[Mapbender-commits] r8348 - trunk/mapbender/http/php
svn_mapbender at osgeo.org
Fri May 11 03:41:50 EDT 2012
Author: verenadiewald
Date: 2012-05-11 00:41:50 -0700 (Fri, 11 May 2012)
New Revision: 8348
trunk/mapbender/http/php/mod_editElementVars.php
trunk/mapbender/http/php/mod_editElements.php
http://trac.osgeo.org/mapbender/ticket/856
Modified: trunk/mapbender/http/php/mod_editElementVars.php
--- trunk/mapbender/http/php/mod_editElementVars.php 2012-05-11 04:27:36 UTC (rev 8347)
+++ trunk/mapbender/http/php/mod_editElementVars.php 2012-05-11 07:41:50 UTC (rev 8348)
@@ -37,6 +37,7 @@
//import_request_variables("PG");
+require_once(dirname(__FILE__)."/../classes/class_administration.php");
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
@@ -133,6 +134,27 @@
<?php
+if((isset($myDelete) && $myDelete == '1') || (isset($mySave) && $mySave == '1')){
+ $checkAdmin = new administration();
+ $myOwnedGuis = $checkAdmin->getGuisByOwner(Mapbender::session()->get("mb_user_id"),true);
+ $modOwnerAlert = false;
+ $ownerAlert = "You do not have the permission to change the elements of this application.";
+ if(!in_array($fkey_gui_id, $myOwnedGuis)) {
+ if($modOwnerAlert == false){
+ $modOwnerAlert = true;
+ if($modOwnerAlert == true){
+ unset($myDelete);
+ unset($mySave);
+ echo "<script language='JavaScript'>";
+ echo "alert('".$ownerAlert."');";
+ echo "</script>";
# handle database updates etc.....
if(isset($mySave) && ($mySave == '1')){
Modified: trunk/mapbender/http/php/mod_editElements.php
--- trunk/mapbender/http/php/mod_editElements.php 2012-05-11 04:27:36 UTC (rev 8347)
+++ trunk/mapbender/http/php/mod_editElements.php 2012-05-11 07:41:50 UTC (rev 8348)
@@ -129,6 +129,29 @@
</style>
<?php
+if((isset($myDelete) && $myDelete == '1') || (isset($mySave) && ($mySave == '1' || $mySave == '2')) || (isset($myDuplicate) && $myDuplicate == '1')){
+ if($_POST["originGuiOfSelectedElement"] && !in_array($_POST["originGuiOfSelectedElement"], $myOwnedGuis)) {
+ unset($myDelete);
+ unset($mySave);
+ unset($myDuplicate);
+ echo "</script>";
if((isset($mySave) && ($mySave == '1' || $mySave == '2')) || isset($myDuplicate)) {
# check module-permission ---------------------------------------------------------
@@ -303,7 +326,7 @@
if(isset($myDelete) && $myDelete == '1'){
- $sql = "DELETE FROM gui_element WHERE e_id = $1 AND fkey_gui_id = $2";
+ $sql = "DELETE FROM gui_element WHERE e_id = $1 AND fkey_gui_id = $2";
$v = array($e_id_,$guiList1);
$t = array('s','s');
$res = db_prep_query($sql,$v,$t);
More information about the Mapbender_commits
