[Mapbender-commits] r8342 - in trunk/mapbender: http/classes
http/php http/plugins resources/db/pgsql/UTF-8/update
svn_mapbender at osgeo.org
Mon May 7 05:54:47 EDT 2012
Author: armin11
Date: 2012-05-07 02:54:47 -0700 (Mon, 07 May 2012)
New Revision: 8342
trunk/mapbender/http/classes/class_universal_wfs_factory.php
trunk/mapbender/http/classes/class_wfsToDb.php
trunk/mapbender/http/classes/class_wfs_1_0_factory.php
trunk/mapbender/http/classes/class_wfs_1_1_factory.php
trunk/mapbender/http/classes/class_wfs_factory.php
trunk/mapbender/http/classes/class_wfs_featuretype.php
trunk/mapbender/http/php/mod_dataISOMetadata.php
trunk/mapbender/http/php/mod_loadwfs.php
trunk/mapbender/http/plugins/mb_metadata_wfs_server.php
trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.7.2_to_2.7.3_pgsql_UTF-8.sql
More work on the wfs metadata editor for inspire. The datamodel is extended to manage othersrs and latlonbboxes for wfs_featuretypes.
Modified: trunk/mapbender/http/classes/class_universal_wfs_factory.php
--- trunk/mapbender/http/classes/class_universal_wfs_factory.php 2012-05-03 15:35:37 UTC (rev 8341)
+++ trunk/mapbender/http/classes/class_universal_wfs_factory.php 2012-05-07 09:54:47 UTC (rev 8342)
@@ -113,4 +113,4 @@
\ No newline at end of file
Modified: trunk/mapbender/http/classes/class_wfsToDb.php
--- trunk/mapbender/http/classes/class_wfsToDb.php 2012-05-03 15:35:37 UTC (rev 8341)
+++ trunk/mapbender/http/classes/class_wfsToDb.php 2012-05-07 09:54:47 UTC (rev 8342)
@@ -164,7 +164,7 @@
$t = array('s', 's', 's', 's', 's', 's', 's', 's' ,'s' ,'s' ,'s' ,'s','s' ,'s','s','s','s','s','s','s','s','s','s','i','i','i','i');
- $e = new mb_exception("UPDATING WFS " . $aWfs->id);
+ $e = new mb_notice("UPDATING WFS " . $aWfs->id);
$res = db_prep_query($sql, $v, $t);
if (!$res) {
$e = new mb_exception("Error while updating WFS in database.");
@@ -189,14 +189,14 @@
array_push($featureTypeNameArray, $currentFeatureType);
if (WfsToDb::featureTypeExists($currentFeatureType)) {
// update existing WFS feature types
- $e = new mb_exception("FT exists");
+ $e = new mb_notice("class_wfsToDb.php: FT exists");
if (!WfsToDb::updateFeatureType($currentFeatureType)) {
db_rollback();
return false;
else {
- $e = new mb_exception("FT ne pas exists");
+ $e = new mb_notice("class_wfsToDb.php: FT ne pas exists");
// insert new feature types
if (!WfsToDb::insertFeatureType($currentFeatureType)) {
db_rollback();
@@ -323,8 +323,35 @@
return true;
+ * Inserts a new WFS feature type crs into the database.
+ * @return Boolean
+ * @param $aWfsFeatureTypeId Integer
+ * @param $aWfsFeatureTypeCrs String
+ private static function insertFeatureTypeCrs ($aWfsFeatureTypeId, $aWfsFeatureTypeCrsString) {
+ $sql = "INSERT INTO wfs_featuretype_epsg (fkey_featuretype_id, epsg) VALUES ($1, $2)";
+ $v = array(
+ $aWfsFeatureTypeId,
+ $aWfsFeatureTypeCrsString
+ $t = array("i", "s");
+ $e = new mb_notice("INSERTING FT Crs (FT: $aWfsFeatureTypeId, Crs: $aWfsFeatureTypeCrsString");
+ $res = db_prep_query($sql, $v, $t);
+ if (!$res) {
+ $e = new mb_exception("Error while inserting WFS feature type crs into the database.");
+ return false;
+ return true;
* Inserts a new WFS feature type element into the database.
* @return Boolean
@@ -453,19 +480,20 @@
private static function insertFeatureType ($aWfsFeatureType) {
$uuid = new Uuid();
$sql = "INSERT INTO wfs_featuretype (fkey_wfs_id, featuretype_name, " .
