[Mapbender-commits] r8378 - trunk/mapbender/resources/db/pgsql
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Thu Jun 14 07:42:36 PDT 2012
Author: armin11
Date: 2012-06-14 07:42:33 -0700 (Thu, 14 Jun 2012)
New Revision: 8378
Added:
   trunk/mapbender/resources/db/pgsql/admin_ows_scheduler.sql
   trunk/mapbender/resources/db/pgsql/admin_wfs_metadata.sql
   trunk/mapbender/resources/db/pgsql/admin_wms_metadata.sql
Backup of some admin guis
Added: trunk/mapbender/resources/db/pgsql/admin_ows_scheduler.sql
--- trunk/mapbender/resources/db/pgsql/admin_ows_scheduler.sql	                        (rev 0)
+++ trunk/mapbender/resources/db/pgsql/admin_ows_scheduler.sql	2012-06-14 14:42:33 UTC (rev 8378)
@@ -0,0 +1,69 @@
+INSERT INTO gui (gui_id, gui_name, gui_description, gui_public) VALUES ('admin_ows_scheduler','admin_ows_scheduler','test_data_upload',1);
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_ows_scheduler','body',1,1,'body (obligatory)','','body','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','','','','');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_ows_scheduler','body','css_class_bg','body{ background-color: #ffffff; margin: 5 5 5 5 }
+        font-family: Verdana;
+        font-size: 96%;
+label {
+        width: 250px;
+        height: 40px;
+        float: left;
+p {
+        clear: both;
+input {
+        font-weight: bold;
+        vertical-align: top;
+        width: 250px;
+        height: 25px;
+fieldset {
+        margin-top: 10px;
+.help-dialog {
+        cursor: pointer;
+','to define the color of the body','text/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_ows_scheduler','body','favicon','../img/favicon.png','favicon','php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_ows_scheduler','body','includeWhileLoading','1','show splash screen while the application is loading','php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_ows_scheduler','body','jq_ui_theme','../extensions/jquery-ui-1.7.2.custom/css/smoothness/jquery-ui-1.7.2.custom.css','UI Theme from Themeroller','file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_ows_scheduler','body','use_load_message','true','show splash screen while the application is loading','php_var');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_ows_scheduler','jq_datatables',1,1,'Includes the jQuery plugin datatables, use like this
+$(selector).datatables(options)','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','../plugins/jq_datatables.js','../extensions/dataTables-1.5/media/js/jquery.dataTables.min.js','','','http://www.datatables.net/');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_ows_scheduler','jq_datatables','defaultCss','../extensions/dataTables-1.5/media/css/demo_table_jui.css','','file/css');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_ows_scheduler','jq_ui',1,1,'The jQuery UI core','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/minified/jquery.ui.core.min.js','','','');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_ows_scheduler','jq_ui','css','../extensions/jquery-ui-1.7.2.custom/css/ui-lightness/jquery-ui-1.7.2.custom.css','','file/css');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_ows_scheduler','jq_ui_effects',1,1,'Effects from the jQuery UI framework','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','jq_ui_effects.php','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/minified/jquery.effects.core.min.js','','','');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_ows_scheduler','jq_ui_effects','blind','1','1 = effect active','php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_ows_scheduler','jq_ui_effects','bounce','0','1 = effect active','php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_ows_scheduler','jq_ui_effects','clip','0','1 = effect active','php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_ows_scheduler','jq_ui_effects','drop','0','1 = effect active','php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_ows_scheduler','jq_ui_effects','explode','0','1 = effect active','php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_ows_scheduler','jq_ui_effects','fold','1','1 = effect active','php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_ows_scheduler','jq_ui_effects','highlight','0','1 = effect active','php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_ows_scheduler','jq_ui_effects','pulsate','0','1 = effect active','php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_ows_scheduler','jq_ui_effects','scale','0','1 = effect active','php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_ows_scheduler','jq_ui_effects','shake','0','1 = effect active','php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_ows_scheduler','jq_ui_effects','slide','0','1 = effect active','php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_ows_scheduler','jq_ui_effects','transfer','0','1 = effect active','php_var');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_ows_scheduler','mb_helpDialog',1,1,'','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','mb_helpDialog.js','','jq_ui_dialog, jq_metadata','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_ows_scheduler','jq_ui_widget',2,1,'jQuery UI widget','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/minified/jquery.ui.widget.min.js','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_ows_scheduler','mb_wms_scheduler_select',2,1,'Select a wms resource','Select wms resource','div','','',NULL ,NULL,NULL ,NULL,NULL ,'','<table class=''display''></table>','div','../plugins/mb_wms_scheduler_select.js','','','jq_datatables','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_ows_scheduler','jq_ui_position',2,1,'jQuery