[Mapbender-commits] r8388 - in trunk/mapbender: http/classes http/php http/plugins resources/db/pgsql/UTF-8/update
svn_mapbender at osgeo.org
Thu Jun 21 00:11:53 PDT 2012
Author: armin11
Date: 2012-06-21 00:11:53 -0700 (Thu, 21 Jun 2012)
New Revision: 8388
trunk/mapbender/http/classes/class_wms.php
trunk/mapbender/http/php/mod_loadCapabilities.php
trunk/mapbender/http/php/mod_updateWMS.php
trunk/mapbender/http/plugins/mb_metadata_server.php
trunk/mapbender/http/plugins/mb_metadata_submit.js
trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.7.2_to_2.7.3_pgsql_UTF-8.sql
Bugfixes and possibility to decide, if loading/update/edit metadata of a wms will result in a twitter and/or rss entry.
Modified: trunk/mapbender/http/classes/class_wms.php
--- trunk/mapbender/http/classes/class_wms.php 2012-06-20 14:18:07 UTC (rev 8387)
+++ trunk/mapbender/http/classes/class_wms.php 2012-06-21 07:11:53 UTC (rev 8388)
@@ -80,7 +80,7 @@
const GEORSS_APPEND_ON_UPDATE_NEWLAYERS = true;
function __construct() {
- if (TWITTER_NEWS) {
+ if (defined("TWITTER_NEWS") && TWITTER_NEWS == true) {
$this->twitterNews = true;
require_once dirname(__FILE__) . "/class_twitter.php";
Modified: trunk/mapbender/http/php/mod_loadCapabilities.php
--- trunk/mapbender/http/php/mod_loadCapabilities.php 2012-06-20 14:18:07 UTC (rev 8387)
+++ trunk/mapbender/http/php/mod_loadCapabilities.php 2012-06-21 07:11:53 UTC (rev 8388)
@@ -178,7 +178,7 @@
echo"<input type='text' name='password' size='50' value=''><br>";
- if (!TWITTER_NEWS) {
echo"<input type='checkbox' name='twitter_news' checked='checked'>Publish via Twitter<br>";
if (defined("GEO_RSS_FILE") && GEO_RSS_FILE != "") {
Modified: trunk/mapbender/http/php/mod_updateWMS.php
--- trunk/mapbender/http/php/mod_updateWMS.php 2012-06-20 14:18:07 UTC (rev 8387)
+++ trunk/mapbender/http/php/mod_updateWMS.php 2012-06-21 07:11:53 UTC (rev 8388)
@@ -119,6 +119,12 @@
echo "REQUEST=GetCapabilities&SERVICE=WMS&VERSION=1.1.0<br>";
echo "REQUEST=capabilities&WMTVER=1.0.0<br><br>";
echo "Link to new WMS Capabilities URL:<br><input size='120' type='text' name='myURL'><br>";
+ echo"<input type='checkbox' name='twitter_news' checked='checked'>Publish via Twitter<br>";
+ if (defined("GEO_RSS_FILE") && GEO_RSS_FILE != "") {
+ echo"<input type='checkbox' name='rss_news' checked='checked'>Publish via RSS<br>";
echo "<input type='button' value='Preview Capabilities' onclick='window.open(this.form.myURL.value,\"\",\"\")'> ";
echo "<input type='button' value='Upload Capabilities' onclick='validate()'><br>";
@@ -132,8 +138,13 @@
if (!MD_OVERWRITE) {
$mywms->overwrite=false;
- $mywms->twitterNews = true;
- $mywms->setGeoRss = true;
+ //possibility to see update information in georss and/or twitter channel
+ if(empty($_POST['twitter_news'])) {
+ $mywms->twitterNews = false;
+ if(empty($_POST['rss_news'])) {
+ $mywms->setGeoRss = false;
$mywms->updateObjInDB($myWMS);
$mywms->displayWMS();
Modified: trunk/mapbender/http/plugins/mb_metadata_server.php
--- trunk/mapbender/http/plugins/mb_metadata_server.php 2012-06-20 14:18:07 UTC (rev 8387)
+++ trunk/mapbender/http/plugins/mb_metadata_server.php 2012-06-21 07:11:53 UTC (rev 8388)
@@ -547,9 +547,39 @@
} else {
$wms->wms_network_access = intval('0');
- //$wms->twitterNews = false;
- //$wms->setGeoRss = false;
+ if ($ajaxResponse->getParameter("twitterNews") == true) {
+ $e = new mb_exception("twitter activated");
+ if ($ajaxResponse->getParameter("setGeoRss") == true) {
+ $e = new mb_exception("GeoRSS activated");
+ if ($ajaxResponse->getParameter("setGeoRss") == false) {
