[Mapbender-commits] r8258 - trunk/mapbender/http/plugins
svn_mapbender at osgeo.org
Fri Feb 17 08:37:29 EST 2012
Author: armin11
Date: 2012-02-17 05:37:29 -0800 (Fri, 17 Feb 2012)
New Revision: 8258
Added:
trunk/mapbender/http/plugins/mb_geodata_edit.js
trunk/mapbender/http/plugins/mb_geodata_edit.php
trunk/mapbender/http/plugins/mb_geodata_import.js
trunk/mapbender/http/plugins/mb_geodata_select.js
trunk/mapbender/http/plugins/mb_geodata_server.php
First frame to allow uploading of geodata files (shapes) which are automatically served via wms and as download.
Added: trunk/mapbender/http/plugins/mb_geodata_edit.js
--- trunk/mapbender/http/plugins/mb_geodata_edit.js (rev 0)
+++ trunk/mapbender/http/plugins/mb_geodata_edit.js 2012-02-17 13:37:29 UTC (rev 8258)
@@ -0,0 +1,167 @@
+ * Package: mb_geodata_edit
+ * Description:
+ * Files:
+ * SQL:
+ * Help:
+ * Maintainer:
+ * http://www.mapbender.org/User:Armin_Retterath
+ * License:
+ * Copyright (c) 2009, Open Source Geospatial Foundation
+ * This program is dual licensed under the GNU General Public License
+ * and Simplified BSD license.
+ * http://svn.osgeo.org/mapbender/trunk/mapbender/license/license.txt
+var $geodataEdit = $(this);
+var $geodataForm = $("<form>No dataset selected.</form>").appendTo($geodataEdit);
+var GeodataEditApi = function (o) {
+ var that = this;
+ var validator;
+ var formReady = false;
+ var metadataId;
+ this.events = {
+ showOriginalGeodata : new Mapbender.Event(),
+ submit: new Mapbender.Event()
+ this.valid = function () {
+ if (validator && validator.numberOfInvalids() > 0) {
+ $geodataForm.valid();
+ return false;
+ return true;
+ this.serialize = function (callback) {
+ $geodataForm.submit();
+ var data = null;
+ if (this.valid()) {
+ data = {
+ metadata: $geodataForm.easyform("serialize")
+ if ($.isFunction(callback)) {
+ callback(data);
+ return data !== null ? data.metadata : data;
+ // second optional parameter formData
+ var fillForm = function (obj) {
+ if (arguments.length >= 2) {
+ $geodataForm.easyform("reset");
+ $geodataForm.easyform("fill", arguments[1]);
+ that.valid();
+ return;
+ // get geodata from server
+ var req = new Mapbender.Ajax.Request({
+ url: "../plugins/mb_geodata_server.php",
+ method: "getGeodata",
+ parameters: {
+ "id": obj
+ callback: function (obj, result, message) {
+ if (!result) {
+ return;
+ $geodataForm.easyform("fill", obj);
+ that.valid();
+ req.send();
+ this.fillMdContact = function(obj) {
+ // get mdContact from server per fkey_mb_group_id
+ method: "getContactGeodata",
+ parameters: {
+ "id": obj
+ if (!result) {
+ return;
+ //fill form on a not so easy way ;-)
+ for (var key in obj) {
+ if (key == 'mb_group_title' || key == 'mb_group_address' || key == 'mb_group_postcode' || key == 'mb_group_city' || key == 'mb_group_logo_path' || key == 'mb_group_email' || key == 'mb_group_voicetelephone'){
+ document.getElementById(key).value = obj[key];
+ req.send();
+ this.fill = function (obj) {
+ var showOriginalGeodata = function () {
+ that.events.showOriginalGeodata.trigger({
+ data : {
+ metadataId : metadataId,
+ metadataData : $geodataForm.easyform("serialize")
+ this.init = function (obj) {
+ metadataId = obj;
+ if (!metadataId) {
+ return;
+ var formData = arguments.length >= 2 ? arguments[1] : undefined;
+ if (!formReady) {
+ $geodataForm.load("../plugins/mb_geodata_edit.php", function () {
+ $geodataForm.find(".help-dialog").helpDialog();
+ $geodataForm.find(".original-geodata-metadata").bind("click", function() {
+ showOriginalGeodata();
+ validator = $geodataForm.validate({
+ submitHandler: function () {
+ return false;
+ if (formData !== undefined) {
+ fillForm(obj, formData);
+ else {
+ fillForm(obj);
+ formReady = true;
+ return;
+ fillForm(obj);
+ Mapbender.events.localize.register(function () {
+ that.valid();
+ var formData = $geodataForm.easyform("serialize");
+ formReady = false;
+ that.init(metadataId, formData);
+ Mapbender.events.init.register(function () {
+ that.valid();
+$geodataEdit.mapbender(new GeodataEditApi(options));
Added: trunk/mapbender/http/plugins/mb_geodata_edit.php
--- trunk/mapbender/http/plugins/mb_geodata_edit.php (rev 0)
+++ trunk/mapbender/http/plugins/mb_geodata_edit.php 2012-02-17 13:37:29 UTC (rev 8258)
@@ -0,0 +1,186 @@
+<?php
+ require_once dirname(__FILE__) . "/../../core/globalSettings.php";
+ require_once dirname(__FILE__) . "/../classes/class_user.php";
+<fieldset>
+ <input name="geodata_id" id="geodata_id" type="hidden"/>
+ <legend><?php echo _mb("Service Level Metadata");?>: <img class="help-dialog" title="<?php echo _mb("Help");?>" help="{text:'<?php echo _mb("Possibility to adapt and add informations in the separate WMS-Layer Metadata. The modified Metadata is stored in the database of the GeoPortal.rlp, outwardly these metadata overwrite the original Service-Metadata.");?>'}" src="../img/questionmark.png" alt="" /></legend>
+ <!--<p>
+ <label for="geodata_title"><?php echo _mb("Show original Service Metadata from last update");?></label>
+ <img class="original-metadata-wms" src="../img/book.png" alt="" />
+ <img class="help-dialog" title="<?php echo _mb("Help");?>" help="{text:'<?php echo _mb("The original WMS-Metadata from the last update could be recovered or updated, so that the original Service-Metadata will be shown outward again.");?>'}" src="../img/questionmark.png" alt="" />
+ </p>-->
+ <p>
+ <label for="geodata_title"><?php echo _mb("Title of dataset");?>:</label>
+ <input name="geodata_title" id="geodata_title" class="required"/>
+ <img class="metadata_img" title="<?php echo _mb("INSPIRE 1.1: resource title");?>" src="../img/misc/inspire_eu_klein.png" alt="" />
+ </p>
+ <p>
+ <label for="geodata_abstract"><?php echo _mb("Abstract of dataset");?>:</label>
+ <input name="geodata_abstract" id="geodata_abstract"/>
