[Mapbender-commits] r8418 - branches/2.7/http/plugins
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Thu Jul 5 07:23:22 PDT 2012
Author: astrid_emde
Date: 2012-07-05 07:23:21 -0700 (Thu, 05 Jul 2012)
New Revision: 8418
Added:
   branches/2.7/http/plugins/mod_WMSpreferencesDiv.php
   branches/2.7/http/plugins/mod_jsonAutocompleteGazetteer.php
merged from tunk
* div for WMS preferences
* srcipt for search
Added: branches/2.7/http/plugins/mod_WMSpreferencesDiv.php
--- branches/2.7/http/plugins/mod_WMSpreferencesDiv.php	                        (rev 0)
+++ branches/2.7/http/plugins/mod_WMSpreferencesDiv.php	2012-07-05 14:23:21 UTC (rev 8418)
@@ -0,0 +1,400 @@
+<?php
+ * Package: mod_WMSpreferencesDiv
+ * Description:
+ * This module generates a table with wms of the mapObject. The user
+ * can change the mapformat, featureinfoformat and the exceptionformat for each wms.
+ * Also the wms priority and the map transparency can be changed interactivly. The module
+ * should exchange the old mod_WMSpreferences module which was an iframe before.
+ * The module is invoked thru a button click. The button must be a mb_button.js module
+ * Files:
+ *  - http/javascripts/mod_WMSpreferencesDiv.php
+ * SQL:
+ * > INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment,
+ * >   e_title, e_element, e_src, e_attributes, e_left, e_top, e_width,
+ * >  e_height, e_z_index, e_more_styles, e_content, e_closetag,
+ * >  e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES(
+ * > '<app_id>','WMS_preferencesDiv',12,1,'Configure WMS preferences - div tag','WMS preferences',
+ * > 'div','','',870,60,400,500,NULL ,'z-index:9999;','','div','../plugins/mod_WMSpreferencesDiv.php',
+ * > '','mapframe1','jq_ui_dialog','http://www.mapbender.org/index.php/mod_WMSpreferencesDiv');
+ * > e_title, e_element, e_src, e_attributes, e_left, e_top, e_width, e_height,
+ * > e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url)
+ * > VALUES('<app_id>','WMS_preferencesButton',2,1,'button for configure the preferences of each loaded wms',
+ * > 'Manage WMS preferences','img','../img/button_blink_red/preferences_off.png','',
+ * > 670,60,24,24,1,'','','','../plugins/mb_button.js','','WMS_preferencesDiv',
+ * > '','http://www.mapbender.org/index.php/mb_button');
+ * > INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value,
+ * > context, var_type) VALUES('gui1', 'WMS_preferencesButton', 'dialogWidth', '400', '' ,'var');
+ * Help:
+ * http://www.mapbender.org/mod_WMSpreferencesDiv
+ * Maintainer:
+ * http://www.mapbender.org/User:Armin_Retterath
+ * Parameters:
+ * none
+ * License:
+ * Copyright (c) 2009, Open Source Geospatial Foundation
+ * This program is dual licensed under the GNU General Public License
+ * and Simplified BSD license.
