[Mapbender-commits] r8266 - trunk/mapbender/http/javascripts
svn_mapbender at osgeo.org
Mon Feb 27 05:13:55 EST 2012
Author: armin11
Date: 2012-02-27 02:13:55 -0800 (Mon, 27 Feb 2012)
New Revision: 8266
Added:
trunk/mapbender/http/javascripts/mod_WMSpreferencesDiv.php
New module WMS_preferencesDiv which exchanges the old one with an iframe less version - new functions: jquery slider for transparency and automatical change of image format. Some little things todo: featureinfo and exception format is not shown! This is also not shown in the old module - broken ?
Added: trunk/mapbender/http/javascripts/mod_WMSpreferencesDiv.php
--- trunk/mapbender/http/javascripts/mod_WMSpreferencesDiv.php (rev 0)
+++ trunk/mapbender/http/javascripts/mod_WMSpreferencesDiv.php 2012-02-27 10:13:55 UTC (rev 8266)
@@ -0,0 +1,388 @@
+<?php
+ * Package: mod_WMSpreferencesDiv
+ * Description:
+ * This module generates a table with wms of the mapObject. The user
+ * can change the mapformat, featureinfoformat and the exceptionformat for each wms.
+ * Also the wms priority and the map transparency can be changed interactivly. The module
+ * should exchange the old mod_WMSpreferences module which was an iframe before.
+ * The module is invoked thru a button click. The button must be a mb_button.js module
+ * Files:
+ * - http/javascripts/mod_WMSpreferencesDiv.php
+ * SQL:
+ * > INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment,
+ * > e_title, e_element, e_src, e_attributes, e_left, e_top, e_width,
+ * > e_height, e_z_index, e_more_styles, e_content, e_closetag,
+ * > e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES(
+ * > '<app_id>','WMS_preferencesDiv',12,1,'Configure WMS preferences - div tag','WMS preferences',
+ * > 'div','','',870,60,400,500,NULL ,'z-index:9999;','','div','mod_WMSpreferencesDiv.php',
+ * > '','mapframe1','jq_ui_dialog','http://www.mapbender.org/index.php/mod_WMSpreferencesDiv.php');
+ * > e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height,
+ * > e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url)
+ * > VALUES('<app_id>','WMS_preferencesButton',2,1,'button for configure the preferences of each loaded wms',
+ * > 'Manage WMS preferences','img','../img/button_blink_red/preferences_off.png','',
+ * > 670,60,24,24,1,'','','','../plugins/mb_button.js','','WMS_preferencesDiv',
+ * > '','http://www.mapbender.org/index.php/mb_button');
+ * > INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value,
+ * > context, var_type) VALUES('gui1', 'WMS_preferencesButton', 'dialogWidth', '400', '' ,'var');
+ * Help:
+ * http://www.mapbender.org/mod_WMSpreferencesDiv
+ * Maintainer:
+ * http://www.mapbender.org/User:Armin_Retterath
+ * Parameters:
+ * none
+ * License:
+ * Copyright (c) 2009, Open Source Geospatial Foundation
+ * This program is dual licensed under the GNU General Public License
+ * and Simplified BSD license.