UI position','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/minified/jquery.ui.position.min.js','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_ows_scheduler','jq_ui_mouse',3,1,'jQuery UI mouse','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/minified/jquery.ui.mouse.min.js','','jq_ui_widget','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_ows_scheduler','jq_ui_button',4,1,'jQuery UI button','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/minified/jquery.ui.button.min.js','','jq_ui,jq_ui_widget','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_ows_scheduler','jq_ui_droppable',4,1,'jQuery UI droppable','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/minified/jquery.ui.droppable.min.js','','jq_ui,jq_ui_widget,jq_ui_mouse,jq_ui_draggable','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_ows_scheduler','jq_ui_dialog',5,1,'Module to manage jQuery UI dialog windows with multiple options for customization.','','div','','',-1,-1,NULL ,NULL,NULL ,'','','div','','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/minified/jquery.ui.dialog.min.js','','jq_ui,jq_ui_widget,jq_ui_button,jq_ui_draggable,jq_ui_mouse,jq_ui_position,jq_ui_resizable','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_ows_scheduler','jq_ui_resizable',5,1,'Resizable from the jQuery UI framework','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','../plugins/jq_ui_resizable.js','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/jquery.ui.resizable.js','','jq_ui,jq_ui_mouse,jq_ui_widget','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_ows_scheduler','jq_ui_draggable',5,1,'Draggable from the jQuery UI framework','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/minified/jquery.ui.draggable.min.js','','jq_ui,jq_ui_mouse,jq_ui_widget','http://jqueryui.com/demos/draggable/');
Added: trunk/mapbender/resources/db/pgsql/admin_wfs_metadata.sql
--- trunk/mapbender/resources/db/pgsql/admin_wfs_metadata.sql	                        (rev 0)
+++ trunk/mapbender/resources/db/pgsql/admin_wfs_metadata.sql	2012-06-14 14:42:33 UTC (rev 8378)
@@ -0,0 +1,313 @@
+INSERT INTO gui (gui_id, gui_name, gui_description, gui_public) VALUES ('admin_wfs_metadata','admin_wfs_metadata','Administration for WFS metadata',1);
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wfs_metadata','body',1,1,'body (obligatory)','','body','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','','','','');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wfs_metadata','body','css_class_bg','body{ background-color: #ffffff; margin: 5 5 5 5 }
+        font-size: 96%;
+label {
+        width: 250px;
+        height: 40px;
+        float: left;
+p {
+        clear: both;
+input {
+        width: 250px;
+        height: 25px;
+.metadata_span {
+        padding-right: 30px;
+.metadata_img {
+        width: 25px;
+        height: 25px;
+.metadata_selectbox {
+        height: 130px;
+        width: 250px;
+div#choose {
+        float: left;
+        width: 20%;
+        height:100%;
+div#layer {
+        margin-left: 20%;
+        width: 80%;
+div#preview {
+        width: 30%;
+        padding-top: 5px;
+        float: left;
+div#classification {
+        margin-left: 50%;
+        padding-top: 5px;
+        width: 50%;
+div#save {
+        margin-left: 45em;
+div#buttons {
+        float: left;
+div#selectbox {
+        margin-left: 312px;
+        padding-top: 20px;
+}','to define the color of the body','text/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wfs_metadata','body','favicon','../img/favicon.png','favicon','php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wfs_metadata','body','includeWhileLoading','','show splash screen while the application is loading','php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wfs_metadata','body','jq_datatables_css','../extensions/dataTables-1.5/media/css/site_jui.ccss.css','css-file for jQuery datatables','file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wfs_metadata','body','jq_datatables_css_ui','../extensions/dataTables-1.5/media/css/demo_table_jui.min.css','css-file for jQuery datatables','file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wfs_metadata','body','jq_ui_theme','../extensions/jquery-ui-1.7.2.custom/css/smoothness/jquery-ui-1.7.2.custom.css','UI Theme from Themeroller','file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wfs_metadata','body','use_load_message','true','show splash screen while the application is loading','php_var');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wfs_metadata','i18n',1,1,'Internationalization module, collects data from all elements and sends them to the server in a single POST request. The strings are translated via gettext only.','Internationalization','div','','',NULL ,NULL,NULL ,NULL,NULL ,'','','div','../plugins/mb_i18n.js','','','','http://www.mapbender.org/Gettext');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wfs_metadata','jq_datatables',1,1,'Includes the jQuery plugin datatables, use like this