+ <img class="metadata_img" title="<?php echo _mb("INSPIRE 1.2: resource abstract");?>" src="../img/misc/inspire_eu_klein.png" alt="" />
+ <img class="help-dialog" title="<?php echo _mb("Help for INSPIRE Abstract");?>" help="{text:'<?php echo _mb("INSPIRE demands some information about the spatial resolution in the abstract tag of the capabilities document. Please insert some words about it.");?>'}" src="../img/questionmark.png" alt="" />
+ </p>
+<!-- <p>
+ <label for="wms_keywords"><?php echo _mb("WMS Keywords (OWS)");?>:</label>
+ <input readonly="readonly" name="wms_keywords" id="wms_keywords"/>
+ <img class="metadata_img" title="<?php echo _mb("INSPIRE 3: keyword");?>" src="../img/misc/inspire_eu_klein.png" alt="" />
+ </p>
+ <p>
+ <label for="fees"><?php echo _mb("WMS Fees (OWS)");?>:</label>
+ <input name="fees" id="fees"/>
+ <img class="metadata_img" title="<?php echo _mb("INSPIRE 8.1: conditions applying to access and use");?>" src="../img/misc/inspire_eu_klein.png" alt="" />
+ </p>
+ <p>
+ <label for="accessconstraints"><?php echo _mb("WMS AccessConstraints (OWS)");?>:</label>
+ <input name="accessconstraints" id="accessconstraints"/>
+ <img class="metadata_img" title="<?php echo _mb("INSPIRE 8.2: limitations on public access");?>" src="../img/misc/inspire_eu_klein.png" alt="" />
+ </p>
+<?php
+ $sql = "SELECT termsofuse_id, name FROM termsofuse";
+ $res = db_query($sql);
+ $termsofuse = array();
+ while ($row = db_fetch_assoc($res)) {
+ $termsofuse[$row["termsofuse_id"]] = $row["name"];
+ <p>
+ <label for="wms_termsofuse"><?php echo _mb("WMS Predefined Licence (Registry)");?>:</label>
+ <select name="wms_termsofuse" id="wms_termsofuse">
+ <option>...</option>
+<?php
+ foreach ($termsofuse as $key => $value) {
+ echo "<option value='" . $key . "'>" . htmlentities($value, ENT_QUOTES, CHARSET) . "</option>";
+ </select>
+ <img class="help-dialog" title="<?php echo _mb("Help");?>" help="{text:'<?php echo _mb("Auswahl von vordefinierten Lizenzen hinsichtlich Gebühren und Zugriffsbeschränkungen.");?>'}" src="../img/questionmark.png" alt="" />
+ </p>
+ <p>
+ <label for="wms_network_access"><?php echo _mb("Restricted Network Access (Registry)");?>:</label>
+ <input name="wms_network_access" id="wms_network_access" type="checkbox"/>
+ </p>
+</fieldset>
+<fieldset>
+ <legend><?php echo _mb("WMS Provider Section (OWS)");?></legend>
+ <p>
+ <label for="contactperson"><?php echo _mb("Contact Individual Name (OWS)");?>:</label>
+ <input name="contactperson" id="contactperson"/>
+ </p>
+ <p>
+ <label for="contactposition"><?php echo _mb("Contact Position Name (OWS)");?>:</label>
+ <input name="contactposition" id="contactposition"/>
+ </p>
+ <p>
+ <label for="contactvoicetelephone"><?php echo _mb("Contact Phone Voice (OWS)");?>:</label>
+ <input name="contactvoicetelephone" id="contactvoicetelephone"/>
+ </p>
+ <p>
+ <label for="contactfacsimiletelephone"><?php echo _mb("Contact Phone Fax (OWS)");?>:</label>
+ <input name="contactfacsimiletelephone" id="contactfacsimiletelephone"/>
+ </p>
+ <p>
+ <label for="contactorganization"><?php echo _mb("Contact Organisation (WMS)");?>:</label>
+ <input name="contactorganization" id="contactorganization"/>
+ <img class="metadata_img" title="<?php echo _mb("INSPIRE 9.1: responsible party name");?>" src="../img/misc/inspire_eu_klein.png" alt="" />
+ </p>
+ <p>
+ <label for="address"><?php echo _mb("Contact Address (WMS)");?>:</label>
+ <input name="address" id="address"/>
+ </p>
+ <p>
+ <label for="city"><?php echo _mb("Contact City (WMS)");?>:</label>
+ <input name="city" id="city"/>
+ </p>
+ <p>
+ <label for="stateorprovince"><?php echo _mb("Contact State or Province (WMS) - ISO 3166-II");?>:</label>
+ <input name="stateorprovince" id="stateorprovince"/>
+ </p>
+ <p>
+ <label for="postcode"><?php echo _mb("Contact Post Code (WMS)");?>:</label>
+ <input name="postcode" id="postcode"/>
+ </p>
+ <p>
+ <label for="country"><?php echo _mb("Contact Post Country (WMS) - ISO 3166");?>:</label>
+ <input name="country" id="country"/>
+ </p>
+ <p>
+ <label for="contactelectronicmailaddress"><?php echo _mb("Contact Electronic Mail Address (WMS)");?>:</label>
+ <input name="contactelectronicmailaddress" id="contactelectronicmailaddress" class="required email"/>
+ <img class="metadata_img" title="<?php echo _mb("INSPIRE 9.1: responsible party email");?>" src="../img/misc/inspire_eu_klein.png" alt="" />
+ </p>
+ <p>
+ <label for="wms_timestamp_create"><?php echo _mb("Date of first registration (Registry)");?>:</label>
+ <input readonly="readonly" name="wms_timestamp_create" id="wms_timestamp_create"/>
+ <img class="metadata_img" title="<?php echo _mb("INSPIRE 5.2: date of publication");?>" src="../img/misc/inspire_eu_klein.png" alt="" />
+ </p>
+ <p>
+ <label for="wms_timestamp"><?php echo _mb("Date of last revision (Registry)");?>:</label>
+ <td><input readonly="readonly" name="wms_timestamp" id="wms_timestamp"/>
+ <img class="metadata_img" title="<?php echo _mb("INSPIRE 10.2: metadata date");?>" src="../img/misc/inspire_eu_klein.png" alt="" />
+ </p>
+</fieldset>
+<fieldset>
+ <legend><?php echo _mb("Metadata Point of contact (registry)");?>: <img class="help-dialog" title="<?php echo _mb("Help");?>" help="{text:'<?php echo _mb("Information about the organization which is responsible for contributing the metadata. The information will be automaticcaly generated from the mapbender database mb_group object. The information came from the primary group of the service owner or from a group which has authorized the owner to publish metadata in their name.");?>'}" src="../img/questionmark.png" alt="" /></legend>
+<?php
+//selectbox for organizationswhich allows the publishing of metadatasets for the specific user
