[Mapbender-commits] r8370 - in trunk/mapbender: http/classes http/php http/plugins resources/db/pgsql/UTF-8/update
svn_mapbender at osgeo.org
Wed Jun 6 08:19:06 PDT 2012
Author: armin11
Date: 2012-06-06 08:19:06 -0700 (Wed, 06 Jun 2012)
New Revision: 8370
Added:
trunk/mapbender/http/classes/class_iso19139.php
trunk/mapbender/http/classes/class_wms.php
trunk/mapbender/http/php/mod_dataISOMetadata.php
trunk/mapbender/http/php/wms.php
trunk/mapbender/http/plugins/mb_metadata_server.php
trunk/mapbender/http/plugins/mb_metadata_wfs_server.php
trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.7.2_to_2.7.3_pgsql_UTF-8.sql
New class to parse ISO19139 files - can be used from different classes. Further work have to be done. Bugfixes for INSPIRE.
Added: trunk/mapbender/http/classes/class_iso19139.php
--- trunk/mapbender/http/classes/class_iso19139.php (rev 0)
+++ trunk/mapbender/http/classes/class_iso19139.php 2012-06-06 15:19:06 UTC (rev 8370)
@@ -0,0 +1,161 @@
+<?php
+# $Id: class_iso19139.php 3094 2008-10-01 13:52:35Z christoph $
+# http://www.mapbender.org/index.php/class_iso19139.php
+# Copyright (C) 2002 CCGIS
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+require_once(dirname(__FILE__)."/../../core/globalSettings.php");
+require_once(dirname(__FILE__)."/class_connector.php");
+class Iso19139 {
+ //values for handling apriori ows metadataurls
+ var $fileIdentifier;
+ var $createDate;
+ var $changeDate;
+ var $title;
+ var $abstract;
+ var $metadata;
+ var $datasetId;
+ var $datasetIdCodeSpace;
+ var $keywords = array();
+ var $hierachyLevel;
+ var $tmpExtentBegin;
+ var $tmpExtentEnd;
+ var $refSystem;
+ var $randomId;
+ var $href;
+ var $format;
+ var $type;
+ var $origin;
+ public function removeGetRecordTag ($xml) {
+ $regex = "#<csw:GetRecordByIdResponse .*?>#";
+ $xml = preg_replace($regex,"",$xml);
+ $regex = "#</csw:GetRecordByIdResponse>#";
+ return $xml;
+ public function createMapbenderMetadataFromXML($xml){
+ $this->metadata = $xml;
+ $this->metadata = $this->removeGetRecordTag($this->metadata);
+ libxml_use_internal_errors(true);
+ try {
+ $iso19139Xml = simplexml_load_string($this->metadata);
+ if ($iso19139Xml === false) {
+ foreach(libxml_get_errors() as $error) {
+ $e = new mb_exception($error->message);
+ throw new Exception('Cannot parse Metadata XML!');
+ catch (Exception $e) {
+ $e = new mb_exception($e->getMessage());
+ //if parsing was successful
+ if ($iso19139Xml != false) {
+ $this->fileIdentifier = $iso19139Xml->xpath('/gmd:MD_Metadata/gmd:fileIdentifier/gco:CharacterString');
+ $this->createDate = $iso19139Xml->xpath('/gmd:MD_Metadata/gmd:dateStamp/gco:Date');
+ $this->changeDate = $iso19139Xml->xpath('/gmd:MD_Metadata/gmd:dateStamp/gco:Date');
+ //TODO: check if this is set, maybe DateTime must be searched instead?
+ $this->title = $iso19139Xml->xpath('/gmd:MD_Metadata/gmd:identificationInfo/gmd:MD_DataIdentification/gmd:citation/gmd:CI_Citation/gmd:title/gco:CharacterString');
+ //dataset identifier - howto model into md_metadata?
+ //check where datasetid is defined - maybe as RS_Identifier or as MD_Identifier see http://inspire.jrc.ec.europa.eu/documents/Metadata/INSPIRE_MD_IR_and_ISO_v1_2_20100616.pdf page 18
+ //First check if MD_Identifier is set, then check if RS_Identifier is used!