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wfs_metadata','jq_datatables','defaultCss','../extensions/dataTables-1.5/media/css/demo_table_jui.css','','file/css');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wfs_metadata','mb_helpDialog',1,1,'','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','mb_helpDialog.js','','jq_ui_dialog, jq_metadata','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wfs_metadata','jq_ui_effects',1,1,'Effects from the jQuery UI framework','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','jq_ui_effects.php','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/minified/jquery.effects.core.min.js','','','');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wfs_metadata','jq_ui_effects','blind','1','1 = effect active','php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wfs_metadata','jq_ui_effects','bounce','0','1 = effect active','php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wfs_metadata','jq_ui_effects','clip','0','1 = effect active','php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wfs_metadata','jq_ui_effects','drop','0','1 = effect active','php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wfs_metadata','jq_ui_effects','explode','0','1 = effect active','php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wfs_metadata','jq_ui_effects','fold','1','1 = effect active','php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wfs_metadata','jq_ui_effects','highlight','0','1 = effect active','php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wfs_metadata','jq_ui_effects','pulsate','0','1 = effect active','php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wfs_metadata','jq_ui_effects','scale','0','1 = effect active','php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wfs_metadata','jq_ui_effects','shake','0','1 = effect active','php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wfs_metadata','jq_ui_effects','slide','0','1 = effect active','php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wfs_metadata','jq_ui_effects','transfer','0','1 = effect active','php_var');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wfs_metadata','mb_pane',1,1,'','','div','','',NULL ,NULL,NULL ,NULL,NULL ,'height:100%;width:100%','','div','../plugins/mb_pane.js','','','jq_layout','http://layout.jquery-dev.net');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wfs_metadata','mb_pane','center','mb_tabs_horizontal','','var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wfs_metadata','mb_pane','south','mb_md_wfs_submit','','var');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wfs_metadata','jq_validate',1,1,'The jQuery validation plugin','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','../javascripts/jq_validate.js','../extensions/jquery-validate/jquery.validate.min.js','','','http://docs.jquery.com/Plugins/Validation');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wfs_metadata','jq_validate','css','label.error { float: none; color: red; padding-left: .5em; vertical-align: top; }','','text/css');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wfs_metadata','jq_ui',1,1,'The jQuery UI core','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/minified/jquery.ui.core.min.js','','','');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wfs_metadata','jq_ui','css','../extensions/jquery-ui-1.7.2.custom/css/ui-lightness/jquery-ui-1.7.2.custom.css','','file/css');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wfs_metadata','jq_jstree_1',1,1,'jsTree','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jsTree.v.1.0rc/jquery.jstree.min.js','','','http://www.jstree.com/');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wfs_metadata','jq_metadata',1,1,'Metadata plugin','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery.metadata.2.1/jquery.metadata.min.js','','','http://plugins.jquery.com/project/metadata');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wfs_metadata','mb_md_wfs_submit',1,1,'','','div','','',NULL ,NULL,NULL ,NULL,NULL ,'','<span style=''float:right''><input disabled="disabled" type=''button'' value=''Preview metadata''><input type=''submit'' value=''Save metadata''></span>','div','../plugins/mb_metadata_wfs_submit.js','','','','');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wfs_metadata','mb_md_wfs_submit','inputs','[
+        "method": "enable",
+        "linkedTo": [
+                "id": "mb_md_wfs_select",
+                "event": "selected"
+]','','var');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wfs_metadata','jq_layout',1,1,'','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery.layout.all-1.2.0/jquery.layout.min.js','','','http://layout.jquery-dev.net');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wfs_metadata','jq_upload',1,1,'Allows to upload files into Mapbender''s temporary files folder','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../plugins/jq_upload.js','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wfs_metadata','mb_metadata_xml_import',1,1,'','','div','','',NULL ,NULL,NULL ,NULL,NULL ,'','','div','../plugins/mb_metadata_xml_import_wfs.js','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wfs_metadata','jq_ui_position',2,1,'jQuery UI position','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/minified/jquery.ui.position.min.js','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wfs_metadata','jq_ui_widget',2,1,'jQuery UI widget','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/minified/jquery.ui.widget.min.js','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wfs_metadata','mb_md_showMetadataAddonWfs',2,1,'Show addon editor for metadata','Metadata Addon Editor','div','','',NULL ,NULL,NULL ,NULL,NULL ,'display:none;','','div','../plugins/mb_metadata_showMetadataAddonWfs.js','','','jq_ui_dialog','');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wfs_metadata','mb_md_showMetadataAddonWfs','differentFromOriginalCss','.differentFromOriginal{
+background-color:#FFFACD;
+}','css for class differentFromOriginal','text/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wfs_metadata','mb_md_showMetadataAddonWfs','inputs','[
+        "method": "init",
+        "title": "initialize",
+        "linkedTo": [
+                "id": "mb_md_edit",
+                "event": "showOriginalMetadata",
+                "attr": "data"
