[Mapbender-commits] r8442 - trunk/mapbender/tools
svn_mapbender at osgeo.org
Mon Jul 9 08:05:23 PDT 2012
Author: armin11
Date: 2012-07-09 08:05:22 -0700 (Mon, 09 Jul 2012)
New Revision: 8442
trunk/mapbender/tools/mod_runScheduler.php
Error messages
Modified: trunk/mapbender/tools/mod_runScheduler.php
--- trunk/mapbender/tools/mod_runScheduler.php 2012-07-09 15:05:05 UTC (rev 8441)
+++ trunk/mapbender/tools/mod_runScheduler.php 2012-07-09 15:05:22 UTC (rev 8442)
@@ -15,91 +15,98 @@
//$resultObj = array();
//array containing all wms which should be updated
$wmsToUpdate = array();
+echo "Scheduler for WMS start work...\n";
while ($row = db_fetch_array($res)) {
$resultObj = array(
"scheduler_id" => $row['scheduler_id'],
"wms_id" => $row['wms_id'],
"wms_title" => $row['wms_title'],
- "last_change" => $row['last_change'],
- "last_status" => $row['last_status'],
+ "last_change" => $row['last_change'],
+ "last_status" => $row['last_status'],
"wms_upload_url" => $row['wms_upload_url'],
- "fkey_upload_id" => $row['fkey_upload_id'],
- "scheduler_interval" => $row['scheduler_interval'],
- "scheduler_mail" => $row['scheduler_mail'],
- "scheduler_publish" => $row['scheduler_publish'],
- "scheduler_searchable" => $row['scheduler_searchable'],
+ "fkey_upload_id" => $row['fkey_upload_id'],
+ "scheduler_interval" => $row['scheduler_interval'],
+ "scheduler_mail" => $row['scheduler_mail'],
+ "scheduler_publish" => $row['scheduler_publish'],
+ "scheduler_searchable" => $row['scheduler_searchable'],
"scheduler_overwrite" => $row['scheduler_overwrite'],
- "scheduler_status" => $row['scheduler_status']
+ "scheduler_status" => $row['scheduler_status']
if($row['scheduler_interval'] == '1 mon') {
$row['scheduler_interval'] = "1 month";
- //check wms timestamp , schedule interval with current date for update
- $currentDate = date('Y-m-d',time());
- $schedulerDateTimestamp = date("Y-m-d",strtotime(date("Y-m-d", strtotime($row['last_change'])) . $row['scheduler_interval']));
- //last monitoring date
- $lastMonitorDate = date("Y-m-d",$row['fkey_upload_id']);
- $schedulerDateMonitoring = date("Y-m-d",strtotime(date("Y-m-d", $row['fkey_upload_id']) . $row['scheduler_interval']));
+ //check wms timestamp , schedule interval with current date for update
+ $currentDate = date('Y-m-d',time());
+ $schedulerDateTimestamp = date("Y-m-d",strtotime(date("Y-m-d", strtotime($row['last_change'])) . $row['scheduler_interval']));
+ //last monitoring date
+ $lastMonitorDate = date("Y-m-d",$row['fkey_upload_id']);
+ $schedulerDateMonitoring = date("Y-m-d",strtotime(date("Y-m-d", $row['fkey_upload_id']) . $row['scheduler_interval']));
- //if calculated $schedulerDateTimestamp is in the past
- //or last_status value of monitoring does not have the value 1 which means wms has been updated by monitoring
- if($currentDate >= $schedulerDateTimestamp) {
- if ($row['last_status'] == 1) {
- if($currentDate >= $schedulerDateMonitoring) {
- array_push($wmsToUpdate, $resultObj);
- else{
- else {
- if ($row['last_status'] == 0) {
+ //if calculated $schedulerDateTimestamp is in the past
+ //or last_status value of monitoring does not have the value 1 which means wms has been updated by monitoring
+ if($currentDate >= $schedulerDateTimestamp) {
+ if ($row['last_status'] == 1) {
+ if($currentDate >= $schedulerDateMonitoring) {
+ array_push($wmsToUpdate, $resultObj);
+ } else {
+ } else {
+ if ($row['last_status'] == 0) {
+//for debugging purpose:
+/*for ($i=0; $i<count($wmsToUpdate); $i++) {
+ echo "wms_id: ".$wmsToUpdate[$i]['wms_id']."\n";
+die();
