[Mapbender-commits] r8399 - branches/2.7/resources/db
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Mon Jul 2 06:06:44 PDT 2012
Author: tbaschetti
Date: 2012-07-02 06:06:44 -0700 (Mon, 02 Jul 2012)
New Revision: 8399
   branches/2.7/resources/db/install.bat
   branches/2.7/resources/db/install.sh
use template_postgis instead template0
http://trac.osgeo.org/mapbender/ticket/881
Modified: branches/2.7/resources/db/install.bat
--- branches/2.7/resources/db/install.bat	2012-07-02 12:46:19 UTC (rev 8398)
+++ branches/2.7/resources/db/install.bat	2012-07-02 13:06:44 UTC (rev 8399)
@@ -1,178 +1,179 @@
- at echo off
-REM Script to install Mapbender  database
-REM
-setlocal
-REM Delete old Logfiles
-del log_*.txt
-del err_*.txt
-:PREP
-echo.
-echo ==============================================================================
-REM Disclaimer
-echo.
-echo DISCLAIMER: Mapbender database setup script. USE AT YOUR OWN RISK!
-echo This script will create a database for you and will import the Mapbender data to the new database
-echo It will possibly also compile the Mapbender.mo files
-echo.
-echo You need:
-echo - a running postgresql 8.x database
-echo - database user with write access
-echo.
-echo If everything is prepared you can continue.
-echo You can give nearly all arguments on commandline:
-echo "%0 <HOST> <PORT> <DBNAME> <DBTEMPLATE> <DBUSER>"
-echo.
-echo e.g.
-echo %0 localhost 5432 mapbender template0 postgres
-echo.
-echo.
-REM 5 Params expected
-if not %5x==x goto ARGSSUPPLIED
-echo Continue?
-set /p PREPARED="(y)es or (n)o:"
-if %PREPARED%x==x goto :PREP
-if %PREPARED%==y goto :PREP_OK
-if %PREPARED%==n goto :End
-goto :PREP
-:PREP_OK
-rem Database
-:DB_TYPE
-echo.
-set /p DBHOST="Database host (just hit return for default 'localhost'):"
-echo.
-echo.
-set /p DBPORT="Database port (just hit return for default '5432'):"
-echo.
-echo.
-set /p DBNAME="Database name:"
-echo.
-echo.
-set /p DBTEMPLATE="database template to use (just hit return for default 'template0'):"
-echo.
-echo.
-set /p DBUSER="Database user:"
-echo.
-rem Password
-rem echo.
-echo Database Password will be asked many times during install, unless pgpass.conf is used...
-IF %DBTEMPLATE%x==x set DBTEMPLATE=template0
-IF %DBHOST%x==x set DBHOST=localhost
-IF %DBPORT%x==x set DBPORT=5432
-goto CHOICES
-:ARGSSUPPLIED
-set DBHOST=%1
-set DBPORT=%2
-set DBNAME=%3
-set DBTEMPLATE=%4
-set DBUSER=%5
-echo.
-:CHOICES
-REM dbtype and encoding are fixed
-set USEDBTYPE=PostgreSQL
-set USEDBENC=UTF-8
-echo.
-echo Your Choices:
-echo Databasetype: %USEDBTYPE%
-echo Encoding: %USEDBENC%
-echo Database Host: %DBHOST%
-echo Database Port: %DBPORT%
-echo Database Name: %DBNAME%
-echo Database Template: %DBTEMPLATE%
-echo Database User: %DBUSER%
-echo.
-echo Looks ok, start install?
-echo.
-rem delete ARG#5
-shift
-set /p START_INSTALL="(y)es or (n)o? "
-if %START_INSTALL%x==x goto CHOICES
-if %START_INSTALL%==y goto START_INSTALL
-goto PREP
-:START_INSTALL
-rem echo on
-:INSTPOSTGRESQL
-REM do these exist?