+        "method": "initLayer",
+        "linkedTo": [
+                "id": "mb_md_layer",
+                "event": "showOriginalLayerMetadata",
+                "attr": "data"
+]','','var');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wfs_metadata','mb_md_featuretype_tree',2,1,'Select a featuretype from a featuretype tree','Select a featuretype from a featuretype tree','div','','',NULL ,NULL,NULL ,NULL,NULL ,'','','div','../plugins/mb_metadata_featuretypeTree.js','','','','');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wfs_metadata','mb_md_featuretype_tree','inputs','[
+        "method": "init",
+        "linkedTo": [
+                "id": "mb_md_featuretype",
+                "event": "initialized",
+                "attr": "wfsId"
+        "method": "serialize",
+        "linkedTo": [
+                "id": "mb_md_wfs_submit",
+                "event": "submit",
+                "attr": "callback"
+] ','','var');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wfs_metadata','mb_md_wfs_edit',2,1,'Edit WFS metadata','Edit WFS metadata','div','','',NULL ,NULL,NULL ,NULL,NULL ,'overflow:auto','','div','../plugins/mb_metadata_wfs_edit.js','','','','');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wfs_metadata','mb_md_wfs_edit','inputs','[
+        "method": "init",
+        "linkedTo": [
+                "event": "selected",
+                "attr": "wfsId"
+        "linkedTo": [
+        "method": "fill",
+        "linkedTo": [
+                "id": "mb_md_wfs_showOriginal",
+                "event": "replaceMetadata",
+                "attr": "data"
+]','','var');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wfs_metadata','mb_md_wfs_select',2,1,'Select a WFS','Select WFS','div','','',NULL ,NULL,NULL ,NULL,NULL ,'','<table class=''display''></table>','div','../plugins/mb_metadata_wfs_select.js','','','jq_datatables','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wfs_metadata','mb_md_wfs_showOriginal',2,1,'Show original metadata','Show original metadata','div','','',NULL ,NULL,NULL ,NULL,NULL ,'display:none;','','div','../plugins/mb_metadata_wfs_showOriginal.js','','','jq_ui_dialog','');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wfs_metadata','mb_md_wfs_showOriginal','differentFromOriginalCss','.differentFromOriginal{
+}','','text/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wfs_metadata','mb_md_wfs_showOriginal','inputs','[
+        "method": "init",
+        "linkedTo": [
+                "id": "mb_md_wfs_edit",
+                "attr": "data"
+        "linkedTo": [
+                "event": "showOriginalFeaturetypeMetadata",
+                "attr": "data"
+]','','var');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wfs_metadata','mb_tabs_horizontal',3,1,'Puts existing elements into horizontal tabs, using jQuery UI tabs. List the elements comma-separated under target, and make sure they have a title.','','div','','',NULL ,NULL,NULL ,NULL,NULL ,'','<ul></ul><div class=''ui-layout-content''></div>','div','../plugins/mb_tabs_horizontal.js','','mb_md_wfs_select,mb_md_wfs_edit,mb_md_featuretype','jq_ui_tabs','');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wfs_metadata','mb_tabs_horizontal','inputs','[
+        "type": "id",
+        "method": "select",
+        "title": "Select a tab",
+        "linkedTo": [
+                "value": "mb_md_wfs_edit"
+] ','','var');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wfs_metadata','mb_md_featuretype',3,1,'Edit featuretype metadata','Edit featuretype metadata','div','','',NULL ,NULL,NULL ,NULL,NULL ,'','','div','../plugins/mb_metadata_featuretype.js','','','','');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wfs_metadata','mb_md_featuretype','inputs','[
+        "method": "init",
+        "title": "initialize wfs data",
+        "linkedTo": [
+                "attr": "wfsId"
+        "method": "fillForm",
+        "title": "initialize featuretype data",
+        "linkedTo": [
+                "id": "mb_md_featuretype_tree",
+                "attr": "featuretype"
+        "linkedTo": [
+        "method": "fill",
+        "linkedTo": [
+                "attr": "data"
+] ','','var');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wfs_metadata','jq_ui_mouse',3,1,'jQuery UI mouse','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/minified/jquery.ui.mouse.min.js','','jq_ui_widget','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wfs_metadata','jq_ui_droppable',4,1,'jQuery UI droppable','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/minified/jquery.ui.droppable.min.js','','jq_ui,jq_ui_widget,jq_ui_mouse,jq_ui_draggable','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wfs_metadata','jq_ui_button',4,1,'jQuery UI button','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/minified/jquery.ui.button.min.js','','jq_ui,jq_ui_widget','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wfs_metadata','jq_ui_tabs',5,1,'horizontal tabs from the jQuery UI framework','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/minified/jquery.ui.tabs.min.js','','jq_ui,jq_ui_widget','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wfs_metadata','jq_ui_draggable',5,1,'Draggable from the jQuery UI framework','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/minified/jquery.ui.draggable.min.js','','jq_ui,jq_ui_mouse,jq_ui_widget','http://jqueryui.com/demos/draggable/');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wfs_metadata','jq_ui_resizable',5,1,'Resizable from the jQuery UI