+ $sql = "SELECT fkey_mb_group_id, mb_group_name FROM (SELECT fkey_mb_group_id FROM mb_user_mb_group WHERE fkey_mb_user_id = $1 AND (mb_user_mb_group_type = 3 OR mb_user_mb_group_type = 2)) AS a LEFT JOIN mb_group ON a.fkey_mb_group_id = mb_group.mb_group_id";
+ $user = new User();
+ $userId = $user->id;
+ $v = array($userId);
+ $t = array('i');
+ $res = db_prep_query($sql,$v,$t);
+ $metadataGroup = array();
+ $metadataGroup[$row["fkey_mb_group_id"]] = $row["mb_group_name"];
+ <p>
+ <label for="mb_group_name"><?php echo _mb("Organization responsible for metadata");?>:</label>
+ <select name="fkey_mb_group_id" id="fkey_mb_group_id" onChange="var chosenoption=this.options[this.selectedIndex];$('#mb_md_edit').mapbender().fillMdContact(chosenoption.value);">
+ <option value="0">...</option>
+<?php
+ foreach ($metadataGroup as $key => $value) {
+ </select>
+ <img class="help-dialog" title="<?php echo _mb("Help");?>" help="{text:'<?php echo _mb("Selection of different organizations which authorized you to publish metadata in their name.");?>'}" src="../img/questionmark.png" alt="" />
+ </p> -->
+ <p>
+ <label for="mb_group_title"><?php echo _mb("Title");?>:</label>
+ <input readonly="readonly" name="mb_group_title" id="mb_group_title"/>
+ <img class="metadata_img" title="<?php echo _mb("INSPIRE 10.1: metadata point of contact name");?>" src="../img/misc/inspire_eu_klein.png" alt="" />
+ </p>
+ <p>
+ <label for="mb_group_address"><?php echo _mb("Address");?>:</label>
+ <input readonly="readonly" name="mb_group_address" id="mb_group_address"/>
+ </p>
+ <p>
+ <label for="mb_group_postcode"><?php echo _mb("Postcode");?>:</label>
+ <input readonly="readonly" name="mb_group_postcode" id="mb_group_postcode"/>
+ </p>
+ <p>
+ <label for="mb_group_city"><?php echo _mb("City");?>:</label>
+ <input readonly="readonly" name="mb_group_city" id="mb_group_city"/>
+ </p>
+ <p>
+ <label for="mb_group_voicetelephone"><?php echo _mb("Telephone");?>:</label>
+ <input readonly="readonly" name="mb_group_voicetelephone" id="mb_group_voicetelephone"/>
+ </p>
+ <p>
+ <label for="mb_group_email"><?php echo _mb("Email");?>:</label>
+ <input readonly="readonly" name="mb_group_email" id="mb_group_email"/>
+ <img class="metadata_img" title="<?php echo _mb("INSPIRE 10.1: metadata point of contact email");?>" src="../img/misc/inspire_eu_klein.png" alt="" />
+ </p>
+ <p>
+ <label for="mb_group_logo_path"><?php echo _mb("Logo url");?>:</label>
+ <input readonly="readonly" name="mb_group_logo_path" id="mb_group_logo_path"/>
+ </p>
+</fieldset>
Added: trunk/mapbender/http/plugins/mb_geodata_import.js
--- trunk/mapbender/http/plugins/mb_geodata_import.js (rev 0)
+++ trunk/mapbender/http/plugins/mb_geodata_import.js 2012-02-17 13:37:29 UTC (rev 8258)
@@ -0,0 +1,84 @@
+var $geodataImport = $(this);
+var importGeodataId;
+var GeodataImportApi = function () {
+ var that = this;
+ var type;
+ this.events = {
+ "uploadComplete" : new Mapbender.Event()
+ this.events.uploadComplete.register(function () {
+ $geodataImport.dialog("close");
+ var importUploadedFile = function(filename, Id, callback){
+ method: "store",
+ parameters: {
+ filename: filename,
+ layerId: Id
+ callback: function (obj, result, message, errorCode) {
+ if (!result) {
+ switch (errorCode) {
+ case -1002:
+ alert("file: "+filename+"has problems: "+message);
+ break;
+ default:
+ alert(message);
+ return;
+ alert(message);
+ callback(obj.id);
+ req.send();
+ $geodataImport.upload({
+ size: 10,
+ timeout: 20000,
+ url: "../plugins/jq_upload.php",
+ callback: function(result,stat,msg){
+ if(!result){
+ alert(msg);
+ return;
+ var uploadResultName = result.filename;
+ var uploadResultOrigName = result.origFilename;
+ importUploadedFile(result.filename, that.importGeodataId, function (id) {
+ that.events.uploadComplete.trigger({
+ "type": type,
+ "id": id
+ }).dialog({
+ title: 'Geodata Import',
+ autoOpen: false,
+ modal: true,
+ width: 580
+ type = obj.type;
+ $geodataImport.dialog("open");
+ alert('test');
+ initGeodataImport = function (Id) {
+ that.importGeodataId = Id;
+ return true;
+$geodataImport.mapbender(new GeodataImportApi());
Added: trunk/mapbender/http/plugins/mb_geodata_select.js
--- trunk/mapbender/http/plugins/mb_geodata_select.js (rev 0)
+++ trunk/mapbender/http/plugins/mb_geodata_select.js 2012-02-17 13:37:29 UTC (rev 8258)
@@ -0,0 +1,103 @@
+ * Package: mb_geodata_select
+ * Description:
+ * Files:
+ * SQL:
+ * Help:
+ * Maintainer:
+ * License:
+var $geodataSelect = $(this);
+$geodataSelect.prepend("<img src='../img/indicator_wheel.gif'>");
+var GeodataSelectApi = function (o) {
+ var table = null;
+ var that = this;
+ var fnGetSelected = function (oTableLocal){
+ var aReturn = [];
+ var aTrs = oTableLocal.fnGetNodes();
+ for ( var i=0 ; i<aTrs.length ; i++ ){
+ if ( $(aTrs[i]).hasClass('row_selected') ){
+ aReturn.push( aTrs[i] );
+ return aReturn;
+ this.getData = function () {
+ parameters: {
+ if (!result) {
+ return;
+ $geodataSelect.find("img").remove();
+ var aoColumns = [];
+ for (var i in obj.header) {
+ if (obj.header[i] === "Geodata ID") {
+ continue;
+ aoColumns.push({"sTitle": obj.header[i]});
+ // initialize datatables
+ table = $geodataSelect.find("table").dataTable({
+ "aoColumns": aoColumns,
+ "bJQueryUI": true
+ // add rows
+ for (var j in obj.data) {
+ var data = obj.data[j];
+ var wmsId = data[0];
+ data.shift();
+ var index = table.fnAddData(data);
+ var rowNode = table.fnGetNodes(index[0]);
+ $(rowNode).data("wmsId", wmsId);
+ // make rows selectable
+ $geodataSelect.find("tbody").click(function (e) {
+ $(table.fnSettings().aoData).each(function (){
+ $(this.nTr).removeClass('row_selected');
+ $(e.target.parentNode).addClass('row_selected');
+ var selectedRow = fnGetSelected(table);
+ $geodataSelect.fadeOut(function () {
+ that.events.selected.trigger({
+ wmsId: $(selectedRow).data("wmsId")