-psql --version 2> nul 1> nul
-if NOT %ERRORLEVEL% == 0 goto PGNOTFOUND
-echo creating db
-createdb -U %DBUSER% -E %USEDBENC% -h %DBHOST% -p %DBPORT% -T %DBTEMPLATE% %DBNAME% "Mapbender Database Version 2.6"
-echo creating schema
-psql -U %DBUSER% -h %DBHOST% -p %DBPORT% -f pgsql/pgsql_schema_2.5.sql %DBNAME% 1>log_schema.txt 2> err_schema.txt
-echo importing data
-psql -U %DBUSER% -h %DBHOST% -p %DBPORT% -f pgsql/%USEDBENC%/pgsql_data_2.5.sql %DBNAME% 1>log_data.txt 2> err_data.txt
-echo setting sequences
-psql -U %DBUSER% -h %DBHOST% -p %DBPORT% -f pgsql/pgsql_serial_set_sequences_2.5.sql %DBNAME% 1>log_sequences.txt 2> err_sequences.txt
-echo performing updates
-echo   update to 2.5.1rc1
-psql -U %DBUSER% -h %DBHOST% -p %DBPORT% -f pgsql/%USEDBENC%/update/update_2.5_to_2.5.1rc1_pgsql_%USEDBENC%.sql %DBNAME% 1>log_update.txt 2> err_update.txt
-psql -U %DBUSER% -h %DBHOST% -p %DBPORT% -f pgsql/%USEDBENC%/update/update_2.5.1rc1_to_2.5.1_pgsql_%USEDBENC%.sql %DBNAME% 1>>log_update.txt 2>> err_update.txt
-echo   update to 2.6rc1
-psql -U %DBUSER% -h %DBHOST% -p %DBPORT% -f pgsql/%USEDBENC%/update/update_2.5.1_to_2.6rc1_pgsql_%USEDBENC%.sql %DBNAME% 1>>log_update.txt 2>> err_update.txt
-echo   update to 2.6
-psql -U %DBUSER% -h %DBHOST% -p %DBPORT% -f pgsql/%USEDBENC%/update/update_2.6rc1_to_2.6_pgsql_%USEDBENC%.sql %DBNAME% 1>>log_update.txt 2>> err_update.txt
-echo   update to 2.6.1
-psql -U %DBUSER% -h %DBHOST% -p %DBPORT% -f pgsql/%USEDBENC%/update/update_2.6_to_2.6.1_pgsql_%USEDBENC%.sql %DBNAME% 1>> log_update.txt 2>> err_update.txt
-echo   update to 2.6.2
-psql -U %DBUSER% -h %DBHOST% -p %DBPORT% -f pgsql/%USEDBENC%/update/update_2.6.1_to_2.6.2_pgsql_%USEDBENC%.sql %DBNAME% 1>> log_update.txt 2>> err_update.txt
-echo   update to 2.7rc1
-psql -U %DBUSER% -h %DBHOST% -p %DBPORT% -f pgsql/%USEDBENC%/update/update_2.6.2_to_2.7rc1_pgsql_%USEDBENC%.sql %DBNAME% 1>> log_update.txt 2>> err_update.txt
-echo   update to 2.7rc2 to 2.7.1
-psql -U %DBUSER% -h %DBHOST% -p %DBPORT% -f pgsql/%USEDBENC%/update/update_2.7rc1_to_2.7rc2_pgsql_%USEDBENC%.sql %DBNAME% 1>> log_update.txt 2>> err_update.txt
-echo   update to 2.7.2
+ at echo off
+REM Script to install Mapbender  database
+REM
+setlocal
+REM Delete old Logfiles
+del log_*.txt
+del err_*.txt
+:PREP
+echo.
+echo ==============================================================================
+REM Disclaimer
+echo.
+echo DISCLAIMER: Mapbender database setup script. USE AT YOUR OWN RISK!
+echo This script will create a database for you and will import the Mapbender data to the new database
+echo It will possibly also compile the Mapbender.mo files
+echo.
+echo You need:
+echo - a running postgresql 8.x database
+echo - database user with write access
+echo.
+echo If everything is prepared you can continue.
+echo You can give nearly all arguments on commandline:
+echo "%0 <HOST> <PORT> <DBNAME> <DBTEMPLATE> <DBUSER>"
+echo.
+echo e.g.
+echo %0 localhost 5432 mapbender template_postgis postgres
+echo.
+echo.
+REM 5 Params expected
+if not %5x==x goto ARGSSUPPLIED
+echo Continue?
+set /p PREPARED="(y)es or (n)o:"
+if %PREPARED%x==x goto :PREP
+if %PREPARED%==y goto :PREP_OK
+if %PREPARED%==n goto :End
+goto :PREP
+:PREP_OK
+rem Database
+:DB_TYPE
+echo.
+set /p DBHOST="Database host (just hit return for default 'localhost'):"
+echo.
+echo.
+set /p DBPORT="Database port (just hit return for default '5432'):"
+echo.
+echo.
+set /p DBNAME="Database name:"
+echo.
+echo.
+echo "The following database template should be postgis-enabled!"
+set /p DBTEMPLATE="database template to use (just hit return for default 'template_postgis'):"
+echo.
+echo.
+set /p DBUSER="Database user:"
+echo.
+rem Password
+rem echo.
+echo Database Password will be asked many times during install, unless pgpass.conf is used...