+ //Initialize datasetid
+ $this->datasetId = 'undefined';
+ $code = $iso19139Xml->xpath('/gmd:MD_Metadata/gmd:identificationInfo/gmd:MD_DataIdentification/gmd:citation/gmd:CI_Citation/gmd:identifier/gmd:MD_Identifier/gmd:code/gco:CharacterString');
+ if (isset($code[0]) && $code[0] != '') {
+ $this->datasetId = $code[0];
+ $this->datasetIdCodeSpace = "";
+ } else { //try to read code from RS_Identifier
+ $code = $iso19139Xml->xpath('/gmd:MD_Metadata/gmd:identificationInfo/gmd:MD_DataIdentification/gmd:citation/gmd:CI_Citation/gmd:identifier/gmd:RS_Identifier/gmd:code/gco:CharacterString');
+ $codeSpace = $iso19139Xml->xpath('/gmd:MD_Metadata/gmd:identificationInfo/gmd:MD_DataIdentification/gmd:citation/gmd:CI_Citation/gmd:identifier/gmd:RS_Identifier/gmd:codeSpace/gco:CharacterString');
+ if (isset($codeSpace[0]) && isset($code[0]) && $codeSpace[0] != '' && $code[0] != '') {
+ $this->datasetIdCodeSpace = $codeSpace[0];
+ } else {
+ //neither MD_Identifier nor RS_Identifier are defined in a right way
+ $e = new mb_notice("class_iso19139.php: No datasetId found in metadata record!");
+ //abstract
+ $this->abstract = $iso19139Xml->xpath('/gmd:MD_Metadata/gmd:identificationInfo/gmd:MD_DataIdentification/gmd:abstract/gco:CharacterString');
+ $this->keywords = $iso19139Xml->xpath('/gmd:MD_Metadata/gmd:identificationInfo/gmd:MD_DataIdentification/gmd:descriptiveKeywords/gmd:MD_Keywords/gmd:keyword/gco:CharacterString');
+ $this->hierachyLevel = $iso19139Xml->xpath('/gmd:MD_Metadata/gmd:hierarchyLevel/gmd:MD_ScopeCode');
+ $this->tmpExtentBegin = $iso19139Xml->xpath('/gmd:MD_Metadata/gmd:identificationInfo/gmd:MD_DataIdentification/gmd:extent/gmd:EX_Extent/gmd:temporalElement/gmd:EX_TemporalExtent/gmd:extent/gml:TimePeriod/gml:beginPosition');
+ $this->tmpExtentEnd = $iso19139Xml->xpath('/gmd:MD_Metadata/gmd:identificationInfo/gmd:MD_DataIdentification/gmd:extent/gmd:EX_Extent/gmd:temporalElement/gmd:EX_TemporalExtent/gmd:extent/gml:TimePeriod/gml:endPosition');
+ //spatial_res_type
+ //spatial_res_value
+ //ref_system
+ //format
+ //inspire_charset
+ //inspire_top_consistence
+ //responsible_party
+ //fees
+ //"constraints"
+ //fill database with elements:
+ return $this;
+ } else {
+ return false;
+ public function createFromUrl($url){
+ $metadataConnector = new connector($url);
+ $xml = $metadataConnector->file;
+ $mbMetadata = $this->createMapbenderMetadataFromXML($xml);
+ return $mbMetadata;
+ public function createFromDB($fileIdentifier){
+ return $this;
+ public function insertToDB(){
+ $sql = "INSERT INTO mb_metadata (link, origin, md_format, data, linktype, uuid, title, createdate, changedate, abstract, searchtext, type, tmp_reference_1, tmp_reference_2, export2csw, datasetid, datasetid_codespace, randomid) ";
+ $sql .= "VALUES($1, 'capabilities', $2, $3, $4, $5, $6, $7, $8, $9, $10, $11, $12, $13, $14, $15, $16, $17)";
+ $v = array($this->href,
+ $this->format,
+ $this->metadata,
+ $this->type,
+ $this->fileIdentifier[0],
+ $this->title[0],
+ $this->createDate[0],
+ $this->changeDate[0],
+ $this->abstract[0],
+ $this->keywords[0],
+ $this->hierachyLevel[0],
+ $this->tmpExtentBegin[0],
+ $this->tmpExtentEnd[0],
+ 't',
+ $this->datasetId,
+ $this->datasetIdCodeSpace,
+ $this->randomId
+ $t = array('s','s','s','s','s','s','s','s','s','s','s','s','s','b','s','s','s');
+ $res = db_prep_query($sql,$v,$t);
+ if(!$res){
+ db_rollback();
+ return false;
+ } else {
+ return true;
Modified: trunk/mapbender/http/classes/class_wms.php
--- trunk/mapbender/http/classes/class_wms.php 2012-06-06 11:56:32 UTC (rev 8369)
+++ trunk/mapbender/http/classes/class_wms.php 2012-06-06 15:19:06 UTC (rev 8370)
@@ -12,6 +12,7 @@
require_once dirname(__FILE__) . "/class_administration.php";
require_once dirname(__FILE__) . "/class_georss_factory.php";
require_once dirname(__FILE__) . "/class_mb_exception.php";
+require_once dirname(__FILE__) . "/class_iso19139.php";
require_once dirname(__FILE__) . "/../classes/class_universal_wms_factory.php";
class wms {
@@ -2370,198 +2371,107 @@
//parse the content if iso19139 is given
//TODO: generate temporal uuid for inserting and getting the serial afterwards
for($j=0; $j<count($this->objLayer[$i]->layer_metadataurl);$j++){
//check for returned format?
