[Mapbender-commits] r8599 - trunk/mapbender/http/classes
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Wed Apr 10 07:14:33 PDT 2013
Author: armin11
Date: 2013-04-10 07:14:32 -0700 (Wed, 10 Apr 2013)
New Revision: 8599
   trunk/mapbender/http/classes/class_connector.php
Rewind some changes, because they had influence in wfs client - json differ and will not be shown
Modified: trunk/mapbender/http/classes/class_connector.php
--- trunk/mapbender/http/classes/class_connector.php	2013-04-10 12:05:24 UTC (rev 8598)
+++ trunk/mapbender/http/classes/class_connector.php	2013-04-10 14:14:32 UTC (rev 8599)
@@ -1,450 +1,430 @@
-<?php
-# $Id$
-# http://www.mapbender.org/index.php/class_connector
-# Copyright (C) 2002 CCGIS
-# This program is free software; you can redistribute it and/or modify
-# it under the terms of the GNU General Public License as published by
-# the Free Software Foundation; either version 2, or (at your option)
-# any later version.
-# This program is distributed in the hope that it will be useful,
-# but WITHOUT ANY WARRANTY; without even the implied warranty of
-# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
-# GNU General Public License for more details.
-# You should have received a copy of the GNU General Public License
-# along with this program; if not, write to the Free Software
-# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
-require_once(dirname(__FILE__)."/../../core/globalSettings.php");
- * Establishes a connection to a given URL (and loads the content).
- * Supports HTTP (GET and POST), cURL and socket connections.
- * @class
-class connector {
-	var $file;
-	private $connectionType;
-	private $timeOut = 20;
-	private $httpType = "get";
-	private $httpVersion = "1.0";
-	private $httpPostData;
-	private $httpContentType;
-	private $accept;
-	private $httpPostFieldsNumber;
-	private $curlSendCustomHeaders = true; //decide to send own headers or not
-	private $curlCookiesession = true;
-	 * @constructor
-	 * @param String url the URL that will be loaded (optional)
-	public function __construct() {
-		$this->set("connectionType", CONNECTION);
-		if (func_num_args() == 1) {
-			$url = func_get_arg(0);
-			if ($url) {
-				$this->load($url);
-		else if (func_num_args() == 2) {
-       		$auth = func_get_arg(1);
-			if ($url) {
-				$this->load($url,$auth);
-	 * Loads content from the given URL.
-	public function load($url) {
-		//some firewalls have problems to allow requests from a server behind it to the same server through
-		//an internet connection. It can be that some requests are done thru this class to the urls of
-		//HTTP_AUTH_PROXY or OWSPROXY. If some of those are part of the url they must be exchanged with 127.0.0.1 - 			//which hopefully should work.
-		//TODO: check if http is ok for all
-		$posPROXY = strpos($url,OWSPROXY);
-		//$e = new mb_exception('class_connector: old url: '.$url);
- 		if($posPROXY !== false && OWSPROXY_USE_LOCALHOST == true){
-			$e = new mb_notice('class_connector: old url: '.$url);
-			$url = str_replace($_SERVER['HTTP_HOST'], "127.0.0.1", $url);
-			$url = str_replace("https", "http", $url);//localhost no https should needed - it will be faster without
-			$e = new mb_notice('class_connector: new url: '.$url);
-		$e = new mb_notice('class_connector: load url: '.$url);
-		if (!$url) {
-			$e = new mb_exception("connector: no URL given");
-			return false;
-		switch ($this->connectionType) {
-			case "curl":
-			    if (func_num_args() == 2) {
-						if (isset($auth)) {
-							$e = new mb_notice("connector: curl auth");
-							$this->file = $this->getCURL($url,$auth);
-				else {
-				$e = new mb_notice("connector: curl without auth");
-					$this->file = $this->getCURL($url);
-				break;
-			case "http":
-			$e = new mb_notice("connector: http");
-				$this->file = $this->getHTTP($url);
-				break;
-			case "socket":
-			$e = new mb_notice("connector: socket");
-				$this->file = $this->getSOCKET($url);
-				break;
-		if(!$this->file){
-			$e = new mb_exception("connector: unable to load: ".$url);
-			return false;
-		return $this->file;
-	 * Sets the environment variables. The following can be set:
-	 * - connectionType ("http", "curl", "socket")
-	 * - httpType ("get", "post")
-	 * - etc.