- "featuretype_title, featuretype_abstract, featuretype_searchable, featuretype_srs, uuid) " .
- "VALUES($1, $2, $3, $4, $5, $6)";
+ "featuretype_title, featuretype_abstract, featuretype_searchable, featuretype_srs, featuretype_latlon_bbox, uuid) " .
+ "VALUES($1, $2, $3, $4, $5, $6, $7, $8)";
$v = array(
$aWfsFeatureType->wfs->id,
$aWfsFeatureType->name,
$aWfsFeatureType->title,
$aWfsFeatureType->summary,
- 1, //default to allow search for a inserted featuretype
+ 1, //default to allow search for a inserted featuretype (searchable)
$aWfsFeatureType->srs,
+ $aWfsFeatureType->latLonBboxArray['minx'].','.$aWfsFeatureType->latLonBboxArray['miny'].','.$aWfsFeatureType->latLonBboxArray['maxx'].','.$aWfsFeatureType->latLonBboxArray['maxy'],
$uuid
- $t = array('i','s','s','s','i','s','s');
+ $t = array('i','s','s','s','i','s','s','s');
$e = new mb_notice("INSERTING FT (FT: $aWfsFeatureType->name)");
$res = db_prep_query($sql,$v,$t);
@@ -484,7 +512,15 @@
return false;
+ // insert feature type crs
+ for ($i = 0; $i < count($aWfsFeatureType->crsArray); $i++) {
+ $crs = $aWfsFeatureType->crsArray[$i];
+ if (!WfsToDb::insertFeatureTypeCrs($aWfsFeatureType->id, $crs)) {
+ return false;
// insert feature type namespaces
for ($i = 0; $i < count($aWfsFeatureType->namespaceArray); $i++) {
$namespace = $aWfsFeatureType->namespaceArray[$i];
@@ -509,19 +545,21 @@
$sql .= "featuretype_title = $1,";
$sql .= "featuretype_abstract = $2,";
$sql .= "featuretype_searchable = $3,";
- $sql .= "featuretype_srs = $4 ";
- $sql .= "WHERE featuretype_id = $5";
+ $sql .= "featuretype_srs = $4, ";
+ $sql .= "featuretype_latlon_bbox = $5 ";
+ $sql .= "WHERE featuretype_id = $6";
$v = array(
$aWfsFeatureType->searchable,
- $t = array('s','s','s','s','i');
+ $t = array('s','s','s','s','s','i');
$e = new mb_notice("UPDATING FT (FT: $aWfsFeatureType->id)");
- $e = new mb_exception("UPDATING FT (FT searchable: $aWfsFeatureType->searchable)");
+ $e = new mb_notice("UPDATING FT (FT searchable: $aWfsFeatureType->searchable)");
if (!$res) {
$e = new mb_exception("Error while updating WFS feature type in database.");
@@ -716,7 +754,7 @@
- $e = new mb_exception($sql . " " . print_r($v, true));
+ $e = new mb_notice($sql . " " . print_r($v, true));
if ($row = db_fetch_array($res)) {
return $row["featuretype_id"];
Modified: trunk/mapbender/http/classes/class_wfs_1_0_factory.php
--- trunk/mapbender/http/classes/class_wfs_1_0_factory.php 2012-05-03 15:35:37 UTC (rev 8341)
+++ trunk/mapbender/http/classes/class_wfs_1_0_factory.php 2012-05-07 09:54:47 UTC (rev 8342)
@@ -180,9 +180,11 @@
if($tag == "GETFEATURE" && $element[type] == "open"){
$section = "getfeature";
if($section == "getfeature" && $tag == "POST"){
$myWfs->getFeature = $element[attributes][onlineResource];
if($tag == "GETFEATURE" && $element[type] == "close"){
$section = "";
@@ -190,36 +192,54 @@
if($tag == "TRANSACTION" && $element[type] == "open"){
$section = "transaction";
if($section == "transaction" && $tag == "POST"){
$myWfs->transaction = $element[attributes][onlineResource];
if($tag == "TRANSACTION" && $element[type] == "close"){
$section = "";
if($tag == "FEATURETYPE" && $element[type] == "open"){
$section = "featuretype";
+ //part for featuretypes
if($section == "featuretype" && $tag == "NAME"){
$featuretype_name = $element[value];
if($section == "featuretype" && $tag == "TITLE"){
$featuretype_title = $this->stripEndlineAndCarriageReturn($element[value]);
