[Mapbender-commits] r8374 - in trunk/mapbender: http/classes http/php http/plugins resources/db/pgsql/UTF-8/update
svn_mapbender at osgeo.org
Mon Jun 11 13:56:50 PDT 2012
Author: armin11
Date: 2012-06-11 13:56:49 -0700 (Mon, 11 Jun 2012)
New Revision: 8374
trunk/mapbender/http/classes/class_iso19139.php
trunk/mapbender/http/classes/class_wfsToDb.php
trunk/mapbender/http/classes/class_wms.php
trunk/mapbender/http/php/mod_deleteWMS.php
trunk/mapbender/http/plugins/mb_metadata_server.php
trunk/mapbender/http/plugins/mb_metadata_wfs_server.php
trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.7.2_to_2.7.3_pgsql_UTF-8.sql
Change of mb_metadata handling for INSPIRE and SDI conformity. With the new handling, no doubled entries should be generated. Mapbender checks if a MetadataURL does already exists. If so, the metadata will be updated and only a new relation will be inserted into database. Independent updates of wms and wfs resources will result in independent updates of coupled metadata resources. TODOs: 1. check handling for metadata upload and linkage (mapbender ows metadata editors), 2. push origin from mb_metadata to ows_relation_metadata for existing dbs (update sql), 3. give back messages from class_iso19139 to metadata_server components. 4. control internal link function - make a concept for this (a posteriori service-metadata coupling), 5. less debug messages
Modified: trunk/mapbender/http/classes/class_iso19139.php
--- trunk/mapbender/http/classes/class_iso19139.php 2012-06-07 09:03:25 UTC (rev 8373)
+++ trunk/mapbender/http/classes/class_iso19139.php 2012-06-11 20:56:49 UTC (rev 8374)
@@ -1,5 +1,4 @@
<?php
-# $Id: class_iso19139.php 3094 2008-10-01 13:52:35Z christoph $
# http://www.mapbender.org/index.php/class_iso19139.php
# Copyright (C) 2002 CCGIS
@@ -39,6 +38,18 @@
var $format;
var $type;
var $origin;
+ var $owner;
+ var $harvestResult;
+ var $harvestException;
+ //new
+ var $lineage;
+ var $inspireTopConsistence; //bool
+ var $spatialResType;
+ var $spatialResValue;
+ var $export2Csw; //bool
+ var $updateFrequency;
+ var $dataFormat;
+ var $inspireCharset;
function __construct() {
//initialize empty iso19139 object
@@ -55,12 +66,25 @@
$this->tmpExtentBegin = "1900-01-01";
$this->tmpExtentEnd = "1900-01-01";
$this->randomId = "";
+ $this->owner = 0; //dummy entry for metadata owner - in case of metadataURL entries the owner of the corresponding service
$this->href = "";
$this->format = "";
$this->type = "";
$this->origin = "";
$this->refSystem = "";
+ $this->harvestResult = 0;
+ $this->harvestException = "";
+ $this->lineage = "";
+ $this->inspireTopConsistence = "f";
+ $this->spatialResType = "";
+ $this->spatialResValue = "";
+ $this->export2Csw = "t";
+ $this->updateFrequency = "";
+ $this->dataFormat = "";
+ $this->inspireCharset = "";
public function removeGetRecordTag ($xml) {
$regex = "#<csw:GetRecordByIdResponse .*?>#";
$xml = preg_replace($regex,"",$xml);
@@ -146,6 +170,7 @@
public function createFromUrl($url){
$metadataConnector = new connector($url);
+ $metadataConnector->set("timeOut", "5");
$xml = $metadataConnector->file;
$mbMetadata = $this->createMapbenderMetadataFromXML($xml);
return $mbMetadata;
@@ -155,23 +180,104 @@
return $this;
- public function insertMetadataUrlToDB($resourceType, $resourceId){
- $sql = "INSERT INTO mb_metadata (link, origin, md_format, linktype, createdate, changedate, export2csw, randomid) ";
- $sql .= "VALUES($1, $2, $3, $4, now(), now(), $5, $6)";
+ public function deleteMetadataRelation($resourceType, $resourceId, $relationType){
+ //delete all relations which are defined from capabilities - this don't delete the metadata entries themself!
+ //all other relations stay alive
+ $sql = "DELETE FROM ows_relation_metadata WHERE fkey_".$resourceType."_id = $1 AND relation_type = '".$relationType."'";
+ $v = array($resourceId);
+ $t = array('i');
+ $res = db_prep_query($sql,$v,$t);
+ if(!$res){
+ $e = new mb_exception("Cannot delete metadata relations for resource ".$resourceType." with id: ".$resourceId);
+ return false;
+ } else {
+ return true;
+public function checkMetadataRelation($resourceType, $resourceId, $metadataId){
+ //check if one relation already exists - if so no new one should be generated!!!
+ public function isLinkAlreadyInDB(){
+ $sql = <<<SQL
+SELECT metadata_id FROM mb_metadata WHERE link = $1 ORDER BY lastchanged DESC
+SQL;
$v = array(
- $this->href,
- $this->origin,
- $this->format,
- $this->type,
- 'f',
- $this->randomId
+ $this->href
- $t = array('s','s','s','s','b','s');
+ $t = array('s');
+ while ($row = db_fetch_array($res)){
+ $metadataId[] = $row['metadata_id'];
+ if (count($metadataId) > 0) {
+ return $metadataId;
+ } else {
+ return false;
+ public function isFileIdentifierAlreadyInDB(){
+ $sql = <<<SQL
+SELECT metadata_id FROM mb_metadata WHERE uuid = $1 ORDER BY lastchanged DESC
+SQL;
+ $v = array(
+ $this->fileIdentifier
+ $t = array('s');
+ $metadataId = array();
+ } else {
+ return false;
+ public function insertMetadataUrlToDB($resourceType, $resourceId){
+ //check if metadata record already exists, if not create a new one else insert relation only!
