[Mapbender-commits] r8352 -
branches/2.7/resources/db/pgsql/UTF-8/update
trunk/mapbender/resources/db/pgsql/UTF-8/update
svn_mapbender at osgeo.org
Wed May 16 03:57:22 EDT 2012
Author: verenadiewald
Date: 2012-05-16 00:57:22 -0700 (Wed, 16 May 2012)
New Revision: 8352
branches/2.7/resources/db/pgsql/UTF-8/update/update_2.7.2_to_2.7.3_pgsql_UTF-8.sql
trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.7.2_to_2.7.3_pgsql_UTF-8.sql
corrected sql
Modified: branches/2.7/resources/db/pgsql/UTF-8/update/update_2.7.2_to_2.7.3_pgsql_UTF-8.sql
--- branches/2.7/resources/db/pgsql/UTF-8/update/update_2.7.2_to_2.7.3_pgsql_UTF-8.sql 2012-05-14 13:13:12 UTC (rev 8351)
+++ branches/2.7/resources/db/pgsql/UTF-8/update/update_2.7.2_to_2.7.3_pgsql_UTF-8.sql 2012-05-16 07:57:22 UTC (rev 8352)
@@ -53,8 +53,18 @@
-- update all body elements for guis containing wz_jsgraphics.js
---> otherwise new wz_jsgraphics version leads to an error
-UPDATE gui_element set
-e_mb_mod = CASE WHEN e_mb_mod IS NULL THEN '../extensions/RaphaelJS/raphael-1.4.7.min.js' ELSE e_mb_mod::text ||',../extensions/RaphaelJS/raphael-1.4.7.min.js' END where e_id = 'body' and fkey_gui_id IN (SELECT DISTINCT fkey_gui_id FROM gui_element where e_js_file LIKE '%wz_jsgraphics%' OR e_mb_mod LIKE '%wz_jsgraphics%');
+UPDATE gui_element set e_mb_mod =
+CASE
+WHEN e_mb_mod IS NULL
+THEN '../extensions/RaphaelJS/raphael-1.4.7.min.js'
+ELSE
+ CASE
+ WHEN e_mb_mod LIKE '%../extensions/RaphaelJS/raphael-1.4.7.min.js%'
+ THEN e_mb_mod
+ ELSE e_mb_mod::text ||',../extensions/RaphaelJS/raphael-1.4.7.min.js'
+ END
+END
+where e_id = 'body' and fkey_gui_id IN (SELECT DISTINCT fkey_gui_id FROM gui_element where e_js_file LIKE '%wz_jsgraphics%' OR e_mb_mod LIKE '%wz_jsgraphics%');
--update all gui elements using jquery-ui version 1.8.1 to 1.8.16
update gui_element set e_mb_mod = replace(e_mb_mod, 'jquery-ui-1.8.1.custom', 'jquery-ui-1.8.16.custom') where e_mb_mod LIKE '%jquery-ui-1.8.1.custom%';
Modified: trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.7.2_to_2.7.3_pgsql_UTF-8.sql
--- trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.7.2_to_2.7.3_pgsql_UTF-8.sql 2012-05-14 13:13:12 UTC (rev 8351)
+++ trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.7.2_to_2.7.3_pgsql_UTF-8.sql 2012-05-16 07:57:22 UTC (rev 8352)
@@ -53,8 +53,18 @@
+CASE
+ELSE
+ CASE
+ THEN e_mb_mod
+ END
+END
More information about the Mapbender_commits
