[Mapbender-commits] r8241 - trunk/mapbender/http/geoportal
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Mon Feb 13 02:59:04 EST 2012
Author: armin11
Date: 2012-02-12 23:59:03 -0800 (Sun, 12 Feb 2012)
New Revision: 8241
Added:
   trunk/mapbender/http/geoportal/mod_readCSWResults.php
   trunk/mapbender/http/geoportal/mod_readCSWResultsDetail.php
   trunk/mapbender/http/geoportal/gaz.php
Rewind disclaimer information for wmc. Show upper layer terms of use at first position. New search via CSW 2.0.2 AP ISO 1.0 interfaces for geoportal applications.
Modified: trunk/mapbender/http/geoportal/gaz.php
--- trunk/mapbender/http/geoportal/gaz.php	2012-02-10 12:53:41 UTC (rev 8240)
+++ trunk/mapbender/http/geoportal/gaz.php	2012-02-13 07:59:03 UTC (rev 8241)
@@ -114,8 +114,11 @@
 } else {
 	$openSearchFilter .= "+ranking:score";
+//apply filter
+//following part is only set if the portalu opensearch is used!
+//$searchTextOS .= $openSearchFilter;
-$searchTextOS .= $openSearchFilter;
 // check if some extended is requested - in the old version this is defined by one parameter. The new interface would not distinguish between this two kind of search cases. Every search is a also an extented search. See mod_callMetadata.php
@@ -130,7 +133,9 @@
 exec($exec);
 #OpenSearch Search over distributed instances of Portal-U - configuration in mapbender database
-$exec = "php5 /data/mapbender/http/geoportal/mod_readOpenSearchResults.php '".$searchId."' '".$searchTextOS."' > ".$resdir."/request_".$id."_opensearch.xml &";
+//$exec = "php5 /data/mapbender/http/geoportal/mod_readOpenSearchResults.php '".$searchId."' '".$searchTextOS."' > ".$resdir."/request_".$searchId."_opensearch.xml &";
+#Search via CSW 2.0.2 AP ISO 1.0 Interfaces:
+$exec = "php5 /data/mapbender/http/geoportal/mod_readCSWResults.php '".$searchId."' '".$searchTextOS."' > ".$resdir."/request_".$searchId."_opensearch.xml &";
 //$exec = "php5 /data/mapbender/http/x_geoportal/mod_readOpenSearchResults.php '".$searchId."' '".$searchTextOS."' '+t1:2006-05-01+t2:2010-07-01' > ".$resdir."/request_".$id."_opensearch.xml &";
 exec($exec);
Added: trunk/mapbender/http/geoportal/mod_readCSWResults.php
--- trunk/mapbender/http/geoportal/mod_readCSWResults.php	                        (rev 0)
+++ trunk/mapbender/http/geoportal/mod_readCSWResults.php	2012-02-13 07:59:03 UTC (rev 8241)
@@ -0,0 +1,684 @@
+<?php
+require_once(dirname(__FILE__)."/../../core/globalSettings.php");
+//require_once(dirname(__FILE__)."/../../conf/geoportal.conf");
+require_once(dirname(__FILE__)."/../classes/class_connector.php");
+//Script to read Results from CSW 2.0.2 Interfaces from mapbender geoportal
+//example requests:
+//GetRecords with textfilter
+/*gp_csw
+CREATE TABLE gp_csw (
+    csw_id integer,
+    csw_name text,
+    fkey_cat_id integer,
+    csw_p integer, --start page
+    csw_h integer --results per page
+alter table gp_csw add column hierachylevel char(50);
+--insert into gp_csw (csw_id, csw_name, fkey_cat_id, csw_p, csw_h, hierachylevel) values (1,'GDK-DE Datensätze',3,1,10,'dataset');
+--insert into gp_csw (csw_id, csw_name, fkey_cat_id, csw_p, csw_h, hierachylevel) values (2,'GDK-DE Dienste',3,1,10,'service');
+--http://ims7.bkg.bund.de/geonetwork/srv/en/csw?Request=GetCapabilities&Service=CSW&VERSION=2.0.2
+ALTER TABLE mapbender.gp_csw OWNER TO postgres;
+select param_value from cat_op_conf where fk_cat_id=2 and param_type='getrecords';
+select param_value from cat_op_conf where fk_cat_id=2 and param_type='getrecordsbyid';*/
+//$resdir = TMPDIR;
+$resdir = "/data/mapbender/http/tmp/";
+$con = db_connect(DBSERVER,OWNER,PW);
+db_select_db(DB,$con);
+function logit($text){
+	 	if($h = fopen(TMPDIR."/opensearch_log.txt","a")){
+					$content = $text .chr(13).chr(10);
+					if(!fwrite($h,$content)){
+						#exit;
+					fclose($h);
+#test if script was requested over http or from cli
+#if it came from cli, use output to tmp folder - > typo3 would find it and will show it in template, there should be an identifier from the gaz.php script which controls the different search moduls
+#if it came as http request it should generate its own html window
+#Maybe problematic: if requested from command-line, how would mapbender get the content? Should be tested.
+#check if requested as cli
+if (isset($argv[0])&isset($argv[1])){
+	echo "\nthe script was invoked from commandline\n";
+	$from_cli=true;
+	#do something with the searchstring if needed
+	#from cli no pagenumber will be given. Therefor everytime page number 1 will be requested
+	$request_p = 1;
+	$_REQUEST["q"] = $argv[2];//.$argv[3];//$searchPortaluFilter = $argv[3];
+	$cli_id = $argv[1];
+	echo "\nID: ".$argv[1]."\n";
+	echo "\nSearchstring: ".$argv[2]."\n";
+	else
+		echo "<html><body>";
+		echo "\n<br>no commandline args set!\n<br>";
+		$from_cli=false;
+#When script was not invoked from cli it should have been invoked per http - check the params
+if (!$from_cli){
+	#***Validation of GET Parameters
+	#handle errors
+	//make html frame
+	if(!isset($_REQUEST["q"]) ) {
+		echo "No search string found! Please send a query!<br>";
+		die();
+	if(!isset($_REQUEST["p"]) ) {
+		$request_p = 1;
+	else
+		$request_p = $_REQUEST["p"];
+	if(!isset($_REQUEST["request_id"]) or $_REQUEST["request_id"]=='') {
+		echo "<br> request_id is not set <br>";
+		$requeststring="&request_id=from_http";
+		$cli_id="from_http";
+	else
+		echo "<br>request_id is set<br>";
+		$cli_id=$_REQUEST["request_id"];
+	echo "<br>Search string: <b>".$_REQUEST["q"]."</b> will be send<br>";
+//convert the the opensearch filter to ogc filter encoding
+#get the information out of the mapbender-db
+#get urls to search interfaces (csw):
+$sql_csw = "SELECT * from gp_csw ORDER BY csw_id";
+#do db select
+$res_csw = db_query($sql_csw);
+#initialize count of search interfaces
+$cnt_csw = 0;
+#initialize result array
+$csw_list=array(array());
+#fill result array
+while($row_csw = db_fetch_array($res_csw)){
+	$csw_list[$cnt_csw]['id'] = $row_csw["csw_id"];
+	$csw_list[$cnt_csw]['name'] = $row_csw["csw_name"];
+	echo "csw_name=".$row_csw["csw_name"];
+	$csw_list[$cnt_csw]['hierachylevel'] = $row_csw["hierachylevel"];
+	$csw_list[$cnt_csw]['fkey_cat_id'] = $row_csw["fkey_cat_id"];
+	//echo "<br>CAT ID from DB: ".$row_csw["fkey_cat_id"]."<br>";
+	//get urls for getrecords and getrecordbyid from table cat
+        $v = $row_csw["fkey_cat_id"];
+	$t = 'i';
+	$sql_gr = "select param_value from cat_op_conf where fk_cat_id = $1 and param_type = 'getrecords' and param_name='get'";
+	$res_gr = db_prep_query($sql_gr, $v, $t);
+        $row_gr = db_fetch_array($res_gr);
+	$csw_list[$cnt_csw] ['getrecordsurl'] = $row_gr['param_value'];
+	echo "<br>getrecordsurl: ".$csw_list[$cnt_csw]['getrecordsurl']."<br>";
+	$sql_grbi = "select param_value from cat_op_conf where fk_cat_id = $1 and param_type = 'getrecordbyid' and param_name='get'";
+	$res_grbi = db_prep_query($sql_grbi, $v, $t);
+        $row_grbi = db_fetch_array($res_grbi);
+	$csw_list[$cnt_csw] ['getrecordbyidurl'] = $row_grbi['param_value'];
+	echo "<br>getrecordbyidurl: ".$csw_list[$cnt_csw]['getrecordbyidurl']."<br>";
+	$csw_list[$cnt_csw] ['h'] = $row_csw["csw_h"];
+	$csw_list[$cnt_csw] ['p'] = $row_csw["csw_p"];
+	$cnt_csw++;
+//debug output
+if (!$from_cli) {
+	echo "<br>Count of registrated OpenSearch Interfaces: ".count($csw_list)."<br>";
+#get command_line args
+#$cli_id="1234567-1234567-1234567-test";
+#if the request came from http and the first request came from a commandline - add a get parameter to the following requests and change set the $cli_id
+#if(!isset($_REQUEST["request_id"]) ) {
+#		$cli_id=$_REQUEST["request_id"];
+#		$requeststring="&request_id=".$cli_id;
+	#else
+	#	$requeststring="";
+#string to add to further requests:
+$requeststring="&request_id=".$cli_id;
+#***write xml with list of opensearch catalogs
+#$from_cli=true;# for testing only
+#if ($from_cli) {
+	#write out xml 'is really no xml!' with opensearch-catalogs
+if ($from_cli) {
+echo "\nFolder to write to: ".$resdir."\n";
+echo "\nFile to open: ".$resdir."/".$cli_id."_os.xml\n";
+	if($os_catalogs_file_handle = fopen($resdir."/".$cli_id."_os.xml","w")){
+		fwrite($os_catalogs_file_handle,"<interfaces>\n");
+		for ($i_c = 0; $i_c < count($csw_list); $i_c++) {
+			$content = $csw_list[$i_c] ['name'];
+			fwrite($os_catalogs_file_handle,"<opensearchinterface>");
+			fwrite($os_catalogs_file_handle,$content);
+			fwrite($os_catalogs_file_handle,"</opensearchinterface>\n");
+		fwrite($os_catalogs_file_handle,"</interfaces>\n");
+		fclose($os_catalogs_file_handle);
+	else
+		if ($from_cli) {
+			echo "\nCouldn't open file!\n";
+#$from_cli=false;# for testing only
+#***loop for things to do for each registrated search interface - only if the search should be done in all interfaces!