+ * http://svn.osgeo.org/mapbender/trunk/mapbender/license/license.txt
+require_once(dirname(__FILE__)."/../php/mb_validateSession.php");
+$e_id = 'WMS_preferencesDiv';
+$gui_id = array(Mapbender::session()->get("mb_user_gui"));
+//include all element vars from the given element
+include '../include/dyn_js.php';
+include '../include/dyn_php.php';
+$vis = "";
+$wmsid = "";
+$sql_visible = "SELECT * FROM gui_wms WHERE fkey_gui_id = $1";
+$v = array(Mapbender::session()->get("mb_user_gui"));
+$t = array("s");
+$res_visible = db_prep_query($sql_visible, $v, $t);
+$cnt_visible = 0;
+while($row = db_fetch_array($res_visible)){
+ $gui_wms_visible[$cnt_visible] = $row["gui_wms_visible"];
+ $fkey_wms_id_visible[$cnt_visible] = $row["fkey_wms_id"];
+ if($cnt_visible>0){
+ $vis .= ",";
+ $wmsid .= ",";
+ $vis .= $gui_wms_visible[$cnt_visible];
+ $wmsid .= $fkey_wms_id_visible[$cnt_visible];
+ $cnt_visible++;
+echo "var mod_gui_wms_visible = '".$vis."';";
+echo "var mod_fkey_wms_id_visible = '".$wmsid."';";
+//initialize module
+var WMS_preferencesDiv = function() {
+ var that = this;
+ var targetName = options.target;
+ var ind = getMapObjIndexByName(targetName);
+ var my = mb_mapObj[ind];
+ //functions
+ this.mb_swapWmsByIndex = function(mapObj_ind, indexA, indexB) {
+ var myMapObj = mb_mapObj[mapObj_ind];
+ if (indexA != indexB && indexA >= 0 && indexA < myMapObj.wms.length && indexB >= 0 && indexB < myMapObj.wms.length) {
+ upper = myMapObj.wms[indexA];
+ myMapObj.wms[indexA] = myMapObj.wms[indexB];
+ myMapObj.wms[indexB] = upper;
+ var upperLayers = myMapObj.layers[indexA];
+ var upperStyles = myMapObj.styles[indexA];
+ var upperQuerylayers = myMapObj.querylayers[indexA];
+ myMapObj.layers[indexA] = myMapObj.layers[indexB];
+ myMapObj.styles[indexA] = myMapObj.styles[indexB];
+ myMapObj.querylayers[indexA] = myMapObj.querylayers[indexB];
+ myMapObj.layers[indexB] = upperLayers;
+ myMapObj.styles[indexB] = upperStyles;
+ myMapObj.querylayers[indexB] = upperQuerylayers;
+ return true;
+ else {
+ return false;
+ this.setMapformat = function(val) {
+ var tmp = val.split(",");
+ my.wms[tmp[0]].gui_wms_mapformat = tmp[1];
+ Mapbender.modules[options.target].setMapRequest();
+ this.formContainer.remove();
+ this.initForm();
+ this.setFeatureformat = function(val) {
+ my.wms[tmp[0]].gui_wms_featureinfoformat = tmp[1];
+ this.initForm();
+ this.setExceptionformat = function(val) {
+ my.wms[tmp[0]].gui_wms_exceptionformat = tmp[1];
+ this.initForm();
+ this.swap = function(index1, index2) {
+ if (this.mb_swapWmsByIndex(ind, index1, index2) == true) {
+ this.initForm();
+ zoom(options.target, true, 1.0);
+ mb_execloadWmsSubFunctions();
+ this.remove_wms = function(num) {
+ var cnt_vis=0;
+ var wms_visible_down = mod_gui_wms_visible.split(",");
+ var wms_vis_down = wms_visible_down.length;
+ //check if there are more than two visible wms's
+ for(var i=0; i < wms_visible_down.length; i++){
+ var my_wms_visible = wms_visible_down[i];
+ if(my_wms_visible == 0){
+ var cnt_vis = cnt_vis+1;
+ if(my.wms.length - cnt_vis>1){
+ var ind = getMapObjIndexByName(options.target);
+ mb_mapObjremoveWMS(ind,num)
+ else{
+ alert ("Last WMS can't be removed.\n(Der letzte WMS kann nicht entfernt werden.)");
+ this.initForm();
+ this.deleteForm = function() {
+ this.refreshTransparency = function(visibleWmsIndexArray) {
+ for (var i = 0 ; i < visibleWmsIndexArray.length ; i++) {
+ wmsId = my.wms[visibleWmsIndexArray[i]].wms_id;
+ $( "#transparency_"+wmsId ).val( $( "#slider_" + wmsId ).slider( "value" ) );
+ my.wms[visibleWmsIndexArray[i]].setOpacity(100-($( "#slider_" + wmsId ).slider( "value" )));
