[Mapbender-commits] r8244 - trunk/mapbender/http/geoportal
svn_mapbender at osgeo.org
Mon Feb 13 11:16:37 EST 2012
Author: armin11
Date: 2012-02-13 08:16:37 -0800 (Mon, 13 Feb 2012)
New Revision: 8244
trunk/mapbender/http/geoportal/gaz.php
trunk/mapbender/http/geoportal/mod_readCSWResults.php
Allow spatial search for CSW 2.0.2 - BBOX, Within, Disjoint
Modified: trunk/mapbender/http/geoportal/gaz.php
--- trunk/mapbender/http/geoportal/gaz.php 2012-02-13 08:00:28 UTC (rev 8243)
+++ trunk/mapbender/http/geoportal/gaz.php 2012-02-13 16:16:37 UTC (rev 8244)
@@ -59,7 +59,7 @@
$searchTextOS = str_replace(",","+",$searchText);
if ($searchTextOS ==='false' || $searchTextOS ==='*'){
- $searchTextOS = '1';
+ $searchTextOS = '*';
$openSearchFilter = "";
@@ -92,12 +92,12 @@
$openSearchFilter .= "+y2:".$spatialFilterCoords[3];
if (isset($searchTypeBbox) & ($searchTypeBbox != 'false')){
- #if ($searchTypeBbox == 'intersects') {
- # $openSearchFilter .= "+coord:intersect";
- #if ($searchTypeBbox == 'outside') {
- # $openSearchFilter .= "+coord:include";
+ if ($searchTypeBbox == 'intersects') {
+ $openSearchFilter .= "+coord:intersect";
+ if ($searchTypeBbox == 'outside') {
+ $openSearchFilter .= "+coord:outside";
if ($searchTypeBbox == 'inside') {
$openSearchFilter .= "+coord:inside";
@@ -116,7 +116,7 @@
//apply filter
//following part is only set if the portalu opensearch is used!
-//$searchTextOS .= $openSearchFilter;
+$searchTextOS .= $openSearchFilter;
// check if some extended is requested - in the old version this is defined by one parameter. The new interface would not distinguish between this two kind of search cases. Every search is a also an extented search. See mod_callMetadata.php
Modified: trunk/mapbender/http/geoportal/mod_readCSWResults.php
--- trunk/mapbender/http/geoportal/mod_readCSWResults.php 2012-02-13 08:00:28 UTC (rev 8243)
+++ trunk/mapbender/http/geoportal/mod_readCSWResults.php 2012-02-13 16:16:37 UTC (rev 8244)
@@ -99,10 +99,102 @@
//convert the the opensearch filter to ogc filter encoding
+//extract query string - explode by +
+$queryString = $_REQUEST["q"];
+$queryStringParts = explode("+",$queryString);
+//extract single elements into variables
+//first entry is allways the query string for any text
+$queryText = $queryStringParts[0];
+//extract the other elements
+for ($i=1;$i < count($queryStringParts);$i++) {
+ //check the elements
+ $queryParam = explode(":",$queryStringParts[$i]);
+ switch ($queryParam[0]) {
+ case "x1":
+ $x1 = $queryParam[1];
+ break;
+ case "x2":
+ $x2 = $queryParam[1];
+ break;
+ case "y1":
+ $y1 = $queryParam[1];
+ break;
+ case "y2":
+ $y2 = $queryParam[1];
+ break;
+ case "coord":
+ $coord = $queryParam[1];
+ break;
+ case "ranking":
+ $ranking = $queryParam[1];
+ break;
+//build bbox if all infos are given
+$e = new mb_exception("q= : ".$_REQUEST["q"]);
+$e = new mb_notice("ranking: ".$ranking);
+$e = new mb_notice("coord: ".$coord);
+$e = new mb_exception("queryText: ".$queryText);
+if (isset($x1) && isset($x2) && isset($y1) && isset($y2) && isset($coord)) {
+/* <BBOX>
+ <PropertyName>ows:BoundingBox</PropertyName>
+ <gml:Envelope>
+ <gml:lowerCorner>-180 -90</gml:lowerCorner>
+ <gml:upperCorner>180 90</gml:upperCorner>
+ </gml:Envelope>
+ </BBOX>*/
+/*<ogc:Intersects> <ogc:PropertyName>ows:BoundingBox</ogc:PropertyName>
+<gml:Envelope>
+<gml:lowerCorner>14.05 46.46</gml:lowerCorner>
+<gml:upperCorner>17.24 48.42</gml:upperCorner>
+</gml:Envelope>
+</ogc:Intersects>*/
+ $existsSpatialFilter = true;
+ //$spatialFilter = "<BBOX>";
+ switch ($coord) {
+ case "intersect":
+ $spatialFilter .= "<ogc:BBOX>";
+ break;
+ case "inside":
+ $spatialFilter .= "<ogc:Within>";