+ * http://svn.osgeo.org/mapbender/trunk/mapbender/license/license.txt
+require_once(dirname(__FILE__)."/../php/mb_validateSession.php");
+$e_id = 'WMS_preferencesDiv';
+$gui_id = array(Mapbender::session()->get("mb_user_gui"));
+//include all element vars from the given element
+include '../include/dyn_js.php';
+include '../include/dyn_php.php';
+$vis = "";
+$wmsid = "";
+$sql_visible = "SELECT * FROM gui_wms WHERE fkey_gui_id = $1";
+$v = array(Mapbender::session()->get("mb_user_gui"));
+$t = array("s");
+$res_visible = db_prep_query($sql_visible, $v, $t);
+$cnt_visible = 0;
+while($row = db_fetch_array($res_visible)){
+	$gui_wms_visible[$cnt_visible] = $row["gui_wms_visible"];
+	$fkey_wms_id_visible[$cnt_visible] = $row["fkey_wms_id"];
+	if($cnt_visible>0){
+		$vis .= ",";
+		$wmsid .= ",";
+	$vis .= $gui_wms_visible[$cnt_visible];
+	$wmsid .= $fkey_wms_id_visible[$cnt_visible];
+	$cnt_visible++;
+echo "var mod_gui_wms_visible = '".$vis."';";
+echo "var mod_fkey_wms_id_visible = '".$wmsid."';";
+//initialize module
+var WMS_preferencesDiv = function() {
+	var that = this;
+	var targetName = options.target;
+	var ind = getMapObjIndexByName(targetName);
+	var my = mb_mapObj[ind];
+	//functions
+	this.mb_swapWmsByIndex = function(mapObj_ind, indexA, indexB) {
+ 		var myMapObj = mb_mapObj[mapObj_ind];
+		if (indexA != indexB && indexA >= 0 && indexA < myMapObj.wms.length && indexB >= 0 && indexB < myMapObj.wms.length) {
+			upper = myMapObj.wms[indexA];
+			myMapObj.wms[indexA] = myMapObj.wms[indexB];
+			myMapObj.wms[indexB] = upper;
+			var upperLayers = myMapObj.layers[indexA];
+			var upperStyles = myMapObj.styles[indexA];
+			var upperQuerylayers = myMapObj.querylayers[indexA];
+			myMapObj.layers[indexA] = myMapObj.layers[indexB];
+			myMapObj.styles[indexA] = myMapObj.styles[indexB];
+			myMapObj.querylayers[indexA] = myMapObj.querylayers[indexB];
+			myMapObj.layers[indexB] = upperLayers;
+			myMapObj.styles[indexB] = upperStyles;
+			myMapObj.querylayers[indexB] = upperQuerylayers;
+			return true;
+		else {
+			return false;
+	this.setMapformat = function(val) {
+		var tmp = val.split(",");
+		my.wms[tmp[0]].gui_wms_mapformat = tmp[1];
+		Mapbender.modules[options.target].setMapRequest();
+		this.formContainer.remove();
+		this.initForm();
+	this.setFeatureformat = function(val) {
+		my.wms[tmp[0]].gui_wms_featureinfoformat = tmp[1];
+		this.initForm();
+	this.setExceptionformat = function(val) {
+		my.wms[tmp[0]].gui_wms_exceptionformat = tmp[1];
+		this.initForm();
+	this.swap = function(index1, index2) {
+		if (this.mb_swapWmsByIndex(ind, index1, index2) == true) {
+			this.initForm();
+			zoom(options.target, true, 1.0);
+			mb_execloadWmsSubFunctions();
+	this.remove_wms = function(num) {
+		var cnt_vis=0;
+		var wms_visible_down = mod_gui_wms_visible.split(",");
+		var wms_vis_down = wms_visible_down.length;
+		//check if there are more than two visible wms's
+		for(var i=0; i < wms_visible_down.length; i++){
+			var my_wms_visible = wms_visible_down[i];
+			if(my_wms_visible == 0){
+  				var cnt_vis = cnt_vis+1;
+		if(my.wms.length - cnt_vis>1){
+	  		var ind = getMapObjIndexByName(options.target);
+  			mb_mapObjremoveWMS(ind,num)
+		else{
+			alert ("<?php echo _mb('Last WMS cannot be removed'); ?>");
+		this.initForm();
+	this.deleteForm = function() {
+	this.refreshTransparency = function(visibleWmsIndexArray) {
+		for (var i = 0 ; i < visibleWmsIndexArray.length ; i++) {
+			wmsId = my.wms[visibleWmsIndexArray[i]].wms_id;
+			$( "#transparency_"+wmsId ).val( $( "#slider_" + wmsId ).slider( "value" ) );
+			my.wms[visibleWmsIndexArray[i]].setOpacity(100-($( "#slider_" + wmsId ).slider( "value" )));
+	this.initForm = function() {
+		var str = "";
+		var wms_visible = mod_gui_wms_visible.split(",");
+		var wms_id_visible = mod_fkey_wms_id_visible.split(",");
+		var visibleWmsIndexArray = new Array();
+		this.formContainer = $(document.createElement('form')).attr({'id':'wms-preferences-form'}).appendTo('#' + options.id);