+#use only one catalogue if a further page is requested
+$start_cat=0;
+$end_cat=count($csw_list);
+$cat=$_REQUEST["cat"];
+if (isset($cat)){
+$start_cat=(int)$cat;
+$end_cat=(int)$cat+1;
+for ($i_si = $start_cat; $i_si < $end_cat ; $i_si++) {
+	//$i_si = 0;
+	//echo "<br>".$csw_list[$i_si]['getrecordsurl']."<br>";
+	$openSearchUrl[$i_si]=$csw_list[$i_si] ['getrecordsurl'];
+	$openSearchWrapperDetail="mod_readCSWResultsDetail.php";
+	//define the right request for the page
+	//calculate the startindex for the requested pagenumber
+ 	$startIndex = ((real)$csw_list[$i_si] ["h"]*((integer)$request_p - 1)) + 1;
+	//$number_of_pages=ceil((real)$n_results/(real)$csw_list[$i_si] ['h']);
+	$getRecords = '<GetRecords xmlns="http://www.opengis.net/cat/csw/2.0.2"';
+	$getRecords .= '            xmlns:gmd="http://www.isotc211.org/2005/gmd"';
+	$getRecords .= '            xmlns:csw="http://www.opengis.net/cat/csw/2.0.2"';
+	$getRecords .= '           maxRecords="'.$csw_list[$i_si] ["h"].'"';
+	$getRecords .= '           outputFormat="application/xml"';
+	$getRecords .= '           outputSchema="http://www.isotc211.org/2005/gmd"';
+	$getRecords .= '           resultType="results"';
+	$getRecords .= '           service="CSW"';
+	$getRecords .= '          startPosition="'.$startIndex.'"'; //set this for paging - maybe it must be calculated from max count
+	$getRecords .= '          version="2.0.2">';
+	$getRecords .= '          <csw:Query typeNames="csw:Record">';
+	$getRecords .= '          <csw:ElementSetName>summary</csw:ElementSetName>';
+	$getRecords .= '          <csw:Constraint version="1.1.0">';
+	$getRecords .= '          <Filter xmlns="http://www.opengis.net/ogc" xmlns:gml="http://www.opengis.net/gml">';
+	$getRecords .= '          <And>';
+	$getRecords .= '          <PropertyIsLike wildCard="%" singleChar="_" escape="">';
+	$getRecords .= '          <PropertyName>AnyText</PropertyName>';
+	$getRecords .= '          <Literal>%'.$_REQUEST["q"].'%</Literal>';
+	$type = trim($csw_list[$i_si]['hierachylevel']);
+	switch ($type) {
+    		case ($type=='dataset' || $type=='series' || $type=='service' || $type=='nonGeographicDataset' || $type=='application'):
+			$getRecords .= '          </PropertyIsLike>';
+			$getRecords .= '          <PropertyIsEqualTo>';
+			$getRecords .= '          <PropertyName>Type</PropertyName>';
+			$getRecords .= '          <Literal>'.$type.'</Literal>';
+			$getRecords .= '          </PropertyIsEqualTo>';
+		break;
+		case 'dataset/series':
+			$getRecords .= '          <Or>';
+			$getRecords .= '          <Literal>dataset</Literal>';
+			$getRecords .= '          <Literal>series</Literal>';
+			$getRecords .= '          </Or>';
+		break;
+		default:
+	//$getRecords .= '          <Literal>dataset</Literal>';
+	$getRecords .= '          </And>';
+	$getRecords .= '          </Filter>';
+	$getRecords .= '          </csw:Constraint>';
+	$getRecords .= '          </csw:Query>';
+	$getRecords .= '</GetRecords>';
+echo "<br>REQUEST for results<br>".htmlentities($getRecords)."<br>";
+//for CSW define POST REQUEST for getrecords
+	$cswInterfaceObject = new connector();
+	$cswInterfaceObject->set('httpType','POST');
+	$postData = $getRecords;
+	$postData = stripslashes($postData);
+	$dataXMLObject = new SimpleXMLElement($postData);
+	$postData = $dataXMLObject->asXML();
+	$cswInterfaceObject->set('curlSendCustomHeaders',true);
+	$cswInterfaceObject->set('httpPostData', $postData);
+	$cswInterfaceObject->set('httpContentType','text/xml');
+	//extent url when needed
+	$openSearchUrlSearch[$i_si] = $openSearchUrl[$i_si];
+	echo "<br><br>".$openSearchUrlSearch[$i_si]."<br>";
+	//echo $openSearchUrl[$i_si]."<br>";
+	$cswInterfaceObject->load($openSearchUrl[$i_si]);
+	#echo "<br>Results: ".htmlentities($cswInterfaceObject->file)."<br><br>";
+	$openSearchResult = $cswInterfaceObject->file;
+	$openSearchUrlDetail[$i_si]=$csw_list[$i_si] ['getrecordbyidurl']."?";
+	//get resultlists
+	//$url=$openSearchUrlSearch[$i_si]."q=".$_REQUEST["q"].$csw_list[$i_si] ['standardfilter']."&h=".$csw_list[$i_si] ['h']."&p=".$request_p;
+	$url = $openSearchUrl[$i_si];
+	if (!$from_cli) {
+	echo "<br> url: ".$url."<br>";
+	else
+	#save resultset in temporary folder identified by sessionid, katalog_id and page_id! Now there would be more tmp files than before!
+	#this has to be done in order to give the information to typo3
+	#**************to be done!************************************
+	$e = new mb_exception('external xml : '.$openSearchResult);
+	#parse result to simplexml
+	$openSearchXml =  new SimpleXMLElement($openSearchResult);
+	//$openSearchXml = ($openSearchResult);
+	#read out array with docids and plugids
+	#read out number of results - there are two ways: with namespaces and without!:
+	$n_results = $openSearchXml->xpath('/csw:GetRecordsResponse/csw:SearchResults/@numberOfRecordsMatched');
+	$n_results = $n_results[0];
+	//if ($csw_list[$i_si] ['version']=='2') {
+	//	$opensearchElements=$openSearchXml->channel->children('http://a9.com/-/spec/opensearch/1.1/');
+	//	$n_results=$opensearchElements->totalResults;
+	if (!isset($n_results)) {
+		$n_results = 0;
+	if ($from_cli) {
+		logit( "Number of Results in Catalogue ".$i_si.": ".$n_results."\n");
+	//calculate number of needed pages to show all results:
+	$number_of_pages=ceil((real)$n_results/(real)$csw_list[$i_si] ['h']);
+	#do some debugging output
+	#var_dump($openSearchXml);
+	#show total results
+#do a html output for showing results of the different opensearch catalogues
+//if (!$from_cli) {
+	echo "<b>".$n_results."</b> Ergebnisse in Katalog <b>".$csw_list[$i_si] ['name']."</b><br><br>";
+	#show Pagenumbers
+	if ((int)$request_p>1) {
+	echo "<a href=\"mod_readCSWResults.php?q=".$_REQUEST['q']."&p=".(string)((int)$request_p-1)."&cat=".$i_si.$requeststring."\"> Vorige Seite </a> ";
+	echo "Seite: <b>".$request_p."</b> von <b>".$number_of_pages."</b>";
+	if ((int)$request_p < (int)$number_of_pages) {
+	echo " <a href=\"mod_readCSWResults.php?q=".$_REQUEST['q']."&p=".(string)((int)$request_p+1)."&cat=".$i_si.$requeststring."\"> Nächste Seite </a>";
+	echo "<br><br>";
+//else
+#echo "Keine Blättermöglichkeit in CLI\n";
+$from_cli=true; //- do this everytime
+if ($from_cli) { #do these things if the request was done from the commandline - it is done by the central search function
+	#generate the output for each page! Like: xyz_os1_1_10.xml = this means: searchid_os#catalogid_#page_#totalpages.xml
+	#open the specific file for writing
+	#number of the actual catalog:
+	$catalog_number=(int)$i_si+1;
+	logit($resdir."/".$cli_id."_os".$catalog_number."_".$request_p.".xml");
+	if($os_catalogs_file_handle = fopen($resdir."/".$cli_id."_os".$catalog_number."_".$request_p.".xml","w")){
+		fwrite($os_catalogs_file_handle,"<resultlist>\n");
+		#logit("<resultlist>\n");
+		fwrite($os_catalogs_file_handle,"<querystring>".urlencode($_REQUEST["q"])."</querystring>\n");
+		#logit("<querystring>".urlencode($_REQUEST["q"])."</querystring>\n");
+		fwrite($os_catalogs_file_handle,"<totalresults>".$n_results."</totalresults>\n");
+		#logit("<totalresults>".$n_results."</totalresults>\n");
+		fwrite($os_catalogs_file_handle,"<npages>".$number_of_pages."</npages>\n");
+		#logit("<npages>".$number_of_pages."</npages>\n");
+		fwrite($os_catalogs_file_handle,"<nresults>".(int)$csw_list[$i_si] ['h']."</nresults>\n");
+		//write rssurl only, if opensearch version not equal to 1
+		//if ($csw_list[$i_si] ['version']=='1') {
+			fwrite($os_catalogs_file_handle,"<rssurl></rssurl>\n");
+		//else
+		//	fwrite($os_catalogs_file_handle,"<rssurl>".urlencode($openSearchXml->channel->link)."</rssurl>\n");
+		#logit("<nresults>".(int)$csw_list[$i_si] ['h']."</nresults>\n");
+		#loop for single results in first list
+		#problematic: if less than 10 results are in the list, let the loop run only nresults times
+		if ($n_results < (int)$csw_list[$i_si] ['h']) {
+			$upperLimit = $n_results;
+		else
+			$upperLimit = (int)$csw_list[$i_si] ['h'];
+		//parse all gmd:MD_Metadata elements as single xml obbjects
+		/*foreach($openSearchXml->xpath('//gmd:MD_Metadata') as $gmd_MD_Metadata){
+    			// 'derefence' into a seperate xml tree for performance
+    			$gmd_MD_Metadata = simplexml_load_string($gmd_MD_Metadata->asXML());
+    			$uuid = $gmd_MD_Metadata->xpath('//gmd:fileIdentifier/gco:CharacterString');
+			echo "<br>uuid:".$uuid."<br>";
+		$openSearchXml->registerXPathNamespace('csw', 'http://www.opengis.net/cat/csw/2.0.2');
+		$openSearchXml->registerXPathNamespace('gmd', 'http://www.isotc211.org/2005/gmd');
+		$openSearchXml->registerXPathNamespace('gco', 'http://www.isotc211.org/2005/gco');
+		$openSearchXml->registerXPathNamespace('srv', 'http://www.isotc211.org/2005/srv');
+ 		for ($i=0; $i < $upperLimit; $i++) {
+			//initialize/unset the variables which have been read from iso 19139xml files
+			unset($accessUrl);
+			unset($uuid);
+			unset($bbox);
+			unset($graphicURL);
+			unset($isViewService);
+			//$uuid = $openSearchXml->xpath('/csw:GetRecordsResponse/gmd:MD_Metadata['.$i.']/gmd:fileIdentifier/gco:CharacterString');
+			$index = $i + 1 ;
+			//Check for type of record
+			$typeOfRecord = $openSearchXml->xpath('/csw:GetRecordsResponse/csw:SearchResults/gmd:MD_Metadata['.$index.']/gmd:hierarchyLevel/gmd:MD_ScopeCode/@codeListValue');
+			$typeOfRecord = $typeOfRecord[0];
+			#echo "<br><br>".$typeOfRecord."<br>";
+			$uuid = $openSearchXml->xpath('/csw:GetRecordsResponse/csw:SearchResults/gmd:MD_Metadata['.$index.']/gmd:fileIdentifier/gco:CharacterString');
+			$uuid = $uuid[0];
+			$dateStamp = $openSearchXml->xpath('/csw:GetRecordsResponse/csw:SearchResults/gmd:MD_Metadata['.$index.']/gmd:dateStamp/*');