+ this.initForm = function() {
+ var str = "";
+ var wms_visible = mod_gui_wms_visible.split(",");
+ var wms_id_visible = mod_fkey_wms_id_visible.split(",");
+ var visibleWmsIndexArray = new Array();
+ this.formContainer = $(document.createElement('form')).attr({'id':'wms-preferences-form'}).appendTo('#' + options.id);
+ for(var i=0; i < my.wms.length; i++){
+ var found = false;
+ for(var j=0; j < wms_id_visible.length; j++){
+ if (wms_visible[j] == 1 && wms_id_visible[j] == my.wms[i].wms_id){
+ visibleWmsIndexArray[visibleWmsIndexArray.length] = i;
+ found = true;
+ if (found == false && my.wms[i].gui_wms_visible == 1) {
+ //loop over all visible wms
+ z = visibleWmsIndexArray[i];
+ var mapString = "";
+ var featureinfoString = "";
+ var exceptionString = "";
+ for(var j=0; j<my.wms[z].data_type.length; j++){
+ if(my.wms[z].data_type[j] == 'map'){
+ mapString += "<option value='"+z+","+my.wms[z].data_format[j]+"'";
+ if(my.wms[z].data_format[j] == my.wms[z].gui_wms_mapformat){
+ mapString += "selected";
+ mapString += ">"+my.wms[z].data_format[j]+"</option>";
+ else if(my.wms[z].data_type[j] == 'featureinfo'){
+ featureinfoString += "<option value='"+z+","+my.wms[z].data_format[j]+"'";
+ if(my.wms[z].data_format[j] == my.wms[z].gui_wms_featureinfoformat){
+ featureinfoString += "selected";
+ featureinfoString += ">"+my.wms[z].data_format[j]+"</option>";
+ else if(my.wms[z].data_type[j] == 'exception'){
+ exceptionString += "<option value='"+z+","+my.wms[z].data_format[j]+"'";
+ if(my.wms[z].data_format[j] == my.wms[z].gui_wms_exceptionformat){
+ exceptionString += "selected";
+ exceptionString += ">"+my.wms[z].data_format[j]+"</option>";
+ //extract wms title, id and abstract
+ var wmsTitle = my.wms[z].wms_title;
+ var wmsAbstract = my.wms[z].wms_abstract;
+ var wmsId = my.wms[z].wms_id;
+ //generate Form
+ this.tableContainer = $(document.createElement('table')).appendTo(this.formContainer);
+ this.tableContainer.attr({'border':'1'});
+ this.tableContainer.attr({'rules':'rows'});
+ this.tableContainer.attr({'width':'300'});
+ this.rowContainer = $(document.createElement('tr')).appendTo(this.tableContainer);
+ this.columnContainer = $(document.createElement('th')).appendTo(this.rowContainer);
+ if (visibleWmsIndexArray.length > 1) {
+ if (i != 0) {
+ //show up arrow only if it is not the first entry and if the count of entries is greater than 1
+ this.wmsUp = $(document.createElement('img')).appendTo(this.columnContainer);
+ this.wmsUp.attr({'src':'../img/button_gray/up.png'});
+ this.wmsUp.attr({'id':'wmsUp_'+i});
+ //this.wmsUp.attr({'style':'filter:Chroma(color=#C2CBCF);'});
+ this.wmsUp.attr({'value':'up'});
+ this.wmsUp.attr({'title':'move WMS up'});
+ $("#" + "wmsUp" + "_" + i).click((function (i,z) {
+ return function(){
+ Mapbender.modules[options.id].swap(visibleWmsIndexArray[i-1],z);
+ //alert("move up");
+ })(i,z));
+ //show down arrow only if the entry is not the last one and if the count of entries is greater than 1
+ if (i != visibleWmsIndexArray.length-1) {
+ this.wmsDown = $(document.createElement('img')).appendTo(this.columnContainer);
+ this.wmsDown.attr({'src':'../img/button_gray/down.png'});
+ this.wmsDown.attr({'id':'wmsDown_'+i});
+ //this.wmsDown.attr({'style':'filter:Chroma(color=#C2CBCF);'});
+ this.wmsDown.attr({'onclick':'alert("move up");'});
+ this.wmsDown.attr({'value':'down'});
+ this.wmsDown.attr({'title':'move WMS down'});
+ $("#" + "wmsDown" + "_" + i).click((function (i,z) {
+ Mapbender.modules[options.id].swap(z,visibleWmsIndexArray[i+1]);