if (($this->objLayer[$i]->layer_metadataurl[$j]->type == 'ISO19115:2003' && $this->objLayer[$i]->layer_metadataurl[$j]->format =='text/xml') || ($this->objLayer[$i]->layer_metadataurl[$j]->type == 'TC211' && $this->objLayer[$i]->layer_metadataurl[$j]->format =='text/xml')) {
//load metadata from link
- $metadataConnector = new connector($this->objLayer[$i]->layer_metadataurl[$j]->href);
- $metaData = $metadataConnector->file;
- //delete getRecordByIdResponse from xml if there cause we handle only iso19139 files !
- $regex = "#<csw:GetRecordByIdResponse .*?>#";
- $output = preg_replace($regex,"",$metaData);
- $regex = "#</csw:GetRecordByIdResponse>#";
- $output = preg_replace($regex,"",$output);
- //$e = new mb_exception($output);
- $metaData = $output;
- //parse metadata
- libxml_use_internal_errors(true);
- try {
- $iso19139Xml = simplexml_load_string($metaData);
- //$iso19139Xml = new SimpleXMLElement($metaData);
- if ($iso19139Xml === false) {
- foreach(libxml_get_errors() as $error) {
- $e = new mb_exception($error->message);
- throw new Exception('Cannot parse Metadata XML!');
- catch (Exception $e) {
- $e = new mb_exception($e->getMessage());
- if ($iso19139Xml != false) {
- //get elements for database from xml by using xpath
- //uuid
- $uuid = $iso19139Xml->xpath('/gmd:MD_Metadata/gmd:fileIdentifier/gco:CharacterString');
- //createdate
- $createdate = $iso19139Xml->xpath('/gmd:MD_Metadata/gmd:dateStamp/gco:Date');
- //changedate
- $changedate = $iso19139Xml->xpath('/gmd:MD_Metadata/gmd:dateStamp/gco:Date');
- //TODO: check if this is set, maybe DateTime must be searched instead?
- //title
- $title = $iso19139Xml->xpath('/gmd:MD_Metadata/gmd:identificationInfo/gmd:MD_DataIdentification/gmd:citation/gmd:CI_Citation/gmd:title/gco:CharacterString');
- //dataset identifier - howto model into md_metadata?
- //check where datasetid is defined - maybe as RS_Identifier or as MD_Identifier see http://inspire.jrc.ec.europa.eu/documents/Metadata/INSPIRE_MD_IR_and_ISO_v1_2_20100616.pdf page 18
- //First check if MD_Identifier is set, then check if RS_Identifier is used!
- //Initialize datasetid
- $datasetid = 'undefined';
- $code = $iso19139Xml->xpath('/gmd:MD_Metadata/gmd:identificationInfo/gmd:MD_DataIdentification/gmd:citation/gmd:CI_Citation/gmd:identifier/gmd:MD_Identifier/gmd:code/gco:CharacterString');
- if (isset($code[0]) && $code[0] != '') {
- $e = new mb_notice("class_wms.php: code given thru MD_Identifier: ".$code[0]);
- //check if code is defined by codespace and code
- $codeSplit = explode("#",$code);
- if (isset($codeSplit[0]) && $codeSplit[0] != '' && isset($codeSplit[1]) && $codeSplit[1] != '') {
- $e = new mb_notice("class_wms.php: code was constructed via codespace#code !");
- $datasetid = $codeSplit[0]."#".$codeSplit[1];
- } else {
- $e = new mb_notice("class_wms.php: code was not constructed via codespace#code !");
- $datasetid = $code;
+ $mbMetadata = new Iso19139();
+ $randomid = new Uuid();
+ $mbMetadata = $mbMetadata->createFromUrl($this->objLayer[$i]->layer_metadataurl[$j]->href);
+ if ($mbMetadata != false) {
+ //create randomId for metadata
+ $mbMetadata->randomId = $randomid;
+ $mbMetadata->href = $this->objLayer[$i]->layer_metadataurl[$j]->href;
+ $mbMetadata->format = $this->objLayer[$i]->layer_metadataurl[$j]->format;
+ $mbMetadata->type = $this->objLayer[$i]->layer_metadataurl[$j]->type;
+ $mbMetadata->origin = "capabilities";