+ $metadataId = $this->isLinkAlreadyInDB();
+ if ($metadataId != false) {
+ //update the metadataURL entry
+ $e = new mb_exception("existing metadata link(s) found: ".$metadataId[0]." - update will be performed");
+ $sql = "UPDATE mb_metadata SET link = $1, origin = $2, md_format = $3, linktype = $4, changedate = now(), export2csw = $5, randomid = $6, harvestresult = $8, harvestexception = $9 WHERE metadata_id = $7";
+ $v = array(
+ $this->href,
+ $this->origin,
+ $this->format,
+ $this->type,
+ 'f',
+ $this->randomId,
+ $metadataId[0],
+ $this->harvestResult,
+ $t = array('s','s','s','s','b','s','i','i','s');
+ } else {
+ $sql = "INSERT INTO mb_metadata (link, origin, md_format, linktype, createdate, changedate, export2csw, randomid, fkey_mb_user_id, harvestresult, harvestexception) ";
+ $sql .= "VALUES($1, $2, $3, $4, now(), now(), $5, $6, $7, $8, $9)";
+ $v = array(
+ $this->href,
+ $this->origin,
+ $this->format,
+ $this->type,
+ 'f',
+ $this->randomId,
+ $this->owner,
+ $this->harvestresult,
+ $this->harvestexception
if(!$res){
db_rollback();
- $e = new mb_exception(_mb("Cannot save metadataUrl top database!"));
+ $e = new mb_exception(_mb("Cannot insert or update metadataUrl in database!"));
return false;
} else {
//insert relation into db
@@ -198,13 +304,13 @@
$metadataId = $row['metadata_id'];
//insert relation to layer/featuretype
if ($resourceType == 'layer') {
- $sql = "INSERT INTO ows_relation_metadata (fkey_layer_id, fkey_metadata_id) values ($1, $2);";
+ $sql = "INSERT INTO ows_relation_metadata (fkey_layer_id, fkey_metadata_id, relation_type) values ($1, $2, $3);";
if ($resourceType == 'featuretype') {
- $sql = "INSERT INTO ows_relation_metadata (fkey_featuretype_id, fkey_metadata_id) values ($1, $2);";
+ $sql = "INSERT INTO ows_relation_metadata (fkey_featuretype_id, fkey_metadata_id, relation_type) values ($1, $2, $3);";
- $v = array($resourceId, $metadataId);
- $t = array('i','i');
+ $v = array($resourceId, $metadataId, $this->origin);
+ $t = array('i','i', 's');
if(!$res){
db_rollback();
@@ -228,32 +334,99 @@
public function insertToDB($resourceType, $resourceId){
- $sql = "INSERT INTO mb_metadata (link, origin, md_format, data, linktype, uuid, title, createdate, changedate, abstract, searchtext, type, tmp_reference_1, tmp_reference_2, export2csw, datasetid, datasetid_codespace, randomid) ";
- $sql .= "VALUES($1, $18, $2, $3, $4, $5, $6, $7, $8, $9, $10, $11, $12, $13, $14, $15, $16, $17)";
- $v = array($this->href,
- $this->format,
- $this->metadata,
- $this->type,
- $this->fileIdentifier[0],
- $this->title[0],
- $this->createDate,
- $this->changeDate,
- $this->abstract[0],
- $this->keywords[0],
- $this->hierachyLevel,
- $this->tmpExtentBegin,
- $this->tmpExtentEnd,
- 't',
- $this->datasetId,
- $this->datasetIdCodeSpace,
- $this->randomId,
- $this->origin
- $t = array('s','s','s','s','s','s','s','s','s','s','s','s','s','b','s','s','s','s');
- $res = db_prep_query($sql,$v,$t);
+ //check if metadata record already exists, if not create a new one, else insert relation only!
+ $metadataId = $this->isFileIdentifierAlreadyInDB();
+ //update the metadata - new random id set therefor there is no problem when setting the relation afterwards
+ $e = new mb_exception("existing metadata fileIdentifier found at metadata with id: ".$metadataId[0]." - update will be performed");
+ //problem: <<<SQL have a limited number of chars!
+ $sql = "UPDATE mb_metadata SET link = $1, origin = $18, md_format = $2, data = $3, ";
+ $sql .= "linktype = $4, uuid = $5, title = $6, createdate = $7, changedate = $8, lastchanged = now(), ";
+ $sql .= "abstract = $9, searchtext = $10, type = $11, tmp_reference_1 = $12, tmp_reference_2 = $13, export2csw = $14, datasetid = $15, ";
+ $sql .= "datasetid_codespace = $16, randomid = $17, harvestresult = $20, harvestexception = $21, lineage = $22, inspire_top_consistence = $23, ";
+ $sql .= "spatial_res_type = $24, spatial_res_value = $25, update_frequency = $26, format = $27, inspire_charset = $28 WHERE metadata_id = $19";
+ $v = array(
+ $this->href,
+ $this->format,
+ $this->metadata,
+ $this->type,
+ $this->fileIdentifier,
+ $this->title,
+ $this->createDate,
+ $this->changeDate,
+ $this->abstract,
+ $this->keywords[0],
+ $this->hierachyLevel,
+ $this->tmpExtentBegin,
+ $this->tmpExtentEnd,
+ $this->export2Csw,
+ $this->datasetId,
+ $this->datasetIdCodeSpace,
+ $this->randomId,
+ $this->origin,
+ //$this->owner, //owner is the old one - maybe here we have something TODO!
+ $metadataId[0], //The first metadataId which was found will be selected!