+ break;
+ case "outside":
+ $spatialFilter .= "<ogc:Disjoint>";
+ break;
+ default:
+ $spatialFilter .= "<ogc:PropertyName>BoundingBox</ogc:PropertyName>";
+ $spatialFilter .= "<gml:Envelope>";
+ $spatialFilter .= "<gml:lowerCorner>".$x1." ".$y1."</gml:lowerCorner>";
+ $spatialFilter .= "<gml:upperCorner>".$x2." ".$y2."</gml:upperCorner>";
+ $spatialFilter .= "</gml:Envelope>";
+ switch ($coord) {
+ case "intersect":
+ $spatialFilter .= "</ogc:BBOX>";
+ break;
+ case "inside":
+ $spatialFilter .= "</ogc:Within>";
+ break;
+ case "outside":
+ $spatialFilter .= "</ogc:Disjoint>";
+ break;
+ default:
+ $spatialFilter .= "/<ogc:BBOX>";
+ //$spatialFilter .= "</BBOX>";
+} else {
+ $existsSpatialFilter = false;
+//set kind of filter
+//debug output
+$e = new mb_notice($spatialFilter);
#get the information out of the mapbender-db
#get urls to search interfaces (csw):
$sql_csw = "SELECT * from gp_csw ORDER BY csw_id";
@@ -211,61 +303,108 @@
//calculate the startindex for the requested pagenumber
$startIndex = ((real)$csw_list[$i_si] ["h"]*((integer)$request_p - 1)) + 1;
//$number_of_pages=ceil((real)$n_results/(real)$csw_list[$i_si] ['h']);
- $getRecords = '<GetRecords xmlns="http://www.opengis.net/cat/csw/2.0.2"';
+ $getRecords = '<csw:GetRecords xmlns:csw="http://www.opengis.net/cat/csw/2.0.2"';
$getRecords .= ' xmlns:gmd="http://www.isotc211.org/2005/gmd"';
- $getRecords .= ' xmlns:csw="http://www.opengis.net/cat/csw/2.0.2"';
+ $getRecords .= ' xmlns:ogc="http://www.opengis.net/ogc"';
+ $getRecords .= ' xmlns:gml="http://www.opengis.net/gml"';
$getRecords .= ' maxRecords="'.$csw_list[$i_si] ["h"].'"';
$getRecords .= ' outputFormat="application/xml"';
$getRecords .= ' outputSchema="http://www.isotc211.org/2005/gmd"';
$getRecords .= ' resultType="results"';
+ //sortby
+ $getRecords .= ' sortby="Title:A"';
$getRecords .= ' service="CSW"';
$getRecords .= ' startPosition="'.$startIndex.'"'; //set this for paging - maybe it must be calculated from max count
$getRecords .= ' version="2.0.2">';
$getRecords .= ' <csw:Query typeNames="csw:Record">';
$getRecords .= ' <csw:ElementSetName>summary</csw:ElementSetName>';
$getRecords .= ' <csw:Constraint version="1.1.0">';
- $getRecords .= ' <Filter xmlns="http://www.opengis.net/ogc" xmlns:gml="http://www.opengis.net/gml">';
- $getRecords .= ' <And>';
- $getRecords .= ' <PropertyIsLike wildCard="%" singleChar="_" escape="">';
- $getRecords .= ' <PropertyName>AnyText</PropertyName>';
- $getRecords .= ' <Literal>%'.$_REQUEST["q"].'%</Literal>';
+ $getRecords .= ' <ogc:Filter>';
+ $getRecords .= ' <ogc:And>';
+ if ($queryText != '*') {
+ $getRecords .= ' <ogc:PropertyIsLike wildCard="%" singleChar="_" escape="">';
+ $getRecords .= ' <ogc:PropertyName>AnyText</ogc:PropertyName>';
+ $getRecords .= ' <ogc:Literal>%'.$queryText.'%</ogc:Literal>';
+ $getRecords .= ' </ogc:PropertyIsLike>';
$type = trim($csw_list[$i_si]['hierachylevel']);
switch ($type) {
case ($type=='dataset' || $type=='series' || $type=='service' || $type=='nonGeographicDataset' || $type=='application'):
- $getRecords .= ' </PropertyIsLike>';
- $getRecords .= ' <PropertyIsEqualTo>';
- $getRecords .= ' <PropertyName>Type</PropertyName>';
- $getRecords .= ' <Literal>'.$type.'</Literal>';
- $getRecords .= ' </PropertyIsEqualTo>';
+ $getRecords .= ' <ogc:PropertyIsEqualTo>';
+ $getRecords .= ' <ogc:PropertyName>Type</ogc:PropertyName>';
+ $getRecords .= ' <ogc:Literal>'.$type.'</ogc:Literal>';
+ $getRecords .= ' </ogc:PropertyIsEqualTo>';
break;
case 'dataset/series':
- $getRecords .= ' <Or>';
- $getRecords .= ' <Literal>dataset</Literal>';
- $getRecords .= ' <Literal>series</Literal>';
- $getRecords .= ' </Or>';