+ if ($mbMetadata->insertToDB()){
+ //get inserted metadata_id
+ $sql = <<<SQL
+SELECT metadata_id FROM mb_metadata WHERE randomid = $1
+SQL;
+ //maybe there are more than one results - which should be used??? case of creating new linkage with old metadata TODO TODO
+ $v = array($randomid);
+ $t = array('s');
+ try {
- } else { //try to read code from RS_Identifier
- $code = $iso19139Xml->xpath('/gmd:MD_Metadata/gmd:identificationInfo/gmd:MD_DataIdentification/gmd:citation/gmd:CI_Citation/gmd:identifier/gmd:RS_Identifier/gmd:code/gco:CharacterString');
- $codeSpace = $iso19139Xml->xpath('/gmd:MD_Metadata/gmd:identificationInfo/gmd:MD_DataIdentification/gmd:citation/gmd:CI_Citation/gmd:identifier/gmd:RS_Identifier/gmd:codeSpace/gco:CharacterString');
- #$e = new mb_exception("class_wms.php: code: ".$code[0]);
- #$e = new mb_exception("class_wms.php: codeSpace: ".$codeSpace[0]);
- if (isset($codeSpace[0]) && isset($code[0]) && $codeSpace[0] != '' && $code[0] != '') {
- $datasetid = $codeSpace[0]."#".$code[0];
- $e = new mb_notice("class_wms.php: datasetid: ".$datasetid);
+ catch (Exception $e){
+ $e = new mb_exception(_mb("Cannot get metadata record with following uuid from database: ".$uuid));
+ if (!$res) {
+ //do nothing
} else {
- //neither MD_Identifier nor RS_Identifier are defined in a right way
- $e = new mb_notice("class_wms.php: the service data coupling has problems, cause the metadata doesnt have defined a datasetid");
+ //insert relation
+ $row = db_fetch_assoc($res);
+ $metadata_id = $row['metadata_id'];
+ //insert relation to layer
+ $sql = "INSERT INTO ows_relation_metadata (fkey_layer_id, fkey_metadata_id) values ($1, $2);";
+ $v = array($this->objLayer[$i]->db_id, $metadata_id);
+ $t = array('i','i');
+ if(!$res){
+ db_rollback();
+ } else {
+ $sql = "UPDATE mb_metadata SET harvestresult = 1 where metadata_id = $1";
+ $v = array($metadata_id);
+ $t = array('i');
- //abstract
- $abstract = $iso19139Xml->xpath('/gmd:MD_Metadata/gmd:identificationInfo/gmd:MD_DataIdentification/gmd:abstract/gco:CharacterString');
- //searchtext -- use keywords!
- $keywords = $iso19139Xml->xpath('/gmd:MD_Metadata/gmd:identificationInfo/gmd:MD_DataIdentification/gmd:descriptiveKeywords/gmd:MD_Keywords/gmd:keyword/gco:CharacterString');
- //type
- $type = $iso19139Xml->xpath('/gmd:MD_Metadata/gmd:hierarchyLevel/gmd:MD_ScopeCode');
- //tmp_reference_1
- $tmp_reference_1 = $iso19139Xml->xpath('/gmd:MD_Metadata/gmd:identificationInfo/gmd:MD_DataIdentification/gmd:extent/gmd:EX_Extent/gmd:temporalElement/gmd:EX_TemporalExtent/gmd:extent/gml:TimePeriod/gml:beginPosition');
- //tmp_reference_2
- $tmp_reference_2 = $iso19139Xml->xpath('/gmd:MD_Metadata/gmd:identificationInfo/gmd:MD_DataIdentification/gmd:extent/gmd:EX_Extent/gmd:temporalElement/gmd:EX_TemporalExtent/gmd:extent/gml:TimePeriod/gml:endPosition'); //spatial_res_type
- //spatial_res_value
- //ref_system
- //format
- //inspire_charset
- //inspire_top_consistence
- //responsible_party
- //fees
- //"constraints"
- //fill database with elements:
- $sql = "INSERT INTO mb_metadata (link, origin, md_format, data, linktype, uuid, title, createdate, changedate, abstract, searchtext, type, tmp_reference_1, tmp_reference_2, export2csw, datasetid) ";
- $sql .= "VALUES($1, 'capabilities', $2, $3, $4, $5, $6, $7, $8, $9, $10, $11, $12, $13, $14, $15)";
+ } else {