+ $this->harvestException,
+ $this->lineage,
+ $this->inspireTopConsistence,
+ $this->spatialResType,
+ $this->spatialResValue,
+ $this->updateFrequency,
+ $this->dataFormat,
+ $t = array('s','s','s','s','s','s','s','s','s','s','s','s','s','b','s','s','s','s','i','i','s','s','b','s','s','s','s','s');
+ } else {
+ //insert new record
+ $e = new mb_exception("existing metadata fileIdentifier found at metadata with id: ".$metadataId[0]);
+ $sql = <<<SQL
+INSERT INTO mb_metadata (lastchanged, link, origin, md_format, data, linktype, uuid, title, createdate, changedate, abstract, searchtext, type, tmp_reference_1, tmp_reference_2, export2csw, datasetid, datasetid_codespace, randomid, fkey_mb_user_id, harvestresult, harvestexception, lineage, inspire_top_consistence, spatial_res_type, spatial_res_value, update_frequency, format, inspire_charset) VALUES(now(), $1, $18, $2, $3, $4, $5, $6, $7, $8, $9, $10, $11, $12, $13, $14, $15, $16, $17, $19, $20, $21, $22, $23, $24, $25, $26, $27, $28)
+SQL;
+ $v = array(
+ $this->href,
+ $this->format,
+ $this->metadata,
+ $this->type,
+ $this->title,
+ $this->abstract,
+ $this->datasetId,
+ $this->randomId,
+ $this->origin,
+ $this->owner,
+ $this->lineage,
if(!$res){
db_rollback();
- $e = new mb_exception(_mb("Cannot insert metadata record into mapbenders mb_metadata table!"));
+ $e = new mb_exception(_mb("Cannot insert or update metadata record into mapbenders mb_metadata table!"));
return false;
} else {
@@ -280,13 +453,13 @@
+ $t = array('i','i','s');
if(!$res){
db_rollback();
Modified: trunk/mapbender/http/classes/class_wfsToDb.php
--- trunk/mapbender/http/classes/class_wfsToDb.php 2012-06-07 09:03:25 UTC (rev 8373)
+++ trunk/mapbender/http/classes/class_wfsToDb.php 2012-06-11 20:56:49 UTC (rev 8374)
@@ -22,6 +22,7 @@
require_once(dirname(__FILE__)."/class_administration.php");
require_once(dirname(__FILE__)."/class_wfs.php");
require_once dirname(__FILE__) . "/class_Uuid.php";
+require_once dirname(__FILE__) . "/class_iso19139.php";
//require_once dirname(__FILE__) . "//class_Uuid.php";
class WfsToDb {
@@ -267,7 +268,7 @@
public static function delete ($aWfs) {
//first delete coupled metadata, cause there is no contraints in the database to do so
$e = new mb_exception("Deleting MetadataURLs for wfs with id :".$aWfs->id);
- WfsToDb::deleteFeatureTypeMetadataUrls($aWfs->id);
+ //WfsToDb::deleteFeatureTypeMetadataUrls($aWfs->id); //Not needed any more, cause the relations are deleted thru class_iso19139.php
//then delete wfs itself
$sql = "DELETE FROM wfs WHERE wfs_id = $1";
$v = array($aWfs->id);
@@ -366,94 +367,70 @@
* @param $metadataUrl object
private static function insertFeatureTypeMetadataUrl ($aWfsFeatureTypeId, $metadataUrl, $withParsing = false) {
- $randomid = new Uuid();
- if ($withParsing == true) {
- //check if format can be parsed - possible only for one format (INSPIRE)
- if (($metadataUrl->type == 'ISO19115:2003' && $metadataUrl->format =='text/xml') || ($metadataUrl->type == 'TC211' && $metadataUrl->format =='text/xml')) {
- //extract all relevant information - maybe mapbender metadata object! TODO!!!
- $metaData = "";
- $uuid = "";
- $title = "";
- $createdate = "1900-01-01";
- $changedate = "1900-01-01";
- $abstract = "";
- $keywords = "";
- $type = "";
- $tmp_reference_1 = "1900-01-01";
- $tmp_reference_2 = "1900-01-01";
- $export2csw = 't';
- $datasetid = "";
- //harvest metadata thru web
- //harvest = 1;
+ //function as defined in class wms!
+ //origin 2 - set by mapbender metadata editor - new record
+ //origin 3 - set by mapbender metadata editor - new linkage
+ //harvest the record if some readable format is given - should this be adoptable?
+ //parse the content if iso19139 is given
+ //TODO: generate temporal uuid for inserting and getting the serial afterwards
+ //delete old relations for this resource - only those which are from 'capabilities'
+ $mbMetadata_1 = new Iso19139();
+ $mbMetadata_1->deleteMetadataRelation("featuretype", $aWfsFeatureTypeId,"capabilities");
+ //check for returned format?
+ if (($metadataUrl->type == 'ISO19115:2003' && $metadataUrl->format =='text/xml') || ($metadataUrl->type == 'TC211' && $metadataUrl->format =='text/xml')) {
+ //load metadata from link
+ $mbMetadata = new Iso19139();
+ $randomid = new Uuid();
+ $mbMetadata = $mbMetadata->createFromUrl($metadataUrl->href);
+ $mdOwner = Mapbender::session()->get("mb_user_id");
+ $e = new mb_exception("owner: ".$mdOwner);
+ if ($mbMetadata != false) { //metadata has been parsed
+ //set randomId for metadata
+ $mbMetadata->randomId = $randomid;
+ $mbMetadata->href = $metadataUrl->href;
+ $mbMetadata->format = $metadataUrl->format;
+ $mbMetadata->type = $metadataUrl->type;
+ $mbMetadata->origin = "capabilities";
+ $mbMetadata->owner = $mdOwner;
+ //push metadata object into database
+ if (!$mbMetadata->insertToDB("featuretype",$aWfsFeatureTypeId)) {
+ $e = new mb_exception("Problem while storing metadata to mb_metadata table!");
+ } else {
+ $e = new mb_notice("Metadata with id ".$randomid." stored to db!");
+ } else {
+ //parsing had problems - fill only the urls into database and give a reasonable error message
+ if (!$mbMetadata->insertMetadataUrlToDB("featuretype",$aWfsFeatureTypeId)) {
+ $e = new mb_exception("Problem while storing MetadataURL entry from wfs capabilities to mb_metadata table!");
+ } else {
+ $e = new mb_exception("Stored MetadataURL ".$mbMetadata->href." from wfs capabilities to mb database cause the target could not be accessed or parsed!");
} else {
- $metaData = "";
- $uuid = "";
- $title = "";
- $abstract = "";
- $keywords = "";
- $type = "";
- $datasetid = "";
+ //insert link into database but do not try to parse the metadata
+ $mbMetadata->harvestException = "Metadata format is not known to mapbender!";
+ $mbMetadata->harvestResult = 0;
+ } else {
- //insert result into database