framework','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','../plugins/jq_ui_resizable.js','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/jquery.ui.resizable.js','','jq_ui,jq_ui_mouse,jq_ui_widget','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wfs_metadata','jq_ui_datepicker',5,1,'Datepicker from jQuery UI framework','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','../plugins/jq_ui_datepicker.js','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/jquery.ui.datepicker.js','','jq_ui','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wfs_metadata','jq_ui_dialog',5,1,'Module to manage jQuery UI dialog windows with multiple options for customization.','','div','','',-1,-1,NULL ,NULL,NULL ,'','','div','','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/minified/jquery.ui.dialog.min.js','','jq_ui,jq_ui_widget,jq_ui_button,jq_ui_draggable,jq_ui_mouse,jq_ui_position,jq_ui_resizable','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wfs_metadata','switchLocale_noreload',8,1,'changes the locale without reloading the client','Sprache auswählen','div','','',900,20,50,30,5,'','<form id="form_switch_locale" action="window.location.href" name="form_switch_locale" target="parent"><select id="language" name="language" onchange="validate_locale()"></select></form>','div','mod_switchLocale_noreload.php','','','','');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wfs_metadata','switchLocale_noreload','languages','de,en,bg,gr,nl,hu,it,fr,es,pt','','var');
Added: trunk/mapbender/resources/db/pgsql/admin_wms_metadata.sql
--- trunk/mapbender/resources/db/pgsql/admin_wms_metadata.sql	                        (rev 0)
+++ trunk/mapbender/resources/db/pgsql/admin_wms_metadata.sql	2012-06-14 14:42:33 UTC (rev 8378)
@@ -0,0 +1,390 @@
+INSERT INTO gui (gui_id, gui_name, gui_description, gui_public) VALUES ('admin_wms_metadata','admin_wms_metadata','Administration for WMS metadata',1);
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','jq_datatables',1,1,'Includes the jQuery plugin datatables, use like this
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata','jq_datatables','defaultCss','../extensions/dataTables-1.5/media/css/demo_table_jui.css','','file/css');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','jq_jstree',1,0,'jsTree','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jsTree.v.0.9.9a2/jquery.tree.js','','','http://www.jstree.com/');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','jq_jstree_1',1,1,'jsTree','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jsTree.v.1.0rc/jquery.jstree.min.js','','','http://www.jstree.com/');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','jq_jstree_checkbox',1,0,'jsTree checkbox plugin','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jsTree.v.0.9.9a2/plugins/jquery.tree.checkbox.testbaudson.js','','','http://www.jstree.com/');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','mb_md_submit',1,1,'','','div','','',NULL ,NULL,NULL ,NULL,NULL ,'','<span style=''float:right''><input disabled="disabled" type=''button'' value=''Preview metadata''><input disabled="disabled" type=''submit'' value=''Save metadata''></span>','div','../plugins/mb_metadata_submit.js','','','','');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata','mb_md_submit','inputs','[
+        "linkedTo": [
+                "id": "mb_md_select",
+]','','var');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','mb_helpDialog',1,1,'','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','mb_helpDialog.js','','jq_ui_dialog, jq_metadata','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','mapframe1',1,1,'frame for a map','','div','','',230,55,200,200,3,'border:1px solid black;overflow:hidden;background-color:#ffffff;display:none;','','div','../plugins/mb_map.js','../../lib/history.js,map_obj.js,map.js,wms.js,wfs_obj.js,initWms.php','','','http://www.mapbender.org/index.php/Mapframe');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata','mapframe1','skipWmsIfSrsNotSupported','0','if set to 1, it skips the WMS request if the current SRS is not supported by the WMS; if set to 0, the WMS is always queried. Default is 0, because of backwards compatibility','var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata','mapframe1','slippy','0','1 = Activates an animated, pseudo slippy map','var');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','jq_validate',1,1,'The jQuery validation plugin','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','../javascripts/jq_validate.js','../extensions/jquery-validate/jquery.validate.min.js','','','http://docs.jquery.com/Plugins/Validation');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata','jq_validate','css','label.error { float: none; color: red; padding-left: .5em; vertical-align: top; }','','text/css');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','jq_ui',1,1,'The jQuery UI core','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/minified/jquery.ui.core.min.js','','','');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata','jq_ui','css','../extensions/jquery-ui-1.7.2.custom/css/ui-lightness/jquery-ui-1.7.2.custom.css','','file/css');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','jq_ui_effects',1,1,'Effects from the jQuery UI framework','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','jq_ui_effects.php','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/minified/jquery.effects.core.min.js','','','');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata','jq_ui_effects','blind','1','1 = effect active','php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata','jq_ui_effects','bounce','0','1 = effect active','php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata','jq_ui_effects','clip','0','1 = effect active','php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata','jq_ui_effects','drop','0','1 = effect active','php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata','jq_ui_effects','explode','0','1 = effect active','php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata','jq_ui_effects','fold','1','1 = effect active','php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata','jq_ui_effects','highlight','0','1 = effect active','php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata','jq_ui_effects','pulsate','0','1 = effect active','php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata','jq_ui_effects','scale','0','1 = effect active','php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata','jq_ui_effects','shake','0','1 = effect active','php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata','jq_ui_effects','slide','0','1 = effect active','php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata','jq_ui_effects','transfer','0','1 = effect active','php_var');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','jq_metadata',1,1,'Metadata plugin','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery.metadata.2.1/jquery.metadata.min.js','','','http://plugins.jquery.com/project/metadata');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','mb_metadata_xml_import',1,1,'','','div','','',NULL ,NULL,NULL ,NULL,NULL ,'','','div','../plugins/mb_metadata_xml_import.js','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','jq_upload',1,1,'Allows to upload files into Mapbender''s temporary files folder','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../plugins/jq_upload.js','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','jq_layout',1,1,'','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery.layout.all-1.2.0/jquery.layout.min.js','','','http://layout.jquery-dev.net');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','mb_geodata_import',1,0,'Allows to upload files into Mapbender''s temporary files folder','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','../plugins/mb_metadata_import.js','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','body',1,1,'body (obligatory)','','body','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','','','','');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata','body','css_class_bg','body{ background-color: #ffffff; margin: 5 5 5 5 }
+        font-size: 96%;
+label {
+        width: 250px;
+        height: 40px;
+        float: left;
+p {
+        clear: both;
+input {
+        width: 250px;
+        height: 25px;
+fieldset {
+        margin-top: 10px;
+.metadata_span {
+.help-dialog {
+        cursor: pointer;
+.metadata_img, .help-dialog, .original-metadata-wms {
+        width: 25px;
+        height: 25px;
+        vertical-align: middle;
+        height: 66px;
+        width: 250px;
+.label_classification {
+        width: 150px;
+        height: 40px;
+        float: left;
+div#choose {
+        float: left;
+        width: 35%;
+        height:100%;
+position:relative;
+div#layer {
+        margin-left: 35%;
+        width: 65%;
+div#preview {
+        padding: 5px 0px 0px 35%;
+        width: 25%;
+        float: left;
+        margin-left: 60%;
+        padding-top: 5px;
+        width: 40%;
+div#buttons {
+        float: left;
+div#selectbox {
+        margin-left: 280px;
+        padding-top: 60px;
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata','body','favicon','../img/favicon.png','favicon','php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata','body','includeWhileLoading','','show splash screen while the application is loading','php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata','body','jq_datatables_css','../extensions/dataTables-1.5/media/css/site_jui.css','css-file for jQuery datatables','file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata','body','jq_datatables_css_ui','../extensions/dataTables-1.5/media/css/demo_table_jui.min.css','css-file for jQuery datatables','file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata','body','jq_ui_theme','../extensions/jquery-ui-1.7.2.custom/css/smoothness/jquery-ui-1.7.2.custom.css','UI Theme from Themeroller','file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata','body','use_load_message','true','show splash screen while the application is loading','php_var');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','mb_pane',1,1,'','','div','','',NULL ,NULL,NULL ,NULL,NULL ,'height:100%;width:100%','','div','../plugins/mb_pane.js','','','jq_layout','http://layout.jquery-dev.net');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata','mb_pane','center','mb_tabs_horizontal','','var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata','mb_pane','south','mb_md_submit','','var');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','i18n',1,1,'Internationalization module, collects data from all elements and sends them to the server in a single POST request. The strings are translated via gettext only.','Internationalization','div','','',NULL ,NULL,NULL ,NULL,NULL ,'','','div','../plugins/mb_i18n.js','','','','http://www.mapbender.org/Gettext');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','zoomOut1',2,1,'zoomOut button','Aus der Karte herauszoomen','img','../img/button_gray/zoomOut2_off.png','',245,10,24,24,1,'','','','mod_zoomOut1.js','','mapframe1','','http://www.mapbender.org/index.php/ZoomOut');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','jq_ui_position',2,1,'jQuery UI position','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/minified/jquery.ui.position.min.js','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','jq_ui_widget',2,1,'jQuery UI widget','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/minified/jquery.ui.widget.min.js','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','changeEPSG',2,1,'change EPSG, Postgres required, overview is targed for full extent','Projektion ändern','select','','',432,25,107,24,1,'','<option value="">undefined</option>