+			//or date time - check and extract this information
+			$dateStamp = substr($dateStamp[0],0,10);
+			$title = $openSearchXml->xpath('/csw:GetRecordsResponse/csw:SearchResults/gmd:MD_Metadata['.$index.']/gmd:identificationInfo/gmd:MD_DataIdentification/gmd:citation/gmd:CI_Citation/gmd:title/gco:CharacterString');
+			$orgaName = $openSearchXml->xpath('/csw:GetRecordsResponse/csw:SearchResults/gmd:MD_Metadata['.$index.']/gmd:identificationInfo/gmd:MD_DataIdentification/gmd:pointOfContact/gmd:CI_ResponsibleParty/gmd:organisationName/gco:CharacterString');
+			$abstract = $openSearchXml->xpath('/csw:GetRecordsResponse/csw:SearchResults/gmd:MD_Metadata['.$index.']/gmd:identificationInfo/gmd:MD_DataIdentification/gmd:abstract/gco:CharacterString');
+			$accessUrl = $openSearchXml->xpath('/csw:GetRecordsResponse/csw:SearchResults/gmd:MD_Metadata['.$index.']/gmd:distributionInfo/gmd:MD_Distribution/gmd:transferOptions/gmd:MD_DigitalTransferOptions/gmd:onLine/gmd:CI_OnlineResource/gmd:linkage/gmd:URL');
+			echo "<br>General first accessUrl: ".$accessUrl[0]."<br>";
+			//generate link to original csw
+			$cswSearchUrlDetail = $openSearchUrlDetail[$i_si];
+			$cswSearchUrlDetail = $cswSearchUrlDetail."request=GetRecordById&service=CSW&version=2.0.2&Id=".$uuid."&ElementSetName=full&OUTPUTSCHEMA=http://www.isotc211.org/2005/gmd";
+			$e = new mb_notice("URL for calling full iso19139 service record over csw api: ".$cswSearchUrlDetail);
+			//extract title from iso19139 record
+			switch ($typeOfRecord) {
+    				case 'dataset':
+					$graphicURL = $openSearchXml->xpath('/csw:GetRecordsResponse/csw:SearchResults/gmd:MD_Metadata['.$index.']/gmd:identificationInfo/gmd:MD_DataIdentification/gmd:graphicOverview/gmd:MD_BrowseGraphic/gmd:fileName/gco:CharacterString');
+					$bbox = $openSearchXml->xpath('/csw:GetRecordsResponse/csw:SearchResults/gmd:MD_Metadata['.$index.']/gmd:identificationInfo/*/*/gmd:EX_Extent/gmd:geographicElement/gmd:EX_GeographicBoundingBox/*/gco:Decimal');
+        				break;
+				case 'series':
+					break;
+				case 'application':
+					break;
+    				case 'service':
+					//Graphic URL: <gmd:graphicOverview> <gmd:MD_BrowseGraphic> <gmd:fileName> <gco:CharacterString>http://www.geoportal.rlp.de/mapbender/geoportal/preview/24641_layer_map_preview.jpg</gco:CharacterString> </gmd:fileName> </gmd:MD_BrowseGraphic> </gmd:graphicOverview>
+					$graphicURL = $openSearchXml->xpath('/csw:GetRecordsResponse/csw:SearchResults/gmd:MD_Metadata['.$index.']/gmd:identificationInfo/srv:SV_ServiceIdentification/gmd:graphicOverview/gmd:MD_BrowseGraphic/gmd:fileName/gco:CharacterString');
+					$orgaName = $openSearchXml->xpath('/csw:GetRecordsResponse/csw:SearchResults/gmd:MD_Metadata['.$index.']/gmd:identificationInfo/srv:SV_ServiceIdentification/gmd:pointOfContact/gmd:CI_ResponsibleParty/gmd:organisationName/gco:CharacterString');
+					$title = $openSearchXml->xpath('/csw:GetRecordsResponse/csw:SearchResults/gmd:MD_Metadata['.$index.']/gmd:identificationInfo/srv:SV_ServiceIdentification/gmd:citation/gmd:CI_Citation/gmd:title/gco:CharacterString');
+					$abstract = $openSearchXml->xpath('/csw:GetRecordsResponse/csw:SearchResults/gmd:MD_Metadata['.$index.']/gmd:identificationInfo/srv:SV_ServiceIdentification/gmd:abstract/gco:CharacterString');
+					$typeOfService = $openSearchXml->xpath('/csw:GetRecordsResponse/csw:SearchResults/gmd:MD_Metadata['.$index.']/gmd:identificationInfo/srv:SV_ServiceIdentification/srv:serviceType/gco:LocalName');
+					$typeOfService = $typeOfService[0];
+					///gmd:MD_Metadata/gmd:identificationInfo/*/*/gmd:EX_Extent/gmd:geographicElement/gmd:EX_GeographicBoundingBox/*/gco:Decimal
+					//if service is found, the whole record must be called to find the access url to this service - :-(
+					#create connector object
+					$cswSearchDetailObject = new connector($cswSearchUrlDetail);
+					#get results
+					$cswSearchDetail = $cswSearchDetailObject->file;
+					//echo "<br>".htmlentities($cswSearchDetail)."<br>";
+					//solve problem with xlink namespace for href attributes:
+					$cswSearchDetail = str_replace('xlink:href', 'xlinkhref', $cswSearchDetail);
+					#http://forums.devshed.com/php-development-5/simplexml-namespace-attributes-problem-452278.html
+					#http://www.leftontheweb.com/message/A_small_SimpleXML_gotcha_with_namespaces
+					#$openSearchDetail = str_replace('xmlns=', 'ns=', $openSearchDetail);
+					$cswSearchDetailXML = simplexml_load_string($cswSearchDetail);
+					#extract objects to iso19139 elements
+					$cswSearchDetailXML->registerXPathNamespace("csw", "http://www.opengis.net/cat/csw/2.0.2");
+					$cswSearchDetailXML->registerXPathNamespace("gml", "http://www.opengis.net/gml");
+					$cswSearchDetailXML->registerXPathNamespace("gco", "http://www.isotc211.org/2005/gco");
+					$cswSearchDetailXML->registerXPathNamespace("gmd", "http://www.isotc211.org/2005/gmd");
+					$cswSearchDetailXML->registerXPathNamespace("gts", "http://www.isotc211.org/2005/gts");
+					$cswSearchDetailXML->registerXPathNamespace("srv", "http://www.isotc211.org/2005/srv");
+					$cswSearchDetailXML->registerXPathNamespace("xlink", "http://www.w3.org/1999/xlink");
+					//first read the inspire kind of impelmentaion of the access to capabilities documents
+					$accessUrl = $cswSearchDetailXML->xpath('/csw:GetRecordByIdResponse/gmd:MD_Metadata/gmd:distributionInfo/gmd:MD_Distribution/gmd:transferOptions/gmd:MD_DigitalTransferOptions/gmd:onLine/gmd:CI_OnlineResource/gmd:linkage/gmd:URL');
+					/*if ($accessUrl[0] == '') {
+						$accessUrl = $cswSearchDetailXML->xpath('/csw:GetRecordByIdResponse/gmd:MD_Metadata/gmd:distributionInfo/gmd:MD_Distribution/gmd:transferOptions/gmd:MD_DigitalTransferOptions/gmd:onLine/gmd:CI_OnlineResource/gmd:linkage');*/
+						if ($accessUrl[0] == '') {
+							//search for another accessUrl - as defined in csw ap iso
+							$accessUrl = $cswSearchDetailXML->xpath('/csw:GetRecordByIdResponse/gmd:MD_Metadata/gmd:identificationInfo/srv:SV_ServiceIdentification/srv:containsOperations/srv:SV_OperationMetadata/srv:connectPoint/gmd:CI_OnlineResource/gmd:linkage/gmd:URL');
+        				break;
+    				default:
+			$accessUrl = $accessUrl[0];
+			echo "<br>accessUrl: ".$accessUrl."<br>";
+			echo "<br>typeOfService:*".strtoupper($typeOfService)."*<br>";
+			echo "<br>typeOfRecord:*".$typeOfRecord."*<br>";
+			$title = $title[0];
+			$graphicURL = $graphicURL[0];
+			$orgaName = $orgaName[0];
+			if ($title == '') {
+				$title = 'Ohne Titel';
+			//check for view service type
+			if (strtoupper($typeOfService) == 'WMS' || strtoupper($typeOfService) == 'VIEW'  || strpos(strtoupper($typeOfService,'WMS')) !== false) {
+				$isViewService = true;
+				echo "view service identified<br>";
+			//check if service is view or wms and correct it for wms 1.1.1 caabilities request
+			if ($typeOfRecord == 'service' && $isViewService) {
+				if ($accessUrl != '') {
+					$accessUrl = correctWmsUrl($accessUrl);
+				} else {
+					$accessUrl = '';
+			} else {
+				echo "<b>no</b> view service identified<br>";
+				$isViewService = false;
+			//give dummy if orgaName not given
+			if ($orgaName == '') {
+				$orgaName = 'Organisation unbekannt';
+			$abstract = $abstract[0];
+			if (isset($bbox) && count($bbox) == 4) {
+				$bbox = "(".implode(',',$bbox).")";
+			} else {
+				$bbox = '';
+                        $abstractShort = substr($abstract,0,250)."...";
+			//echo "<br>Resultlist:<br>";
+			echo "<br><span>";
+			if (isset($graphicURL) && $graphicURL != '') {
+				echo "<img src='".$graphicURL."' width='100' height='100'/>";
+			echo "<a href = '".$openSearchWrapperDetail."?cat_id=".$csw_list[$i_si] ['id']."&uuid=".$uuid."&mdtype=html'>".$title."</a><br>";
+			echo $dateStamp." - ".$orgaName."<br>";
+			if (isset($bbox) && $bbox != '') {
+				echo $bbox."<br>";
+			echo $abstractShort."</span>";
+			//check for isViewService to allow integration into Viewer by link TODO
+			if (isset($accessUrl) && $accessUrl != '') {
+				if ($isViewService) {
+					echo "<br><span><a href ='".$accessUrl."'>Capabilities</a><br><br></span>";
+				} else {
+					echo "<br><span><a href ='".$accessUrl."'>Link</a><br><br></span>";
+			//output to file in tmp folder:
+			if (isset($uuid) && $uuid != ''){
+				#Do result XML output to file
+				fwrite($os_catalogs_file_handle,"<result>\n");
+				#Tags for catalogtitle and link to detailed information
+				fwrite($os_catalogs_file_handle,"<catalogtitle>");
+				fwrite($os_catalogs_file_handle, $orgaName." (ID=".$uuid.")");
+				fwrite($os_catalogs_file_handle,"</catalogtitle>\n");
+				fwrite($os_catalogs_file_handle,"<catalogtitlelink>");
+				fwrite($os_catalogs_file_handle,urlencode($openSearchWrapperDetail."?cat_id=".$csw_list[$i_si] ['id']."&uuid=".$uuid."&mdtype=html"));
+				fwrite($os_catalogs_file_handle,"</catalogtitlelink>\n");
+				#Tags for objecttitle and abstract
+				fwrite($os_catalogs_file_handle,"<title>");
+				fwrite($os_catalogs_file_handle, $title);
+				fwrite($os_catalogs_file_handle,"</title>\n");
+				fwrite($os_catalogs_file_handle,"<abstract>");
+                               	fwrite($os_catalogs_file_handle, $abstractShort);
+				fwrite($os_catalogs_file_handle,"</abstract>\n");
+				#Tag for link to original metadata view
+				fwrite($os_catalogs_file_handle,"<urlmdorig>");
+				fwrite($os_catalogs_file_handle,urlencode($cswSearchUrlDetail));
+				fwrite($os_catalogs_file_handle,"</urlmdorig>\n");
+				#if a wms resource is found, the url will be in the list
+				if (isset($accessUrl) && $isViewService && $accessUrl != ''){