-	public function set ($key, $value) {
-		switch ($key) {
-			case "connectionType":
-				if ($this->isValidConnectionType($value)) {
-					$this->connectionType = $value;
-				break;
-			case "httpVersion":
-				if (in_array($value, array("1.0", "1.1"))) {
-					$this->httpVersion = $value;
-				else {
-					$e = new mb_exception("class_connector.php: invalid http type '" . $value . "'");
-				break;
-			case "httpType":
-				if (in_array(mb_strtoupper($value), array("POST", "GET"))) {
-					$this->httpType = $value;
-				else {
-				break;
-			case "httpPostData":
-				$this->httpPostData = $value;
-				break;
-			case "httpPostFieldsNumber":
-				$this->httpPostFieldsNumber = $value;
-				break;
-			case "curlSendCustomHeaders":
-				$this->curlSendCustomHeaders = $value;
-				break;
-			case "timeOut":
-				$this->timeOut = (integer)$value;
-				break;
-			case "httpContentType":
-				if ($this->isValidHttpContentType($value)) {
-					$this->httpContentType = $value;
-				break;
-			case "accept":
-				$this->accept = $value;
-				break;
-	private function isValidConnectionType ($value) {
-		if (in_array(mb_strtoupper($value), array("HTTP", "CURL", "SOCKET"))) {
-			return true;
-		else {
-			$e = new mb_exception("class_connector.php: invalid connection type '" . $value . "'");
-			return false;
-	private function isValidHttpContentType ($value) {
-		$validHttpContentTypeArray = array("XML","TEXT/XML","APPLICATION/XML","MULTIPART/FORM-DATA");
-		if (in_array(mb_strtoupper($value), $validHttpContentTypeArray) or strpos(mb_strtoupper($value), "MULTIPART/FORM-DATA") !== false) {
-			switch (mb_strtoupper($value)) {
-				case "XML":
-					$this->httpContentType = "application/xml";
-					break;
-			return true;
-		else {
-			$e = new mb_exception("class_connector.php: invalid HTTP content type '" . $value . "'");
-			return false;
-	private function getCURL($url){
-		//urls should begin with http ;-)
-		$url=ltrim($url);
-		$url=Str_replace(" ","+",$url); //to have no problems with image/png; mode=24bit!
-		$url=str_replace(";","%3B",$url);
-		} //auth should be an array of ['username', 'realm', 'password', 'auth_type'] - or false - problem would be, that these are stored without hashing them!
-		$ch = curl_init ($url);
-		curl_setopt($ch, CURLOPT_BINARYTRANSFER, true); //for images
-		curl_setopt($ch, CURLOPT_FOLLOWLOCATION, true);
-		curl_setopt($ch, CURLOPT_RETURNTRANSFER, true);
-		//hold cookies on redirects (302) - http://stackoverflow.com/questions/1458683/how-do-i-pass-cookies-on-a-curl-redirect - needed for print via internal owsproxy!
-		curl_setopt($ch, CURLOPT_COOKIEFILE, "");
-		//allow https connections and handle certificates quite simply ;-)
-		curl_setopt($ch,CURLOPT_SSL_VERIFYHOST,0);
-		curl_setopt($ch, CURLOPT_SSL_VERIFYPEER, 0);
-		curl_setopt($ch, CURLOPT_CONNECTTIMEOUT, $this->timeOut);
-		//$e = new mb_notice("connector: test1:");
-		//get hostname/ip out of url
-		//$host = parse_url($url,PHP_URL_HOST);
-		$arURL = parse_url($url);
-		$host = $arURL["host"];
-		$port = $arURL["port"];
-		if($port == ''){
-			$port = 80;
-		$path = $arURL["path"];
-		// fill array (HOSTs not for Proxy)
-		$e = new mb_notice("class_connector.php: NOT_PROXY_HOSTS:".NOT_PROXY_HOSTS);
- 	    	$NOT_PROXY_HOSTS_array = explode(",", NOT_PROXY_HOSTS);
- 	    	//check if http_proxy is set as env, if yes, unset it for the curl action here, it will be reset somewhere below - normally not needed, cause it will be only available when at execution time of the script http://php.net/manual/en/function.putenv.php
-		if (getenv('http_proxy')) {
-			$e = new mb_notice("class_connector.php: current http_proxy: ".getenv('http_proxy')." will be unset by putenv('http_proxy')");
-			$tmpHttpProxy = getenv('http_proxy');
-			putenv("http_proxy"); //this should unset the variable???