+<option value="EPSG:4326">EPSG:4326</option>
+<option value="EPSG:31466">EPSG:31466</option>
+<option value="EPSG:31467">EPSG:31467</option>
+<option value="EPSG:31468">EPSG:31468</option>
+<option value="EPSG:31469">EPSG:31469</option>','select','mod_changeEPSG.js','','overview','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','mb_md_edit',2,1,'Edit WMS metadata','Edit WMS metadata','div','','',NULL ,NULL,NULL ,NULL,NULL ,'overflow:auto','','div','../plugins/mb_metadata_edit.js','','','','');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata','mb_md_edit','inputs','[
+        "method": "init",
+        "linkedTo": [
+                "attr": "wmsId"
+        "linkedTo": [
+                "id": "mb_md_submit",
+        "method": "fill",
+        "linkedTo": [
+                "id": "mb_md_showOriginal",
+                "attr": "data"
+]','','var');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','mb_md_layer_preview_save',2,1,'','','img','../img/button_gray/wmc_save_off.png','',NULL ,NULL,NULL ,NULL,NULL ,'display: none;','','','../plugins/mb_metadata_saveLayerPreview.js','','mapframe1','','');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata','mb_md_layer_preview_save','inputs','[
+        "method":"setLayer",
+        "title":"set the current Layer",
+        "linkedTo": [
+                "id":"mb_md_layer_tree",
+                "event":"selected",
+                "attr":"layer"
+]','','var');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','mb_md_layer_tree',2,1,'Select a layer from a layer tree','Select a layer from a layer tree','div','','',NULL ,NULL,NULL ,NULL,NULL ,'','','div','../plugins/mb_metadata_layerTree.js','','','','');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata','mb_md_layer_tree','inputs','[
+        "method": "init",
+        "linkedTo": [
+                "attr": "wmsId"
+        "linkedTo": [
+] ','','var');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','mb_md_select',2,1,'Select a WMS','Select WMS','div','','',NULL ,NULL,NULL ,NULL,NULL ,'','<table class=''display''></table>','div','../plugins/mb_metadata_select.js','','','jq_datatables','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','mb_md_showOriginal',2,1,'Show original metadata','Show original metadata','div','','',NULL ,NULL,NULL ,NULL,NULL ,'display:none;','','div','../plugins/mb_metadata_showOriginal.js','','','jq_ui_dialog','');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata','mb_md_showOriginal','differentFromOriginalCss','.differentFromOriginal{
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata','mb_md_showOriginal','inputs','[
+        "method": "init",
+        "linkedTo": [
+                "attr": "data"
+        "linkedTo": [
+                "attr": "data"
+]','','var');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','pan1',2,1,'pan','Ausschnitt verschieben','img','../img/button_gray/pan_off.png','',270,10,24,24,1,'','','','mod_pan.js','','mapframe1','','http://www.mapbender.org/index.php/Pan');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','sandclock',2,1,'displays a sand clock while waiting for requests','','div','','',80,0,NULL ,NULL,NULL ,'','','div','mod_sandclock.js','','mapframe1','','');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata','sandclock','mod_sandclock_image','../img/sandclock.gif','define a sandclock image ','var');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','scaleSelect',2,1,'Scale-Selectbox','Auswahl des Maßstabes','select','','',555,25,100,20,1,'','<option value = ''''>Scale</option> <option value=''100''>1 : 100</option> <option value=''250''>1 : 250</option> <option value=''500''>1 : 500</option> <option value=''1000''>1 : 1000</option> <option value=''2500''>1 : 2500</option> <option value=''5000''>1 : 5000</option> <option value=''10000''>1 : 10000</option> <option value=''25000''>1 : 25000</option> <option value=''30000''>1 : 30000</option> <option value=''50000''>1 : 50000</option> <option value=''75000''>1 : 75000</option> <option value=''100000''>1 : 100000</option> <option value=''200000''>1 : 200000</option> <option value=''300000''>1 : 300000</op
 tion> <option value=''400000''>1 : 400000</option> <option value=''500000''>1 : 500000</option> <option value=''600000''>1 : 600000</option> <option value=''700000''>1 : 700000</option> <option value=''800000''>1 : 800000</option> <option value=''900000''>1 : 900000</option> <option value=''1000000''>1 : 1000000</option>','select','../plugins/mb_selectScale.js','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','selArea1',2,1,'zoombox','Ausschnitt wählen','img','../img/button_gray/selArea_off.png','',295,10,24,24,3,'display: none;','','','mod_selArea.js','mod_box1.js','mapframe1','','http://www.mapbender.org/index.php/SelArea1');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','zoomFull',2,1,'zoom to full extent button','gesamte Karte anzeigen','img','../img/button_gray/zoomFull_off.png','',320,10,24,24,2,'display: none;','','','mod_zoomFull.js','','mapframe1','','http://www.mapbender.org/index.php/ZoomFull');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','zoomIn1',2,1,'zoomIn button','In die Karte hineinzoomen','img','../img/button_gray/zoomIn2_off.png','',220,10,24,24,1,'','','','mod_zoomIn1.js','','mapframe1','','http://www.mapbender.org/index.php/ZoomIn');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','mb_md_showMetadataAddon',2,1,'Show addon editor for metadata','Metadata Addon Editor','div','','',NULL ,NULL,NULL ,NULL,NULL ,'display:none;','','div','../plugins/mb_metadata_showMetadataAddon.js','','','jq_ui_dialog','');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata','mb_md_showMetadataAddon','differentFromOriginalCss','.differentFromOriginal{