+		for(var i=0; i < my.wms.length; i++){
+			var found = false;
+			for(var j=0; j < wms_id_visible.length; j++){
+				if (wms_visible[j] == 1 && wms_id_visible[j] == my.wms[i].wms_id){
+					visibleWmsIndexArray[visibleWmsIndexArray.length] = i;
+					found = true;
+			if (found == false && my.wms[i].gui_wms_visible == 1) {
+		//loop over all visible wms if reversed layer order is wished, reverse visibleWmsIndexArray
+		options.reversePreferences = true;
+		if (options.reversePreferences) {
+			visibleWmsIndexArray.reverse();
+			z = visibleWmsIndexArray[i];
+			var mapString = "";
+			var featureinfoString = "";
+			var exceptionString = "";
+			for(var j=0; j<my.wms[z].data_type.length; j++){
+				if(my.wms[z].data_type[j] == 'map'){
+					mapString += "<option value='"+z+","+my.wms[z].data_format[j]+"'";
+					if(my.wms[z].data_format[j] == my.wms[z].gui_wms_mapformat){
+						mapString += "selected";
+					mapString += ">"+my.wms[z].data_format[j]+"</option>";
+				else if(my.wms[z].data_type[j] == 'featureinfo'){
+					featureinfoString += "<option value='"+z+","+my.wms[z].data_format[j]+"'";
+					if(my.wms[z].data_format[j] == my.wms[z].gui_wms_featureinfoformat){
+						featureinfoString += "selected";
+					featureinfoString += ">"+my.wms[z].data_format[j]+"</option>";
+				else if(my.wms[z].data_type[j] == 'exception'){
+					exceptionString += "<option value='"+z+","+my.wms[z].data_format[j]+"'";
+					if(my.wms[z].data_format[j] == my.wms[z].gui_wms_exceptionformat){
+						exceptionString += "selected";
+					exceptionString += ">"+my.wms[z].data_format[j]+"</option>";
+			//extract wms title, id and abstract
+			var wmsTitle = my.wms[z].wms_title;
+			var wmsAbstract = my.wms[z].wms_abstract;
+			var wmsId = my.wms[z].wms_id;
+			//generate Form
+			this.tableContainer = $(document.createElement('table')).appendTo(this.formContainer);
+			this.tableContainer.attr({'border':'1'});
+			this.tableContainer.attr({'rules':'rows'});
+			this.tableContainer.attr({'width':'300'});
+			this.rowContainer = $(document.createElement('tr')).appendTo(this.tableContainer);
+			this.columnContainer = $(document.createElement('th')).appendTo(this.rowContainer);
+			if (visibleWmsIndexArray.length > 1) {
+				if (i != 0) {
+					//show up arrow only if it is not the first entry and if the count of entries is greater than 1
+					this.wmsUp = $(document.createElement('img')).appendTo(this.columnContainer);
+					this.wmsUp.attr({'src':'../img/button_gray/up.png'});
+					this.wmsUp.attr({'id':'wmsUp_'+i});
+					//this.wmsUp.attr({'style':'filter:Chroma(color=#C2CBCF);'});
+					this.wmsUp.attr({'value':'up'});
+					this.wmsUp.attr({'title':'move WMS up'});
+					$("#" + "wmsUp" + "_" + i).click((function (i,z) {
+						return function(){
+							Mapbender.modules[options.id].swap(visibleWmsIndexArray[i-1],z);
+                        			//alert("move up");
+ 		        		})(i,z));
+				//show down arrow only if the entry is not the last one and if the count of entries is greater than 1
+				if (i != visibleWmsIndexArray.length-1) {
+					this.wmsDown = $(document.createElement('img')).appendTo(this.columnContainer);
+					this.wmsDown.attr({'src':'../img/button_gray/down.png'});
+					this.wmsDown.attr({'id':'wmsDown_'+i});
+					//this.wmsDown.attr({'style':'filter:Chroma(color=#C2CBCF);'});
+					//this.wmsDown.attr({'onclick':'alert("move up");'});
+					this.wmsDown.attr({'value':'down'});
+					this.wmsDown.attr({'title':'move WMS down'});
+					$("#" + "wmsDown" + "_" + i).click((function (i,z) {
+							Mapbender.modules[options.id].swap(z,visibleWmsIndexArray[i+1]);
+ 		        		})(i,z));
+				this.wmsRemove = $(document.createElement('img')).appendTo(this.columnContainer);
+				this.wmsRemove.attr({'src':'../img/button_gray/del.png'});
+				this.wmsRemove.attr({'id':'wmsRemove_'+i});
+				//this.wmsRemove.attr({'onclick':'alert("remove");'});