+					fwrite($os_catalogs_file_handle,"<wmsaccessUrl>");
+					fwrite($os_catalogs_file_handle, urlencode($accessUrl));
+					fwrite($os_catalogs_file_handle,"</wmsaccessUrl>\n");
+					fwrite($os_catalogs_file_handle,"<mbaddurl>");
+					fwrite($os_catalogs_file_handle,"testurl");
+					fwrite($os_catalogs_file_handle,"</mbaddurl>\n");
+				} else {#add empty tags
+					fwrite($os_catalogs_file_handle,"<wmsaccessUrl></wmsaccessUrl>\n<mbaddurl></mbaddurl>\n");
+				if ($typeOfRecord =='application' || $typeOfRecord =='dataset'){
+					fwrite($os_catalogs_file_handle,"<accessUrl>");
+					fwrite($os_catalogs_file_handle,"</accessUrl>\n");
+				} else {
+				if (isset($graphicURL) && $graphicURL != '' && isValidURL($graphicURL)){
+					fwrite($os_catalogs_file_handle,"<graphicUrl>");
+					fwrite($os_catalogs_file_handle, urlencode($graphicURL));
+					fwrite($os_catalogs_file_handle,"</graphicUrl>\n");
+				} else {
+				if (isset($bbox)){
+					fwrite($os_catalogs_file_handle,"<georssurl>");
+					//$urlToId = $openSearchUrlSearch[$i_si]."q=t01_object.obj_id:".$docuuid.$csw_list[$i_si] ['standardfilter']."&h=".$csw_list[$i_si] ['h']."&p=".$request_p;
+					//fwrite($os_catalogs_file_handle,urlencode($urlToId));
+					fwrite($os_catalogs_file_handle,"</georssurl>\n");
+				else
+				fwrite($os_catalogs_file_handle,"<iso19139url>");
+				fwrite($os_catalogs_file_handle,urlencode($openSearchWrapperDetail."?cat_id=".$csw_list[$i_si] ['id']."&uuid=".$uuid."&mdtype=iso19139"));
+				fwrite($os_catalogs_file_handle,"</iso19139url>\n");
+				fwrite($os_catalogs_file_handle,"<inspireurl>");
+				fwrite($os_catalogs_file_handle,urlencode($openSearchWrapperDetail."?cat_id=".$csw_list[$i_si] ['id']."&uuid=".$uuid."&mdtype=iso19139&validate=true"));
+				fwrite($os_catalogs_file_handle,"</inspireurl>\n");
+				fwrite($os_catalogs_file_handle,"</result>\n");
+	fwrite($os_catalogs_file_handle,"</resultlist>\n");
+	echo "</body></html>";
+function correctWmsUrl($wms_url) {
+	//check if last sign is ? or & or none of them
+	$lastChar = substr($wms_url,-1);
+	//check if getcapabilities is set as a parameter
+	$findme = "getcapabilities";
+	$posGetCap = strpos(strtolower($wms_url), $findme);
+	if ($posGetCap === false) {
+		$posGetAmp = strpos(strtolower($wms_url), "?");
+		if ($posGetAmp === false) {
+			$wms_url .= "?REQUEST=GetCapabilities&VERSION=1.1.1&SERVICE=WMS";
+		} else {
+			switch ($lastChar) {
+				case "?":
+					$wms_url .= "REQUEST=GetCapabilities&VERSION=1.1.1&SERVICE=WMS";
+				break;
+				case "&":
+				break;
+				default:
+					$wms_url .= "&REQUEST=GetCapabilities&VERSION=1.1.1&SERVICE=WMS";
+				break;
+	} else {
+		//check if version is defined
+		$findme1 = "version=";
+		$posVersion = strpos(strtolower($wms_url), $findme1);
+		if ($posVersion === false) {
+			$wms_url .= "&VERSION=1.1.1";
+		} else {
+			//mapbender only handle 1.1.1
+			$wms_url = str_replace('version=1.3.0', 'VERSION=1.1.1', $wms_url);
+			$wms_url = str_replace('VERSION=1.3.0', 'VERSION=1.1.1', $wms_url);
+	//exchange &? with & and &amp;
+	$wms_url = str_replace('&?', '&', $wms_url);
+	$wms_url = str_replace('&amp;?', '&', $wms_url);
+	$wms_url = str_replace('&amp;', '&', $wms_url);
+return $wms_url;
+function isValidURL($url) {
+	return preg_match('|^http(s)?://[a-z0-9-]+(.[a-z0-9-]+)*(:[0-9]+)?(/.*)?$|i', $url);
Added: trunk/mapbender/http/geoportal/mod_readCSWResultsDetail.php
--- trunk/mapbender/http/geoportal/mod_readCSWResultsDetail.php	                        (rev 0)
+++ trunk/mapbender/http/geoportal/mod_readCSWResultsDetail.php	2012-02-13 07:59:03 UTC (rev 8241)
@@ -0,0 +1,1266 @@
+<?php
+#http://localhost/mapbender/geoportal/mod_readCSWResultsDetail.php?cat_id=1&uuid=...
+#$con = db_connect(DBSERVER,OWNER,PW);
+#db_select_db(DB,$con);
+require_once dirname(__FILE__) . "/../../tools/wms_extent/extent_service.conf";
+$languageCode = "de";
+$layout = "tabs";
+//get language parameter out of mapbender session if it is set else set default language to de_DE
+if (isset($_SESSION['mb_lang']) && ($_SESSION['mb_lang']!='')) {
+	$e = new mb_notice("mod_readCSWResultsDetail.php: language found in session: ".$_SESSION['mb_lang']);
+	$language = $_SESSION["mb_lang"];
+	$langCode = explode("_", $language);
+	$langCode = $langCode[0]; # Hopefully de or s.th. else
+	$languageCode = $langCode; #overwrite the GET Parameter with the SESSION information
+if (isset($_REQUEST["languageCode"]) & $_REQUEST["languageCode"] != "") {
+	//validate to csv integer list
+	$testMatch = $_REQUEST["languageCode"];
+	if (!($testMatch == 'de' or $testMatch == 'fr' or $testMatch == 'en')){
+		echo 'languageCode: <b>'.$testMatch.'</b> is not valid.<br/>';
+		die();
+	$languageCode = $testMatch;
+	$testMatch = NULL;
+if(!isset($_REQUEST["cat_id"])) {
+	echo "no opensearch id set";
+	die();
+} else {
+	#if(isset($_REQUEST["mdtype"])&($_REQUEST["mdtype"]=='debug') ) {
+	#	echo "opensearch interface no.: ".$_REQUEST["osid"]." will be requested<br>";
+	$cat_id = $_REQUEST["cat_id"];
+if(!isset($_REQUEST["uuid"])) {
+	echo "No uuid of dataset given!";
+	die();
+} else {
+	$uuid = $_REQUEST["uuid"];
+function getExtentGraphic($layer_4326_box) {
+		$rlp_4326_box = array(6.05,48.9,8.6,50.96);
+		if ($layer_4326_box[0] <= $rlp_4326_box[0] || $layer_4326_box[2] >= $rlp_4326_box[2] || $layer_4326_box[1] <= $rlp_4326_box[1] || $layer_4326_box[3] >= $rlp_4326_box[3]) {
+			if ($layer_4326_box[0] < $rlp_4326_box[0]) {
+				$rlp_4326_box[0] = $layer_4326_box[0];
+			if ($layer_4326_box[2] > $rlp_4326_box[2]) {
+				$rlp_4326_box[2] = $layer_4326_box[2];
+			if ($layer_4326_box[1] < $rlp_4326_box[1]) {
+				$rlp_4326_box[1] = $layer_4326_box[1];
+			if ($layer_4326_box[3] > $rlp_4326_box[3]) {
+				$rlp_4326_box[3] = $layer_4326_box[3];
+			$d_x = $rlp_4326_box[2] - $rlp_4326_box[0];
+			$d_y = $rlp_4326_box[3] - $rlp_4326_box[1];
+			$new_minx = $rlp_4326_box[0] - 0.05*($d_x);
+			$new_maxx = $rlp_4326_box[2] + 0.05*($d_x);
+			$new_miny = $rlp_4326_box[1] - 0.05*($d_y);
+			$new_maxy = $rlp_4326_box[3] + 0.05*($d_y);
+			if ($new_minx < -180) $rlp_4326_box[0] = -180; else $rlp_4326_box[0] = $new_minx;
+			if ($new_maxx > 180) $rlp_4326_box[2] = 180; else $rlp_4326_box[2] = $new_maxx;
+			if ($new_miny < -90) $rlp_4326_box[1] = -90; else $rlp_4326_box[1] = $new_miny;
+			if ($new_maxy > 90) $rlp_4326_box[3] = 90; else $rlp_4326_box[3] = $new_maxy;
+		$getMapUrl = EXTENTSERVICEURL."VERSION=1.1.1&REQUEST=GetMap&SERVICE=WMS&LAYERS=".EXTENTSERVICELAYER."&STYLES=&SRS=EPSG:4326&BBOX=".$rlp_4326_box[0].",".$rlp_4326_box[1].",".$rlp_4326_box[2].",".$rlp_4326_box[3]."&WIDTH=120&HEIGHT=120&FORMAT=image/png&BGCOLOR=0xffffff&TRANSPARENT=TRUE&EXCEPTIONS=application/vnd.ogc.se_inimage&minx=".$layer_4326_box[0]."&miny=".$layer_4326_box[1]."&maxx=".$layer_4326_box[2]."&maxy=".$layer_4326_box[3];
+		return $getMapUrl;
+function display_text($string) {
+    $string = eregi_replace("[[:alpha:]]+://[^<>[:space:]]+[[:alnum:]/]", "<a href=\"\\0\" target=_blank>\\0</a>", $string);
+    $string = eregi_replace("^[_a-z0-9-]+(\.[_a-z0-9-]+)*@([0-9a-z](-?[0-9a-z])*\.)+[a-z]{2}([zmuvtg]|fo|me)?$", "<a href=\"mailto:\\0\" target=_blank>\\0</a>", $string);
+    $string = eregi_replace("\n", "<br>", $string);
+    return $string;
+function guid(){
+    if (function_exists('com_create_guid')){
+        return com_create_guid();
+    }else{
+        mt_srand((double)microtime()*10000);//optional for php 4.2.0 and up.
+        $charid = strtoupper(md5(uniqid(rand(), true)));
+        $hyphen = chr(45);// "-"
+        $uuid = chr(123)// "{"
+                .substr($charid, 0, 8).$hyphen
+                .substr($charid, 8, 4).$hyphen
+                .substr($charid,12, 4).$hyphen
+                .substr($charid,16, 4).$hyphen
+                .substr($charid,20,12)
+                .chr(125);// "}"
+        return $uuid;
+//function to validate against the inspire validation service
+function validateInspireMetadataFromData($iso19139Xml){
+	$validatorUrl = 'http://www.inspire-geoportal.eu/INSPIREValidatorService/resources/validation/inspire';
+	#$validatorUrl2 = 'http://localhost/mapbender/x_geoportal/log_requests.php'; //for debugging purposes
+	//send inspire xml to validator and push the result to requesting user
+	$validatorInterfaceObject = new connector();
+	$validatorInterfaceObject->set('httpType','POST');
+	$validatorInterfaceObject->set('httpContentType','multipart/form-data'); # maybe given automatically
+	//first test with data from ram - doesn't function :-(
+	$fields = array(
+		'dataFile'=>urlencode($iso19139Xml)
+	//generate file identifier:
+	$fileId = guid();
+	//generate temporary file under tmp
+	 if($h = fopen(TMPDIR."/".$fileId."iso19139_validate_tmp.xml","w")){
+		if(!fwrite($h,$iso19139Xml)){
+			$e = new mb_exception("geoportal/mod_readCSWResultsDetail.php: cannot write to file: ".TMPDIR."iso19139_validate_tmp.xml");
+	fclose($h);
+	//send file as post like described under http://www.tecbrat.com/?itemid=13&catid=1
+	$fields['dataFile']='@'.TMPDIR.'/'.$fileId.'iso19139_validate_tmp.xml';
+	$postData = $fields;
+	$validatorInterfaceObject->set('httpPostFieldsNumber',count($postData));
+	$validatorInterfaceObject->set('curlSendCustomHeaders',false);
+	$validatorInterfaceObject->set('httpPostData', $postData); #give an array
+	$validatorInterfaceObject->load($validatorUrl);
+	header("Content-type: text/html; charset=UTF-8");
+	echo $validatorInterfaceObject->file;
+	//delete file in tmp
+	//TODO - this normally done by a cronjob
+	die();
+//INSPIRE Mapping
+$md_ident = array(
+//Metadata Identifier - not neccessary?