+ //parsing made problems - fill only the urls into database and give a reasonable error message
+ $sql = "INSERT INTO mb_metadata (link, origin, md_format, linktype, randomid) ";
+ $sql .= "VALUES($1, 'capabilities', $2, $3, $4)";
$v = array($this->objLayer[$i]->layer_metadataurl[$j]->href,
$this->objLayer[$i]->layer_metadataurl[$j]->format,
- $metaData,
$this->objLayer[$i]->layer_metadataurl[$j]->type,
- $uuid[0],
- $title[0],
- $createdate[0],
- $changedate[0],
- $abstract[0],
- $keywords[0],
- $type[0],
- $tmp_reference_1[0],
- $tmp_reference_2[0],
- 't',
- $datasetid
+ $randomid
- $t = array('s','s','s','s','s','s','s','s','s','s','s','s','s','b','s');
+ $t = array('s','s','s','s');
if(!$res){
db_rollback();
- //get last inserted serial_id
- $mdId = db_insert_id($con, 'mb_metadata','metadata_id');
- //insert into ows_relation_metadata (fkey_layer_id, fkey_metadata_id) values (20131,3);
- $sql = "INSERT INTO ows_relation_metadata (fkey_layer_id, fkey_metadata_id) values ($1, $2);";
- $v = array($this->objLayer[$i]->db_id, $mdId);
- $t = array('i','i');
- $res = db_prep_query($sql,$v,$t);
- if(!$res){
- db_rollback();
} else {
- $sql = "UPDATE mb_metadata SET harvestresult = 1 where metadata_id = $1";
- $v = array($mdId);
- $t = array('i');
- } else {
- //parsing was not ok - fill only the urls into database and give a reasonable error message
- $sql = "INSERT INTO mb_metadata (link, origin, md_format, linktype) ";
- $sql .= "VALUES($1, 'capabilities', $2, $3)";
- $v = array($this->objLayer[$i]->layer_metadataurl[$j]->href,
- $this->objLayer[$i]->layer_metadataurl[$j]->format,
- $this->objLayer[$i]->layer_metadataurl[$j]->type
- $t = array('s','s','s');
- if(!$res){
- db_rollback();
+ //get last inserted metadata_id
+ $sql = <<<SQL
+SQL;
+ $t = array('s');
+ try {
+ if (!$res) {
+ //do nothing
+ } else {
+ //insert relation
+ if(!$res){
+ db_rollback();
+ //TODO delete mb_metadata from table, cause the relation cannot be inserted
+ } else {
+ $sql = "UPDATE mb_metadata SET harvestresult = 0, harvestexception = 'Problem occured while parsing ISO19139 metadata!' where metadata_id = $1";
+ $t = array('i');
- if(!$res){
- db_rollback();
- } else {
- //set harvest result to 0 cause this metadata had problems while parsing
- $sql = "UPDATE mb_metadata SET harvestresult = 0, harvestexception = 'Problem occured while parsing ISO19139 metadata!' where metadata_id = $1";
- $t = array('i');
- } else {//no readable format given - only store the links!
- //don't push single elements into database
- if(!$res){
- db_rollback();
- if(!$res){
- db_rollback();
- } else {
- //set harvest result to 0 cause this metadata format can not to be parsed
- $sql = "UPDATE mb_metadata SET harvestresult = 0 where metadata_id = $1";
- $t = array('i');
+ } //either links or metadata stored to database
Modified: trunk/mapbender/http/php/mod_dataISOMetadata.php
--- trunk/mapbender/http/php/mod_dataISOMetadata.php 2012-06-06 11:56:32 UTC (rev 8369)
+++ trunk/mapbender/http/php/mod_dataISOMetadata.php 2012-06-06 15:19:06 UTC (rev 8370)
@@ -179,7 +179,7 @@
//function to give away the xml data
function pushISO19139($iso19139Doc, $recordId) {
//echo $recordId;
- header("Content-type: application/xhtml+xml; charset=UTF-8");
+ header("Content-type: text/xml; charset=UTF-8");
$xml = fillISO19139($iso19139Doc, $recordId);
echo $xml;
die();
@@ -304,17 +304,19 @@
$userMetadata = db_fetch_array($res);