+ $geodataSelect.show();
+ req.send();
+ this.events = {
+ selected: new Mapbender.Event()
+$geodataSelect.mapbender(new GeodataSelectApi(options));
+$geodataSelect.mapbender("getData");
Added: trunk/mapbender/http/plugins/mb_geodata_server.php
--- trunk/mapbender/http/plugins/mb_geodata_server.php (rev 0)
+++ trunk/mapbender/http/plugins/mb_geodata_server.php 2012-02-17 13:37:29 UTC (rev 8258)
@@ -0,0 +1,1172 @@
+<?php
+require_once dirname(__FILE__) . "/../../core/globalSettings.php";
+require_once dirname(__FILE__) . "/../classes/class_user.php";
+require_once dirname(__FILE__) . "/../classes/class_wms.php";
+require_once dirname(__FILE__) . "/../classes/class_Uuid.php";
+$ajaxResponse = new AjaxResponse($_POST);
+function abort ($message) {
+ global $ajaxResponse;
+ $ajaxResponse->setSuccess(false);
+ $ajaxResponse->setMessage($message);
+ $ajaxResponse->send();
+ die();
+function getGeodata ($geodataId = null) {
+ $user = new User(Mapbender::session()->get("mb_user_id"));
+ $e = new mb_exception("plugins/mb_geodata_server.php: mb_user_id: ".$user);
+ $geodataIdArray = $user->getOwnedGeodata();
+ if (!is_null($geodataId) && !in_array($geodataId, $geodataIdArray)) {
+ abort(_mb("You are not allowed to access this dataset."));
+ return $geodataIdArray;
+function getLayer ($layerId = null) {
+ $wmsIdArray = $user->getOwnedWms();
+ if (!is_array($wmsIdArray) || count($wmsIdArray) === 0) {
+ abort(_mb("No metadata sets available."));
+ $wmsId = wms::getWmsIdByLayerId($layerId);
+ if (is_null($wmsId) || !in_array($wmsId, $wmsIdArray)) {
+ abort(_mb("You are not allowed to access WMS " . $wmsId));
+ return;
+switch ($ajaxResponse->getMethod()) {
+ case "getGeodata" :
+ $geodataIdArray = getGeodata();
+ $geodataList = implode(",", $geodataIdArray);
+ $sql = <<<SQL
+SELECT metadata_id, title, lastchanged, changedate, origin, datasetid, uuid FROM
+mb_metadata WHERE metadata_id IN ($geodataList);
+SQL;
+ $resultObj = array(
+ "header" => array(
+ _mb("Geodata ID"),
+ _mb("title"),
+ _mb("last change"),
+ _mb("change"),
+ _mb("origin"),
+ _mb("datasetid"),
+ _mb("uuid")
+ "data" => array()
+ while ($row = db_fetch_row($res)) {
+ // convert NULL to '', NULL values cause datatables to crash
+ $walk = array_walk($row, create_function('&$s', '$s=strval($s);'));
+ $resultObj["data"][]= $row;
+ $ajaxResponse->setResult($resultObj);
+ $ajaxResponse->setSuccess(true);
+ break;
+ case "getWmsMetadata" :
+ $wmsId = $ajaxResponse->getParameter("id");
+ getWms($wmsId);
+ $wms = new wms();
+ $wms->createObjFromDBNoGui($wmsId);//here the owsproxyurls will be read out - to make previews with proxy urls
+ $fields = array(
+ "wms_id",
+ "wms_abstract",
+ "wms_title",
+ "fees",
+ "accessconstraints",
+ "contactperson",
+ "contactposition",
+ "contactvoicetelephone",
+ "contactfacsimiletelephone",
+ "contactorganization",
+ "address",
+ "city",
+ "stateorprovince",
+ "postcode",
+ "country",
+ "contactelectronicmailaddress",
+ "wms_timestamp",
+ "wms_timestamp_create",
+ "wms_network_access",
+ "fkey_mb_group_id"
+ $resultObj = array();
+ foreach ($fields as $field) {
+ if ($field == "wms_timestamp" || $field == "wms_timestamp_create") {
+ if ($wms->$field != "") {
+ $resultObj[$field] = date('d.m.Y', $wms->$field);
+ else {
+ $resultObj[$field] = $wms->$field;
+ //$e = new mb_exception("mb_metadata_server: resultObject[".$field."]=".$wms->$field);
+ // layer searchable
+ $resultObj["layer_searchable"] = array();
+ foreach ($wms->objLayer as $layer) {
+ if (intval($layer->layer_searchable) === 1) {
+ $resultObj["layer_searchable"][] = intval($layer->layer_uid);
+ $keywordSql = <<<SQL
+SELECT DISTINCT keyword FROM keyword, layer_keyword
+WHERE keyword_id = fkey_keyword_id AND fkey_layer_id IN (
+ SELECT layer_id from layer, wms
+ WHERE fkey_wms_id = wms_id AND wms_id = $wmsId
+) ORDER BY keyword
+SQL;
+ $keywordRes = db_query($keywordSql);
+ $keywords = array();
+ while ($keywordRow = db_fetch_assoc($keywordRes)) {
+ $keywords[]= $keywordRow["keyword"];
+ $resultObj["wms_keywords"] = implode(", ", $keywords);
+ $termsofuseSql = <<<SQL
+SELECT fkey_termsofuse_id FROM wms_termsofuse WHERE fkey_wms_id = $wmsId
+SQL;
+ $termsofuseRes = db_query($termsofuseSql);
+ if ($termsofuseRes) {
+ $termsofuseRow = db_fetch_assoc($termsofuseRes);
+ $resultObj["wms_termsofuse"] = $termsofuseRow["fkey_termsofuse_id"];
+ else {
+ $resultObj["wms_termsofuse"] = null;
+ $resultObj['wms_network_access'] = $resultObj['wms_network_access'] == 1 ? true : false;
+ //get contact information from group relation
+ //check if fkey_mb_group_id has been defined before - in service table
+ if ($resultObj["fkey_mb_group_id"] == "" || !isset($resultObj["fkey_mb_group_id"])){
+ $e = new mb_notice("fkey_mb_group_id is null or empty");
+ //check if primary group is set
+ $user = new User;
+ //$e = new mb_exception("user id:".$userId);
+ $sql = <<<SQL
+SELECT fkey_mb_group_id, mb_group_name, mb_group_title, mb_group_address, mb_group_email, mb_group_postcode, mb_group_city, mb_group_logo_path, mb_group_voicetelephone FROM (SELECT fkey_mb_group_id FROM mb_user_mb_group WHERE fkey_mb_user_id = $1 AND mb_user_mb_group_type = 2) AS a LEFT JOIN mb_group ON a.fkey_mb_group_id = mb_group.mb_group_id
+SQL;
+ $t = array('i');
+ $row = array();
+ if ($res) {
+ $row = db_fetch_assoc($res);
+ $resultObj["fkey_mb_group_id"] = $row["fkey_mb_group_id"];
+ $resultObj["mb_group_title"] = $row["mb_group_title"];
+ $resultObj["mb_group_address"] = $row["mb_group_address"];
+ $resultObj["mb_group_email"] = $row["mb_group_email"];
+ $resultObj["mb_group_postcode"] = $row["mb_group_postcode"];
+ $resultObj["mb_group_city"] = $row["mb_group_city"];
+ $resultObj["mb_group_logo_path"] = $row["mb_group_logo_path"];
+ $resultObj["mb_group_voicetelephone"] = $row["mb_group_voicetelephone"];
