"
+msgstr "INSPIRE ATOM Feed Client"
+msgid "ATOM Feed url"
+msgstr "URL zum ATOM Feed"
+msgid "Dataset title"
+msgstr "Bezeichnung"
+msgid "Dataset abstract"
+msgstr "Beschreibung"
+msgid "Rights"
+msgstr "Rechtliche Angaben"
+msgid "Available representations"
+msgstr "Verfügbare Varianten"
+msgid "Select to download dataset"
+msgstr "Auswahl zum Download"
More information about the Mapbender_commits