- $sql = "INSERT INTO mb_metadata (link, origin, md_format, data, linktype, uuid, title, createdate, changedate, abstract, searchtext, type, tmp_reference_1, tmp_reference_2, export2csw, datasetid, randomid) ";
- $sql .= "VALUES($1, 'capabilities', $2, $3, $4, $5, $6, $7, $8, $9, $10, $11, $12, $13, $14, $15, $16)";
- $v = array($metadataUrl->href,
- $metadataUrl->format,
- $metaData,
- $metadataUrl->type,
- $uuid,
- $title,
- $createdate,
- $changedate,
- $abstract,
- $keywords,
- $type,
- $tmp_reference_1,
- $tmp_reference_2,
- $export2csw,
- $datasetid,
- $randomid
- $t = array('s','s','s','s','s','s','s','s','s','s','s','s','s','b','s','s');
- if(!$res){
- db_rollback();
- //get metadata id with uuid which was generated
- $sql = <<<SQL
-SELECT metadata_id FROM mb_metadata WHERE randomid = $1 ORDER BY lastchanged DESC LIMIT 1
-SQL;
- //maybe there are more than one results - which should be used??? case of creating new linkage with old metadata TODO TODO
- $v = array($randomid);
- $t = array('s');
- try {
- catch (Exception $e){
- abort(_mb("Cannot get metadata record with following uuid from database: ".$uuid));
- if ($res) {
- $row = db_fetch_assoc($res);
- $mdId = $row['metadata_id'];
- //insert into ows_relation_metadata (fkey_layer_id, fkey_metadata_id) values (20131,3);
- $v = array($aWfsFeatureTypeId, $mdId);
- if(!$res){
- db_rollback();
- $e = new mb_exception("MetadataURL of featuretype with id: ".$aWfsFeatureTypeId." cannot be stored to database!");
- $e = new mb_exception("INSERTING FT MetadataURL (FT: ".$aWfsFeatureTypeId.", MetadataURL: ".$metadataUrl->href);
return true;
@@ -797,15 +774,15 @@
//update MetadataURLs
- //delete old MetadataURLs from caps
- $sql = <<<SQL
+ //delete old MetadataURLs from caps - TODO delete this, cause the new way is only to delete the relations and to hold the metadata entries
+ /*$sql = <<<SQL
DELETE FROM mb_metadata WHERE metadata_id IN (SELECT metadata_id FROM mb_metadata INNER JOIN (SELECT * from ows_relation_metadata WHERE fkey_featuretype_id = $1) as relation ON mb_metadata.metadata_id = relation.fkey_metadata_id AND mb_metadata.origin = 'capabilities')
SQL;
$v = array($aWfsFeatureType->id);
$t = array('i');
+ $res = db_prep_query($sql,$v,$t);*/
// insert feature type MetadataURL from caps
for ($i = 0; $i < count($aWfsFeatureType->metadataUrlArray); $i++) {
$metadataUrl = $aWfsFeatureType->metadataUrlArray[$i];
@@ -891,7 +868,7 @@
- * Deletes an implicitly coupled metadata of a wfs from the database.
+ * Deprecated: Deletes an implicitly coupled metadata of a wfs from the database.
* @return Boolean
Modified: trunk/mapbender/http/classes/class_wms.php
--- trunk/mapbender/http/classes/class_wms.php 2012-06-07 09:03:25 UTC (rev 8373)
+++ trunk/mapbender/http/classes/class_wms.php 2012-06-11 20:56:49 UTC (rev 8374)
@@ -12,6 +12,7 @@
require_once dirname(__FILE__) . "/class_administration.php";
require_once dirname(__FILE__) . "/class_georss_factory.php";
require_once dirname(__FILE__) . "/class_mb_exception.php";
+$e = new mb_exception("test");
require_once dirname(__FILE__) . "/../classes/class_universal_wms_factory.php";
@@ -2357,19 +2358,16 @@
function insertLayerMetadataUrls($i){
- //first delete the old ones - but only those who have been harvested thru caps before!
global $con;
- $sql = "DELETE FROM mb_metadata WHERE metadata_id IN (SELECT metadata_id FROM mb_metadata INNER JOIN";
- $sql .= " (SELECT * from ows_relation_metadata WHERE fkey_layer_id = $1) as relation ON ";
- $sql .= " mb_metadata.metadata_id = relation.fkey_metadata_id AND mb_metadata.origin = 'capabilities')";
- $v = array($this->objLayer[$i]->db_id);
- $t = array('i');
+ $mbMetadata_1->deleteMetadataRelation("layer", $this->objLayer[$i]->db_id,"capabilities");
+ //delete object?
for($j=0; $j<count($this->objLayer[$i]->layer_metadataurl);$j++){
if (($this->objLayer[$i]->layer_metadataurl[$j]->type == 'ISO19115:2003' && $this->objLayer[$i]->layer_metadataurl[$j]->format =='text/xml') || ($this->objLayer[$i]->layer_metadataurl[$j]->type == 'TC211' && $this->objLayer[$i]->layer_metadataurl[$j]->format =='text/xml')) {
@@ -2377,13 +2375,19 @@
$mbMetadata = $mbMetadata->createFromUrl($this->objLayer[$i]->layer_metadataurl[$j]->href);
- //create randomId for metadata
$mbMetadata->href = $this->objLayer[$i]->layer_metadataurl[$j]->href;
$mbMetadata->format = $this->objLayer[$i]->layer_metadataurl[$j]->format;
$mbMetadata->type = $this->objLayer[$i]->layer_metadataurl[$j]->type;
if (!$mbMetadata->insertToDB("layer",$this->objLayer[$i]->db_id)) {
@@ -2398,12 +2402,30 @@
if (!$mbMetadata->insertMetadataUrlToDB("layer",$this->objLayer[$i]->db_id)) {
$e = new mb_exception("Problem while storing MetadataURL entry from wms capabilities to mb_metadata table!");
} else {
$e = new mb_notice("Stored MetadataURL ".$mbMetadata->href." from wms capabilities to mb database cause the target could not be accessed or parsed!");
+ } else {
+ $mbMetadata->href = $this->objLayer[$i]->layer_metadataurl[$j]->href;
+ $mbMetadata->format = $this->objLayer[$i]->layer_metadataurl[$j]->format;
+ $mbMetadata->type = $this->objLayer[$i]->layer_metadataurl[$j]->type;
+ if (!$mbMetadata->insertMetadataUrlToDB("layer",$this->objLayer[$i]->db_id)) {
+ $e = new mb_exception("Problem while storing MetadataURL entry from wms capabilities to mb_metadata table!");
+ } else {
+ $e = new mb_notice("Stored MetadataURL ".$mbMetadata->href." from wms capabilities to mb database cause the target could not be accessed or parsed!");
Modified: trunk/mapbender/http/php/mod_deleteWMS.php
--- trunk/mapbender/http/php/mod_deleteWMS.php 2012-06-07 09:03:25 UTC (rev 8373)
+++ trunk/mapbender/http/php/mod_deleteWMS.php 2012-06-11 20:56:49 UTC (rev 8374)
@@ -204,7 +204,7 @@
//Before the wms will be deleted, the metadataUrls and dataUrls from the Layers must be deleted!