+ $e = new mb_exception("GeoRSS deactivated");
+ if ($ajaxResponse->getParameter("twitterNews") == false) {
+ $e = new mb_exception("twitter deactivated");
+ $wms->twitterNews = $ajaxResponse->getParameter("twitterNews");
+ $twitterIsConfigured == true;
+ } else {
+ $twitterIsConfigured == false;
+ if(defined("GEO_RSS_FILE") && GEO_RSS_FILE != "") {
+ $wms->setGeoRss = $ajaxResponse->getParameter("setGeoRss");
+ $rssIsConfigured == true;
+ } else {
+ $rssIsConfigured == false;
//try {
+ $e = new mb_exception("update object in db");
$wms->updateObjInDB($wmsId,true);
//catch (Exception $e) {
@@ -557,9 +587,16 @@
// $ajaxResponse->setMessage(_mb("Could not update wms object in database!"));
// $ajaxResponse->send();
- $ajaxResponse->setMessage("Updated WMS metadata for ID " . $wmsId);
+ $e = new mb_exception("object in db updated");
+ $messResult = "Updated WMS metadata for ID " . $wmsId.". ";
+ //Add helpful hint if publishing is demanded, but not configured in mapbender.conf
+ if ($wms->twitterNews && !$twitterIsConfigured) {
+ $messResult .= " Publishing via twitter was requested, but this is not configured. Please check your mapbender.conf! ";
+ if ($wms->setGeoRss && !$rssIsConfigured) {
+ $messResult .= " Publishing via rss was requested, but this is not configured. Please check your mapbender.conf! ";
+ $ajaxResponse->setMessage($messResult);
$ajaxResponse->setSuccess(true);
break;
Modified: trunk/mapbender/http/plugins/mb_metadata_submit.js
--- trunk/mapbender/http/plugins/mb_metadata_submit.js 2012-06-20 14:18:07 UTC (rev 8387)
+++ trunk/mapbender/http/plugins/mb_metadata_submit.js 2012-06-21 07:11:53 UTC (rev 8388)
@@ -33,7 +33,9 @@
this.events.submit.trigger({
callback: serializeCallback
+ //get publish options
+ twitterNews = $("#twitter_news").is(':checked');
+ setGeoRss = $("#rss_news").is(':checked');
// The form didn't validate
if (formData === null) {
alert("Please complete or correct the data in the form.");
@@ -45,7 +47,9 @@
url: "../plugins/mb_metadata_server.php",
method: "save",
parameters: {
- "data": formData
+ "data": formData,
+ "twitterNews": twitterNews,
+ "setGeoRss": setGeoRss
callback: function (obj, result, message) {
if (!result) {
Modified: trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.7.2_to_2.7.3_pgsql_UTF-8.sql
--- trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.7.2_to_2.7.3_pgsql_UTF-8.sql 2012-06-20 14:18:07 UTC (rev 8387)
+++ trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.7.2_to_2.7.3_pgsql_UTF-8.sql 2012-06-21 07:11:53 UTC (rev 8388)
@@ -443,6 +443,6 @@
ALTER TABLE ows_relation_metadata ADD COLUMN relation_type TEXT;
--update table ows_relation_metadata set type from table mb_metadata -- it is better to have it for relation not for instance - this is only a initial filling, afterwards the code handles the updates and inserts automatical
UPDATE ows_relation_metadata SET relation_type = origin FROM mb_metadata WHERE ows_relation_metadata.fkey_metadata_id = mb_metadata.metadata_id AND ows_relation_metadata.relation_type IS NULL;
+--allow to decide if update of wms metadata will be published via twitter/rss
+UPDATE gui_element set e_content = '<span style=''float:right''><input type=''checkbox'' id=''twitter_news''>Publish via Twitter<input type=''checkbox'' id=''rss_news''>Publish via RSS</input><input disabled="disabled" type=''button'' value=''Preview metadata''><input disabled="disabled" type=''submit'' value=''Save metadata''></span>' WHERE fkey_gui_id = 'admin_wms_metadata' and e_id = 'mb_md_submit';
More information about the Mapbender_commits