+				this.wmsRemove.attr({'value':'remove'});
+				this.wmsRemove.attr({'title':'remove WMS from GUI'});
+				$("#" + "wmsRemove" + "_" + i).click((function (z) {
+						Mapbender.modules[options.id].remove_wms(z);
+ 		       		})(z));
+			this.wmsTitleDiv = $(document.createElement('div')).appendTo(this.columnContainer);
+			this.wmsTitleDiv.attr({'id':'id_'+wmsId});
+			this.wmsTitleDiv.attr({'style':'cursor:pointer'});
+			this.wmsTitleDiv.attr({'onmouseover':'title=\"'+'id:'+wmsId+' '+my.wms[z].wms_abstract+'\"'});
+			//this.wmsTitleDiv.attr({'width':'300'});
+			this.wmsTitle = $(document.createElement('b')).appendTo(this.columnContainer);
+			this.wmsTitle.attr({'title':wmsId+':'+wmsAbstract});
+			this.wmsTitle.append(wmsTitle);
+			//new row mapImageFormat
+			this.columnContainer = $(document.createElement('td')).appendTo(this.rowContainer);
+			this.mapInfoTitle = this.columnContainer.append('<?php echo _mb('MapFormat'); ?>: ');
+			this.mapInfoSelect = $(document.createElement('select')).appendTo(this.columnContainer);
+			this.mapInfoSelect.change(function () {
+					Mapbender.modules[options.id].setMapformat(this.value);
+			this.mapInfoSelect.attr({'onchange':'Mapbender.modules[options.id].setMapformat(this.value);'});
+			this.mapInfoSelect.append(mapString);
+			//new row featureInfoFormat
+			this.featureInfoTitle = this.columnContainer.append('<?php echo _mb('FeatureInfoFormat'); ?>: ');
+			this.featureInfoSelect = $(document.createElement('select')).appendTo(this.columnContainer);
+			this.featureInfoSelect.attr({'onchange':'Mapbender.modules[options.id].setFeatureformat(this.value);'});
+			this.featureInfoSelect.append(featureinfoString);
+			//new row exceptionFormat
+			this.exceptionTitle = this.columnContainer.append('<?php echo _mb('ExceptionFormat'); ?>: ');
+			this.exceptionSelect = $(document.createElement('select')).appendTo(this.columnContainer);
+			this.exceptionSelect.attr({'onchange':'Mapbender.modules[options.id].setExceptionformat(this.value);'});
+			this.exceptionSelect.append(exceptionString);
+			this.transparencyTitle = this.columnContainer.append('<?php echo _mb('Transparency'); ?>: ');
+			this.transparencyValue = $(document.createElement('input')).appendTo(this.columnContainer);
+			this.transparencyValue.attr({'type':'text'});
+			this.transparencyValue.attr({'id':'transparency_'+wmsId});
+			if (isNaN(my.wms[visibleWmsIndexArray[i]].gui_wms_mapopacity)) {
+				thisWmsOpacity = 0;
+			} else {
+				thisWmsOpacity =  100-(my.wms[visibleWmsIndexArray[i]].gui_wms_mapopacity*100);
+			this.transparencyValue.attr({'value':thisWmsOpacity});
+			this.transparencyValue.attr({'style':'border:0; color:#f6931f; font-weight:bold;'});
+			this.wmsTransparencySliderDiv = $(document.createElement('div')).appendTo(this.columnContainer)
+			this.wmsTransparencySliderDiv.attr({'id':'slider_'+wmsId});
+			$("#slider_" + wmsId).slider({
+				min: 0,
+				max: 100,
+				step: 10,
+				value: thisWmsOpacity,
+				change: function( event, ui) {
+						that.refreshTransparency(visibleWmsIndexArray);
+			/*$("#slider_" + wmsId).slider();
+			$("#slider_" + wmsId).slider( "option", "min", 100 );
+			$("#slider_" + wmsId).slider( "option", "max", 0 );
+			$("#slider_" + wmsId).slider( "option", "step", -10 );*/
+			this.formContainer.append('<br>');
+this.initForm();
+Mapbender.events.init.register(function() {
+	Mapbender.modules[options.id] = $.extend(new WMS_preferencesDiv(),Mapbender.modules[options.id]);
Added: branches/2.7/http/plugins/mod_jsonAutocompleteGazetteer.php
--- branches/2.7/http/plugins/mod_jsonAutocompleteGazetteer.php	                        (rev 0)
+++ branches/2.7/http/plugins/mod_jsonAutocompleteGazetteer.php	2012-07-05 14:23:21 UTC (rev 8418)
@@ -0,0 +1,269 @@
+<?php
+ * Package: mod_jsonAutocompleteGazetteer
+ * Description:
+ * This module is a client for a json gazetteer webservice as used by http://www.geonames.org. The default