+IF %DBTEMPLATE%x==x set DBTEMPLATE=template_postgis
+IF %DBHOST%x==x set DBHOST=localhost
+IF %DBPORT%x==x set DBPORT=5432
+goto CHOICES
+:ARGSSUPPLIED
+set DBHOST=%1
+set DBPORT=%2
+set DBNAME=%3
+set DBTEMPLATE=%4
+set DBUSER=%5
+echo.
+:CHOICES
+REM dbtype and encoding are fixed
+set USEDBTYPE=PostgreSQL
+set USEDBENC=UTF-8
+echo.
+echo Your Choices:
+echo Databasetype: %USEDBTYPE%
+echo Encoding: %USEDBENC%
+echo Database Host: %DBHOST%
+echo Database Port: %DBPORT%
+echo Database Name: %DBNAME%
+echo Database Template: %DBTEMPLATE%
+echo Database User: %DBUSER%
+echo.
+echo Looks ok, start install?
+echo.
+rem delete ARG#5
+shift
+set /p START_INSTALL="(y)es or (n)o? "
+if %START_INSTALL%x==x goto CHOICES
+if %START_INSTALL%==y goto START_INSTALL
+goto PREP
+:START_INSTALL
+rem echo on
+:INSTPOSTGRESQL
+REM do these exist?
+psql --version 2> nul 1> nul
+if NOT %ERRORLEVEL% == 0 goto PGNOTFOUND
+echo creating db
+createdb -U %DBUSER% -E %USEDBENC% -h %DBHOST% -p %DBPORT% -T %DBTEMPLATE% %DBNAME% "Mapbender Database Version 2.6"
+echo creating schema
+psql -U %DBUSER% -h %DBHOST% -p %DBPORT% -f pgsql/pgsql_schema_2.5.sql %DBNAME% 1>log_schema.txt 2> err_schema.txt
+echo importing data
+psql -U %DBUSER% -h %DBHOST% -p %DBPORT% -f pgsql/%USEDBENC%/pgsql_data_2.5.sql %DBNAME% 1>log_data.txt 2> err_data.txt
+echo setting sequences
+psql -U %DBUSER% -h %DBHOST% -p %DBPORT% -f pgsql/pgsql_serial_set_sequences_2.5.sql %DBNAME% 1>log_sequences.txt 2> err_sequences.txt
+echo performing updates
+echo   update to 2.5.1rc1
+psql -U %DBUSER% -h %DBHOST% -p %DBPORT% -f pgsql/%USEDBENC%/update/update_2.5_to_2.5.1rc1_pgsql_%USEDBENC%.sql %DBNAME% 1>log_update.txt 2> err_update.txt
+psql -U %DBUSER% -h %DBHOST% -p %DBPORT% -f pgsql/%USEDBENC%/update/update_2.5.1rc1_to_2.5.1_pgsql_%USEDBENC%.sql %DBNAME% 1>>log_update.txt 2>> err_update.txt
+echo   update to 2.6rc1
+psql -U %DBUSER% -h %DBHOST% -p %DBPORT% -f pgsql/%USEDBENC%/update/update_2.5.1_to_2.6rc1_pgsql_%USEDBENC%.sql %DBNAME% 1>>log_update.txt 2>> err_update.txt
+echo   update to 2.6
+psql -U %DBUSER% -h %DBHOST% -p %DBPORT% -f pgsql/%USEDBENC%/update/update_2.6rc1_to_2.6_pgsql_%USEDBENC%.sql %DBNAME% 1>>log_update.txt 2>> err_update.txt
+echo   update to 2.6.1
+psql -U %DBUSER% -h %DBHOST% -p %DBPORT% -f pgsql/%USEDBENC%/update/update_2.6_to_2.6.1_pgsql_%USEDBENC%.sql %DBNAME% 1>> log_update.txt 2>> err_update.txt
+echo   update to 2.6.2
+psql -U %DBUSER% -h %DBHOST% -p %DBPORT% -f pgsql/%USEDBENC%/update/update_2.6.1_to_2.6.2_pgsql_%USEDBENC%.sql %DBNAME% 1>> log_update.txt 2>> err_update.txt
+echo   update to 2.7rc1
+psql -U %DBUSER% -h %DBHOST% -p %DBPORT% -f pgsql/%USEDBENC%/update/update_2.6.2_to_2.7rc1_pgsql_%USEDBENC%.sql %DBNAME% 1>> log_update.txt 2>> err_update.txt
+echo   update to 2.7rc2 to 2.7.1
+psql -U %DBUSER% -h %DBHOST% -p %DBPORT% -f pgsql/%USEDBENC%/update/update_2.7rc1_to_2.7rc2_pgsql_%USEDBENC%.sql %DBNAME% 1>> log_update.txt 2>> err_update.txt
+echo   update to 2.7.2
 psql -U %DBUSER% -h %DBHOST% -p %DBPORT% -f pgsql/%USEDBENC%/update/update_2.7.1_to_2.7.2_pgsql_%USEDBENC%.sql %DBNAME% 1>> log_update.txt 2>> err_update.txt
-echo   update to 2.7.3
-psql -U %DBUSER% -h %DBHOST% -p %DBPORT% -f pgsql/%USEDBENC%/update/update_2.7.2_to_2.7.3_pgsql_%USEDBENC%.sql %DBNAME% 1>> log_update.txt 2>> err_update.txt
-echo   update sequences
-psql -U %DBUSER% -h %DBHOST% -p %DBPORT% -f pgsql/pgsql_serial_set_sequences_2.7.sql %DBNAME% 1>> log_sequences.txt 2>> err_sequences.txt
-:POFILES
-rem install mapbender.conf
-if not exist ..\..\conf\mapbender.conf copy ..\..\conf\mapbender.conf-dist ..\..\conf\mapbender.conf
-echo please check and edit your mapbender.conf.