//The other things will be done by class_wms!
+ /*$sql = "DELETE FROM mb_metadata WHERE metadata_id IN (SELECT metadata_id FROM mb_metadata INNER JOIN";
$sql .= " (SELECT * from ows_relation_metadata WHERE fkey_layer_id IN ";
$sql .= " (SELECT layer_id FROM layer WHERE fkey_wms_id = $1) )";
$sql .= " as relation ON ";
@@ -212,7 +212,7 @@
$v = array($wmsList);
$t = array('i');
$sql = "DELETE FROM datalink WHERE datalink_id IN (SELECT datalink_id FROM datalink INNER JOIN";
$sql .= " (SELECT * from ows_relation_data WHERE fkey_layer_id IN ";
Modified: trunk/mapbender/http/plugins/mb_metadata_server.php
--- trunk/mapbender/http/plugins/mb_metadata_server.php 2012-06-07 09:03:25 UTC (rev 8373)
+++ trunk/mapbender/http/plugins/mb_metadata_server.php 2012-06-11 20:56:49 UTC (rev 8374)
@@ -717,7 +717,7 @@
break;
case "getOwnedMetadata" :
- $featuretypeId = $ajaxResponse->getParameter("layerId");
+ $layerId = $ajaxResponse->getParameter("layerId");
$user = new User(Mapbender::session()->get("mb_user_id"));
//$e = new mb_exception("plugins/mb_metadata_wfs_server.php: user_id: ".$user->id);
@@ -741,7 +741,7 @@
$ajaxResponse->setResult($resultObj);
$ajaxResponse->setSuccess(true);
break;
case "insertLayerMetadataAddon" :
$data = $ajaxResponse->getParameter("data");
@@ -756,7 +756,7 @@
$sql = <<<SQL
-INSERT INTO ows_relation_metadata (fkey_metadata_id, fkey_layer_id, internal) VALUES ( $1, $2, $3)
+INSERT INTO ows_relation_metadata (fkey_metadata_id, fkey_layer_id, internal, relation_type) VALUES ( $1, $2, $3, 'internal')
SQL;
$v = array($data->internal_relation,$layerId, 1);
@@ -790,252 +790,102 @@
//generate a uuid for the record:
$uuid = new Uuid();
//initialize database objects
- $link = '';
- $title = '';
- $abstract = '';
- $format = '';
- $ref_system = '';
- $export2csw = 'f';
- $inspire_top_consistence = 'f';
- $tmp_reference_1 = '';
- $tmp_reference_2 = '';
- $lineage = '';
- $spatial_res_type = '';
- $spatial_res_value = '';
- $inspire_charset = '';
- $update_frequency = '';
+ //are initialized from class_iso19139
//read out json objects
if (isset($data->link)) {
- $link = $data->link;
+ $mbMetadata->href = $data->link;
if (isset($data->export2csw)) {
- $export2csw = $data->export2csw;
+ $mbMetadata->export2Csw = $data->export2csw;
} else {
+ $mbMetadata->export2Csw = 'f';
if (isset($data->title)) {
- $title = $data->title;
+ $mbMetadata->title = $data->title;
if (isset($data->abstract)) {
- $abstract = $data->abstract;
+ $mbMetadata->abstract = $data->abstract;
if (isset($data->format)) {
- $format = $data->format;
+ $mbMetadata->dataFormat = $data->format;
if (isset($data->ref_system)) {
- $ref_system = $data->ref_system;
+ $mbMetadata->refSystem = $data->ref_system;
if (isset($data->inspire_top_consistence)) {
- $inspire_top_consistence = $data->inspire_top_consistence;
+ $mbMetadata->inspireTopConsistence = $data->inspire_top_consistence;
if (isset($data->tmp_reference_1)) {
- $tmp_reference_1 = $data->tmp_reference_1;
+ $mbMetadata->tmpExtentBegin = $data->tmp_reference_1;
- if ($tmp_reference_1 == "") {
- $tmp_reference_1 = "2000-01-01";
if (isset($data->tmp_reference_2)) {
- $tmp_reference_2 = $data->tmp_reference_2;
+ $mbMetadata->tmpExtentEnd = $data->tmp_reference_2;
- if ($tmp_reference_2 == "") {
- $tmp_reference_2 = "2000-01-01";
if (isset($data->lineage)) {
- $lineage = $data->lineage;
+ $mbMetadata->lineage = $data->lineage;
if (isset($data->spatial_res_type)) {
- $spatial_res_type = $data->spatial_res_type;
+ $mbMetadata->spatialResType = $data->spatial_res_type;
if (isset($data->spatial_res_value)) {
- $spatial_res_value = $data->spatial_res_value;
+ $mbMetadata->spatialResValue = $data->spatial_res_value;
if (isset($data->inspire_charset)) {
- $inspire_charset = $data->inspire_charset;
+ $mbMetadata->inspireCharset = $data->inspire_charset;
if (isset($data->update_frequency)) {
- $update_frequency = $data->update_frequency;
+ $mbMetadata->updateFrequency = $data->update_frequency;
//Check if origin is external and export2csw is activated!
