[Mapbender-commits] r8356 - in trunk/mapbender/resources/db/pgsql: . UTF-8/update
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Wed May 16 05:11:57 EDT 2012
Author: tbaschetti
Date: 2012-05-16 02:11:57 -0700 (Wed, 16 May 2012)
New Revision: 8356
   trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.7rc1_to_2.7rc2_pgsql_UTF-8.sql
   trunk/mapbender/resources/db/pgsql/template_print.sql
removed double "A4_landscape"
Modified: trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.7rc1_to_2.7rc2_pgsql_UTF-8.sql
--- trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.7rc1_to_2.7rc2_pgsql_UTF-8.sql	2012-05-16 09:10:06 UTC (rev 8355)
+++ trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.7rc1_to_2.7rc2_pgsql_UTF-8.sql	2012-05-16 09:11:57 UTC (rev 8356)
@@ -248,7 +248,7 @@
 ]','','var');
-INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('template_print','printPDF','mbPrintConfig','{"A4 landscape": "A4_landscape_template.json","A4 portrait": "A4_portrait_template.json","A4 landscape": "A4_landscape_template.json","A3 landscape": "A3_landscape_template.json","A3 portrait": "A3_portrait_template.json"}','','var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('template_print','printPDF','mbPrintConfig','{"A4 landscape": "A4_landscape_template.json","A4 portrait": "A4_portrait_template.json","A3 landscape": "A3_landscape_template.json","A3 portrait": "A3_portrait_template.json"}','','var');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('template_print','dragMapSize',2,1,'drag & drop Mapsize','Karte vergrößern','div','','class="ui-state-default"',-59,1,15,15,2,'font-size:1px; cursor:move;','<span class="ui-icon ui-icon ui-icon-arrow-4"></span>','div','mod_dragMapSize.php','','mapframe1','','http://www.mapbender.org/index.php/DragMapSize');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('template_print','jq_ui_mouse',2,1,'jQuery UI mouse','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.1.custom/development-bundle/ui/jquery.ui.mouse.js','','jq_ui_widget','');
 INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('template_print','mapframe1_navigation',4,1,'Adds navigation arrows on top of the map','Navigation','div','','',20,30,NULL ,NULL,1001,'','','div','../plugins/mb_navigation.js','','mapframe1','mapframe1','http://www.mapbender.org/Navigation');
Modified: trunk/mapbender/resources/db/pgsql/template_print.sql
--- trunk/mapbender/resources/db/pgsql/template_print.sql	2012-05-16 09:10:06 UTC (rev 8355)
+++ trunk/mapbender/resources/db/pgsql/template_print.sql	2012-05-16 09:11:57 UTC (rev 8356)
@@ -4,7 +4,7 @@
 'template_print','printPDF',2,1,'pdf print','Print','div','','',1,1,2,2,5,'','<div id="printPDF_working_bg"></div><div id="printPDF_working"><img src="../img/indicator_wheel.gif" style="padding:10px 0 0 10px">Generating PDF</div><div id="printPDF_input"><form id="printPDF_form" action="../print/printFactory.php"><div id="printPDF_selector"></div><div class="print_option"><input type="hidden" id="map_url" name="map_url" value=""/><input type="hidden" id="overview_url" name="overview_url" value=""/><input type="hidden" id="map_scale" name="map_scale" value=""/><input type="hidden" name="measured_x_values" /><input type="hidden" name="measured_y_values" /><br /></div><div class="print_option" id="printPDF_formsubmit"><input id="submit" type="submit" value="Print"><br /></div></form><div id="printPDF_result"></div></div>','div','../plugins/mb_print.js','../../lib/printbox.js,../extensions/jquery-ui-1.7.2.custom/development-bundle/external/bgiframe/jquery.bgiframe.min.js,../exten
 sions/jquery.form.min.js','mapframe1','','http://www.mapbender.org/index.php/Print');
 INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES(
-'template_print', 'printPDF', 'mbPrintConfig', '{"A4 landscape": "A4_landscape_template.json","A4 portrait": "A4_portrait_template.json","A4 landscape": "A4_landscape_template.json","A3 landscape": "A3_landscape_template.json"}', '' ,'var');
+'template_print', 'printPDF', 'mbPrintConfig', '{"A4 landscape": "A4_landscape_template.json","A4 portrait": "A4_portrait_template.json","A3 landscape": "A3_landscape_template.json"}', '' ,'var');
 'template_print', 'body', 'print_css', '../css/print_div.css', '' ,'file/css');
More information about the Mapbender_commits mailing list