//check if resource is freely available to anonymous user - which are all users who search thru metadata catalogues:
$hasPermission=$admin->getLayerPermission($mapbenderMetadata['wms_id'],$mapbenderMetadata['layer_name'],PUBLIC_USER);
+ //schemas for metadata:
+ <gmd:MD_Metadata xsi:schemaLocation="http://www.isotc211.org/2005/gmd http://schemas.opengis.net/iso/19139/20060504/gmd/gmd.xsd" xmlns:gmd="http://www.isotc211.org/2005/gmd" xmlns:gco="http://www.isotc211.org/2005/gco" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:gml="http://www.opengis.net/gml" xmlns:xlink="http://www.w3.org/1999/xlink">
//Creating the "MD_Metadata" node
- $MD_Metadata = $iso19139->createElementNS('http://www.isotc211.org/2005/gmd', 'gmd:MD_Metadata');
+ $MD_Metadata = $iso19139->createElement("gmd:MD_Metadata");
$MD_Metadata = $iso19139->appendChild($MD_Metadata);
- $MD_Metadata->setAttribute("xmlns:srv", "http://www.isotc211.org/2005/srv");
+ $MD_Metadata->setAttribute("xsi:schemaLocation", "http://www.isotc211.org/2005/gmd http://schemas.opengis.net/iso/19139/20060504/gmd/gmd.xsd");
+ $MD_Metadata->setAttribute("xmlns:gmd", "http://www.isotc211.org/2005/gmd");
+ $MD_Metadata->setAttribute("xmlns:gco", "http://www.isotc211.org/2005/gco");
+ $MD_Metadata->setAttribute("xmlns:xsi", "http://www.w3.org/2001/XMLSchema-instance");
$MD_Metadata->setAttribute("xmlns:gml", "http://www.opengis.net/gml");
- $MD_Metadata->setAttribute("xmlns:gco", "http://www.isotc211.org/2005/gco");
$MD_Metadata->setAttribute("xmlns:xlink", "http://www.w3.org/1999/xlink");
- $MD_Metadata->setAttribute("xmlns:xsi", "http://www.w3.org/2001/XMLSchema-instance");
- #$MD_Metadata->setAttribute("xsi:schemaLocation", "http://www.isotc211.org/2005/gmd ./xsd/gmd/gmd.xsd://www.isotc211.org/2005/srv ./xsd/srv/srv.xsd");
-$MD_Metadata->setAttribute("xsi:schemaLocation", "http://www.isotc211.org/2005/gmd");
-//$MD_Metadata->setAttribute("xsi:schemaLocation=","http://www.isotc211.org/2005/gmd http://schemas.opengis.net/iso/19139/20060504/gmd/gmd.xsd");
//generate fileidentifier part (metadata record identification)
$identifier = $iso19139->createElement("gmd:fileIdentifier");
Modified: trunk/mapbender/http/php/wms.php
--- trunk/mapbender/http/php/wms.php 2012-06-06 11:56:32 UTC (rev 8369)
+++ trunk/mapbender/http/php/wms.php 2012-06-06 15:19:06 UTC (rev 8370)
@@ -729,7 +729,7 @@
$inspire_common_Language = $inspire_common_ResponseLanguage->appendChild($inspire_common_Language);
-#Querying layer table
+#Querying layer table for root layer information!
$layer_sql = "SELECT * FROM layer WHERE layer.fkey_wms_id = $1 AND layer.layer_parent = ''";
$v = array($wms_row['wms_id']);
$t = array("i");
@@ -762,12 +762,14 @@
#Creating the "Abstract" node
if($layer_row['layer_abstract'] <> "" AND $layer_row['layer_abstract'] <> NULL) {
+ $layerAbstract = $layer_row['layer_abstract'];
+} else {
+ $layerAbstract = _mb("Layer abstract not given - please give a description for this layer.");
$abstract = $doc->createElement("Abstract");
$abstract = $layer->appendChild($abstract);
- $abstractText = $doc->createTextNode($layer_row['layer_abstract']);
- $abstractText = $abstract->appendChild($abstractText);
+ $abstractText = $doc->createTextNode($layerAbstract);
+ $abstractText = $abstract->appendChild($abstractText);
#Request the specific wms- and layerkeywords
$keyword_sql = "SELECT DISTINCT keyword FROM keyword, layer_keyword, layer " .