if ($origin == 'external' ) {
//harvest link from location, parse the content for datasetid and push xml into data column
- //load metadata from link TODO: function from class_wms - generate a class for metadata management and include it here and in class_wms
- $metadataConnector = new connector();
- $metadataConnector->set("timeOut", "5");
- $metaData = $metadataConnector->load($link);
- //$e = new mb_exception($metaData);
- if (!$metaData) {
- abort(_mb("Could not load metadata from source url!"));
- //delete getRecordByIdResponse from xml if there
- $regex = "#<csw:GetRecordByIdResponse .*?>#";
- $output = preg_replace($regex,"",$metaData);
- $regex = "#</csw:GetRecordByIdResponse>#";
- $output = preg_replace($regex,"",$output);
- //$e = new mb_exception($output);
- $metaData = $output;
- //write metadata to temporary file:
- $randomFileId = new Uuid();
- $tmpMetadataFile = fopen(TMPDIR.'/link_metadata_file_'.$randomFileId.'.xml', 'w');
- fwrite($tmpMetadataFile, $metaData);
- fclose($tmpMetadataFile);
- $e = new mb_exception("File which has been written: link_metadata_file_".$randomFileId.".xml");
- //read out objects from xml structure
- if (file_exists(TMPDIR.'/link_metadata_file_'.$randomFileId.'.xml')) {
- $iso19139Xml=simplexml_load_file(TMPDIR.'/link_metadata_file_'.$randomFileId.'.xml');
- //$metaData = file_get_contents(TMPDIR.'/link_metadata_file_'.$randomFileId.'.xml');
+ $mbMetadata = $mbMetadata->createFromUrl($mbMetadata->href);
+ $mbMetadata->format = "text/xml";
+ $mbMetadata->type = "ISO19115:2003";
+ $mbMetadata->origin = "external";
+ if (!$mbMetadata->insertToDB("layer",$layerId)) {
+ } else {
} else {
- abort(_mb("Temporary file could not be parsed!"));
- //$metaData = $metadataConnector->file;
- //parse metadata
- /*try {
- $iso19139Xml = new SimpleXMLElement($metaData);
- catch (Exception $e) {
- abort(_mb("Parsing ISO19139 XML failed!"));
- if ($iso19139Xml != false) {
- //get elements for database from xml by using xpath
- //uuid
- $uuid = $iso19139Xml->xpath('/gmd:MD_Metadata/gmd:fileIdentifier/gco:CharacterString');
- $e = new mb_exception("plugins/mb_metadata_server.php: File Identifier found: ".$uuid);
- //createdate
- $createdate = $iso19139Xml->xpath('/gmd:MD_Metadata/gmd:dateStamp/gco:Date');
- //changedate
- $changedate = $iso19139Xml->xpath('/gmd:MD_Metadata/gmd:dateStamp/gco:Date');
- //TODO: check if this is set, maybe DateTime must be searched instead?
- //title
- $title = $iso19139Xml->xpath('/gmd:MD_Metadata/gmd:identificationInfo/gmd:MD_DataIdentification/gmd:citation/gmd:CI_Citation/gmd:title/gco:CharacterString');
- //datasetid
- //next came from class_wms - TODO maybe put it into a special function
- //dataset identifier - howto model into md_metadata?
- //check where datasetid is defined - maybe as RS_Identifier or as MD_Identifier see http://inspire.jrc.ec.europa.eu/documents/Metadata/INSPIRE_MD_IR_and_ISO_v1_2_20100616.pdf page 18
- //First check if MD_Identifier is set, then check if RS_Identifier is used!
- //Initialize datasetid
- $datasetid = 'undefined';
- $code = $iso19139Xml->xpath('/gmd:MD_Metadata/gmd:identificationInfo/gmd:MD_DataIdentification/gmd:citation/gmd:CI_Citation/gmd:identifier/gmd:MD_Identifier/gmd:code/gco:CharacterString');
- if (isset($code[0]) && $code[0] != '') {
- $e = new mb_exception("plugins/mb_metadata_server.php: code given thru MD_Identifier: ".$code[0]);
- //check if code is defined by codespace and code
- $codeSplit = explode("#",$code[0]);
- if (isset($codeSplit[0]) && $codeSplit[0] != '' && isset($codeSplit[1]) && $codeSplit[1] != '') {
- $e = new mb_exception("plugins/mb_metadata_server.php: code was constructed via codespace#code !");
- $datasetid = $code[0];
- $datasetid_codespace = "";
- } else {
- $e = new mb_exception("plugins/mb_metadata_server.php: code was not constructed via codespace#code !");
- } else { //try to read code from RS_Identifier
- $code = $iso19139Xml->xpath('/gmd:MD_Metadata/gmd:identificationInfo/gmd:MD_DataIdentification/gmd:citation/gmd:CI_Citation/gmd:identifier/gmd:RS_Identifier/gmd:code/gco:CharacterString');
- $codeSpace = $iso19139Xml->xpath('/gmd:MD_Metadata/gmd:identificationInfo/gmd:MD_DataIdentification/gmd:citation/gmd:CI_Citation/gmd:identifier/gmd:RS_Identifier/gmd:codeSpace/gco:CharacterString');
- #$e = new mb_exception("plugins/mb_metadata_server.php: code: ".$code[0]);
- #$e = new mb_exception("plugins/mb_metadata_server.php: codeSpace: ".$codeSpace[0]);
- if (isset($codeSpace[0]) && isset($code[0]) && $codeSpace[0] != '' && $code[0] != '') {
- $datasetid_codespace = $codeSpace[0];
- $e = new mb_exception("plugins/mb_metadata_server.php: datasetid: ".$datasetid);
- } else {
- //neither MD_Identifier nor RS_Identifier are defined in a right way
- $e = new mb_exception("plugins/mb_metadata_server.php: the service data coupling has problems, cause the metadata doesnt have defined a datasetid");
+ if (!$mbMetadata->insertMetadataUrlToDB("layer",$layerId)) {
+ } else {
+ $e = new mb_exception("Stored MetadataURL ".$mbMetadata->href." from wms capabilities to mb database cause the target could not be accessed or parsed!");
- //abstract
- $abstract = $iso19139Xml->xpath('/gmd:MD_Metadata/gmd:identificationInfo/gmd:MD_DataIdentification/gmd:abstract/gco:CharacterString');
- //searchtext -- use keywords!
