[Mapbender-commits] r8366 - in trunk/mapbender/http: classes php plugins
svn_mapbender at osgeo.org
Tue May 29 08:35:13 PDT 2012
Author: armin11
Date: 2012-05-29 08:35:12 -0700 (Tue, 29 May 2012)
New Revision: 8366
trunk/mapbender/http/classes/class_wfsToDb.php
trunk/mapbender/http/classes/class_wfs_factory.php
trunk/mapbender/http/php/mod_deleteWFS.php
trunk/mapbender/http/plugins/mb_metadata_wfs_server.php
Handling of MetadataURL for WFS featuretypes
Modified: trunk/mapbender/http/classes/class_wfsToDb.php
--- trunk/mapbender/http/classes/class_wfsToDb.php 2012-05-25 12:52:15 UTC (rev 8365)
+++ trunk/mapbender/http/classes/class_wfsToDb.php 2012-05-29 15:35:12 UTC (rev 8366)
@@ -266,7 +266,8 @@
public static function delete ($aWfs) {
//first delete coupled metadata, cause there is no contraints in the database to do so
- $this->deleteFeatureTypeMetadataUrls($aWfs->id);
+ $e = new mb_notice("Deleting MetadataURLs");
+ WfsToDb::deleteFeatureTypeMetadataUrls($aWfs->id);
//then delete wfs itself
$sql = "DELETE FROM wfs WHERE wfs_id = $1";
$v = array($aWfs->id);
@@ -897,8 +898,9 @@
* @param $wfsId integer
private static function deleteFeatureTypeMetadataUrls ($wfsId) {
+ $e = new mb_notice("Deleting coupled WFS MetadataURLs from database.");
$sql = "DELETE FROM mb_metadata INNER JOIN (select * from ows_relation_metadata where (internal is NULL OR internal != 1) and fkey_featuretype_id in ";
$sql .= "(select fkey_featuretype_id from wfs_featuretype where fkey_wfs_id = $1)) as relation on ";
$sql .= "mb_metadata.metadata_id = relation.fkey_metadata_id where mb_metadata.origin = 'capabilities'";
Modified: trunk/mapbender/http/classes/class_wfs_factory.php
--- trunk/mapbender/http/classes/class_wfs_factory.php 2012-05-25 12:52:15 UTC (rev 8365)
+++ trunk/mapbender/http/classes/class_wfs_factory.php 2012-05-29 15:35:12 UTC (rev 8366)
@@ -58,14 +58,14 @@
* @param $id Integer
* @param $aWfs Wfs is being created by the subclass
- public function createFromDb ($id, $withProxyUrls = true) {
+ public function createFromDb ($id) {
if (func_num_args() == 2) {
- $aWfs = func_get_arg(1);
+ $aWfs = func_get_arg(1);//set object to use given wfs object to be extented
else {
return null;
+ $withProxyUrls = true;
// WFS
$sql = "SELECT * FROM wfs WHERE wfs_id = $1;";
$v = array($id);
Modified: trunk/mapbender/http/php/mod_deleteWFS.php
--- trunk/mapbender/http/php/mod_deleteWFS.php 2012-05-25 12:52:15 UTC (rev 8365)
+++ trunk/mapbender/http/php/mod_deleteWFS.php 2012-05-29 15:35:12 UTC (rev 8366)
@@ -17,7 +17,10 @@
# along with this program; if not, write to the Free Software
# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+require_once(dirname(__FILE__)."/../../core/globalSettings.php");
require_once(dirname(__FILE__)."/../php/mb_validatePermission.php");
+require_once(dirname(__FILE__)."/../classes/class_wfs.php");
+require_once(dirname(__FILE__)."/../classes/class_universal_wfs_factory.php");
$e_id="deleteWFS";
$gui_id = Mapbender::session()->get("mb_user_gui");
@@ -48,7 +51,7 @@
<?php
echo '<meta http-equiv="Content-Type" content="text/html; charset='.CHARSET.'">';
-<title>Delete WFS - All Users</title>
+<title>Delete own WFS</title>
<?php
include '../include/dyn_css.php';
@@ -66,10 +69,6 @@
function sel(){
var ind = document.form1.wfsList.selectedIndex;
var wfsData = document.form1.wfsList.options[ind].value.split("###");
@@ -129,16 +128,33 @@
<?php
$logged_user_name=Mapbender::session()->get("mb_user_name");
$logged_user_id=Mapbender::session()->get("mb_user_id");
+###delete if del is set thru GET Parameter
-###delete
-if($del!='-1'){
- $sql = "DELETE FROM wfs WHERE wfs_id = '".$del."'";
- $res = db_query($sql);
+//$del = intval($del);
+if (isset($del) && $del != '') {
+ //parse as integer
+ $del = intval($del);
+ if(is_int($del)){
+ $myWfsFactory = new UniversalWfsFactory();
+ $myWfs = $myWfsFactory->createFromDb($del);
+ if ($myWfs->exists()) {
+ if ($myWfs->owner == $logged_user_id) {
+ $e = new mb_exception("User with id ".$logged_user_id." delete wfs with id ".$myWfs->id);
+ $myWfs->delete();
+ } else {
+ $e = new mb_exception("User with id ".$logged_user_id." is not allowed to delete wfs with id ".$myWfs->id);
+ } else {
+ $e = new mb_exception("Wfs with id ".$myWfs->id." does not exists in mapbender database!");
+ } else {
+ echo "GET Value for wfs to delete is no integer: ".$del;
+} else {
+ echo "GET Value for wfs to delete is not set or empty<br>";
+//echo "user logged in: ".$logged_user_id;
//adopted for owned wfs and not all!!!!!!
$sql_wfs = "SELECT * FROM wfs ";
Modified: trunk/mapbender/http/plugins/mb_metadata_wfs_server.php
--- trunk/mapbender/http/plugins/mb_metadata_wfs_server.php 2012-05-25 12:52:15 UTC (rev 8365)
+++ trunk/mapbender/http/plugins/mb_metadata_wfs_server.php 2012-05-29 15:35:12 UTC (rev 8366)
@@ -1050,7 +1050,7 @@
$wfsFactory = new UniversalWfsFactory();
- $wfs = $wfsFactory->createFromDb($wfsId, false);
+ $wfs = $wfsFactory->createFromDb($wfsId);
if (is_null($wfs)) {
More information about the Mapbender_commits