if($section == "featuretype" && $tag == "ABSTRACT"){
$featuretype_abstract = $element[value];
if($section == "featuretype" && $tag == "SRS"){
$featuretype_srs = $element[value];
+ //The last element to be parsed
+ if($section == "featuretype" && $tag == "LATLONGBOUNDINGBOX"){
+ $featuretype_latlon_minx = $element[attributes][minx];
+ $featuretype_latlon_miny = $element[attributes][miny];
+ $featuretype_latlon_maxx = $element[attributes][maxx];
+ $featuretype_latlon_maxy = $element[attributes][maxy];
// Do not add defective featuretypes
try {
$currentFeatureType = $this->createFeatureTypeFromUrl($myWfs, $featuretype_name);
if ($currentFeatureType !== null) {
$currentFeatureType->name = $featuretype_name;
$currentFeatureType->title = $featuretype_title;
$currentFeatureType->summary = $featuretype_abstract;
$currentFeatureType->srs = $featuretype_srs;
+ $currentFeatureType->latLonBboxArray['minx'] = $featuretype_latlon_minx;
+ $currentFeatureType->latLonBboxArray['miny'] = $featuretype_latlon_miny;
+ $currentFeatureType->latLonBboxArray['maxx'] = $featuretype_latlon_maxx;
+ $currentFeatureType->latLonBboxArray['maxy'] = $featuretype_latlon_maxy;
$myWfs->addFeatureType($currentFeatureType);
Modified: trunk/mapbender/http/classes/class_wfs_1_1_factory.php
--- trunk/mapbender/http/classes/class_wfs_1_1_factory.php 2012-05-03 15:35:37 UTC (rev 8341)
+++ trunk/mapbender/http/classes/class_wfs_1_1_factory.php 2012-05-07 09:54:47 UTC (rev 8342)
@@ -89,7 +89,7 @@
$doc = new DOMDocument();
$doc->loadXML($xml);
- $e = new mb_exception($xml);
+ $e = new mb_notice("class_wfs_1_1_factory.php: Got following FeatureType XML: ".$xml);
$xpath = new DOMXpath($doc);
$xpath->registerNamespace("xs","http://www.w3.org/2001/XMLSchema");
@@ -175,6 +175,8 @@
$myWfs->getCapabilitiesDoc = $admin->char_encode($xml);
$myWfs->id = $this->createId();
+ $featuretype_crsArray = array();
foreach ($values as $element) {
$tag = $this->sepNameSpace(strtoupper($element[tag]));
@@ -282,19 +284,51 @@
$featureTypeNsArray = $element[attributes];
+ //<DefaultSRS>urn:ogc:def:crs:EPSG::4326</DefaultSRS><OtherSRS>urn:ogc:def:crs:EPSG::4269</OtherSRS><OtherSRS>urn:ogc:def:crs:EPSG::3978</OtherSRS><OtherSRS>urn:ogc:def:crs:EPSG::3857</OtherSRS><OtherSRS>urn:ogc:def:crs:EPSG::31466</OtherSRS><OtherSRS>urn:ogc:def:crs:EPSG::25832</OtherSRS><OtherSRS>urn:ogc:def:crs:EPSG::4258</OtherSRS>
if($section == "featuretype" && $tag == "DEFAULTSRS"){
+ if($section == "featuretype" && $tag == "OTHERSRS"){
+ $featuretype_crsArray[] = $element[value];
+ //<ows:WGS84BoundingBox dimensions="2"><ows:LowerCorner>-9.16611817848171e+15 -3.4016616708962e+32</ows:LowerCorner><ows:UpperCorner>464605646503609 3.4016616708962e+32</ows:UpperCorner></ows:WGS84BoundingBox>
+ if($tag == "WGS84BOUNDINGBOX" && $element[type] == "open"){
+ $section = "bbox";
+ if($section == "bbox" && $tag == "LOWERCORNER"){
+ $lowerCorner = explode(" ",$element[value]);
+ $featuretype_latlon_minx = $lowerCorner[0];
+ $featuretype_latlon_miny = $lowerCorner[1];
+ //The last element which has to be parsed
+ if($section == "bbox" && $tag == "UPPERCORNER"){
+ $upperCorner = explode(" ",$element[value]);
+ $featuretype_latlon_maxx = $upperCorner[0];
+ $featuretype_latlon_maxy = $upperCorner[1];
$e = new mb_notice("class_wfs_1_1_factory.php: parse featuretype ".$featuretype_name);
foreach ( $featureTypeNsArray as $currentNamespace) {