+ } else {
+ //get current fkey_mb_group_id and the corresponding data
+ $sql = <<<SQL
+SELECT mb_group_name, mb_group_title, mb_group_address, mb_group_email, mb_group_postcode, mb_group_city, mb_group_logo_path, mb_group_voicetelephone FROM mb_group WHERE mb_group_id = $1
+SQL;
+ $v = array($resultObj["fkey_mb_group_id"]);
+ $t = array('i');
+ $row = array();
+ if ($res) {
+ else {
+ $resultObj["fkey_mb_group_id"] = null;
+ break;
+ case "getLayerMetadata" :
+ $layerId = $ajaxResponse->getParameter("id");
+ getLayer($layerId);
+ $sql = <<<SQL
+SELECT layer_id, layer_name, layer_title, layer_abstract, layer_searchable, fkey_wms_id as wms_id
+FROM layer WHERE layer_id = $layerId;
+SQL;
+ foreach ($row as $key => $value) {
+ $resultObj[$key] = $value;
+ $e = new mb_notice("plugins/mb_metadata_server.php: get ".$value." for ".$key);
+ $sql = <<<SQL
+SELECT fkey_md_topic_category_id
+FROM layer_md_topic_category
+WHERE fkey_layer_id = $layerId
+SQL;
+ $resultObj["layer_md_topic_category_id"][]= $row["fkey_md_topic_category_id"];
+ $sql = <<<SQL
+SELECT fkey_inspire_category_id
+FROM layer_inspire_category
+SQL;
+ $resultObj["layer_inspire_category_id"][]= $row["fkey_inspire_category_id"];
+ $sql = <<<SQL
+SELECT fkey_custom_category_id
+FROM layer_custom_category
+SQL;
+ $resultObj["layer_custom_category_id"][]= $row["fkey_custom_category_id"];
+ $sql = <<<SQL
+SELECT keyword FROM keyword, layer_keyword
+WHERE keyword_id = fkey_keyword_id AND fkey_layer_id = $layerId
+SQL;
+ $resultObj["layer_keyword"] = array();
+ $resultObj["layer_keyword"][]= $row["keyword"];
+ //get MetadataURLs from md_metadata table
+ $sql = <<<SQL
+SELECT metadata_id, uuid, link, linktype, md_format, origin FROM mb_metadata
+INNER JOIN (SELECT * from ows_relation_metadata
+WHERE fkey_layer_id = $layerId ) as relation ON
+mb_metadata.metadata_id = relation.fkey_metadata_id WHERE mb_metadata.origin IN ('capabilities','external','metador','upload')
+SQL;
+ $resultObj["md_metadata"]->metadata_id = array();
+ $resultObj["md_metadata"]->uuid = array();
+ $resultObj["md_metadata"]->origin = array();
+ $resultObj["md_metadata"]->linktype = array();
+ $resultObj["md_metadata"]->link = array();
+ $i = 0;
+ $resultObj["md_metadata"]->metadata_id[$i]= $row["metadata_id"];
+ $resultObj["md_metadata"]->link[$i]= $row["link"];
+ $resultObj["md_metadata"]->uuid[$i]= $row["uuid"];
+ $resultObj["md_metadata"]->origin[$i]= $row["origin"];
+ $resultObj["md_metadata"]->linktype[$i]= $row["linktype"];
+ $i++;
+ break;
+ case "getLayerByWms" :
+// getWms($wmsId);
+ $sql = <<<SQL
+SELECT layer_id, f_count_layer_couplings(layer_id) as count_coupling, f_collect_inspire_cat_layer(layer_id) AS inspire_cats, layer_pos, layer_parent, layer_name, layer_title, layer_abstract, layer_searchable
+FROM layer WHERE fkey_wms_id = $wmsId ORDER BY layer_pos;
+SQL;
+ $rows = array();
+ $rows[] = $row;
+ $left = 1;
+ function createNode ($left, $right, $row) {
+ $inspireCatsArray = explode(",",str_replace("}","",str_replace("{","",$row["inspire_cats"])));
+ if (count($inspireCatsArray) >= 0) {
+ $inspireCats = 1;
+ } else {
+ $inspireCats = 0;
+ return array(
+ "left" => $left,
+ "right" => $right,
+ "parent" => $row["layer_parent"] !== "" ? intval($row["layer_parent"]) : null,
+ "pos" => intval($row["layer_pos"]),
+ "attr" => array (
+ "layer_id" => intval($row["layer_id"]),
+ "layer_name" => $row["layer_name"],
+ "layer_title" => $row["layer_title"],
+ "layer_abstract" => $row["layer_abstract"],
+ "layer_searchable" => intval($row["layer_searchable"]),
+ "layer_coupling" => intval($row["count_coupling"]),
+ "inspire_cats" => intval($inspireCats)
+ function addSubTree ($rows, $i, $left) {
+ $nodeArray = array();
+ $addNewNode = true;
+ for ($j = $i; $j < count($rows); $j++) {
+ $row = $rows[$j];
+ $pos = intval($row["layer_pos"]);
+ $parent = $row["layer_parent"] !== "" ? intval($row["layer_parent"]) : null;
+ // first node of subtree
+ if ($addNewNode) {
+ $nodeArray[]= createNode($left, null, $row);
+ $addNewNode = false;
+ else {
+ // new sub tree
+ if ($parent === $nodeArray[count($nodeArray)-1]["pos"]) {
+ $addedNodeArray = addSubTree($rows, $j, ++$left);
+ $nodeArray[count($nodeArray)-1]["right"] =
+ $nodeArray[count($nodeArray)-1]["left"] +
+ 2 * count($addedNodeArray) + 1;
+ $left = $nodeArray[count($nodeArray)-1]["right"] + 1;
+ $nodeArray = array_merge($nodeArray, $addedNodeArray);
+ $j += count($addedNodeArray) - 1;
+ // siblings
+ elseif ($parent === $nodeArray[count($nodeArray)-1]["parent"]) {
+ $nodeArray[count($nodeArray)-1]["right"] = ++$left;
+ $nodeArray[]= createNode(++$left, null, $row);
+ if (is_null($nodeArray[count($nodeArray)-1]["right"])) {
+ return $nodeArray;
+ $nodeArray = addSubTree($rows, 0, 1);
+ "nestedSets" => $nodeArray
+ break;
+ case "save":
+ $data = $ajaxResponse->getParameter("data");
+ try {
+ $wmsId = intval($data->wms->wms_id);
+ catch (Exception $e) {
+ $ajaxResponse->setMessage(_mb("Invalid WMS ID."));
+ getWms($wmsId);
+ $wms = new wms();
+ $wms->createObjFromDBNoGui($wmsId,false);//here the original urls will be used - cause the object will used to update the wms table
+ $columns = array(
+ "wms_abstract",
+ "wms_title",
+ "fees",
+ "contactperson",
+ "address",
+ "city",
+ "postcode",
+ "country",
+ "wms_termsofuse",
+ foreach ($columns as $c) {
+ $value = $data->wms->$c;
+ if (!is_null($value)) {
+ $wms->$c = $value;
+ if (is_array($data->wms->layer_searchable)) {
+ foreach ($wms->objLayer as &$layer) {
+ $layer->layer_searchable = 0;//why
+ $e = new mb_notice("mb_metadata_server.php: Check layer with id ".$layer->layer_uid." to be searchable");
+ for ($i = 0; $i < count($data->wms->layer_searchable); $i++) {
+ //$e = new mb_exception("mb_metadata_server.php: Layer with id ".$id." found to be searchable");