+ $getRecords .= ' <ogc:Or>';
+ $getRecords .= ' <ogc:Literal>dataset</ogc:Literal>';
+ $getRecords .= ' <ogc:Literal>series</ogc:Literal>';
+ $getRecords .= ' </ogc:Or>';
break;
default:
+/*<?xml version="1.0" encoding="UTF-8"?>
+<csw:GetRecords
+ xmlns:csw="http://www.opengis.net/cat/csw/2.0.2"
+ xmlns:ogc="http://www.opengis.net/ogc"
+ xmlns:gml="http://www.opengis.net/gml"
+ service="CSW"
+ version="2.0.2"
+ resultType="results"
+ outputSchema="http://www.isotc211.org/2005/gmd">
+ <csw:Query typeNames="gmd:MD_Metadata">
+ <csw:ElementSetName>brief</csw:ElementSetName>
+ <csw:Constraint version="1.1.0">
+ <ogc:Filter>
+<ogc:And>
+<ogc:PropertyIsLike wildCard="%" singleChar="_" escape="">
+<ogc:PropertyName>AnyText</ogc:PropertyName>
+<ogc:Literal>Wald</ogc:Literal>
+</ogc:PropertyIsLike>
+ <ogc:BBOX>
+ <ogc:PropertyName>BoundingBox</ogc:PropertyName>
+ <gml:Envelope>
+ <gml:lowerCorner>5 49</gml:lowerCorner>
+ <gml:upperCorner>9 51</gml:upperCorner>
+ </gml:Envelope>
+ </ogc:BBOX>
+</ogc:And>
+ </ogc:Filter>
+ </csw:Constraint>
+ </csw:Query>
+</csw:GetRecords>
//$getRecords .= ' <Literal>dataset</Literal>';
- $getRecords .= ' </And>';
- $getRecords .= ' </Filter>';
+ //deactivate spatialFilter cause there is a bug in geonetwork 2.6.4!
+ //http://trac.osgeo.org/geonetwork/ticket/585
+ if ($existsSpatialFilter) {
+ $getRecords .= $spatialFilter;
+ $getRecords .= ' </ogc:And>';
+ $getRecords .= ' </ogc:Filter>';
$getRecords .= ' </csw:Constraint>';
$getRecords .= ' </csw:Query>';
- $getRecords .= '</GetRecords>';
+ $getRecords .= '</csw:GetRecords>';
echo "<br>REQUEST for results<br>".htmlentities($getRecords)."<br>";
+$e = new mb_exception($getRecords);
//for CSW define POST REQUEST for getrecords
$cswInterfaceObject = new connector();
$cswInterfaceObject->set('httpType','POST');
@@ -288,7 +427,7 @@
$openSearchUrlDetail[$i_si]=$csw_list[$i_si] ['getrecordbyidurl']."?";
//get resultlists
- //$url=$openSearchUrlSearch[$i_si]."q=".$_REQUEST["q"].$csw_list[$i_si] ['standardfilter']."&h=".$csw_list[$i_si] ['h']."&p=".$request_p;
+ //$url=$openSearchUrlSearch[$i_si]."q=".$queryText.$csw_list[$i_si] ['standardfilter']."&h=".$csw_list[$i_si] ['h']."&p=".$request_p;
$url = $openSearchUrl[$i_si];
if (!$from_cli) {
echo "<br> url: ".$url."<br>";
@@ -300,7 +439,11 @@
#save resultset in temporary folder identified by sessionid, katalog_id and page_id! Now there would be more tmp files than before!
#this has to be done in order to give the information to typo3
#**************to be done!************************************
- $e = new mb_exception('external xml : '.$openSearchResult);
+ //if ($existsSpatialFilter) {
+ // $e = new mb_exception('external xml : '.$openSearchResult);
+ $e = new mb_notice('external xml : '.$openSearchResult);
#parse result to simplexml
$openSearchXml = new SimpleXMLElement($openSearchResult);
//$openSearchXml = ($openSearchResult);
@@ -358,8 +501,8 @@
if($os_catalogs_file_handle = fopen($resdir."/".$cli_id."_os".$catalog_number."_".$request_p.".xml","w")){
fwrite($os_catalogs_file_handle,"<resultlist>\n");
#logit("<resultlist>\n");
- fwrite($os_catalogs_file_handle,"<querystring>".urlencode($_REQUEST["q"])."</querystring>\n");
- #logit("<querystring>".urlencode($_REQUEST["q"])."</querystring>\n");
+ fwrite($os_catalogs_file_handle,"<querystring>".urlencode($queryText)."</querystring>\n");
+ #logit("<querystring>".urlencode($queryText)."</querystring>\n");
fwrite($os_catalogs_file_handle,"<totalresults>".$n_results."</totalresults>\n");
#logit("<totalresults>".$n_results."</totalresults>\n");
fwrite($os_catalogs_file_handle,"<npages>".$number_of_pages."</npages>\n");
More information about the Mapbender_commits
