[Mapbender-commits] r8432 - in branches/2.7/http: classes javascripts
svn_mapbender at osgeo.org
Fri Jul 6 03:19:23 PDT 2012
Author: astrid_emde
Date: 2012-07-06 03:19:22 -0700 (Fri, 06 Jul 2012)
New Revision: 8432
branches/2.7/http/classes/class_map.php
branches/2.7/http/classes/class_wmc.php
branches/2.7/http/javascripts/mod_loadwmc.js
merged changes concerning ticket 877
from trunk
http://trac.osgeo.org/mapbender/ticket/877
http://trac.osgeo.org/mapbender/changeset/8286
Modified: branches/2.7/http/classes/class_map.php
--- branches/2.7/http/classes/class_map.php 2012-07-06 10:06:48 UTC (rev 8431)
+++ branches/2.7/http/classes/class_map.php 2012-07-06 10:19:22 UTC (rev 8432)
@@ -516,7 +516,12 @@
$wms->gui_wms_mapformat = $currentWms->gui_wms_mapformat;
$wms->gui_wms_featureinfoformat = $currentWms->gui_wms_featureinfoformat;
$wms->gui_wms_exceptionformat = $currentWms->gui_wms_exceptionformat;
- $wms->gui_wms_opacity = $currentWms->gui_wms_opacity;
+ $e = new mb_notice('class_map: gui_wms_mapopacity: '.$currentWms->gui_wms_mapopacity);
+ if (!isset($currentWms->gui_wms_mapopacity) || $currentWms->gui_wms_mapopacity =='') {
+ $wms->gui_wms_opacity = 100;
+ } else {
+ $wms->gui_wms_opacity = ($currentWms->gui_wms_mapopacity)*100;//this definition is not easy to understand. TODO: find another, consistent behavior.
$wms->gui_wms_sldurl = $currentWms->gui_wms_sldurl;
$wms->gui_wms_visible = $currentWms->gui_wms_visible;
$wms->gui_wms_epsg = $currentWms->gui_wms_epsg;
Modified: branches/2.7/http/classes/class_wmc.php
--- branches/2.7/http/classes/class_wmc.php 2012-07-06 10:06:48 UTC (rev 8431)
+++ branches/2.7/http/classes/class_wmc.php 2012-07-06 10:19:22 UTC (rev 8432)
@@ -548,8 +548,8 @@
$LegendResources = $xpath->query("../../wmc:StyleList/wmc:Style/wmc:LegendURL/wmc:OnlineResource",$WMSId);
foreach ($LegendResources as $LegendResource) {
- $e = new mb_notice("class_wmc.php: old getlegendurl (WMC): ".$LegendResource->getAttribute("xlink:href"));
- $e = new mb_notice("class_wmc.php: new getlegendurl (OWSPROXY): ".$wmsGetLegendUrl);
+ $e = new mb_exception("class_wmc.php: old getlegendurl (WMC): ".$LegendResource->getAttribute("xlink:href"));
+ $e = new mb_exception("class_wmc.php: new getlegendurl (OWSPROXY): ".$wmsGetLegendUrl);
//get param part of getlegend url from xml
$arURL = parse_url($LegendResource->getAttribute("xlink:href"));
$query = $arURL["query"];
@@ -559,6 +559,7 @@
} else { //service is not secured - exchange urls only when they may have changed
$wmsGetMapUrl = $row["wms_getmap"];
$wmsGetLegendUrl = $row["wms_getlegendurl"];
//in cases when no owsproxy is defined exchange only if timestamp are not in sync
$wms_timestamp = $row["wms_timestamp"];
//if ($this->timestamp < $wms_timestamp) {//TODO: check if such a distiction is really needful - the timestamp of a wmc changes if some metadata changes - therefor it is needed - exchange all urls by default!
@@ -573,16 +574,17 @@
$MapResource->setAttribute("xlink:href",$wmsGetMapUrl);
- $LegendResources = $xpath->query("../../wmc:StyleList/wmc:Style/wmc:LegendURL/wmc:OnlineResource",$WMSId);
- foreach ($LegendResources as $LegendResource) {
- $e = new mb_notice("class_wmc.php: new getlegendurl (DB): ".$wmsGetLegendUrl);
+ //$LegendResources = $xpath->query("../../wmc:StyleList/wmc:Style/wmc:LegendURL/wmc:OnlineResource",$WMSId);
+ /*foreach ($LegendResources as $LegendResource) {
+ $e = new mb_exception("class_wmc.php: new getlegendurl (DB): ".$wmsGetLegendUrl);
$url = $wmsGetLegendUrl . $query;
$LegendResource->setAttribute("xlink:href",$url);
@@ -1211,14 +1213,18 @@
// .. request the map
+ array_push($wmcJsArray, "lock_maprequest = true;");
+ array_push($wmcJsArray, "eventAfterLoadWMS.trigger();"); //TODO: Why? Reload tree? Other way to do this?
+ array_push($wmcJsArray, "lock_maprequest = false;");
array_push($wmcJsArray, "Mapbender.modules['".$this->mainMap->getFrameName().
"'].setMapRequest();");
if ($this->overviewMap !== null) {
array_push($wmcJsArray, "try {Mapbender.modules['".$this->overviewMap->getFrameName().
"'].setMapRequest()} catch (e) {};");
- array_push($wmcJsArray, "eventAfterLoadWMS.trigger();");
+ //?initializeWms()
+ //eventAfterLoadWMS.register(reloadTree);
return $wmcJsArray;
@@ -1294,7 +1300,11 @@
protected function createObjFromWMC_xml($data) {
// store xml
$this->xml = $data;
+ //$wmcXml = simplexml_load_string(mb_utf8_encode($data));
+ //if ($wmcXml) {
+ // $e = new mb_exception("class_wmc.php: parsing wmc successfully");
$values = administration::parseXml($data);
if (!$values) {
throw new Exception("WMC document could not be parsed.");
Modified: branches/2.7/http/javascripts/mod_loadwmc.js
--- branches/2.7/http/javascripts/mod_loadwmc.js 2012-07-06 10:06:48 UTC (rev 8431)
+++ branches/2.7/http/javascripts/mod_loadwmc.js 2012-07-06 10:19:22 UTC (rev 8432)
@@ -371,8 +371,10 @@
if (obj.javascript && typeof(obj.javascript) == "object") {
for (var j = 0; j < obj.javascript.length; j++) {
-// var e = new Mb_notice("Statement: " + obj.javascript[j]);
-// console.log("Statement: " + obj.javascript[j]);
+ //TODO: prohibit multiple maprequests when load wmc, cause on maprequests the wmc maybe stored to session :-(
+ //alert("Statement: " + obj.javascript[j]);
+ //eventAfterLoadWMS.trigger(); -- load the each wms again and saves the wmc to session for each wms - prohibit this behaviour!!!! - Done by global lock_maprequest in class_wmc.php line 1220+!!
+ //console.log("Statement: " + obj.javascript[j]);
eval(obj.javascript[j]);
if (args.method === "loadWmc") {
More information about the Mapbender_commits