+	array(	ibus => "t01_object.obj_id",
+		iso19139 => "/gmd:MD_Metadata/gmd:fileIdentifier/gco:CharacterString",
+		iso19139explode => "false" ,
+		inspire => "unique resource identifier",
+		inspiremandatory => "false",
+		iso_name => "fileIdentifier",
+		html => _mb("Metadata identifier"),
+		value => "",
+		category => "identification",
+		description => _mb("A value uniquely identifying the resource. The value domain of this metadata element is a mandatory character string code, generally assigned by the data owner, and a character string namespace uniquely identifying the context of the identifier code (for example, the data owner).")
+//B 1.1
+	array(	ibus => "rtitle",
+		iso19139 => "/gmd:MD_Metadata/gmd:identificationInfo/*/gmd:citation/gmd:CI_Citation/gmd:title/gco:CharacterString",
+		inspire => "resource title",
+		inspiremandatory => "true",
+		iso_name => "type",
+		html => _mb("Resource title"),
+		value => "",
+		description => _mb("This a characteristic, and often unique, name by which the resource is known. The value domain of this metadata element is free text.")
+//B 1.2
+	array(	ibus => "abstract",
+		iso19139 => "/gmd:MD_Metadata/gmd:identificationInfo/*/gmd:abstract/gco:CharacterString",
+		inspire => "resource abstract",
+		iso_name => "description",
+		html => _mb("Resource abstract"),
+		value => "",
+		description => _mb("This is a brief narrative summary of the content of the resource.")
+//B 1.3
+	array(	ibus => "rtype",
+		iso19139 => "/gmd:MD_Metadata/gmd:hierarchyLevel/gmd:MD_ScopeCode/@codeListValue",
+		inspire => "resource type",
+		html => _mb("Resource type"),
+		value => "",
+		description => _mb("This is the type of resource being described by the metadata.")
+//B 1.4
+		iso19139 => "/gmd:MD_Metadata/gmd:distributionInfo/gmd:MD_Distribution/gmd:transferOptions/gmd:MD_DigitalTransferOptions/gmd:onLine/gmd:CI_OnlineResource/gmd:linkage/gmd:URL",
+		inspire => "unique resource locator",
+		iso_name => "resourceLocator",
+		html => _mb("Resource locator"),
+		value => "",
+		description => _mb("The resource locator defines the link(s) to the resource and/or the link to additional information about the resource. The value domain of this metadata element is a character string, commonly expressed as uniform resource locator (URL).")
+//B 1.5 - Identifier of dataset!
+//Part 1 id
+		iso19139 => "/gmd:MD_Metadata/gmd:identificationInfo/*/gmd:citation/gmd:CI_Citation/gmd:identifier/gmd:RS_Identifier/gmd:code/gco:CharacterString",
+		inspire => "unique resource identifier namespace",
+		iso_name => "dataset id",
+		html => _mb("Unique resource identifier id"),
+		value => "",
+		description => _mb("A value uniquely identifying the resource. The value domain of this metadata element is a mandatory character string code, generally assigned by the data owner.")
+//Part 2 - namespace
+		iso19139 => "/gmd:MD_Metadata/gmd:identificationInfo/*/gmd:citation/gmd:CI_Citation/gmd:identifier/gmd:RS_Identifier/gmd:codeSpace/gco:CharacterString",
+		iso_name => "dataset namespace",
+		html => _mb("Unique resource identifier namespace"),
+		value => "",
+		description => _mb("A character string namespace uniquely identifying the context of the identifier code (for example, the data owner)")
+//B 1.6 Coupled resource
+//NOTICE: simplexml has problems with namespaced attributes! So we choose a alias for xlink:href which is xlinkhref and exchange this attributes from xml before parsing the xml!
+		iso19139 => "/gmd:MD_Metadata/gmd:identificationInfo/*/srv:operatesOn/@xlinkhref",
+		inspire => "coupled resource",
+		iso_name => "coupled resource",
+		html => _mb("Coupled resource"),
+		value => "",
+		description => _mb("If the resource is a spatial data service, this metadata element identifies, where relevant, the target spatial data set(s) of the service through their unique resource identifiers (URI). The value domain of this metadata element is a mandatory character string code, generally assigned by the data owner, and a character string namespace uniquely identifying the context of the identifier code (for example, the data owner).")
+//B 1.7 Language dataset
+		iso19139 => "/gmd:MD_Metadata/gmd:identificationInfo/*/gmd:language/gmd:LanguageCode/@codeListValue",
+		inspire => "Language",
+		iso_name => "language",
+		html => _mb("Language"),
+		value => "",
+		description => _mb("The language(s) used within the resource. The value domain of this metadata element is limited to the languages defined in ISO 639-2.")
+//B 2.1 Topic category
+		iso19139 => "/gmd:MD_Metadata/gmd:identificationInfo/gmd:MD_DataIdentification/gmd:topicCategory/gmd:MD_TopicCategoryCode",
+		iso19139explode => "true" ,
+		inspire => "topic category",
+		iso_name => "topic category",
+		html => _mb("Topic category"),
+		value => "",
+		category => "classification",
+		description => _mb("The topic category is a high-level classification scheme to assist in the grouping and topic-based search of available spatial data resources. The value domain of this metadata element is defined in Part D.2.")
+//B 2.2 Spatial data service type
+		iso19139 => "/gmd:MD_Metadata/gmd:identificationInfo/srv:SV_ServiceIdentification/srv:serviceType/gco:LocalName",
+		inspire => "spatial data service type",
+		html => _mb("Spatial data service type"),
+		value => "",
+		description => _mb("This is a classification to assist in the search of available spatial data services. A specific service shall be categorised in only one category. The value domain of this metadata element is defined in Part D.3.")
+//B3 Keyword
+//B 3.1 keyword value dataset
+		iso19139 => "/gmd:MD_Metadata/gmd:identificationInfo/*/gmd:descriptiveKeywords/gmd:MD_Keywords/gmd:keyword/gco:CharacterString",
+		inspire => "keyword value",
+		iso_name => "keywordValue",
+		html => _mb("Keyword value"),
+		value => "",
+		category => "keyword",
+		description => _mb("If the resource is a spatial data service, at least one keyword from Part D.4 shall be provided. If a resource is a spatial data set or spatial data set series, at least one keyword shall be provided from the general environmental multilingual thesaurus (GEMET) describing the relevant spatial data theme as defined in Annex I, II or III to Directive 2007/2/EC.")
+//B 4 Geographic Location
+//B 4.1 Geographic bounding box
+		iso19139 => "/gmd:MD_Metadata/gmd:identificationInfo/*/*/gmd:EX_Extent/gmd:geographicElement/gmd:EX_GeographicBoundingBox/*/gco:Decimal",
+		inspire => "geographic bounding box",
+		iso_name => "geographic bounding box",
+		html => _mb("Geographic bounding box"),
+		value => "",
+		category => "location",
+		description => _mb("This is the extent of the resource in the geographic space, given as a bounding box. The bounding box shall be expressed with westbound and eastbound longitudes, and southbound and northbound latitudes in decimal degrees, with a precision of at least two decimals.")
+//B 5. Temporal reference
+//B 5.1 Temporal extent
+		iso19139 => "/gmd:MD_Metadata/gmd:identificationInfo/gmd:extent/gmd:EX_Extent/gmd:temporalElement/gmd:EX_EX_TemporalExtent/gmd:extent/gml:TimePeriod/*",
+		inspire => "temporal extent",
+		iso_name => "Temporal extent",
+		html => _mb("Temporal extent"),
+		value => "",
+		category => "actuality",
+		description => _mb("The temporal extent defines the time period covered by the content of the resource. This time period may be expressed as any of the following: - an individual date, - an interval of dates expressed through the starting date and end date of the interval, - a mix of individual dates and intervals of dates.")
+//B 5.2 Date of publication
+		iso19139 => "/gmd:MD_Metadata/gmd:identificationInfo/*/gmd:citation/gmd:CI_Citation/gmd:date/gmd:CI_Date[gmd:dateType/gmd:CI_DateTypeCode/@codeListValue='publication']/gmd:date/*",
+		inspire => "date of publication",
+		iso_name => "date of publication",
+		html => _mb("Date of publication"),
+		value => "",
+		description => _mb("This is the date of publication of the resource when available, or the date of entry into force. There may be more than one date of publication.")
+//B 5.3 Date of last revision
+		iso19139 => "/gmd:MD_Metadata/gmd:identificationInfo/*/gmd:citation/gmd:CI_Citation/gmd:date/gmd:CI_Date[gmd:dateType/gmd:CI_DateTypeCode/@codeListValue='revision']/gmd:date/*",
+		inspire => "date of last revision",
+		iso_name => "date of last revision",
+		html => _mb("Date of last revision"),
+		value => "",
+		description => _mb("This is the date of last revision of the resource, if the resource has been revised. There shall not be more than one date of last revision.")
+//B 5.4 Date of creation
+		iso19139 => "/gmd:MD_Metadata/gmd:identificationInfo/*/gmd:citation/gmd:CI_Citation/gmd:date/gmd:CI_Date[gmd:dateType/gmd:CI_DateTypeCode/@codeListValue='creation']/gmd:date/*",
+		inspire => "date of creation",
+		iso_name => "date of creation",
+		html => _mb("Date of creation"),
+		value => "",
+		description => _mb("This is the date of creation of the resource. There shall not be more than one date of creation.")
+//B 6. Quality and validity
+//B 6.1 Lineage
+		iso19139 => "/gmd:MD_Metadata/gmd:identificationInfo/gmd:MD_DataIdentification/gmd:lineage/gmd:LI_Lineage/gmd:statement/gco:CharacterString",
+		inspire => "lineage",
+		iso_name => "lineage",
+		html => _mb("Lineage"),
+		value => "",
+		category => "quality",
+		description => _mb("This is a statement on process history and/or overall quality of the spatial data set. Where appropriate it may include a statement whether the data set has been validated or quality assured, whether it is the official version (if multiple versions exist), and whether it has legal validity.")
+//B 6.2 Spatial Resolution
+//B 6.2.1 equivalent scale
+		iso19139 => "/gmd:MD_Metadata/gmd:identificationInfo/gmd:MD_DataIdentification/gmd:spatialResolution/gmd:MD_Resolution/gmd:equivalentScale/gmd:MD_RepresentativeFraction/gmd:denominator/gco:Integer",
+		inspire => "equivalent scale",
+		iso_name => "equivalent scale",
+		html => _mb("Equivalent scale"),
+		value => "",
+		category => "resolution",
+		description => _mb("An equivalent scale is generally expressed as an integer value expressing the scale denominator.")
+//B 6.2.2 ground distance
+//B 6.2.2.1 ground distance value
+		iso19139 => "/gmd:MD_Metadata/gmd:identificationInfo/gmd:MD_DataIdentification/gmd:spatialResolution/gmd:MD_Resolution/gmd:distancegco:Distance",
+		inspire => "ground distance value",
+		iso_name => "groundDistanceValue",
+		html => _mb("Ground Distance Value"),
+		value => "",
+		description => _mb("A resolution distance shall be expressed as a numerical value associated with a unit of length.")
+//TODO maybe everytime m? or parse the href ...