- $keywords = $iso19139Xml->xpath('/gmd:MD_Metadata/gmd:identificationInfo/gmd:MD_DataIdentification/gmd:descriptiveKeywords/gmd:MD_Keywords/gmd:keyword/gco:CharacterString');
- //type
- $type = $iso19139Xml->xpath('/gmd:MD_Metadata/gmd:hierarchyLevel/gmd:MD_ScopeCode');
- //tmp_reference_1
- $tmp_reference_1 = $iso19139Xml->xpath('/gmd:MD_Metadata/gmd:identificationInfo/gmd:MD_DataIdentification/gmd:extent/gmd:EX_Extent/gmd:temporalElement/gmd:EX_TemporalExtent/gmd:extent/gml:TimePeriod/gml:beginPosition');
- //tmp_reference_2
- $tmp_reference_2 = $iso19139Xml->xpath('/gmd:MD_Metadata/gmd:identificationInfo/gmd:MD_DataIdentification/gmd:extent/gmd:EX_Extent/gmd:temporalElement/gmd:EX_TemporalExtent/gmd:extent/gml:TimePeriod/gml:endPosition'); //spatial_res_type
- //spatial_res_value
- //ref_system
- //format
- //inspire_charset
- //inspire_top_consistence
- //responsible_party
- //fees
- //"constraints"
- //fill database with elements:
- $sql = <<<SQL
-INSERT INTO mb_metadata (link, uuid, origin, title, abstract, format, ref_system, export2csw, inspire_top_consistence, tmp_reference_1, tmp_reference_2, lineage, spatial_res_type, spatial_res_value, inspire_charset, createdate, datasetid, randomid, data, harvestresult, datasetid_codespace) VALUES ($1, $2, $3, $4, $5, $6, $7, $8, $9, $10, $11, $12, $13, $14, $15, now(), $16, $17, $18, 1, $19)
-SQL;
- $v = array($link, $uuid[0], $origin, $title[0], $abstract[0], $format, $ref_system, $export2csw,$inspire_top_consistence,$tmp_reference_1[0],$tmp_reference_2[0],$lineage,$spatial_res_type,$spatial_res_value,$inspire_charset, $datasetid, $randomid, $metaData, $datasetid_codespace);
- $t = array('s','s','s','s','s','s','s','b','b','s','s','s','s','s','s','s','s','s','s');
- try {
- abort(_mb("Insert of harvested metadata into database failed!"));
+ } else { //fill thru metador
+ $mbMetadata->origin = "metador";
+ $mbMetadata->fileIdentifier = $uuid;
+ abort("Problem while storing metadata to mb_metadata table!");
} else {
- abort(_mb("Problem with parsing the XML structure with SimpleXML! Record was not inserted into database! Ask your administrator."));
- //give back error message - cause parsing has problems
+ $ajaxResponse->setMessage("Metadata object inserted into md_metadata!");
+ $ajaxResponse->setSuccess(true);
- } else { //fill only links or the edited information into db
- $sql = <<<SQL
-INSERT INTO mb_metadata (link, uuid, origin, title, abstract, format, ref_system, export2csw, inspire_top_consistence, tmp_reference_1, tmp_reference_2, lineage, spatial_res_type, spatial_res_value, inspire_charset, createdate, randomid, update_frequency) VALUES ($1, $2, $3, $4, $5, $6, $7, $8, $9, $10, $11, $12, $13, $14, $15, now(), $16, $17)
-SQL;
- $v = array($link, $uuid, $origin, $title, $abstract, $format, $ref_system, $export2csw,$inspire_top_consistence,$tmp_reference_1,$tmp_reference_2,$lineage,$spatial_res_type,$spatial_res_value,$inspire_charset, $randomid, $update_frequency);
- $t = array('s','s','s','s','s','s','s','b','b','s','s','s','s','s','s','s','s');
- try {
- abort(_mb("Insert of edited metadata into database failed!"));
- //set relation into relation table
- //get metadata_id of record which have been inserted before
- $sql = <<<SQL
-SQL;
- $t = array('s');
- try {
- if ($res) {
- $metadata_id = $row['metadata_id'];
- $sql = <<<SQL
- INSERT INTO ows_relation_metadata (fkey_metadata_id, fkey_layer_id) VALUES ($1, $2)
-SQL;
- $v = array($metadata_id, $layerId);
- try {
- abort(_mb("Cannot write relation between ows and metadata to database!"));
- if ($dbInsertFailed != true) {
- $ajaxResponse->setMessage("Metadata object inserted into md_metadata!");
- $ajaxResponse->setSuccess(true);
break;
case "deleteInternalMetadataLinkage" :
@@ -1084,182 +934,46 @@
$ajaxResponse->setMessage("Metadata deleted!");
break;
case "importLayerXmlAddon" :
-//this is similar to insert the metadata from external link, but came from internal file from tmp folder which has been updated before
+ //this case is similar to insert the metadata from external link, but came from internal file from tmp folder which has been uploaded before
$filename = $ajaxResponse->getParameter("filename");
//normaly the link is only set if a link has been created
//if a record has been created, the link element will be empty
//use this to distinguish between the to different inserts!
//this insert should also push one entry in the ows_relation_metadata table! - after the insert into md_metadata
- //origin
- //generate metador entry
- $origin = 'upload';
- //generate a uuid for the record:
$uuid = new Uuid();
- //initialize database objects
- $link = '';
- $title = '';
- $abstract = '';
- $format = '';
- $ref_system = '';
- $lineage = '';
- $e = new mb_exception("File to load: ".$filename);
- /*if (file_exists($filename)) {
- try {
- $iso19139Xml = simplexml_load_file($filename);
- abort(_mb("Loading ISO19139 XML failed!"));
- else {
- abort(_mb("File not found: ".$filename." !"));
+ $e = new mb_notice("File to load: ".$filename);
$metaData = file_get_contents($filename);
if (!$metaData){
abort(_mb("Reading file ".$filename." failed!"));
- $iso19139Xml = simplexml_load_string($output);
- $e = new mb_exception('');
- //uuid
- if (!isset($uuid) || $uuid == "") {
- abort(_mb(" No fileIdentifier found, parsing ISO19139 XML maybe failed. Check if element /gmd:MD_Metadata/gmd:fileIdentifier/gco:CharacterString is given and not empty!"));
- //$e = new mb_exception("plugins/mb_metadata_server.php: File Identifier found: ".$uuid);
- //createdate
- //changedate
- //title
- $codeSplit = explode("#",$code);