@@ -792,10 +794,12 @@
#Creating the "Keyword" node
- $keyword_dom = $doc->createElement("Keyword");
- $keyword_dom = $keywordList->appendChild($keyword_dom);
- $keyword_domText = $doc->createTextNode($keyword_sql['keyword']);
- $keyword_domText = $keyword_dom->appendChild($keyword_domText);
+ if (trim($keyword_sql['keyword']) <> "" AND $keyword_sql['keyword'] <> NULL) {
+ $keyword_dom = $doc->createElement("Keyword");
+ $keyword_dom = $keywordList->appendChild($keyword_dom);
+ $keyword_domText = $doc->createTextNode($keyword_sql['keyword']);
+ $keyword_domText = $keyword_dom->appendChild($keyword_domText);
@@ -957,9 +961,9 @@
$sub_layer = $parent->appendChild($sub_layer);
- if($sub_layer_row['layer_queryable'] <> "" AND $sub_layer_row['layer_queryable'] <> NULL) {
+ if($sub_layer_row['layer_queryable'] <> "" AND $sub_layer_row['layer_queryable'] <> NULL) {
$sub_layer->setAttribute('queryable', $sub_layer_row['layer_queryable']);
#Getting information about the hierarchie of layers
$cascadeSQL = "SELECT COUNT(*) FROM layer WHERE fkey_wms_id = $1 AND layer_parent = $2";
@@ -972,37 +976,37 @@
$cascade = 1;
- $sub_layer->setAttribute('cascaded', $cascade);
+ $sub_layer->setAttribute('cascaded', $cascade); //TODO: check if this is right!
#Write layer to parent layer array
$parentLayerArray[$sub_layer_row['layer_pos']] = $sub_layer;
#Creating name node
- if($sub_layer_row['layer_name'] <> "" AND $sub_layer_row['layer_name'] <> NULL)
+ if($sub_layer_row['layer_name'] <> "" AND $sub_layer_row['layer_name'] <> NULL) {
$name = $doc->createElement("Name");
$name = $sub_layer->appendChild($name);
$nameText = $doc->createTextNode($sub_layer_row['layer_name']);
$nameText = $name->appendChild($nameText);
#Creating Title node
- if($sub_layer_row['layer_title'] <> "" AND $sub_layer_row['layer_title'] <> NULL)
+ if($sub_layer_row['layer_title'] <> "" AND $sub_layer_row['layer_title'] <> NULL) {
$title = $doc->createElement("Title");
$title = $sub_layer->appendChild($title);
$titleText = $doc->createTextNode($sub_layer_row['layer_title']);
$titleText = $title->appendChild($titleText);
- #Creating the "Abstract" node
- if($sub_layer_row['layer_abstract'] <> "" AND $sub_layer_row['layer_abstract'] <> NULL)
+ #Creating the "Abstract" node
+ if($sub_layer_row['layer_abstract'] <> "" AND $sub_layer_row['layer_abstract'] <> NULL) {
+ $layerAbstract = $sub_layer_row['layer_abstract'];
+ } else {
+ $layerAbstract = _mb('No abtract for the specific layer was given, please add a description to your layer ressource.');
$abstract = $sub_layer->appendChild($abstract);
- $abstractText = $doc->createTextNode($sub_layer_row['layer_abstract']);
$keyword_sql = "SELECT DISTINCT keyword FROM layer LEFT JOIN layer_keyword ON layer_keyword.fkey_layer_id = layer.layer_id LEFT JOIN keyword ON keyword.keyword_id = layer_keyword.fkey_keyword_id WHERE layer.fkey_wms_id = ".$wms_row['wms_id']." AND layer.layer_id = ".$sub_layer_row['layer_id']."";
@@ -1013,7 +1017,7 @@
$keywordlistExist = 0;
while ($keyword_sql = db_fetch_array($res_keyword_sql))
- #Creating the "KeywordList" node
+ #Initially creating the "KeywordList" node
if ($keywordlistExist == 0)
$keywordList = $doc->createElement("KeywordList");
@@ -1023,8 +1027,14 @@
+ $keyword = $keyword_sql['keyword'];
+ } else {
+ $keyword = _mb('Empty keyword was given, please add a keyword to your layer ressource.');
+ $keyword_domText = $doc->createTextNode($keyword);
Modified: trunk/mapbender/http/plugins/mb_metadata_server.php
--- trunk/mapbender/http/plugins/mb_metadata_server.php 2012-06-06 11:56:32 UTC (rev 8369)
+++ trunk/mapbender/http/plugins/mb_metadata_server.php 2012-06-06 15:19:06 UTC (rev 8370)
@@ -920,13 +920,15 @@
$e = new mb_exception("plugins/mb_metadata_server.php: code given thru MD_Identifier: ".$code[0]);
+ $codeSplit = explode("#",$code[0]);