- #echo "WMS ID = ".$wmsToUpdate[$i]['wms_id']."\n";
- #echo "WMS URL = ".$wmsToUpdate[$i]['wms_upload_url']."\n";
+ #echo "WMS ID = ".$wmsToUpdate[$i]['wms_id']."\n";
+ #echo "WMS URL = ".$wmsToUpdate[$i]['wms_upload_url']."\n";
- //create new wms object
- $updateWms = new wms();
- $createObjFromXml = $updateWms->createObjFromXML($wmsToUpdate[$i]['wms_upload_url']);
- if(!$createObjFromXml) {
- $errorMsg = "Error while creating object from GetCapabilities XML";
- //check scheduler_searchable attribute for layer searchable in class_wms.php
- $updateWms->optimizeWMS($wmsToUpdate[$i]['scheduler_searchable']);
+ //create new wms object
+ $updateWms = new wms();
+ $createObjFromXml = $updateWms->createObjFromXML($wmsToUpdate[$i]['wms_upload_url']);
+ if(!$createObjFromXml) {
+ $errorMsg = "Error while creating object from GetCapabilities XML";
+ //check scheduler_searchable attribute for layer searchable in class_wms.php
+ $updateWms->optimizeWMS($wmsToUpdate[$i]['scheduler_searchable']);
- //check overwrite attribute
- if (!$wmsToUpdate[$i]['scheduler_overwrite']) {
+ //check overwrite attribute
+ if (!$wmsToUpdate[$i]['scheduler_overwrite']) {
+ echo "overwrite md = false\n";
$updateWms->overwrite=false;
//check publish attribute for geoRss and twitter attribute in class_wms.php
- if ($wmsToUpdate[$i]['scheduler_publish'] == 1) {
- require_once dirname(__FILE__) . "/../http/classes/class_twitter.php";
+ if ($wmsToUpdate[$i]['scheduler_publish'] == 1) {
+ require_once dirname(__FILE__) . "/../http/classes/class_twitter.php";
$updateWms->twitterNews=true;
$updateWms->setGeoRss=true;
+ echo "publish = true\n";
else {
- $updateWms->twitterNews=false;
+ $updateWms->twitterNews=false;
$updateWms->setGeoRss=false;
+ echo "publish = false\n";
- $updateObjInDb = $updateWms->updateObjInDB($wmsToUpdate[$i]['wms_id']);
- if(!$updateObjInDb) {
- $errorMsg = "Error while updating wms object in database";
+ $updateObjInDb = $updateWms->updateObjInDB($wmsToUpdate[$i]['wms_id']);
+ if(!$updateObjInDb) {
+ $errorMsg = "Error while updating wms object in database";
if($wmsToUpdate[$i]['scheduler_mail']) {
- $admin = new administration();
+ $admin = new administration();
+ //get all users which have the wms integrated in their guis!
$ownerIds = $admin->getOwnerByWms($wmsToUpdate[$i]['wms_id']);
if ($ownerIds && count($ownerIds) > 0) {
$ownerMailAddresses = array();
$j=0;
@@ -113,15 +120,16 @@
$adrRoot = $admin->getEmailByUserId("1");
$from = $adrRoot;
if($from != "") {
- $body = "WMS '" . $admin->getWmsTitleByWmsId($wmsToUpdate[$i]['wms_id']) . "' has been updated by the scheduler update. \n\nYou may want to check the changes as you are an owner of this WMS.";
- $error_msg = "";
- for ($m=0; $m<count($ownerMailAddresses); $m++) {
- if (!$admin->sendEmail($from, $from, $ownerMailAddresses[$m], $ownerMailAddresses[$m], "[Mapbender Update Scheduler] One of your WMS has been updated", $body, $error)) {
- if ($error){
- $error_msg .= $error . " ";
+ $body = "WMS '" . $admin->getWmsTitleByWmsId($wmsToUpdate[$i]['wms_id']) . "' has been updated by the scheduler update. \n\nYou may want to check the changes as you are an owner of this WMS.";
+ $error_msg = "";
+ for ($m=0; $m<count($ownerMailAddresses); $m++) {
+ echo $ownerMailAddresses[$m]."\n";
+ if (!$admin->sendEmail($from, $from, $ownerMailAddresses[$m], $ownerMailAddresses[$m], "[Mapbender Update Scheduler] One of your WMS has been updated", $body, $error)) {
+ if ($error){
+ $error_msg .= $error . " ";
@@ -145,4 +153,4 @@
echo "ERROR";
\ No newline at end of file
More information about the Mapbender_commits