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata','mb_md_showMetadataAddon','inputs','[
+        "method": "init",
+        "linkedTo": [
+                "attr": "data"
+        "linkedTo": [
+                "attr": "data"
+]','','var');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','jq_ui_mouse',3,1,'jQuery UI mouse','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/minified/jquery.ui.mouse.min.js','','jq_ui_widget','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','mb_md_layer',3,1,'Edit layer metadata','Edit layer metadata','div','','',NULL ,NULL,NULL ,NULL,NULL ,'','','div','../plugins/mb_metadata_layer.js','','','','');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata','mb_md_layer','inputs','[
+        "method": "init",
+        "title": "initialize wms data",
+        "linkedTo": [
+                "attr": "wmsId"
+        "title": "initialize layer data",
+        "linkedTo": [
+                "id": "mb_md_layer_tree",
+                "attr": "layer"
+        "linkedTo": [
+        "method": "fill",
+        "linkedTo": [
+                "attr": "data"
+] ','','var');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','mb_tabs_horizontal',3,1,'Puts existing elements into horizontal tabs, using jQuery UI tabs. List the elements comma-separated under target, and make sure they have a title.','','div','','',NULL ,NULL,NULL ,NULL,NULL ,'','<ul></ul><div class=''ui-layout-content''></div>','div','../plugins/mb_tabs_horizontal.js','','mb_md_select,mb_md_edit,mb_md_layer','jq_ui_tabs','');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata','mb_tabs_horizontal','inputs','[
+        "type": "id",
+        "linkedTo": [
+                "value": "mb_md_edit"
+] ','','var');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','mb_md_layer_preview',4,1,'Allows selection of a preview image of a Map','','div','','',NULL ,NULL,NULL ,NULL,NULL ,'','','div','../plugins/mb_metadata_layerPreview.js','mod_addWMSgeneralFunctions.js','','','');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata','mb_md_layer_preview','inputs','[
+        "method": "init",
+        "linkedTo": [
+                "attr": "wmsId"
+        "method":"layer",
+        "linkedTo": [
+                "attr":"layer"
+]','','var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata','mb_md_layer_preview','map','mapframe1','','var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata','mb_md_layer_preview','toolbarLower','[''changeEPSG'',''scaleSelect'']','','var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata','mb_md_layer_preview','toolbarUpper','[''zoomFull'',''zoomOut1'',''zoomIn1'',''selArea1'',''pan1'',''mb_md_layer_preview_save'']','','var');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','jq_ui_droppable',4,1,'jQuery UI droppable','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/minified/jquery.ui.droppable.min.js','','jq_ui,jq_ui_widget,jq_ui_mouse,jq_ui_draggable','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','jq_ui_button',4,1,'jQuery UI button','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/minified/jquery.ui.button.min.js','','jq_ui,jq_ui_widget','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','jq_ui_datepicker',5,1,'Datepicker from jQuery UI framework','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','../plugins/jq_ui_datepicker.js','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/jquery.ui.datepicker.js','','jq_ui','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','jq_ui_tabs',5,1,'horizontal tabs from the jQuery UI framework','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/minified/jquery.ui.tabs.min.js','','jq_ui,jq_ui_widget','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','jq_ui_resizable',5,1,'Resizable from the jQuery UI framework','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','../plugins/jq_ui_resizable.js','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/jquery.ui.resizable.js','','jq_ui,jq_ui_mouse,jq_ui_widget','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','jq_ui_dialog',5,1,'Module to manage jQuery UI dialog windows with multiple options for customization.','','div','','',-1,-1,NULL ,NULL,NULL ,'','','div','','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/minified/jquery.ui.dialog.min.js','','jq_ui,jq_ui_widget,jq_ui_button,jq_ui_draggable,jq_ui_mouse,jq_ui_position,jq_ui_resizable','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','jq_ui_draggable',5,1,'Draggable from the jQuery UI framework','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/minified/jquery.ui.draggable.min.js','','jq_ui,jq_ui_mouse,jq_ui_widget','http://jqueryui.com/demos/draggable/');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('admin_wms_metadata','switchLocale_noreload',8,1,'changes the locale without reloading the client','Sprache auswählen','div','','',900,20,50,30,5,'','<form id="form_switch_locale" action="window.location.href" name="form_switch_locale" target="parent"><select id="language" name="language" onchange="validate_locale()"></select></form>','div','mod_switchLocale_noreload.php','','','','');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('admin_wms_metadata','switchLocale_noreload','languages','de,en,bg,gr,nl,hu,it,fr,es,pt','','var');
More information about the Mapbender_commits mailing list