+//B 7. Conformity
+//B 7.1. Specification
+//B 7.1.1 Title
+		iso19139 => "/gmd:MD_Metadata/gmd:dataQualityInfo/gmd:DQ_DataQuality/gmd:report/gmd:DQ_DomainConsistency/gmd:result/gmd:DQ_ConformanceResult/gmd:specification/gmd:CI_Citation/gmd:title/gco:CharacterString",
+		inspire => "Specification title",
+		iso_name => "Specification title",
+		html => _mb("Specification title"),
+		value => "",
+		description => _mb("This is a citation of the implementing rules adopted under Article 7(1) of Directive 2007/2/EC or other specification to which a particular resource conforms. A resource may conform to more than one implementing rules adopted under Article 7(1) of Directive 2007/2/EC or other specification. This citation shall include at least the title and a reference date (date of publication, date of last revision or of creation) of the implementing rules adopted under Article 7(1) of Directive 2007/2/EC or of the specification.")
+//B 7.1.2 Reference Date
+		iso19139 => "/gmd:MD_Metadata/gmd:dataQualityInfo/gmd:DQ_DataQuality/gmd:report/gmd:DQ_DomainConsistency/gmd:result/gmd:DQ_ConformanceResult/gmd:specification/gmd:CI_Citation/gmd:date/gmd:CI_Date/gmd:date/*",
+		inspire => "specification reference date",
+		iso_name => "Specification reference date",
+		html => _mb("Specification reference date"),
+		value => "",
+//B 7.2. Degree
+		iso19139 => "/gmd:MD_Metadata/gmd:dataQualityInfo/gmd:DQ_DataQuality/gmd:report/gmd:DQ_DomainConsistency/gmd:result/gmd:DQ_ConformanceResult/gmd:pass/gco:Boolean",
+		inspire => "deegree of conformance",
+		iso_name => "Degree of conformance",
+		html => _mb("Degree of conformance"),
+		value => "",
+		description => _mb("This is the degree of conformity of the resource to the implementing rules adopted under Article 7(1) of Directive 2007/2/EC or other specification. The value domain of this metadata element is defined in Part D.")
+//B 8. Constraints related to access and use
+//B 8.1. Conditions applying to access and use
+		iso19139 => "/gmd:MD_Metadata/gmd:identificationInfo/*/gmd:resourceConstraints/gmd:MD_Constraints/gmd:useLimitation/gco:CharacterString",
+		inspire => "conditions applying to access and use",
+		iso_name => "conditions applying to access and use",
+		html => _mb("Conditions applying to access and use"),
+		value => "",
+		category => "useconstraints",
+		description => _mb("A set of conditions applying to access and use.")
+//B 8.2. Limitations on public access
+//B 8.2.1 access constraints codelist
+		iso19139 => "/gmd:MD_Metadata/gmd:identificationInfo/*/gmd:resourceConstraints/gmd:MD_LegalConstraints/gmd:accessConstraints/gmd:MD_RestrictionCode/@codeListValue",
+		inspire => "access constraints code",
+		iso_name => "access constraints code",
+		html => _mb("Access constraints code"),
+		value => "",
+		description => _mb("Code for access constraints")
+//B 8.2.2 other constraints
+		iso19139 => "/gmd:MD_Metadata/gmd:identificationInfo/*/gmd:resourceConstraints/gmd:MD_LegalConstraints/gmd:otherConstraints/gco:CharacterString",
+		inspire => "other constraints",
+		iso_name => "other constraints",
+		html => _mb("Other constraints"),
+		value => "",
+		description => _mb("Other constraints")
+//B 9. Organisations responsible for the establishment, management, maintance and distribution of spatial data sets and services
+//B 9.1. Responsible party
+//B 9.1.1 Responsible party name
+		iso19139 => "/gmd:MD_Metadata/gmd:identificationInfo/*/gmd:pointOfContact/gmd:CI_ResponsibleParty/gmd:organisationName/gco:CharacterString",
+		inspire => "responsible party name",
+		iso_name => "responsible party name",
+		html => _mb("Responsible party name"),
+		value => "",
+		category => "contact",
+		description => _mb("The name of the organisation as free text.")
+//B 9.1.2 Responsible party email
+		iso19139 => "/gmd:MD_Metadata/gmd:identificationInfo/*/gmd:pointOfContact/gmd:CI_ResponsibleParty/gmd:contactInfo/gmd:CI_Contact/gmd:address/gmd:CI_Address/gmd:electronicMailAddress/gco:CharacterString",
+		inspire => "responsible party email",
+		iso_name => "responsible party email",
+		html => _mb("Responsible party email"),
+		value => "",
+		description => _mb("A contact e-mail address as a character string.")
+//B 9.2 Responsible party role
+		iso19139 => "/gmd:MD_Metadata/gmd:identificationInfo/*/gmd:pointOfContact/gmd:CI_ResponsibleParty/gmd:role/gmd:CI_RoleCode/@codeListValue",
+		inspire => "responsible party role",
+		iso_name => "responsible party role",
+		html => _mb("Responsible party role"),
+		value => "",
+		description => _mb("This is the role of the responsible organisation. The value domain of this metadata element is defined in Part D.")
+//TODO some more translations
+//B 10 Metadata on metadata
+//B 10.1. Metadata point of contact
+//B 10.1.1 Metadata point of contact name
+		iso19139 => "/gmd:MD_Metadata/gmd:contact/gmd:CI_ResponsibleParty/gmd:organisationName/gco:CharacterString",
+		inspire => "metadata point of contact name",
+		iso_name => "Metadata point of contact name",
+		html => _mb("Metadata point of contact name"),
+		value => "",
+//B 10.1.2 Metadata point of contact email
+		iso19139 => "/gmd:MD_Metadata/gmd:contact/gmd:CI_ResponsibleParty/gmd:contactInfo/gmd:CI_Contact/gmd:address/gmd:CI_Address/gmd:electronicMailAddress/gco:CharacterString",
+		inspire => "metadata point of contact email",
+		iso_name => "Metadata point of contact email",
+		html => _mb("Metadata point of contact email"),
+		value => "",
+//B 10.2. Metadata date
+		iso19139 => "/gmd:MD_Metadata/gmd:dateStamp/*",
+		inspire => "metadata date",
+		iso_name => "Metadata date",
+		html => _mb("Metadata date"),
+		value => "",
+		category => "metadata",
+		description => _mb("The date which specifies when the metadata record was created or updated. This date shall be expressed in conformity with ISO 8601.")
+//B 10.3. Metadata language
+		iso19139 => "/gmd:MD_Metadata/gmd:language/gmd:LanguageCode/@codeListValue",
+		inspire => "metadata language",
+		iso_name => "Metadata language",
+		html => _mb("Metadata language"),
+		value => "",
+		description => _mb("This is the language in which the metadata elements are expressed. The value domain of this metadata element is limited to the official languages of the Community expressed in conformity with ISO 639-2.")
+//Additional Metadata Elements from the Data Specs
+//Metadata required for interoperability
+//TODO!!
+https://geo-ide.noaa.gov/wiki/index.php?title=ISO_Boilerplate
+<gmd:referenceSystemInfo>
+    <gmd:MD_ReferenceSystem>
+        <gmd:referenceSystemIdentifier>
+            <gmd:RS_Identifier>
+                <gmd:authority>
+                    <gmd:CI_Citation>
+                        <gmd:title>
+                            <gco:CharacterString>European Petroleum Survey Group (EPSG) Geodetic Parameter Registry</gco:CharacterString>
+                        </gmd:title>
+                        <gmd:date>
+                            <gmd:CI_Date>
+                                <gmd:date>
+                                    <gco:Date>2008-11-12</gco:Date>
+                                </gmd:date>
+                                <gmd:dateType>
+                                    <gmd:CI_DateTypeCode codeList="http://www.isotc211.org/2005/resources/Codelist/gmxCodelists.xml#CI_DateTypeCode" codeListValue="publication">publication</gmd:CI_DateTypeCode>
+                                </gmd:dateType>
+                            </gmd:CI_Date>
+                        </gmd:date>
+                        <gmd:citedResponsibleParty>
+                            <gmd:CI_ResponsibleParty>
+                                <gmd:organisationName>
+                                    <gco:CharacterString>European Petroleum Survey Group</gco:CharacterString>
+                                </gmd:organisationName>
+                                <gmd:contactInfo>
+                                    <gmd:CI_Contact>
+                                        <gmd:onlineResource>
+                                            <gmd:CI_OnlineResource>
+                                                <gmd:linkage>
+                                                    <gmd:URL>http://www.epsg-registry.org/</gmd:URL>
+                                                </gmd:linkage>
+                                            </gmd:CI_OnlineResource>
+                                        </gmd:onlineResource>
+                                    </gmd:CI_Contact>
+                                </gmd:contactInfo>
+                                <gmd:role gco:nilReason="missing"/>
+                            </gmd:CI_ResponsibleParty>
+                        </gmd:citedResponsibleParty>
+                    </gmd:CI_Citation>
+                </gmd:authority>
+                <gmd:code>
+                    <gco:CharacterString>urn:ogc:def:crs:EPSG:4326</gco:CharacterString>
+                </gmd:code>
+                <gmd:version>
+                    <gco:CharacterString>6.18.3</gco:CharacterString>
+                </gmd:version>
+            </gmd:RS_Identifier>
+        </gmd:referenceSystemIdentifier>
+    </gmd:MD_ReferenceSystem>
+</gmd:referenceSystemInfo>
+//1. Coordinate Reference System
+		iso19139 => "/gmd:MD_Metadata/gmd:identificationInfo/gmd:MD_DataIdentification/gmd:referenceSystemInfo/gmd:MD_ReferenceSystem/gmd:RS_Identifier/gmd:code/gco:CharacterString",
+		inspire => "coordinate reference system",
+		iso_name => "coordinate reference system",
+		html => _mb("Coordinate reference system"),
+		value => "",
+		category => "dataspec",
+		description => _mb("Description of the coordinate reference system(s) used in the data set.")
+//2. Temporal Reference System - only mandatory if not the standard system!
+		inspire => "temporal reference system",
+		iso_name => "temporal reference system",
+		html => _mb("Temporal reference system"),
+		value => "",
+		description => _mb("Description of the temporal reference system(s) used in the data set. This element is mandatory only if the spatial data set contains temporal information that does not refer to the default temporal reference system.")
+//3. Encoding
+		iso19139 => "/gmd:MD_Metadata/gmd:MD_DataIdentification/gmd:distributionInfo/gmd:MD_Distribution/gmd:distributionFormat/gmd:MD_Format/gmd:name/gco:CharacterString",
+		inspire => "encoding",
+		iso_name => "encoding",
+		html => _mb("Encoding"),
+		value => "",
+		description => _mb("Description of the computer language construct(s) specifying the representation of data objects in a record, file, message, storage device or transmission channel.")
+//4. Topological Consistency
+		inspire => "topological Consistency",
+		iso_name => "topological Consistency",
+		html => _mb("Topological Consistency"),
+		value => "",
+		description => _mb("Correctness of the explicitly encoded topological characteristics of the data set as described by the scope. This element is mandatory only if the data set includes types from the Generic Network Model and does not assure centreline topology (connectivity of centrelines) for the network.")
+//5. Character Encoding
+/*<gmd:characterSet>
+  <gmd:MD_CharacterSetCode
+    codeList="http://www.isotc211.org/2005/resources/Codelist/gmxCodelists.xml#MD_CharacterSetCode"
+    codeListValue="UTF8">UTF8</gmd:MD_CharacterSetCode>
+</gmd:characterSet>
+		iso19139 => "/gmd:MD_Metadata/gmd:identificationInfo/gmd:MD_DataIdentification/gmd:characterSet/gmd:MD_CharacterSetCode/@codeListValue",
+		inspire => "character Encoding",
+		iso_name => "character Encoding",
+		html => _mb("Character encoding"),
+		value => "",
+		description => _mb("The character encoding used in the data set. This element is mandatory only if an encoding is used that is not based on UTF-8.")