-rem update .po files
-echo ""
-msgfmt --version 2> nul 1> nul
-if NOT %ERRORLEVEL% == 0 goto MSGFMTNOTFOUND
-echo "Compiling .po files..."
-pushd ..\..\tools\
-findstr /v "^# ^chmod" i18n_update_mo.sh > i18n_update_mo.bat
-call i18n_update_mo.bat
-del i18n_update_mo.bat
-popd
-goto END:
-:MSGFMTNOTFOUND
-echo Sorry, msgfmt not found, must be in PATH-Variable, won't compile translations...
-echo Have a look at http://www.mapbender.org/Gettext#Utility_programms for msgfmt.
-goto END:
-:PGNOTFOUND
-echo Sorry, psql not found, must be in PATH-Variable, exiting...
-goto END
-REM End, keep Terminal session open
-:END
-endlocal
-echo Finished...check the log files to see if an error occured.
-echo.
-pause
+echo   update to 2.7.3
+psql -U %DBUSER% -h %DBHOST% -p %DBPORT% -f pgsql/%USEDBENC%/update/update_2.7.2_to_2.7.3_pgsql_%USEDBENC%.sql %DBNAME% 1>> log_update.txt 2>> err_update.txt
+echo   update sequences
+psql -U %DBUSER% -h %DBHOST% -p %DBPORT% -f pgsql/pgsql_serial_set_sequences_2.7.sql %DBNAME% 1>> log_sequences.txt 2>> err_sequences.txt
+:POFILES
+rem install mapbender.conf
+if not exist ..\..\conf\mapbender.conf copy ..\..\conf\mapbender.conf-dist ..\..\conf\mapbender.conf
+echo please check and edit your mapbender.conf.
+rem update .po files
+echo ""
+msgfmt --version 2> nul 1> nul
+if NOT %ERRORLEVEL% == 0 goto MSGFMTNOTFOUND
+echo "Compiling .po files..."
+pushd ..\..\tools\
+findstr /v "^# ^chmod" i18n_update_mo.sh > i18n_update_mo.bat
+call i18n_update_mo.bat
+del i18n_update_mo.bat
+popd
+goto END:
+:MSGFMTNOTFOUND
+echo Sorry, msgfmt not found, must be in PATH-Variable, won't compile translations...
+echo Have a look at http://www.mapbender.org/Gettext#Utility_programms for msgfmt.
+goto END:
+:PGNOTFOUND
+echo Sorry, psql not found, must be in PATH-Variable, exiting...
+goto END
+REM End, keep Terminal session open
+:END
+endlocal
+echo Finished...check the log files to see if an error occured.
+echo.
+pause
Modified: branches/2.7/resources/db/install.sh
--- branches/2.7/resources/db/install.sh	2012-07-02 12:46:19 UTC (rev 8398)
+++ branches/2.7/resources/db/install.sh	2012-07-02 13:06:44 UTC (rev 8399)
@@ -63,10 +63,10 @@
 	#ask for database template
         echo ""
-        echo "database template to use (Default: template0)?"
+        echo "database template to use (Default: template_postgis)?"
         echo "the template should be postgis-enabled!"
         read DBTEMPLATE
-        : ${DBTEMPLATE:="template0"}
+        : ${DBTEMPLATE:="template_postgis"}
     echo ""
     echo "database user?"
More information about the Mapbender_commits mailing list
