[Mapbender-commits] r8484 - trunk/mapbender/http/javascripts
    svn_mapbender at osgeo.org
    Tue Sep  4 09:10:27 PDT 2012
Author: armin11
Date: 2012-09-04 09:10:26 -0700 (Tue, 04 Sep 2012)
New Revision: 8484
   trunk/mapbender/http/javascripts/mb_downloadFeedClient.js
small bugfix
Modified: trunk/mapbender/http/javascripts/mb_downloadFeedClient.js
--- trunk/mapbender/http/javascripts/mb_downloadFeedClient.js	2012-09-04 15:31:40 UTC (rev 8483)
+++ trunk/mapbender/http/javascripts/mb_downloadFeedClient.js	2012-09-04 16:10:26 UTC (rev 8484)
@@ -153,7 +153,6 @@
 	//iterate over all single features which can be identified with the entries of the inspire service feed
 	for(var i=0; i<featureCollection.features.length; ++i) {
 		//fill in first title, rights and abstract in fields
-//alert(featureCollection.features[i].properties.title);//$('#dataset_title').value = "";
 		if (i == id) {
 			$('#dataset_title').val(featureCollection.features[i].properties.title);
 			$('#dataset_rights').val(featureCollection.features[i].properties.rights);
@@ -167,9 +166,12 @@
 		selectOptions = selectOptions+"<option value='"+featureCollection.features[i].properties.datasetFeedLink+"' url='"+featureCollection.features[i].properties.datasetFeedLink+"' optionid='"+i+"'>"+featureCollection.features[i].properties.title+"</option>";
 	datasetSelect.append(selectOptions);
+	//preselect option
+	$("#dataset_select option[optionid='" + id + "']").attr("selected","selected");
 	$('#dataset_select').bind('change', function() {
 		var $this = $(this);
-		optionSelected = $(this).find('option:selected').attr('optionid')
+		optionSelected = $(this).find('option:selected').attr('optionid');
+		//alert(optionSelected);
 		showDatasetList(featureCollection,optionSelected);
 		method =  "getDatasetFeedObjectFromUrl";
         	data = $this.val();
@@ -197,20 +199,14 @@
 	//initialize options
 	var selectROptions = "";
 	//iterate over all possible representations, which are modeled as entries in the dataset feed (here features of the featureCollection)
-	//alert(featureCollection.features.length);
 		selectROptions = selectROptions+"<option value='"+i+"' url='"+featureCollection.features[i].properties.datasetFeedLink+"'>"+featureCollection.features[i].properties.title+"</option>";
 	datasetEntrySelect.append(selectROptions);
 	fillSectionList(featureCollection, id);
-	//alert(id);
 	$('#dataset_representation_select').bind('change', function() {
-		//method =  "getDatasetLinkFromUrl";
-        	//data = $this.val();
-		//alert($this.val());
 		fillSectionList(featureCollection,$this.val());
-		//callServer(data,method);
@@ -221,9 +217,6 @@
 		var selectFOptions = "";
 		//count number of links in representation
 		var numberOfLinks = featureCollection.features[k].properties.link.length;
-		//alert("number of links: "+numberOfLinks+"for representation: "+k);
-		//alert(featureCollection.features[0].properties.entry[0].title);
-		//alert("number of links: "+numberOfLinks);
 		if (numberOfLinks >= 1 || numberOfLinks === undefined) {
 			//show list
 			$("#representation_select").css("display","block");
More information about the Mapbender_commits