+ $id = $data->wms->layer_searchable[$i];
+ $e = new mb_notice("mb_metadata_server.php: Layer with id ".$id." found to be searchable");
+ if ($id == intval($layer->layer_uid)) {
+ $e = new mb_notice("mb_metadata_server.php: Layer identical - update it in wms object");
+ $layer->layer_searchable = 1;
+ } else {
+ continue; //with next
+ unset($id);
+ //$layer->layer_searchable = 1;
+ //break;
+ try {
+ $layerId = intval($data->layer->layer_id);
+ $ajaxResponse->setMessage(_mb("Could not read layer ID ".$data->layer->layer_id));
+ if ($layerId) {
+ $e = new mb_notice("Got following layer id from wms metadata editor client: ".$layerId);
+ try {
+ $layer = &$wms->getLayerReferenceById($layerId);
+ $ajaxResponse->setMessage(_mb("Could not get layer with ID ".$layerId));
+ $columns = array(
+ "layer_abstract",
+ "layer_title",
+ "layer_keyword",
+ "layer_md_topic_category_id",
+ "layer_inspire_category_id",
+ "layer_custom_category_id"
+ $value = $data->layer->$c;
+ $e = new mb_notice("plugins/mb_metadata_server.php: layer entry for ".$c.": ".$data->layer->$c);
+ if ($c === "layer_keyword") {
+ $layer->$c = explode(",", $value);
+ foreach ($layer->$c as &$val) {
+ $val = trim($val);
+ elseif ($c === "layer_md_topic_category_id"
+ || $c === "layer_inspire_category_id"
+ || $c === "layer_custom_category_id"
+ if (!is_array($value)) {
+ $layer->$c = array($value);
+ else {
+ $layer->$c = $value;
+ else {
+ if ($wms->wms_network_access == "on") {
+ $wms->wms_network_access = intval('1');
+ } else {
+ $wms->wms_network_access = intval('0');
+ //try {
+ $wms->updateObjInDB($wmsId);
+ //catch (Exception $e) {
+ // $ajaxResponse->setSuccess(false);
+ // $ajaxResponse->setMessage(_mb("Could not update wms object in database!"));
+ // $ajaxResponse->send();
+ $ajaxResponse->setMessage("Updated WMS metadata for ID " . $wmsId);
+ break;
+ case "getContactMetadata" :
+ $mbGroupId = $ajaxResponse->getParameter("id");
+ $sql = <<<SQL
+SQL;
+ $v = array($mbGroupId);
+ $t = array('i');
+ $row = array();
+ if ($res) {
+ $resultObj["fkey_mb_group_id"] = $mbGroupId;
+ $resultObj["mb_group_name"] = $row["mb_group_name"];
+ break;
+ case "getWmsIdByLayerId" :
+ $layerId = $ajaxResponse->getParameter("layerId");
+ $sql = <<<SQL
+SELECT fkey_wms_id from layer where layer_id = $1
+SQL;
+ $v = array($layerId);
+ $t = array('i');
+ $row = array();
+ if ($res) {
+ $resultObj["wms_id"]= $row['fkey_wms_id'];
+ break;
+ case "getLayerMetadataAddon" :
+ $metadataId = $ajaxResponse->getParameter("metadataId");
+ $sql = <<<SQL
+SELECT * from mb_metadata where metadata_id = $1
+SQL;
+ $v = array($metadataId);
+ $t = array('i');
+ $row = array();
+ if ($res) {
+ $resultObj["metadata_id"]= $row['metadata_id']; //serial
+ $resultObj["uuid"] = $row["uuid"]; //char
+ $resultObj["origin"] = $row["origin"]; //char
+ $resultObj["link"] = $row["link"]; //char
+ $resultObj["linktype"] = $row["linktype"]; //char
+ $resultObj["title"] = $row["title"]; //char -- prefill from layer
+ $resultObj["abstract"] = $row["abstract"]; //char - prefill from layer
+ $resultObj["format"] = $row["format"]; //char
+ $resultObj["ref_system"] = $row["ref_system"]; //char
+ $resultObj["spatial_res_type"] = $row["spatial_res_type"]; //integer
+ $resultObj["spatial_res_value"] = $row["spatial_res_value"]; //char
+ $resultObj["inspire_charset"] = $row["inspire_charset"]; //char
+ $resultObj["lineage"] = $row["lineage"]; //text
+ $resultObj["tmp_reference_1"] = $row["tmp_reference_1"]; //text
+ $resultObj["tmp_reference_2"] = $row["tmp_reference_2"]; //text
+ $export2csw = $row["export2csw"]; //boolean
+ $resultObj["update_frequency"] = $row["update_frequency"]; //text
+ switch ($export2csw) {
+ case "t" :
+ $resultObj["export2csw"] = true;
+ break;
+ case "f" :
+ $resultObj["export2csw"] = false;
+ break;
+ default:
+ break;
+ $inspire_top_consistence = $row["inspire_top_consistence"]; //boolean
+ switch ($inspire_top_consistence) {
+ case "t" :
+ $resultObj["inspire_top_consistence"] = true;
+ break;
+ case "f" :
+ $resultObj["inspire_top_consistence"] = false;
+ break;
+ default:
+ break;
+ break;
+case "getInitialLayerMetadata" :
+ $sql = <<<SQL
+SELECT layer_title, layer_abstract from layer where layer_id = $1
+SQL;
+ $t = array('i');
+ $row = array();
+ if ($res) {
+ $resultObj["title"]= $row['layer_title']; //serial
+ $resultObj["abstract"] = $row["layer_abstract"]; //char
+ break;
+ case "updateLayerMetadataAddon" :
+ if ($data->export2csw) {
+ $data->export2csw = 't';
+ } else {
+ $data->export2csw = 'f';
+ if ($data->inspire_top_consistence) {
+ $data->inspire_top_consistence = 't';
+ } else {
+ $data->inspire_top_consistence = 'f';
+ $sql = <<<SQL
+UPDATE mb_metadata SET link = $2, title = $3, abstract = $4, format = $5, ref_system = $6, export2csw = $7, inspire_top_consistence = $8, tmp_reference_1 = $9, tmp_reference_2 = $10, lineage = $11, spatial_res_type = $12, spatial_res_value = $13, inspire_charset = $14, changedate = now(), update_frequency = $15 WHERE metadata_id = $1
+SQL;
+ $v = array($metadataId, $data->link, $data->title, $data->abstract, $data->format, $data->ref_system, $data->export2csw, $data->inspire_top_consistence, $data->tmp_reference_1, $data->tmp_reference_2, $data->lineage, $data->spatial_res_type, $data->spatial_res_value, $data->inspire_charset, $data->update_frequency);
+ $t = array('i','s','s','s','s','s','b','b','s','s','s','s','s','s','s');
+ try {
+ catch (Exception $e){
+ $ajaxResponse->setMessage(_mb("Could not update metadata object in database!"));
+ die;
+ $ajaxResponse->setMessage("Metadata updated!");
+ break;
+ case "insertLayerMetadataAddon" :
+ //normaly the link is only set if a link has been created
+ //if a record has been created, the link element will be empty
+ //use this to distinguish between the to different inserts!