+ * service is the service from geonames.org which allows searching for
+ * Files:
+ *  - http/plugins/mod_jsonAutocompleteGazetteer.php
+ * SQL:
+ * > INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element, e_src,
+ * > e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag,
+ * > e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('<app_id>','jq_ui_autocomplete',5,1,
+ * > 'Module to manage jQuery UI autocomplete module','','div','','',-1,-1,15,15,NULL ,'','','div',
+ * > '','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/jquery.ui.autocomplete.js',
+ * > '','jq_ui,jq_ui_widget,jq_ui_position','');
+ * > e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content,
+ * > e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('<app_id>',
+ * > 'jsonAutocompleteGazetteer',12,1,'Client for json webservices like geonames.org','Gazetteer',
+ * > 'div','','',230,30,NULL ,NULL ,999,'','','div','../plugins/mod_jsonAutocompleteGazetteer.php',
+ * > '','mapframe1','','http://www.mapbender.org/index.php/mod_jsonAutocompleteGazetteer');
+ * > INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type)
+ * > VALUES('<app_id>', 'jsonAutocompleteGazetteer', 'gazetteerUrl', 'http://ws.geonames.org/searchJSON?lang=de&',
+ * >  '' ,'var');
+ * >  VALUES('<app_id>', 'jsonAutocompleteGazetteer', 'isGeonames', 'true', '' ,'var');
+ * Help:
+ * http://www.mapbender.org/mod_jsonAutocompleteGazetteer
+ * Maintainer:
+ * Parameters:
+ * none
+ * License:
+var standingHighlight = null;
+Mapbender.events.afterMapRequest.register( function(){
+	if(standingHighlight){
+		standingHighlight.paint();
+//initialize modul
+if (options.gazetteerUrl === undefined) {
+	options.gazetteerUrl = 'http://ws.geonames.org/searchJSON?lang=de&';
+if (options.isGeonames === undefined) {
+	options.isGeonames = true;
+if (options.latLonZoomExtension === undefined) {
+	options.latLonZoomExtension = 0.1;
+if (options.minLength === undefined) {
+	options.minLength = 3;
+if (options.delay === undefined) {
+	options.delay = 400;
+if (options.isDraggable === undefined) {
+	options.isDraggable = true;
+if (options.maxResults === undefined) {
+	options.maxResults = 15;
+if (options.inputWidth === undefined) {
+	options.inputWidth = 250;
+if (options.searchEpsg === undefined) {
+	options.searchEpsg = "4326";
+if (options.drawCentrePoint === undefined) {
+	options.drawCentrePoint = true;
+if (options.gazetteerFrontImageOn === undefined) {
+	options.gazetteerFrontImageOn = "../img/button_blue_red/gazetteer3_on.png";
+if (options.gazetteerFrontImageOff === undefined) {
+	options.gazetteerFrontImageOff = "../img/button_blue_red/gazetteer3_off.png";
+var JsonAutocompleteGazetteer = function() {
+	var that = this;
+	this.zoomToExtent = function(fromSrs,minx,miny,maxx,maxy) {
+		var parameters = {
+			fromSrs: fromSrs,
+			toSrs: Mapbender.modules[targetName].epsg
+		parameters.bbox = parseFloat(minx)+ "," +parseFloat(miny)+ "," +parseFloat(maxx)+ "," +parseFloat(maxy);
+		//function to transform from one crs to another
+		var req = new Mapbender.Ajax.Request({
+			url: "../php/mod_coordsLookup_server.php",
+			method: "transform",
+			parameters: parameters,
+			callback: function (obj, success, message) {
+				if (!success) {
+					new Mapbender.Exception(message);
+					return;
+				if (options.drawCentrePoint) {
+					//generate layer for visualization of point
+					if(standingHighlight !== null){
+						standingHighlight.clean();
+					}else{
+						standingHighlight = new Highlight(
+							[options.target],
+							"standingHighlight",
+							{"position":"absolute", "top":"0px", "left":"0px", "z-index":10000},
+							2);
+					var point0 = new Point(obj.points[0].x,obj.points[0].y);
+					var point1 = new Point(obj.points[1].x,obj.points[1].y);
+					var x = point0.x + (point1.x - point0.x)/2;
+					var y = point0.y + (point1.y - point0.y)/2;
+					var point = new Point(x,y);
+					var ga = new GeometryArray();
