[Mapbender-commits] r8253 - trunk/mapbender/http/classes
svn_mapbender at osgeo.org
Wed Feb 15 04:41:43 EST 2012
Author: armin11
Date: 2012-02-15 01:41:43 -0800 (Wed, 15 Feb 2012)
New Revision: 8253
trunk/mapbender/http/classes/class_connector.php
Bugfix - some server (e.g. geoserver) capabilities react dynamically on http header information. They pull the port from the host string and push this info into the urls of the capabilities :-( . If the resource is requested thru curl the adopted headers must have this information.
Modified: trunk/mapbender/http/classes/class_connector.php
--- trunk/mapbender/http/classes/class_connector.php 2012-02-15 09:38:37 UTC (rev 8252)
+++ trunk/mapbender/http/classes/class_connector.php 2012-02-15 09:41:43 UTC (rev 8253)
@@ -287,7 +287,7 @@
$headers = array(
"GET ".$path." HTTP/1.1",
"User-Agent: ".$_SERVER['HTTP_USER_AGENT'],
- "Host: ".$host,
+ "Host: ".$host.":".$port,
"Accept: */*",
"Proxy-Connection: Keep-Alive"
More information about the Mapbender_commits