+ //this insert should also push one entry in the ows_relation_metadata table! - after the insert into md_metadata
+ //origin
+ if ($data->kindOfMetadataAddOn == 'link') {
+ //generate metador entry
+ $origin = 'external';
+ } else {
+ $origin = 'metador';
+ //export
+ if ($data->export2csw == "on") {
+ } else {
+ //consistance
+ if ($data->inspire_top_consistence == "on") {
+ } else {
+ //generate a uuid for the record:
+ $uuid = new Uuid();
+ //initialize database objects
+ $link = '';
+ $title = '';
+ $abstract = '';
+ $format = '';
+ $ref_system = '';
+ $export2csw = 'f';
+ $inspire_top_consistence = 'f';
+ $tmp_reference_1 = '';
+ $tmp_reference_2 = '';
+ $lineage = '';
+ $spatial_res_type = '';
+ $spatial_res_value = '';
+ $inspire_charset = '';
+ $update_frequency = '';
+ //read out json objects
+ if (isset($data->link)) {
+ $link = $data->link;
+ if (isset($data->export2csw)) {
+ $export2csw = $data->export2csw;
+ } else {
+ if (isset($data->title)) {
+ $title = $data->title;
+ if (isset($data->abstract)) {
+ $abstract = $data->abstract;
+ if (isset($data->format)) {
+ $format = $data->format;
+ if (isset($data->ref_system)) {
+ $ref_system = $data->ref_system;
+ if (isset($data->inspire_top_consistence)) {
+ $inspire_top_consistence = $data->inspire_top_consistence;
+ if (isset($data->tmp_reference_1)) {
+ $tmp_reference_1 = $data->tmp_reference_1;
+ if ($tmp_reference_1 == "") {
+ $tmp_reference_1 = "2000-01-01";
+ if (isset($data->tmp_reference_2)) {
+ $tmp_reference_2 = $data->tmp_reference_2;
+ if ($tmp_reference_2 == "") {
+ $tmp_reference_2 = "2000-01-01";
+ if (isset($data->lineage)) {
+ $lineage = $data->lineage;
+ if (isset($data->spatial_res_type)) {
+ $spatial_res_type = $data->spatial_res_type;
+ if (isset($data->spatial_res_value)) {
+ $spatial_res_value = $data->spatial_res_value;
+ if (isset($data->inspire_charset)) {
+ $inspire_charset = $data->inspire_charset;
+ if (isset($data->update_frequency)) {
+ $update_frequency = $data->update_frequency;
+ $randomid = new Uuid();
+ //Check if origin is external and export2csw is activated!
+ if ($origin == 'external' ) {
+ //harvest link from location, parse the content for datasetid and push xml into data column
+ //load metadata from link TODO: function from class_wms - generate a class for metadata management and include it here and in class_wms
+ $metadataConnector = new connector();
+ $metadataConnector->set("timeOut", "5");
+ $metaData = $metadataConnector->load($link);
+ //$e = new mb_exception($metaData);
+ if (!$metaData) {
+ abort(_mb("Could not load metadata from source url!"));
+ //delete getRecordByIdResponse from xml if there
+ $regex = "#<csw:GetRecordByIdResponse .*?>#";
+ $output = preg_replace($regex,"",$metaData);
+ $regex = "#</csw:GetRecordByIdResponse>#";
+ $output = preg_replace($regex,"",$output);
+ //$e = new mb_exception($output);
+ $metaData = $output;
+ //write metadata to temporary file:
+ $randomFileId = new Uuid();
+ $tmpMetadataFile = fopen(TMPDIR.'/link_metadata_file_'.$randomFileId.'.xml', 'w');
+ fwrite($tmpMetadataFile, $metaData);
+ fclose($tmpMetadataFile);
+ $e = new mb_exception("File which has been written: link_metadata_file_".$randomFileId.".xml");
+ //read out objects from xml structure
+ if (file_exists(TMPDIR.'/link_metadata_file_'.$randomFileId.'.xml')) {
+ $iso19139Xml=simplexml_load_file(TMPDIR.'/link_metadata_file_'.$randomFileId.'.xml');
+ //$metaData = file_get_contents(TMPDIR.'/link_metadata_file_'.$randomFileId.'.xml');
+ } else {
+ abort(_mb("Temporary file could not be parsed!"));
+ //$metaData = $metadataConnector->file;
+ //parse metadata
+ /*try {
+ $iso19139Xml = new SimpleXMLElement($metaData);
+ abort(_mb("Parsing ISO19139 XML failed!"));
+ if ($iso19139Xml != false) {
+ //get elements for database from xml by using xpath
+ //uuid
+ $uuid = $iso19139Xml->xpath('/gmd:MD_Metadata/gmd:fileIdentifier/gco:CharacterString');
+ $e = new mb_exception("plugins/mb_metadata_server.php: File Identifier found: ".$uuid);
+ //createdate
+ $createdate = $iso19139Xml->xpath('/gmd:MD_Metadata/gmd:dateStamp/gco:Date');
+ //changedate
+ $changedate = $iso19139Xml->xpath('/gmd:MD_Metadata/gmd:dateStamp/gco:Date');
+ //TODO: check if this is set, maybe DateTime must be searched instead?
+ //title
+ $title = $iso19139Xml->xpath('/gmd:MD_Metadata/gmd:identificationInfo/gmd:MD_DataIdentification/gmd:citation/gmd:CI_Citation/gmd:title/gco:CharacterString');
+ //datasetid
+ //next came from class_wms - TODO maybe put it into a special function
+ //dataset identifier - howto model into md_metadata?
+ //check where datasetid is defined - maybe as RS_Identifier or as MD_Identifier see http://inspire.jrc.ec.europa.eu/documents/Metadata/INSPIRE_MD_IR_and_ISO_v1_2_20100616.pdf page 18
+ //First check if MD_Identifier is set, then check if RS_Identifier is used!
+ //Initialize datasetid
+ $datasetid = 'undefined';
+ $code = $iso19139Xml->xpath('/gmd:MD_Metadata/gmd:identificationInfo/gmd:MD_DataIdentification/gmd:citation/gmd:CI_Citation/gmd:identifier/gmd:MD_Identifier/gmd:code/gco:CharacterString');
+ if (isset($code[0]) && $code[0] != '') {
+ $e = new mb_exception("plugins/mb_metadata_server.php: code given thru MD_Identifier: ".$code[0]);
+ //check if code is defined by codespace and code
+ $codeSplit = explode("#",$code);
+ if (isset($codeSplit[0]) && $codeSplit[0] != '' && isset($codeSplit[1]) && $codeSplit[1] != '') {
+ $e = new mb_exception("plugins/mb_metadata_server.php: code was constructed via codespace#code !");
+ $datasetid = $codeSplit[0]."#".$codeSplit[1];
+ } else {
+ $e = new mb_exception("plugins/mb_metadata_server.php: code was not constructed via codespace#code !");
+ $datasetid = $code[0];
+ } else { //try to read code from RS_Identifier
+ $code = $iso19139Xml->xpath('/gmd:MD_Metadata/gmd:identificationInfo/gmd:MD_DataIdentification/gmd:citation/gmd:CI_Citation/gmd:identifier/gmd:RS_Identifier/gmd:code/gco:CharacterString');
+ $codeSpace = $iso19139Xml->xpath('/gmd:MD_Metadata/gmd:identificationInfo/gmd:MD_DataIdentification/gmd:citation/gmd:CI_Citation/gmd:identifier/gmd:RS_Identifier/gmd:codeSpace/gco:CharacterString');
+ #$e = new mb_exception("plugins/mb_metadata_server.php: code: ".$code[0]);
+ #$e = new mb_exception("plugins/mb_metadata_server.php: codeSpace: ".$codeSpace[0]);
+ if (isset($codeSpace[0]) && isset($code[0]) && $codeSpace[0] != '' && $code[0] != '') {
+ $datasetid = $codeSpace[0]."#".$code[0];
+ $e = new mb_exception("plugins/mb_metadata_server.php: datasetid: ".$datasetid);
+ } else {
+ //neither MD_Identifier nor RS_Identifier are defined in a right way
+ $e = new mb_exception("plugins/mb_metadata_server.php: the service data coupling has problems, cause the metadata doesnt have defined a datasetid");
+ //abstract
+ $abstract = $iso19139Xml->xpath('/gmd:MD_Metadata/gmd:identificationInfo/gmd:MD_DataIdentification/gmd:abstract/gco:CharacterString');
+ //searchtext -- use keywords!