+//Preview (36)
+		iso19139 => "/gmd:MD_Metadata/gmd:identificationInfo/*/gmd:graphicOverview/gmd:MD_BrowseGraphic/gmd:fileName/gco:CharacterString",
+		inspire => "preview",
+		iso_name => "graphicOverview",
+		value => "",
+$sql_csw = "SELECT * from gp_csw WHERE csw_id = $1 ORDER BY csw_id";
+#do db select
+$v[] = $cat_id;
+$t[] = 'i';
+$res_csw = db_prep_query($sql_csw, $v, $t);
+$cnt_csw = 0;
+#fill result array
+	$csw_list[$cnt_csw] ['id'] = $row_csw["csw_id"];
+	$csw_list[$cnt_csw] ['name'] = $row_csw["csw_name"];
+	#echo "CSW Name:".$row_csw["csw_name"];
+	$csw_list[$cnt_csw] ['fkey_cat_id'] = $row_csw["fkey_cat_id"];
+	#echo "CSW cat_id:".$row_csw["fkey_cat_id"];
+        $v = (integer)$row_csw["fkey_cat_id"];
+	$t = 'i';
+	$sql_gr = "select * from cat_op_conf where fk_cat_id = $1 and param_type = 'getrecords' and param_name='get'";
+	#var_dump($row_gr);
+	#echo "count csw: ".$cnt_csw;
+	#echo "<br>getrecordsurl: ".$csw_list[$cnt_csw]['getrecordsurl']."<br>";
+	$sql_grbi = "select * from cat_op_conf where fk_cat_id = $1 and param_type = 'getrecordbyid' and param_name='get'";
+	#echo "<br>getrecordbyidurl: ".$csw_list[$cnt_csw]['getrecordbyidurl']."<br>";
+	$cnt_csw++;
+#echo "\nCount of registrated OpenSearch Interfaces: ".count($os_list)."\n";
+	#define new csw get record by id search like:
+	#http://www.portalu.de/csw202?request=GetRecordById&service=CSW&version=2.0.2&Id=81FF8BB2-2753-4A95-8C1E-F78C19035780&ElementSetName=full
+	$openSearchUrlDetail = $csw_list[0] ['getrecordbyidurl'];
+	#echo $cat_id;
+	$url = $openSearchUrlDetail."?request=GetRecordById&service=CSW&version=2.0.2&Id=".$uuid."&ElementSetName=full&OUTPUTSCHEMA=http://www.isotc211.org/2005/gmd";
+	#echo $url;
+#create connector object
+$openSearchObject = new connector($url);
+#get results
+$openSearchDetail = $openSearchObject->file;
+//solve problem with xlink namespace for href attributes:
+$openSearchDetail = str_replace('xlink:href', 'xlinkhref', $openSearchDetail);
+#http://forums.devshed.com/php-development-5/simplexml-namespace-attributes-problem-452278.html
+#http://www.leftontheweb.com/message/A_small_SimpleXML_gotcha_with_namespaces
+#$openSearchDetail = str_replace('xmlns=', 'ns=', $openSearchDetail);
+$openSearchDetailXML=simplexml_load_string($openSearchDetail);
+#extract objects to iso19139 elements
+$openSearchDetailXML->registerXPathNamespace("csw", "http://www.opengis.net/cat/csw/2.0.2");
+$openSearchDetailXML->registerXPathNamespace("gml", "http://www.opengis.net/gml");
+$openSearchDetailXML->registerXPathNamespace("gco", "http://www.isotc211.org/2005/gco");
+$openSearchDetailXML->registerXPathNamespace("gmd", "http://www.isotc211.org/2005/gmd");
+$openSearchDetailXML->registerXPathNamespace("gts", "http://www.isotc211.org/2005/gts");
+$openSearchDetailXML->registerXPathNamespace("srv", "http://www.isotc211.org/2005/srv");
+$openSearchDetailXML->registerXPathNamespace("xlink", "http://www.w3.org/1999/xlink");
+//check if only iso19139 data is requested - if so - push the result automatically from the CSW getRecordById request to the user or the validator
+if ($_REQUEST['mdtype']=='iso19139' && $_REQUEST['validate'] != 'true') {
+	header("Content-type: application/xhtml+xml; charset=UTF-8");
+	//delete csw entries from response file
+	$MD_Metadata = str_replace('<csw:GetRecordByIdResponse xmlns:csw="http://www.opengis.net/cat/csw/2.0.2">', '', $openSearchDetail);
+	$MD_Metadata = str_replace('</csw:GetRecordByIdResponse>', '', $MD_Metadata);
+	echo $MD_Metadata;
+	die();
+if ($_REQUEST['mdtype']=='iso19139' && $_REQUEST['validate'] == 'true') {
+	validateInspireMetadataFromData($MD_Metadata);
+$j=0;
+//switch ($os_list[0] ['version']) {
+    	//case 2:
+//register namespaces:
+/* <gmd:MD_Metadata xmlns:gco="http://www.isotc211.org/2005/gco" xmlns:gmd="http://www.isotc211.org/2005/gmd" xmlns:gml="http://www.opengis.net/gml" xmlns:gts="http://www.isotc211.org/2005/gts" xmlns:srv="http://www.isotc211.org/2005/srv" id="_ingrid-group_iplug-rp-udk-db_263">*/
+		for($a = 0; $a < count($md_ident); $a++) {
+			$resultOfXpath = $openSearchDetailXML->xpath('/csw:GetRecordByIdResponse'.$md_ident[$a]['iso19139']);
+			for ($i = 0; $i < count($resultOfXpath); $i++) {
+				$md_ident[$a]['value'] = $md_ident[$a]['value'].",".$resultOfXpath[$i];
+			$md_ident[$a]['value'] = ltrim($md_ident[$a]['value'],',');
+	/*break;
+	default:
+	foreach ( $openSearchDetailXML->channel->item->details->detail as $detail) {
+		$detail_key=(string)$detail->{'detail-key'};		#cast explicitly to string
+		$detail_value=(string)$detail->{'detail-value'};
+		$detail_array[$detail_key] = $detail_value;
+		$detail_keys[$j]=$detail_key;
+		if(isset($_REQUEST["mdtype"])&($_REQUEST["mdtype"]=='debug') ) {
+			if (in_array($detail_key, $ibus_names)) {
+				echo "Key <b>".$detail_key."</b> exists in lookup table!<br>";
+				$i++;
+		$j++;
+	break;
+//generate output for different parameters mdtype
+switch ($_REQUEST["mdtype"]) {
+	case "html":
+		$html = '<html xmlns="http://www.w3.org/1999/xhtml" xml:lang="'.$languageCode.'">';
+		$html .= '<body>';
+		$metadataStr .= '<head>' .
+		'<title>'._mb("Metadata").'</title>' .
+		'<meta name="description" content="'._mb("Metadata").'" xml:lang="'.$languageCode.'" />'.
+		'<meta name="keywords" content="'._mb("Metadata").'" xml:lang="'.$languageCode.'" />'	.
+		'<meta http-equiv="cache-control" content="no-cache">'.
+		'<meta http-equiv="pragma" content="no-cache">'.
+		'<meta http-equiv="expires" content="0">'.
+		'<meta http-equiv="content-language" content="'.$languageCode.'" />'.
+		'<meta http-equiv="content-style-type" content="text/css" />'.
+		'<meta http-equiv="Content-Type" content="text/html; charset='.CHARSET.'">' .
+		'</head>';
+		$html .= $metadataStr;
+		//define the javascripts to include
+		$html .= '<link type="text/css" href="../css/metadata.css" rel="Stylesheet" />';
+		if ($layout == 'tabs') {
+			$html .= '<link type="text/css" href="../extensions/jquery-ui-1.8.1.custom/css/custom-theme/jquery-ui-1.8.5.custom.css" rel="Stylesheet" />';
+			$html .= '<script type="text/javascript" src="../extensions/jquery-ui-1.8.1.custom/js/jquery-1.4.2.min.js"></script>';
+			$html .= '<script type="text/javascript" src="../extensions/jquery-ui-1.8.1.custom/js/jquery-ui-1.8.1.custom.min.js"></script>';
+			//initialize tabs
+			$html .= '<script type="text/javascript">';
+			$html .= '$(function() {';
+			$html .= '	$("#tabs").tabs();';
+			$html .= '});';
+			$html .= '</script>';
+			//independently define the headers of the parts
+			$html .= '<div class="demo">';
+			$html .= '<div id="tabs">';
+			$html .= '<ul>';
+			$html .= 	'<li><a href="#tabs-2">'._mb("Properties").'</a></li>';
+			$html .= 	'<li><a href="#tabs-3">'._mb("Contact").'</a></li>';
+			$html .= 	'<li><a href="#tabs-4">'._mb("Terms of use").'</a></li>';
+			$html .= 	'<li><a href="#tabs-5">'._mb("Quality").'</a></li>';
+			$html .= 	'<li><a href="#tabs-6">'._mb("Interfaces").'</a></li>';
+			$html .= '</ul>';
+		if ($layout == 'accordion') {
+			$html .= '<link type="text/css" href="../extensions/jquery-ui-1.8.1.custom/css/custom-theme/jquery-ui-1.8.4.custom.css" rel="Stylesheet" />';
+			//define the javascript functions
+			$html .= '	$(function() {';
+			$html .= '		$("#accordion").accordion();';
+			//$html .= '		$("#accordion").accordion({ autoHeight: false});';
+			//$html .= '		$("#accordion").accordion({ autoHeight: false , clearStyle: true });';
+			$html .= '	});';
+			$html .= '	</script>';
+			$html .= '<div id="accordion">';
+		if ($layout == 'plain') {
+			$html .= '<div id="plain">';
+		//some placeholders
+		$tableBegin =  "<table>\n";
+		$t_a = "\t<tr>\n\t\t<th>\n\t\t\t";
+		$t_b = "\n\t\t</th>\n\t\t<td>\n\t\t\t";
+		$t_c = "\n\t\t</td>\n\t</tr>\n";
+		$tableEnd = "</table>\n";
+		//**************************overview part begin******************************
+		//generate div tags for the content - the divs are defined in the array
+			$html .= '<div style="height:300px">';
+			$html .= '<div id="tabs-1">';
+			$html .= '<div>';
+		$html .= '<p>';
+		$html .= '<fieldset><legend>'._mb("Metadata").'</legend>';
+		$html .= $tableBegin;
+		$html .= $t_a."<b>".$md_ident[0]['html']."</b>: ".$t_b.$md_ident[0]['value'].$t_c;
+		$html .= $t_a."<b>".$md_ident[31]['html']."</b>: ".$t_b.$md_ident[31]['value'].$t_c;
+		$html .= $t_a."<b>".$md_ident[32]['html']."</b>: ".$t_b.$md_ident[32]['value'].$t_c;
+		$html .= $tableEnd;
+		$html .= '</fieldset>';
+		$html .= '<fieldset><legend>'._mb("Identification").'</legend>';
+		$html .= $t_a."<b>".$md_ident[1]['html']."</b>: ".$t_b.$md_ident[1]['value'].$t_c;
+		$html .= $t_a."<b>".$md_ident[2]['html']."</b>: ".$t_b.$md_ident[2]['value'].$t_c;
+		$html .= $t_a."<b>".$md_ident[3]['html']."</b>: ".$t_b.$md_ident[3]['value'].$t_c;
+		if ($md_ident[36]['value'] != "") {
+			$html .= $t_a."<b>".$md_ident[36]['html']."</b>: ".$t_b."<img width=120 height=120 src = '".$md_ident[36]['value']."'>".$t_c;//preview