$e = new mb_notice("class_wfs_1_1_factory.php: namespace: ".$currentNamespace);
@@ -306,7 +340,11 @@
+ $currentFeatureType->crsArray = $featuretype_crsArray;
Modified: trunk/mapbender/http/classes/class_wfs_factory.php
--- trunk/mapbender/http/classes/class_wfs_factory.php 2012-05-03 15:35:37 UTC (rev 8341)
+++ trunk/mapbender/http/classes/class_wfs_factory.php 2012-05-07 09:54:47 UTC (rev 8342)
@@ -21,7 +21,6 @@
require_once(dirname(__FILE__)."/../classes/class_administration.php");
require_once(dirname(__FILE__)."/../classes/class_ows_factory.php");
require_once(dirname(__FILE__)."/../classes/class_wfs_featuretype.php");
* @return
@@ -128,6 +127,13 @@
$ft->summary = db_result($res_fe, $cnt_fe, "featuretype_abstract");
$ft->searchable = db_result($res_fe, $cnt_fe, "featuretype_searchable");
$ft->srs = db_result($res_fe, $cnt_fe, "featuretype_srs");
+ $latLonBbox = db_result($res_fe, $cnt_fe, "featuretype_latlon_bbox");
+ $e = new mb_notice("class_wfs_factory: FT latlonbbox: ".$latLonBbox);
+ $latLonBboxArray = explode(",", $latLonBbox);
+ $ft->latLonBboxArray['minx'] = $latLonBboxArray[0];
+ $ft->latLonBboxArray['miny'] = $latLonBboxArray[1];
+ $ft->latLonBboxArray['maxx'] = $latLonBboxArray[2];
+ $ft->latLonBboxArray['maxy'] = $latLonBboxArray[3];
$ft->uuid = db_result($res_fe, $cnt_fe, "uuid");
// Elements
@@ -146,6 +152,20 @@
$cnt_el++;
+ // Crs
+ $sql_crs = "SELECT epsg FROM wfs_featuretype_epsg WHERE fkey_featuretype_id = $1";
+ $v = array($ft->id);
+ $t = array("i");
+ $res_crs = db_prep_query($sql_crs, $v, $t);
+ $cnt_crs = 0;
+ while(db_fetch_row($res_crs)){
+ $ft->addCrs(
+ db_result($res_crs, $cnt_crs, "epsg")
+ $cnt_crs++;
//Namespaces
$sql_ns = "SELECT * FROM wfs_featuretype_namespace WHERE fkey_featuretype_id = $1 ORDER BY namespace";
Modified: trunk/mapbender/http/classes/class_wfs_featuretype.php
--- trunk/mapbender/http/classes/class_wfs_featuretype.php 2012-05-03 15:35:37 UTC (rev 8341)
+++ trunk/mapbender/http/classes/class_wfs_featuretype.php 2012-05-07 09:54:47 UTC (rev 8342)
@@ -28,7 +28,9 @@
var $title;
var $summary;
var $searchable;
- var $srs;
+ var $srs; // Tag DefaultSRS in wfs 1.1.0+
+ var $latLonBboxArray = array();
+ var $crsArray = array(); //new for wfs 1.1.0+ (tag OtherSRS)
var $wfs;
var $namespaceArray = array();
var $elementArray = array();
@@ -75,6 +77,11 @@
return $this;
+ public function addCrs ($crs) {
+ array_push($this->crsArray, $crs);
+ return $this;
public function addElement ($name, $type) {
$newElement = new stdClass();
Modified: trunk/mapbender/http/php/mod_dataISOMetadata.php
--- trunk/mapbender/http/php/mod_dataISOMetadata.php 2012-05-03 15:35:37 UTC (rev 8341)
+++ trunk/mapbender/http/php/mod_dataISOMetadata.php 2012-05-07 09:54:47 UTC (rev 8342)
@@ -188,43 +188,93 @@
function fillISO19139($iso19139, $recordId) {
global $admin;
global $mb_metadata;
+ $noLayer = false;
+ $noFeaturetype = false;
//read out relevant information from mapbender database:
- //layer and service information:
+ //layer and wms information:
$sql = <<<SQL
SELECT layer_id, fkey_wms_id FROM layer INNER JOIN ows_relation_metadata ON
-(ows_relation_metadata.fkey_layer_id=layer.layer_id) WHERE ows_relation_metadata.fkey_metadata_id = $1
+(ows_relation_metadata.fkey_layer_id=layer.layer_id) WHERE ows_relation_metadata.fkey_metadata_id = $1 LIMIT 1
SQL;
//TODO: Problem - the metadata may be used for more than one service - not often but sometimes - does one get the right contact data?