+					ga.importPoint({
+						coordinates:[x,y,null]
+					},Mapbender.modules[targetName].epsg)
+					var m = ga.get(-1,-1);
+					standingHighlight.add(m, "#ff0000");
+					//alert(m);
+				if (obj.points) {
+					if (obj.points.length === 2) {
+						var newExtent = new Extent(
+							obj.points[0].x,
+							obj.points[0].y,
+							obj.points[1].x,
+							obj.points[1].y
+						my.calculateExtent(newExtent);
+					my.setMapRequest();
+		req.send();
+	this.toggleInput = function(){
+		if ($("#geographicName").css("display") == 'none') {
+			$("#geographicName").show();
+			$("#symboldForInputId").attr({'src':options.gazetteerFrontImageOn});
+		} else {
+			$("#geographicName").hide();
+			$("#symboldForInputId").attr({'src':options.gazetteerFrontImageOff});
+		epsg = Mapbender.modules[targetName].epsg.replace('EPSG:', '');
+		this.formContainer = $(document.createElement('form')).attr({'id':'json-autocomplete-gazetteer'}).appendTo('#' + options.id);
+		this.formContainer.submit(function() {
+			return false;
+		if (options.isDraggable){
+			//this.formContainer.draggable();//problem with print module
+		this.symbolForInput = $(document.createElement('img')).appendTo(this.formContainer);
+		this.symbolForInput.attr({'id':'symboldForInputId'});
+		this.symbolForInput.attr({'src':options.gazetteerFrontImageOn});
+		this.symbolForInput.attr({'title':'<?php echo _mb('Address'); ?>'});
+		this.symbolForInput.click(function() {
+			that.toggleInput();
+		this.inputAddress = $(document.createElement('input')).appendTo(this.formContainer);
+		this.inputAddress.attr({'id':'geographicName'});
+		//default value
+		this.inputAddress.val('<?php echo _mb('Search for addresses'); ?>');
+		this.inputAddress.css('width',options.inputWidth);
+		$('.ui-menu').css('width','100px');
+		$('.ui-menu-item').css('width','100px');
+		//set the loading symbol for autoloader class
+		//$('.ui-autocomplete-loading').css('background','white url("../img/indicator_wheel.gif") right center no-repeat');
+		//http://stackoverflow.com/questions/622122/how-can-i-change-the-css-class-rules-using-jquery
+		//$("<style type='text/css'> .ui-autocomplete { position: absolute; cursor: default; background:black; color:white} </style>").appendTo("head");
+		$(function() {
+			$( "#geographicName" ).autocomplete({
+				source: function( request, response ) {
+					$.ajax({
+						url: options.gazetteerUrl,
+						dataType: "jsonp",
+						data: {
+							outputFormat: 'json',
+							resultTarget: 'web',
+							searchEPSG: options.searchEpsg,
+							maxResults: options.maxResults,
+							maxRows: options.maxResults,
+							searchText: request.term,
+							featureClass: "P",
+							style: "full",
+							name_startsWith: request.term
+						success: function( data ) {
+							if (options.isGeonames) {
+								response( $.map( data.geonames, function( item ) {
+									return {
+										label: item.name+" - "+item.fclName+" - "+item.countryName,
+										minx: item.lng-options.latLonZoomExtension,
+										miny: item.lat-options.latLonZoomExtension,
+										maxx: item.lng+options.latLonZoomExtension,
+										maxy: item.lat+options.latLonZoomExtension
+							} else {
+									return {
+										label: item.title,
+										minx: item.minx,
+										miny: item.miny,
+										maxx: item.maxx,
+										maxy: item.maxy
+				minLength: options.minLength,
+				delay: options.delay,
+				select: function( event, ui ) {
+					that.zoomToExtent("EPSG:"+options.searchEpsg,ui.item.minx,ui.item.miny,ui.item.maxx,ui.item.maxy);
+				open: function() {
+					$( this ).removeClass( "ui-corner-all" ).addClass( "ui-corner-top" );
+				close: function() {
+					$( this ).removeClass( "ui-corner-top" ).addClass( "ui-corner-all" );
+	this.initForm();
+	Mapbender.modules[options.id] = $.extend(new JsonAutocompleteGazetteer(),Mapbender.modules[options.id]);
More information about the Mapbender_commits mailing list