-		} else {
-			$e = new mb_notice("class_connector.php: http_proxy is not set as env variable!");
- 	    	//$tmpHttpProxy = getenv('http_proxy')?getenv('http_proxy') : "";
- 	    	//putenv("http_proxy");
-		//check if proxy is set and server not in NOT_PROXY_HOSTS
- 	    	if(CONNECTION_PROXY != "" AND (in_array($host, $NOT_PROXY_HOSTS_array)!= true)){
-			curl_setopt($ch, CURLOPT_PROXY,CONNECTION_PROXY.":".CONNECTION_PORT);
-			$e = new mb_notice("class_connector.php: Proxy will be used!");
-			if(CONNECTION_PASSWORD != ""){
-				curl_setopt ($ch, CURLOPT_PROXYUSERPWD, CONNECTION_USER.':'.CONNECTION_PASSWORD);
-		} else {
-			$e = new mb_notice("class_connector.php: Proxy will not be used!");
-		//TODO maybe allow basic authentication for client, but this will store the passwords in plain text
-		//TODO: store the  passwords as digest hash. Therefor we have to handle the realm which is defined in the 401 header and return it back to the scripts like mod_loadwms.php to store the digest into the database - problem: curl cannot handle digest connection without clear username and password - we have to send our own headers
-		if(isset($auth) && $auth != false) {
-			curl_setopt($ch, CURLOPT_USERPWD, $auth['username'].':'.$auth['password']);
-			if ($auth['auth_type'] == 'digest') {
-				curl_setopt($ch, CURLOPT_HTTPAUTH, CURLAUTH_DIGEST);
-			if ($auth['auth_type'] == 'basic') {
-				curl_setopt($ch, CURLOPT_HTTPAUTH, CURLAUTH_BASIC);
-		$useragent=CONNECTION_USERAGENT;
-		//if httpType is POST, set CURLOPT_POST and CURLOPT_POSTFIELDS
-		//and set a usefull http header
-		if(strtoupper($this->httpType) == 'POST'){
-			if (isset($this->accept) && $this->accept != "") {
-				$headers = array(
-					"POST ".$path." HTTP/1.1",
-					"Accept: ".$this->accept,
-					"User-Agent: ".$useragent,
-            			 	"Content-type: ".$this->httpContentType,
-           				"Cache-Control: no-cache",
-	           		 	"Pragma: no-cache",
-	           		 	"Content-length: ".strlen($this->httpPostData)
-			} else {
-				$headers = array(
-            			 	"Content-type: ".$this->httpContentType."; charset=".CHARSET,
-			$e = new mb_notice("connector: CURL POST: ".$this->httpPostData);
-			$e = new mb_notice("connector: CURL POST length: ".strlen($this->httpPostData));
-			$e = new mb_exception("connector: CURL headers: ".print_r($headers));
-			$e = new mb_notice("connector: CURL post fields: ".$this->httpPostFieldsNumber);
-			if ($this->curlSendCustomHeaders) {
-				curl_setopt($ch, CURLOPT_HTTPHEADER, $headers);
-			if ($this->httpPostFieldsNumber != 1){
-				curl_setopt($ch,CURLOPT_POST,$this->httpPostFieldsNumber);
-			} else {
-				curl_setopt($ch, CURLOPT_POST, 1);
-			curl_setopt($ch, CURLOPT_POSTFIELDS, $this->httpPostData);
-			//curl_setopt($ch, CURLOPT_POSTFIELDS, "value=1");
-		//Build own headers for GET Requests - maybe needful?