+ //TODO: Problem - this is also the fact if the data is provided by a wfs featuretype! There maybe other contact infos - maybe the info should be integrated more than once and identical info should be identified
$e = new mb_exception("used metadata id: ".$mb_metadata['metadata_id']);
$v = array($mb_metadata['metadata_id']);
$t = array('i');
if (!$res) {
- $exception = "<exception>No coupled resource found in database!</exception>";
- return $exception;
+ $noLayer = true;
} else {
$mb_metadata_coupling = db_fetch_array($res);
$layerId = $mb_metadata_coupling['layer_id'];
- $wmsId = $mb_metadata_coupling['wms_id'];
+ $wmsId = $mb_metadata_coupling['fkey_wms_id'];
$e = new mb_notice("mod_dataISOMetadata.php: Found coupled layer with id: ".$layerId);
- if ($wmsView != '') {
- $sql = "SELECT * ";
- $sql .= "FROM ".$wmsView." WHERE layer_id = $1";
+ //featuretype and wfs information:
+ $sql = <<<SQL
+SELECT featuretype_id, fkey_wfs_id FROM wfs_featuretype INNER JOIN ows_relation_metadata ON
+(ows_relation_metadata.fkey_featuretype_id=wfs_featuretype.featuretype_id) WHERE ows_relation_metadata.fkey_metadata_id = $1 LIMIT 1
+SQL;
+ //TODO: Problem - the metadata may be used for more than one service - not often but sometimes - does one get the right contact data?
+ $e = new mb_exception("used metadata id: ".$mb_metadata['metadata_id']);
+ $v = array($mb_metadata['metadata_id']);
+ $t = array('i');
+ $res = db_prep_query($sql,$v,$t);
+ if (!$res) {
+ $noFeaturetype = true;
+ } else {
+ $mb_metadata_coupling = db_fetch_array($res);
- else {
- //next function is for normal mapbender installations and read the info directly from the wms and layer tables
+ $featuretypeId = $mb_metadata_coupling['featuretype_id'];
+ $wfsId = $mb_metadata_coupling['fkey_wfs_id'];
+ $e = new mb_notice("mod_dataISOMetadata.php: Found coupled featuretype with id: ".$featuretypeId);
+ //if no coupled resource was found - the metadata cannot be created
+ /*if ($noFeaturetype == true && $noFeaturetype == true) {
+ $exception = "<exception>No coupled service ressource found - metadata cannot be created</exception>";
+ return $exception;
+ /*if (!isset($featuretypeId)) {
+ echo "<exception>no featuretype coupled</exception>";
+ die();
+ if ($wmsView != '') {
+ $sql = "SELECT * ";
+ $sql .= "FROM ".$wmsView." WHERE layer_id = $1";
+ else {
+ //next function is for normal mapbender installations and read the info directly from the wms and layer tables
+ $sql = "SELECT ";
+ $sql .= "layer.layer_id,layer.layer_name, layer.layer_title, layer.layer_abstract, layer.layer_pos, layer.layer_parent, layer.layer_minscale, layer.layer_maxscale, layer.uuid,";
+ $sql .= "wms.wms_title, wms.wms_abstract, wms.wms_id, wms.fees, wms.accessconstraints, wms.contactperson, ";
+ $sql .= "wms.contactposition, wms.contactorganization, wms.address, wms.city, wms_timestamp, wms_owner, ";
+ $sql .= "wms.stateorprovince, wms.postcode, wms.contactvoicetelephone, wms.contactfacsimiletelephone, wms.wms_owsproxy,";
+ $sql .= "wms.contactelectronicmailaddress, wms.country, wms.fkey_mb_group_id, ";
+ $sql .= "layer_epsg.minx || ',' || layer_epsg.miny || ',' || layer_epsg.maxx || ',' || layer_epsg.maxy as bbox ";
+ $sql .= "FROM wms, layer, layer_epsg WHERE layer_id = $1 and layer.fkey_wms_id = wms.wms_id";
+ $sql .= " and layer_epsg.fkey_layer_id=layer.layer_id and layer_epsg.epsg='EPSG:4326'";
