[Mapbender-commits] r8425 - branches/2.7/resources/db/pgsql/UTF-8/update
svn_mapbender at osgeo.org
Fri Jul 6 01:07:44 PDT 2012
Author: astrid_emde
Date: 2012-07-06 01:07:44 -0700 (Fri, 06 Jul 2012)
New Revision: 8425
branches/2.7/resources/db/pgsql/UTF-8/update/update_2.7.2_to_2.7.3_pgsql_UTF-8.sql
enlarge treewidth in gui_digitize
Modified: branches/2.7/resources/db/pgsql/UTF-8/update/update_2.7.2_to_2.7.3_pgsql_UTF-8.sql
--- branches/2.7/resources/db/pgsql/UTF-8/update/update_2.7.2_to_2.7.3_pgsql_UTF-8.sql 2012-07-06 08:05:09 UTC (rev 8424)
+++ branches/2.7/resources/db/pgsql/UTF-8/update/update_2.7.2_to_2.7.3_pgsql_UTF-8.sql 2012-07-06 08:07:44 UTC (rev 8425)
@@ -276,3 +276,7 @@
INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui', 'treeGDE', 'enlargetreewidth', '300', 'false (default): no enlargement of the div, integer value to enlarge on mouseover' ,'var');
INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui', 'treeGDE', 'enlargetreewidthopacity', 'true', '' ,'var');
+UPDATE gui_element set e_width = 220 where fkey_gui_id = 'gui_digitize' and e_id = 'treeGDE';
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui_digitize', 'treeGDE', 'enlargetreewidth', '300', 'false (default): no enlargement of the div, integer value to enlarge on mouseover' ,'var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui_digitize', 'treeGDE', 'enlargetreewidthopacity', 'true', '' ,'var');
More information about the Mapbender_commits