- $datasetid = $codeSplit[0]."#".$codeSplit[1];
+ $mbMetadata = $mbMetadata->createMapbenderMetadataFromXML($metaData);
+ $e = new mb_exception("Result of parsing: ".$mbMetadata);
+ $mbMetadata->origin = "upload";
+ $e = new mb_exception("Problem while storing uploaded metadata xml to mb_metadata table!"); abort("Problem while storing uploaded metadata xml to mb_metadata table!");
} else {
- $datasetid = $code;
+ $e = new mb_exception("Metadata with id ".$randomid." stored to db!");
- $datasetid = $codeSpace[0]."#".$code[0];
- } else {
- //abstract
- //type
- //tmp_reference_1
- //tmp_reference_2
- //ref_system
- //format
- //inspire_charset
- //fees
- //"constraints"
- $sql = <<<SQL
-INSERT INTO mb_metadata (link, uuid, origin, title, abstract, format, ref_system, export2csw, inspire_top_consistence, tmp_reference_1, tmp_reference_2, lineage, spatial_res_type, spatial_res_value, inspire_charset, createdate, datasetid, randomid, data, harvestresult) VALUES ($1, $2, $3, $4, $5, $6, $7, $8, $9, $10, $11, $12, $13, $14, $15, now(), $16, $17, $18, 1)
-SQL;
- $xml = $iso19139Xml->asXML();
- $v = array($link, $uuid[0], $origin, $title[0], $abstract[0], $format, $ref_system, $export2csw,$inspire_top_consistence,$tmp_reference_1[0],$tmp_reference_2[0],$lineage,$spatial_res_type,$spatial_res_value,$inspire_charset, $datasetid, $randomid, $xml);
- $t = array('s','s','s','s','s','s','s','b','b','s','s','s','s','s','s','s','s','s');
- try {
- $sql = <<<SQL
-SQL;
- $t = array('s');
- try {
- if ($res) {
- $sql = <<<SQL
-SQL;
- try {
+ } else {
+ abort("Could not parse metadata from local file!");
+ $ajaxResponse->setMessage("Uploaded metadata object inserted into md_metadata table!");
break;
default:
$ajaxResponse->setSuccess(false);
Modified: trunk/mapbender/http/plugins/mb_metadata_wfs_server.php
--- trunk/mapbender/http/plugins/mb_metadata_wfs_server.php 2012-06-07 09:03:25 UTC (rev 8373)
+++ trunk/mapbender/http/plugins/mb_metadata_wfs_server.php 2012-06-11 20:56:49 UTC (rev 8374)
@@ -3,6 +3,7 @@
require_once dirname(__FILE__) . "/../classes/class_user.php";
require_once dirname(__FILE__) . "/../classes/class_wfs.php";
require_once(dirname(__FILE__)."/../classes/class_universal_wfs_factory.php");
+require_once dirname(__FILE__) . "/../classes/class_iso19139.php";
$ajaxResponse = new AjaxResponse($_POST);
@@ -529,7 +530,7 @@
$sql = <<<SQL
-INSERT INTO ows_relation_metadata (fkey_metadata_id, fkey_featuretype_id, internal) VALUES ( $1, $2, $3)
+INSERT INTO ows_relation_metadata (fkey_metadata_id, fkey_featuretype_id, internal, relation_type) VALUES ( $1, $2, $3, 'internal')
SQL;
$v = array($data->internal_relation,$featuretypeId, 1);
@@ -563,250 +564,102 @@
$uuid = new Uuid();
- $link = '';
- $title = '';
- $abstract = '';
- $format = '';
- $ref_system = '';
- $lineage = '';
} else {
- if (!$metaData) {
+ if (!$mbMetadata->insertToDB("featuretype",$featuretypeId)) {
+ } else {
} else {
- //parse metadata
- /*try {
- //uuid
- //createdate
- //changedate
- //title
- //datasetid
- } else {
- } else {
+ if (!$mbMetadata->insertMetadataUrlToDB("featuretype",$featuretypeId)) {
+ } else {
- //abstract
- //type
- //tmp_reference_1
- //tmp_reference_2
- //ref_system
- //format
- //inspire_charset
- //fees
- //"constraints"
- $sql = <<<SQL
-SQL;
- $v = array($link, $uuid[0], $origin, $title[0], $abstract[0], $format, $ref_system, $export2csw,$inspire_top_consistence,$tmp_reference_1[0],$tmp_reference_2[0],$lineage,$spatial_res_type,$spatial_res_value,$inspire_charset, $datasetid, $randomid, $metaData);
- try {
} else {
- $sql = <<<SQL
-SQL;
- try {
- $sql = <<<SQL
-SQL;
- $t = array('s');
- try {
- if ($res) {
- $sql = <<<SQL
- INSERT INTO ows_relation_metadata (fkey_metadata_id, fkey_featuretype_id) VALUES ($1, $2)
-SQL;
- $v = array($metadata_id, $featuretypeId);
- try {
break;
@@ -855,190 +708,44 @@
break;
case "importFeaturetypeXmlAddon" :
$featuretypeId = $ajaxResponse->getParameter("featuretypeId");
- //origin
$uuid = new Uuid();
- $link = '';
- $title = '';
- $abstract = '';
- $format = '';
- $ref_system = '';
- $lineage = '';
- try {
- else {
if (!$metaData){
- //$e = new mb_notice('');
- //uuid
- //createdate
- //changedate
- //title
- $e = new mb_notice("plugins/mb_metadata_server.php: code given thru MD_Identifier: ".$code[0]);
} else {
- } else {
- //abstract
- //type
- //tmp_reference_1
- //tmp_reference_2
- //ref_system
- //format
- //inspire_charset
- //fees
- //"constraints"
- $sql = <<<SQL
-SQL;
- $v = array($link, $uuid[0], $origin, $title[0], $abstract[0], $format, $ref_system, $export2csw, $inspire_top_consistence,$tmp_reference_1[0],$tmp_reference_2[0],$lineage,$spatial_res_type,$spatial_res_value,$inspire_charset, $datasetid, $randomid, $xml,$datasetid_codespace);
- try {
- $sql = <<<SQL
-SQL;
- $t = array('s');
- try {
- if ($res) {
- $sql = <<<SQL
-SQL;
- try {
+ } else {
break;
case "save":
Modified: trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.7.2_to_2.7.3_pgsql_UTF-8.sql
--- trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.7.2_to_2.7.3_pgsql_UTF-8.sql 2012-06-07 09:03:25 UTC (rev 8373)
+++ trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.7.2_to_2.7.3_pgsql_UTF-8.sql 2012-06-11 20:56:49 UTC (rev 8374)
@@ -440,3 +440,7 @@
--Add handling of codespaces as demanded from the INSPIRE regulation
ALTER TABLE mb_metadata ADD COLUMN datasetid_codespace TEXT;
+ALTER TABLE ows_relation_metadata ADD COLUMN relation_type TEXT;
+--update table ows_relation_metadata set type from table mb_metadata -- it is better to have it for relation not for instance
More information about the Mapbender_commits