+ $v = array((integer)$layerId);
+// noFeaturetype = false
$sql = "SELECT ";
- $sql .= "layer.layer_id,layer.layer_name, layer.layer_title, layer.layer_abstract, layer.layer_pos, layer.layer_parent, layer.layer_minscale, layer.layer_maxscale, layer.uuid,";
- $sql .= "wms.wms_title, wms.wms_abstract, wms.wms_id, wms.fees, wms.accessconstraints, wms.contactperson, ";
- $sql .= "wms.contactposition, wms.contactorganization, wms.address, wms.city, wms_timestamp, wms_owner, ";
- $sql .= "wms.stateorprovince, wms.postcode, wms.contactvoicetelephone, wms.contactfacsimiletelephone, wms.wms_owsproxy,";
- $sql .= "wms.contactelectronicmailaddress, wms.country, wms.fkey_mb_group_id, ";
- $sql .= "layer_epsg.minx || ',' || layer_epsg.miny || ',' || layer_epsg.maxx || ',' || layer_epsg.maxy as bbox ";
- $sql .= "FROM wms, layer, layer_epsg WHERE layer_id = $1 and layer.fkey_wms_id = wms.wms_id";
- $sql .= " and layer_epsg.fkey_layer_id=layer.layer_id and layer_epsg.epsg='EPSG:4326'";
+ $sql .= "wfs_featuretype.featuretype_id,wfs_featuretype.featuretype_name, wfs_featuretype.featuretype_title, wfs_featuretype.featuretype_abstract, wfs_featuretype.uuid,";
+ $sql .= "wfs.wfs_title, wfs.wfs_abstract, wfs.wfs_id, wfs.fees, wfs.accessconstraints, wfs.individualname, ";
+ $sql .= "wfs.positionname, wfs.providername, wfs.deliverypoint, wfs.city, wfs_timestamp, wfs_owner, ";
+ $sql .= "wfs.administrativearea, wfs.postalcode, wfs.voice, wfs.facsimile, wfs.wfs_owsproxy,";
+ $sql .= "wfs.electronicmailaddress, wfs.country, wfs.fkey_mb_group_id, ";
+ $v = array((integer)$featuretypeId);
- $v = array((integer)$layerId);
$t = array('i');
$mapbenderMetadata = db_fetch_array($res);
@@ -831,7 +881,7 @@
//generate keyword part - for services the inspire themes are not applicable!!!**********
- //read keywords for resource out of the database:
+ //read keywords for resource out of the database/not only layer keywords also featuretype keywords if given!
$sql = "SELECT keyword.keyword FROM keyword, layer_keyword WHERE layer_keyword.fkey_layer_id=$1 AND layer_keyword.fkey_keyword_id=keyword.keyword_id";
$t = array('i');
Modified: trunk/mapbender/http/php/mod_loadwfs.php
--- trunk/mapbender/http/php/mod_loadwfs.php 2012-05-03 15:35:37 UTC (rev 8341)
+++ trunk/mapbender/http/php/mod_loadwfs.php 2012-05-07 09:54:47 UTC (rev 8342)
@@ -19,7 +19,7 @@
require_once(dirname(__FILE__)."/../php/mb_validateSession.php");
require_once(dirname(__FILE__)."/mb_validateInput.php");
-require_once(dirname(__FILE__)."/../classes/class_universal_wfs_factory.php");
+require_once(dirname(__FILE__)."/../classes/class_universal_wfs_factory.php");
require_once(dirname(__FILE__)."/../classes/class_gui.php");
echo "file: ".$_REQUEST["xml_file"];
@@ -45,4 +45,4 @@
echo $myWfs;
Modified: trunk/mapbender/http/plugins/mb_metadata_wfs_server.php
--- trunk/mapbender/http/plugins/mb_metadata_wfs_server.php 2012-05-03 15:35:37 UTC (rev 8341)
+++ trunk/mapbender/http/plugins/mb_metadata_wfs_server.php 2012-05-07 09:54:47 UTC (rev 8342)
@@ -876,7 +876,7 @@
$spatial_res_value = '';
$inspire_charset = '';
$randomid = new Uuid();
- $e = new mb_exception("File to load: ".$filename);
+ $e = new mb_notice("File to load: ".$filename);
//read out objects from xml structure
/*if (file_exists($filename)) {
try {
@@ -901,7 +901,7 @@