+		$html .= $t_a."<b>".$md_ident[5]['html']."</b>: ".$t_b.$md_ident[5]['value'].$t_c;
+		$html .= $t_a."<b>".$md_ident[6]['html']."</b>: ".$t_b.$md_ident[6]['value'].$t_c;
+		$html .= $t_a."<b>".$md_ident[26]['html']."</b>: ".$t_b.$md_ident[26]['value'].$t_c;
+		$html .= $t_a."<b>".$md_ident[27]['html']."</b>: ".$t_b.$md_ident[27]['value'].$t_c;
+		$bbox = explode(',',$md_ident[12]['value']);
+		if (count($bbox) == 4) {
+			$wgs84Bbox = $bbox[0].",".$bbox[2].",".$bbox[1].",".$bbox[3];
+			$getMapUrl = getExtentGraphic(explode(",", $wgs84Bbox));
+			$html .= '<fieldset><legend>'._mb("Extent").'</legend>';
+			if (defined('EXTENTSERVICEURL')) {
+				$html .= "<img src='".$getMapUrl."'>";
+			} else {
+				$html .= _mb('Graphic unavailable');
+		$html .= '<fieldset><legend>'._mb("Contact").'</legend>';
+		$html .= '</p>';
+		$html .= '</div>';//element
+		//**************************properties part begin******************************
+			$html .= '<h3><a href="#">'._mb("Properties").'</a></h3>';
+			$html .= '<div id="tabs-2">';
+			$html .= '<h3>'._mb("Properties").'</h3>';
+			$html .= '<div>';
+		$html .= '<p>';
+		$html .= '<fieldset><legend>'._mb("Common").'</legend>';
+		$html .= $t_a."<b>".$md_ident[8]['html']."</b>: ".$t_b.$md_ident[8]['value'].$t_c;
+		$html .= $t_a."<b>".$md_ident[9]['html']."</b>: ".$t_b.$md_ident[9]['value'].$t_c;
+		$html .= $t_a."<b>".$md_ident[11]['html']."</b>: ".$t_b.$md_ident[11]['value'].$t_c;
+		$html .= '<fieldset><legend>'._mb("Geographic extent").'</legend>';
+		$html .= $t_a."<b>".$md_ident[33]['html']."</b>: ".$t_b.$md_ident[33]['value'].$t_c;
+		$html .= $t_a."<b>".$md_ident[12]['html']."</b>: ".$t_b.$md_ident[12]['value'].$t_c;
+		$html .= '<fieldset><legend>'._mb("Temporal extent").'</legend>';
+		$html .= $t_a."<b>".$md_ident[13]['html']."</b>: ".$t_b.$md_ident[13]['value'].$t_c;
+		$html .= $t_a."<b>".$md_ident[14]['html']."</b>: ".$t_b.$md_ident[14]['value'].$t_c;
+		$html .= $t_a."<b>".$md_ident[15]['html']."</b>: ".$t_b.$md_ident[15]['value'].$t_c;
+		$html .= $t_a."<b>".$md_ident[16]['html']."</b>: ".$t_b.$md_ident[16]['value'].$t_c;
+		$html .= '<fieldset><legend>'._mb("Format").'</legend>';
+		$html .= $t_a."<b>".$md_ident[34]['html']."</b>: ".$t_b.$md_ident[34]['value'].$t_c;
+		$html .= $t_a."<b>".$md_ident[35]['html']."</b>: ".$t_b.$md_ident[35]['value'].$t_c;
+		$html .= '<fieldset><legend>'._mb("Service information").'</legend>';
+		$html .= $t_a."<b>".$md_ident[10]['html']."</b>: ".$t_b.$md_ident[10]['value'].$t_c;
+		$html .= $t_a."<b>".$md_ident[7]['html']."</b>: ".$t_b.$md_ident[7]['value'].$t_c;
+		$html .= '</p>';
+		//**************************contact part begin******************************
+			$html .= '<div id="tabs-3">';
+			$html .= '<div>';
+		$html .= '<p>';
+		$html .= '<fieldset><legend>'._mb("Data/Service provider").'</legend>';
+		$html .= $t_a."<b>".$md_ident[28]['html']."</b>: ".$t_b.$md_ident[28]['value'].$t_c;
+		$html .= '<fieldset><legend>'._mb("Metadata provider").'</legend>';
+		$html .= $t_a."<b>".$md_ident[29]['html']."</b>: ".$t_b.$md_ident[29]['value'].$t_c;
+		$html .= $t_a."<b>".$md_ident[30]['html']."</b>: ".$t_b.$md_ident[30]['value'].$t_c;
+		$html .= '</p>';
+		//**************************terms of use part begin******************************
+			$html .= '<h3><a href="#">'._mb("Terms of use").'</a></h3>';
+			$html .= '<div id="tabs-4">';
+			$html .= '<h3>'._mb("Terms of use").'</h3>';
+			$html .= '<div>';
+		$html .= '<p>';
+		$html .= '<fieldset><legend>'._mb("Conditions").'</legend>';
+		$html .= $t_a."<b>".$md_ident[23]['html']."</b>: ".$t_b.$md_ident[23]['value'].$t_c;
+		$html .= '<fieldset><legend>'._mb("Access constraints").'</legend>';
+		$html .= $t_a."<b>".$md_ident[24]['html']."</b>: ".$t_b.$md_ident[24]['value'].$t_c;
+		$html .= $t_a."<b>".$md_ident[25]['html']."</b>: ".$t_b.$md_ident[25]['value'].$t_c;
+		$html .= '</p>';
+		//**************************quality part begin******************************
+			$html .= '<h3><a href="#">'._mb("Quality").'</a></h3>';
+			$html .= '<div id="tabs-5">';
+			$html .= '<h3>'._mb("Quality").'</h3>';
+			$html .= '<div>';
+		$html .= '<p>';
+		$html .= '<fieldset><legend>'._mb("Lineage").'</legend>';
+		$html .= $t_a."<b>".$md_ident[17]['html']."</b>: ".$t_b.$md_ident[17]['value'].$t_c;
+		$html .= '<fieldset><legend>'._mb("Resolution").'</legend>';
+		$html .= $t_a."<b>".$md_ident[18]['html']."</b>: ".$t_b.$md_ident[18]['value'].$t_c;
+		$html .= $t_a."<b>".$md_ident[19]['html']."</b>: ".$t_b.$md_ident[19]['value'].$t_c;
+		$html .= '<fieldset><legend>'._mb("Validity").'</legend>';
+		$html .= $t_a."<b>".$md_ident[20]['html']."</b>: ".$t_b.$md_ident[20]['value'].$t_c;
+		$html .= $t_a."<b>".$md_ident[21]['html']."</b>: ".$t_b.$md_ident[21]['value'].$t_c;
+		$html .= $t_a."<b>".$md_ident[22]['html']."</b>: ".$t_b.$md_ident[22]['value'].$t_c;
+		$html .= '</p>';
+//**************************quality part begin******************************
+			$html .= '<h3><a href="#">'._mb("Interfaces").'</a></h3>';
+			$html .= '<div id="tabs-6">';
+			$html .= '<h3>'._mb("Interfaces").'</h3>';
+			$html .= '<div>';
+		$html .= '<p>';
+		//exchange mdtype html with iso19139
+		$queryNew = str_replace("mdtype=html","mdtype=iso19139",$_SERVER['QUERY_STRING']);
+		$html .= $t_a."<b>"._mb("ISO19139")."</b>: <a href='".$url."' target='_blank'>"._mb("Metadata")."</a><a href='".$_SERVER['PHP_SELF']."?".$queryNew."&validate=true' target='_blank'><img style='border: none;' src = '../img/misc/icn_inspire_validate.png' title='"._mb("INSPIRE Validator")."'></a>".$t_c;
+		$html .= '</p>';
+		$html .= '</div>'; //accordion
+		$html .= '</div>'; //demo
+		$html .= '</body>';
+		$html .= '</html>';
+		echo $html;
+		die();
+	break;
+	case "inspire":
+		echo "<a href='".$url."'>GetRecordById URL</a><br><br>";
+			echo "<b>".$md_ident[$a]['html']."</b>: ".$md_ident[$a]['value']."<br><br>";
+		die();
+	break;
+	case "debug":
+		die();
+	break;
+	default:
+		die();
+	break;
+if ($_REQUEST['mdtype']=='debug'){
+		echo "DEBUG Metadatenanzeige<br>";
+		#define table
+		echo "<html><table border=\"1\"><br>";
+		echo "<tr>";
+		#loop for each detail - tag - sometimes there are other tags in there - if one detail has more than one entry! - maybe this must be interpreted but later!
+		foreach ($detail_keys as $detailkey) {
+			if (in_array($detailkey, $ibus_names)==false){
+				echo  "<td >".$detailkey."</td>";
+				else {
+				echo "<td bgcolor=\"green\">".$md_ident[array_search($detailkey, $ibus_names)]['html']."(".$detailkey.")</td>";
+			#echo "</td>";
+			echo "<td>";
+			echo $detail_array[$detailkey];
+			echo "</tr>";
+		echo "</table></html>";
+if ($_REQUEST['mdtype']=='html'){
+<html xmlns="http://www.w3.org/1999/xhtml" xml:lang="de">
+	<head>
+		<title>GeoPortal Rheinland-Pfalz - Metadaten</title>
+		<meta name="description" content="Metadaten" xml:lang="de" />
+		<meta name="keywords" content="Metadaten" xml:lang="de" />
+		<meta http-equiv="cache-control" content="no-cache">
+		<meta http-equiv="pragma" content="no-cache">
+		<meta http-equiv="expires" content="0">
+		<meta http-equiv="content-language" content="de" />
+		<meta http-equiv="content-style-type" content="text/css" />
+<?php
+	echo '<meta http-equiv="Content-Type" content="text/html; charset='.CHARSET.'">';
+		<link rel="stylesheet" type="text/css" href="../../../portal/fileadmin/design/css/screen.css" media="screen" />
+		<link rel="stylesheet" type="text/css" href="../../../portal/fileadmin/design/css/print.css" media="print" />
+	</head>
+	<body id="top" class="popup">
+	<div id="header_gray">
+	<a href="javascript:window.print()">Drucken <img src="../../../portal/fileadmin/design/images/icon_print.gif" width="14" height="14" alt="" /></a>
+	<a href="javascript:window.close()">Fenster schlie&szlig;en <img src="../../../portal/fileadmin/design/images/icon_close.gif" width="14" height="14" alt="" /></a>
+	</div>
+	<div id="header_redbottom"></div>
+	<div id="header_red"></div>
+	<div class="content">
+<?php
+	echo "<h1>Detailinformationen:</h1>";
+	#define table
+	echo "<html><table class='contenttable-0-wide'>";
+	echo "<tr>";
+		if (in_array($detailkey, $ibus_names)==true){
+			echo "<td>".$md_ident[array_search($detailkey, $ibus_names)]['html']."</td>";
+			echo "<td>";
+			echo display_text($detail_array[$detailkey]);
+			echo "</td></tr>";
+if ($_REQUEST['mdtype']=='inspire') {
+	<head>
+<?php
+	</head>
+	</div>
+<?php
+	echo "<img border=\"0\" src=\"img/inspire_tr_100.png\" alt=\"INSPIRE Logo\"><h1>INSPIRE Metadaten:</h1>";
+	#define table
+	echo "<tr>";
+			if ($md_ident[array_search($detailkey, $ibus_names)]['inspiremandatory']=='true') {
+				echo "<td>".$md_ident[array_search($detailkey, $ibus_names)]['inspire']."</td>";
+				echo "<td>";
+	echo '<br><b>INSPIRE output not completly implemented!<b><br>';
More information about the Mapbender_commits mailing list