+ $keywords = $iso19139Xml->xpath('/gmd:MD_Metadata/gmd:identificationInfo/gmd:MD_DataIdentification/gmd:descriptiveKeywords/gmd:MD_Keywords/gmd:keyword/gco:CharacterString');
+ //type
+ $type = $iso19139Xml->xpath('/gmd:MD_Metadata/gmd:hierarchyLevel/gmd:MD_ScopeCode');
+ //tmp_reference_1
+ $tmp_reference_1 = $iso19139Xml->xpath('/gmd:MD_Metadata/gmd:identificationInfo/gmd:MD_DataIdentification/gmd:extent/gmd:EX_Extent/gmd:temporalElement/gmd:EX_TemporalExtent/gmd:extent/gml:TimePeriod/gml:beginPosition');
+ //tmp_reference_2
+ $tmp_reference_2 = $iso19139Xml->xpath('/gmd:MD_Metadata/gmd:identificationInfo/gmd:MD_DataIdentification/gmd:extent/gmd:EX_Extent/gmd:temporalElement/gmd:EX_TemporalExtent/gmd:extent/gml:TimePeriod/gml:endPosition'); //spatial_res_type
+ //spatial_res_value
+ //ref_system
+ //format
+ //inspire_charset
+ //inspire_top_consistence
+ //responsible_party
+ //fees
+ //"constraints"
+ //fill database with elements:
+ $sql = <<<SQL
+INSERT INTO mb_metadata (link, uuid, origin, title, abstract, format, ref_system, export2csw, inspire_top_consistence, tmp_reference_1, tmp_reference_2, lineage, spatial_res_type, spatial_res_value, inspire_charset, createdate, datasetid, randomid, data, harvestresult) VALUES ($1, $2, $3, $4, $5, $6, $7, $8, $9, $10, $11, $12, $13, $14, $15, now(), $16, $17, $18, 1)
+SQL;
+ $v = array($link, $uuid[0], $origin, $title[0], $abstract[0], $format, $ref_system, $export2csw,$inspire_top_consistence,$tmp_reference_1[0],$tmp_reference_2[0],$lineage,$spatial_res_type,$spatial_res_value,$inspire_charset, $datasetid, $randomid, $metaData);
+ $t = array('s','s','s','s','s','s','s','b','b','s','s','s','s','s','s','s','s','s');
+ try {
+ abort(_mb("Insert of harvested metadata into database failed!"));
+ } else {
+ abort(_mb("Problem with parsing the XML structure with SimpleXML! Record was not inserted into database! Ask your administrator."));
+ //give back error message - cause parsing has problems
+ } else { //fill only links or the edited information into db
+ $sql = <<<SQL
+INSERT INTO mb_metadata (link, uuid, origin, title, abstract, format, ref_system, export2csw, inspire_top_consistence, tmp_reference_1, tmp_reference_2, lineage, spatial_res_type, spatial_res_value, inspire_charset, createdate, randomid, update_frequency) VALUES ($1, $2, $3, $4, $5, $6, $7, $8, $9, $10, $11, $12, $13, $14, $15, now(), $16, $17)
+SQL;
+ $v = array($link, $uuid, $origin, $title, $abstract, $format, $ref_system, $export2csw,$inspire_top_consistence,$tmp_reference_1,$tmp_reference_2,$lineage,$spatial_res_type,$spatial_res_value,$inspire_charset, $randomid, $update_frequency);
+ $t = array('s','s','s','s','s','s','s','b','b','s','s','s','s','s','s','s','s');
+ try {
+ abort(_mb("Insert of edited metadata into database failed!"));
+ //set relation into relation table
+ //get metadata_id of record which have been inserted before
+ $sql = <<<SQL
+SELECT metadata_id FROM mb_metadata WHERE randomid = $1
+SQL;
+ //maybe there are more than one results - which should be used??? case of creating new linkage with old metadata TODO TODO
+ $v = array($randomid);
+ $t = array('s');
+ try {
+ abort(_mb("Cannot get metadata record with following uuid from database: ".$uuid));
+ if ($res) {
+ $metadata_id = $row['metadata_id'];
+ $sql = <<<SQL
+ INSERT INTO ows_relation_metadata (fkey_metadata_id, fkey_layer_id) VALUES ($1, $2)
+SQL;
+ $v = array($metadata_id, $layerId);
+ $t = array('i','i');
+ try {
+ abort(_mb("Cannot write relation between ows and metadata to database!"));
+ if ($dbInsertFailed != true) {
+ $ajaxResponse->setMessage("Metadata object inserted into md_metadata!");
+ break;
+ case "deleteLayerMetadataAddon" :
+ $sql = <<<SQL
+DELETE FROM mb_metadata WHERE metadata_id = $1
+SQL;
+ $t = array('i');
+ try {
+ $ajaxResponse->setMessage(_mb("Could not delete metadata from database!"));
+ die;
+ $ajaxResponse->setMessage("Metadata deleted!");
+ break;
+ case "importLayerXmlAddon" :
+//this is similar to insert the metadata from external link, but came from internal file from tmp folder which has been updated before
+ $filename = $ajaxResponse->getParameter("filename");
+ //origin
+ $origin = 'upload';
+ $link = '';
+ $title = '';
+ $abstract = '';
+ $format = '';
+ $ref_system = '';
+ $export2csw = 't';
+ $lineage = '';
+ $e = new mb_exception("File to load: ".$filename);
+ /*if (file_exists($filename)) {
+ try {
+ $iso19139Xml = simplexml_load_file($filename);
+ abort(_mb("Loading ISO19139 XML failed!"));
+ else {
+ abort(_mb("File not found: ".$filename." !"));
+ $metaData = file_get_contents($filename);
+ if (!$metaData){
+ abort(_mb("Reading file ".$filename." failed!"));
+ $iso19139Xml = simplexml_load_string($output);
+ $e = new mb_exception('');
+ //uuid
+ if (!isset($uuid) || $uuid == "") {
+ abort(_mb(" No fileIdentifier found, parsing ISO19139 XML maybe failed. Check if element /gmd:MD_Metadata/gmd:fileIdentifier/gco:CharacterString is given and not empty!"));
+ //$e = new mb_exception("plugins/mb_metadata_server.php: File Identifier found: ".$uuid);
+ //createdate
+ //changedate
+ //title
+ } else {
+ $datasetid = $code;
+ } else {
+ //abstract
+ //type
+ //tmp_reference_1
+ //tmp_reference_2
+ //ref_system
+ //format
+ //inspire_charset
+ //fees
+ //"constraints"
+ $sql = <<<SQL
+SQL;
+ $xml = $iso19139Xml->asXML();
+ $v = array($link, $uuid[0], $origin, $title[0], $abstract[0], $format, $ref_system, $export2csw,$inspire_top_consistence,$tmp_reference_1[0],$tmp_reference_2[0],$lineage,$spatial_res_type,$spatial_res_value,$inspire_charset, $datasetid, $randomid, $xml);
+ try {
+ $sql = <<<SQL
+SQL;
+ $t = array('s');
+ try {
+ if ($res) {
+ $sql = <<<SQL
+SQL;
+ try {
+ break;
+ default:
+ $ajaxResponse->setMessage(_mb("An unknown error occured."));
+ break;
+$ajaxResponse->send();
More information about the Mapbender_commits