$output = preg_replace($regex,"",$output);
//$e = new mb_exception($output);
$iso19139Xml = simplexml_load_string($output);
- $e = new mb_exception('');
+ //$e = new mb_notice('');
//get elements for database from xml by using xpath
//uuid
@@ -925,7 +925,7 @@
$datasetid = 'undefined';
$code = $iso19139Xml->xpath('/gmd:MD_Metadata/gmd:identificationInfo/gmd:MD_DataIdentification/gmd:citation/gmd:CI_Citation/gmd:identifier/gmd:MD_Identifier/gmd:code/gco:CharacterString');
if (isset($code[0]) && $code[0] != '') {
- $e = new mb_exception("plugins/mb_metadata_server.php: code given thru MD_Identifier: ".$code[0]);
+ $e = new mb_notice("plugins/mb_metadata_server.php: code given thru MD_Identifier: ".$code[0]);
//check if code is defined by codespace and code
$codeSplit = explode("#",$code);
if (isset($codeSplit[0]) && $codeSplit[0] != '' && isset($codeSplit[1]) && $codeSplit[1] != '') {
@@ -1044,7 +1044,10 @@
getWfs($wfsId);
$wfsFactory = new UniversalWfsFactory();
$wfs = $wfsFactory->createFromDb($wfsId, false);
if (is_null($wfs)) {
$ajaxResponse->setSuccess(false);
$ajaxResponse->setMessage(_mb("Invalid WFS ID."));
@@ -1084,12 +1087,12 @@
if (is_array($data->wfs->featuretype_searchable)) {
foreach ($wfs->featureTypeArray as &$featuretype) {//for each existing featuretype
$featuretype->searchable = 0;//initialize new
- $e = new mb_exception("mb_metadata_wfs_server.php: Check ft with id ".$featuretype->id." to be searchable");
+ $e = new mb_notice("mb_metadata_wfs_server.php: Check ft with id ".$featuretype->id." to be searchable");
for ($i = 0; $i < count($data->wfs->featuretype_searchable); $i++) {
$id = $data->wfs->featuretype_searchable[$i];
$e = new mb_notice("mb_metadata_wfs_server.php: ft with id ".$id." found to be searchable");
if ($id == intval($featuretype->id)) {
- $e = new mb_exception("mb_metadata_wfs_server.php: ft identical - update it in wfs object");
+ $e = new mb_notice("mb_metadata_wfs_server.php: ft identical - update it in wfs object");
$featuretype->searchable = 1;
} else {
continue; //with next
Modified: trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.7.2_to_2.7.3_pgsql_UTF-8.sql
--- trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.7.2_to_2.7.3_pgsql_UTF-8.sql 2012-05-03 15:35:37 UTC (rev 8341)
+++ trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.7.2_to_2.7.3_pgsql_UTF-8.sql 2012-05-07 09:54:47 UTC (rev 8342)
@@ -388,6 +388,29 @@
ALTER TABLE ows_relation_metadata ADD COLUMN internal INTEGER;
+--new table for wfs featuretype supported crs - new up from wfs 1.1.0 - the bbox are normally not filled!
+CREATE TABLE wfs_featuretype_epsg
+ fkey_featuretype_id integer NOT NULL DEFAULT 0,
+ epsg character varying(50) NOT NULL DEFAULT ''::character varying,
+ minx double precision DEFAULT 0,
+ miny double precision DEFAULT 0,
+ maxx double precision DEFAULT 0,
+ maxy double precision DEFAULT 0,
+ CONSTRAINT wfs_featuretype_epsg_ibfk_1 FOREIGN KEY (fkey_featuretype_id)
+ REFERENCES wfs_featuretype (featuretype_id) MATCH SIMPLE
+ ON UPDATE CASCADE ON DELETE CASCADE
+WITH (
+ OIDS=FALSE
+ALTER TABLE wfs_featuretype_epsg OWNER TO postgres;
+-- Column: featuretype_latlon_bbox
+-- ALTER TABLE wfs_featuretype DROP COLUMN featuretype_latlon_bbox;
+ALTER TABLE wfs_featuretype ADD COLUMN featuretype_latlon_bbox character varying;
More information about the Mapbender_commits