$e = new mb_exception("plugins/mb_metadata_server.php: code was constructed via codespace#code !");
+ $datasetid = $code[0];
+ $datasetid_codespace = "";
} else {
$e = new mb_exception("plugins/mb_metadata_server.php: code was not constructed via codespace#code !");
@@ -934,7 +936,8 @@
#$e = new mb_exception("plugins/mb_metadata_server.php: code: ".$code[0]);
#$e = new mb_exception("plugins/mb_metadata_server.php: codeSpace: ".$codeSpace[0]);
+ $datasetid_codespace = $codeSpace[0];
$e = new mb_exception("plugins/mb_metadata_server.php: datasetid: ".$datasetid);
} else {
@@ -963,11 +966,11 @@
$sql = <<<SQL
-INSERT INTO mb_metadata (link, uuid, origin, title, abstract, format, ref_system, export2csw, inspire_top_consistence, tmp_reference_1, tmp_reference_2, lineage, spatial_res_type, spatial_res_value, inspire_charset, createdate, datasetid, randomid, data, harvestresult) VALUES ($1, $2, $3, $4, $5, $6, $7, $8, $9, $10, $11, $12, $13, $14, $15, now(), $16, $17, $18, 1)
+INSERT INTO mb_metadata (link, uuid, origin, title, abstract, format, ref_system, export2csw, inspire_top_consistence, tmp_reference_1, tmp_reference_2, lineage, spatial_res_type, spatial_res_value, inspire_charset, createdate, datasetid, randomid, data, harvestresult, datasetid_codespace) VALUES ($1, $2, $3, $4, $5, $6, $7, $8, $9, $10, $11, $12, $13, $14, $15, now(), $16, $17, $18, 1, $19)
SQL;
- $v = array($link, $uuid[0], $origin, $title[0], $abstract[0], $format, $ref_system, $export2csw,$inspire_top_consistence,$tmp_reference_1[0],$tmp_reference_2[0],$lineage,$spatial_res_type,$spatial_res_value,$inspire_charset, $datasetid, $randomid, $metaData);
- $t = array('s','s','s','s','s','s','s','b','b','s','s','s','s','s','s','s','s','s');
+ $v = array($link, $uuid[0], $origin, $title[0], $abstract[0], $format, $ref_system, $export2csw,$inspire_top_consistence,$tmp_reference_1[0],$tmp_reference_2[0],$lineage,$spatial_res_type,$spatial_res_value,$inspire_charset, $datasetid, $randomid, $metaData, $datasetid_codespace);
+ $t = array('s','s','s','s','s','s','s','b','b','s','s','s','s','s','s','s','s','s','s');
try {
Modified: trunk/mapbender/http/plugins/mb_metadata_wfs_server.php
--- trunk/mapbender/http/plugins/mb_metadata_wfs_server.php 2012-06-06 11:56:32 UTC (rev 8369)
+++ trunk/mapbender/http/plugins/mb_metadata_wfs_server.php 2012-06-06 15:19:06 UTC (rev 8370)
@@ -750,6 +750,7 @@
} else {
abort(_mb("Problem with parsing the XML structure with SimpleXML! Record was not inserted into database! Ask your administrator."));
//give back error message - cause parsing has problems
@@ -935,10 +936,12 @@
} else {
@@ -946,7 +949,8 @@
} else {
@@ -976,14 +980,14 @@
$sql = <<<SQL
SQL;
$xml = $iso19139Xml->asXML();
- $v = array($link, $uuid[0], $origin, $title[0], $abstract[0], $format, $ref_system, $export2csw,$inspire_top_consistence,$tmp_reference_1[0],$tmp_reference_2[0],$lineage,$spatial_res_type,$spatial_res_value,$inspire_charset, $datasetid, $randomid, $xml);
+ $v = array($link, $uuid[0], $origin, $title[0], $abstract[0], $format, $ref_system, $export2csw, $inspire_top_consistence,$tmp_reference_1[0],$tmp_reference_2[0],$lineage,$spatial_res_type,$spatial_res_value,$inspire_charset, $datasetid, $randomid, $xml,$datasetid_codespace);
try {
Modified: trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.7.2_to_2.7.3_pgsql_UTF-8.sql
--- trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.7.2_to_2.7.3_pgsql_UTF-8.sql 2012-06-06 11:56:32 UTC (rev 8369)
+++ trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.7.2_to_2.7.3_pgsql_UTF-8.sql 2012-06-06 15:19:06 UTC (rev 8370)
@@ -437,5 +437,6 @@
ALTER TABLE mb_monitor ALTER COLUMN map_url TYPE varchar;
ALTER TABLE mb_monitor ALTER COLUMN cap_diff TYPE text;
+--Add handling of codespaces as demanded from the INSPIRE regulation
+ALTER TABLE mb_metadata ADD COLUMN datasetid_codespace TEXT;
More information about the Mapbender_commits