+ })(i,z));
+ this.wmsRemove = $(document.createElement('img')).appendTo(this.columnContainer);
+ this.wmsRemove.attr({'src':'../img/button_gray/del.png'});
+ this.wmsRemove.attr({'id':'wmsRemove_'+i});
+ this.wmsRemove.attr({'onclick':'alert("remove");'});
+ this.wmsRemove.attr({'value':'remove'});
+ this.wmsRemove.attr({'title':'remove WMS from GUI'});
+ $("#" + "wmsRemove" + "_" + i).click((function (z) {
+ Mapbender.modules[options.id].remove_wms(z);
+ })(z));
+ this.wmsTitleDiv = $(document.createElement('div')).appendTo(this.columnContainer);
+ this.wmsTitleDiv.attr({'id':'id_'+wmsId});
+ this.wmsTitleDiv.attr({'style':'cursor:pointer'});
+ this.wmsTitleDiv.attr({'onmouseover':'title=\"'+'id:'+wmsId+' '+my.wms[z].wms_abstract+'\"'});
+ //this.wmsTitleDiv.attr({'width':'300'});
+ this.wmsTitle = $(document.createElement('b')).appendTo(this.columnContainer);
+ this.wmsTitle.attr({'title':wmsId+':'+wmsAbstract});
+ this.wmsTitle.append(wmsTitle);
+ //new row mapImageFormat
+ this.columnContainer = $(document.createElement('td')).appendTo(this.rowContainer);
+ this.mapInfoTitle = this.columnContainer.append('<?php echo _mb('MapFormat'); ?>: ');
+ this.mapInfoSelect = $(document.createElement('select')).appendTo(this.columnContainer);
+ this.mapInfoSelect.change(function () {
+ Mapbender.modules[options.id].setMapformat(this.value);
+ this.mapInfoSelect.attr({'onchange':'Mapbender.modules[options.id].setMapformat(this.value);'});
+ this.mapInfoSelect.append(mapString);
+ //new row featureInfoFormat
+ this.featureInfoTitle = this.columnContainer.append('<?php echo _mb('FeatureInfoFormat'); ?>: ');
+ this.featureInfoSelect = $(document.createElement('select')).appendTo(this.columnContainer);
+ this.featureInfoSelect.attr({'onchange':'Mapbender.modules[options.id].setFeatureformat(this.value);'});
+ this.featureInfoSelect.append(featureinfoString);
+ //new row exceptionFormat
+ this.exceptionTitle = this.columnContainer.append('<?php echo _mb('ExceptionFormat'); ?>: ');
+ this.exceptionSelect = $(document.createElement('select')).appendTo(this.columnContainer);
+ this.exceptionSelect.attr({'onchange':'Mapbender.modules[options.id].setExceptionformat(this.value);'});
+ this.exceptionSelect.append(exceptionString);
+ this.transparencyTitle = this.columnContainer.append('<?php echo _mb('Transparency'); ?>: ');
+ this.transparencyValue = $(document.createElement('input')).appendTo(this.columnContainer);
+ this.transparencyValue.attr({'type':'text'});
+ this.transparencyValue.attr({'id':'transparency_'+wmsId});
+ this.transparencyValue.attr({'value':100-(my.wms[visibleWmsIndexArray[i]].gui_wms_mapopacity*100)});
+ this.transparencyValue.attr({'style':'border:0; color:#f6931f; font-weight:bold;'});
+ this.wmsTransparencySliderDiv = $(document.createElement('div')).appendTo(this.columnContainer)
+ this.wmsTransparencySliderDiv.attr({'id':'slider_'+wmsId});
+ $("#slider_" + wmsId).slider({
+ min: 0,
+ max: 100,
+ step: 10,
+ value: 100-(my.wms[visibleWmsIndexArray[i]].gui_wms_mapopacity*100),
+ change: function( event, ui) {
+ that.refreshTransparency(visibleWmsIndexArray);
+ /*$("#slider_" + wmsId).slider();
+ $("#slider_" + wmsId).slider( "option", "min", 100 );
+ $("#slider_" + wmsId).slider( "option", "max", 0 );
+ $("#slider_" + wmsId).slider( "option", "step", -10 );*/
+ this.formContainer.append('<br>');
+this.initForm();
+Mapbender.events.init.register(function() {
+ Mapbender.modules[options.id] = $.extend(new WMS_preferencesDiv(),Mapbender.modules[options.id]);
More information about the Mapbender_commits