-		if(strtoupper($this->httpType) == 'GET'){
-			$headers = array(
-					"GET ".$path." HTTP/1.1",
-           				"Host: ".$host.":".$port,
-	           		 	"Accept: */*",
-					"Proxy-Connection: Keep-Alive"
-		#curl_setopt($ch, CURLOPT_HEADER, true);
-		$e = new mb_notice("class_connector.php: CURL connect to:".$url);
-		//curl_setopt ($ch,CURLOPT_USERAGENT,$useragent);
-		curl_setopt($ch,CURLOPT_DNS_USE_GLOBAL_CACHE, false);
-		curl_setopt($ch,CURLINFO_HEADER_OUT, true);
-		curl_setopt($ch, CURLOPT_FORBID_REUSE, false);
-		//curl_setopt ($ch,HTTPPROXYTUNNEL, 1);
-		//curl_setopt ($ch,CURLOPT_AUTOREFERER, 1);
-		//curl_setopt ($ch,CURLOPT_VERBOSE, true);
-		//$handle = fopen('/tmp/phpcurl_error.tmp', 'a'); //use this for debugging purposes
-		//curl_setopt ($ch,CURLOPT_STDERR, $handle);
-		$file = curl_exec ($ch);
-		//handle http authentication
-		$info = curl_getinfo($ch);
-		/*$error_log = "";
-		$error_log .= "http code: ".$info['http_code']."\n";
-		$error_log .= "sent header: ".$info['request_header']."\n";
-		$error_log .= "lookup time: ".$info['namelookup_time']."\n";
-		$error_log .= "redirect_time: ".$info['redirect_time']."\n";
-		$error_log .= "redirect_count: ".$info['redirect_count']."\n";*/
-		if ($info['http_code'] == '401') {
-			curl_close ($ch);
-			return $info['http_code'];
-		if ($info['http_code'] == '502') {
-			curl_close ($ch);
-			$e = new mb_exception("class_connector.php: Problem with connecting Gateway - maybe problem with the configuration of the security proxy (mod_proxy?).");
-			/*fwrite($handle,"HEADER: \n");
-			fwrite($handle,$error_log);
-			fwrite($handle,"502: ".$file."\n");*/
-		curl_close ($ch);
-		//fclose($handle);
-		//reset the env variable http_proxy to the former value
-		if ($tmpHttpProxy != '') {
-			putenv("http_proxy=$tmpHttpProxy");
-		$e = new mb_notice("class_connector.php: CURL give back: ".$file);
-		return $file;
-	private function getHTTP($url){
-		if ($this->httpType == "get") {
-			return @file_get_contents($url);
-		else {
-			$errno = 0;
-			$errstr = "";
-			$urlComponentArray = parse_url($url);
-			$scheme = $urlComponentArray["scheme"];
-			$host = $urlComponentArray["host"];
-			$port = $urlComponentArray["port"];
-			if ($port == "") {
-				if ($scheme == "https") {
-					$port = 443;
-				else {
-					$port = 80;
-			$path = $urlComponentArray["path"];
-			$query = $urlComponentArray["query"];
-			$buf = '';
-				$fp = fsockopen("ssl://". $host, $port, $errno, $errstr);
-			else {
-			    $fp = fsockopen($host, $port);
-			$postStr = "";
-			$postPath = "POST " . $path . "?" . $query . " HTTP/".$this->httpVersion . "\r\n";
-			$postStr .= $postPath;
-		    fputs($fp, $postPath);
-			$postHost = "Host: " . $host . "\r\n";
-			$postStr .= $postHost;
-		    fputs($fp, $postHost);
-		    if ($this->isValidHttpContentType($this->httpContentType)) {
-				$postContentType = "Content-type: " . $this->httpContentType . "\r\n";
-				$postStr .= $postContentType;
-		    	fputs($fp, $postContentType);
-			$postContentLength = "Content-length: " . strlen($this->httpPostData) . "\r\n";
-			$postStr .= $postContentLength;
-		    fputs($fp, $postContentLength);
-			$postClose = "Connection: close\r\n\r\n";
-			$postStr .= $postClose;
-		    fputs($fp, $postClose);
-		    $postStr .= $this->httpPostData;
-			fputs($fp, $this->httpPostData);
-			new mb_notice("connector.http.postData: ".$this->httpPostData);
-		    $xmlstr = false;
-		    //@TODO remove possibly infinite loop
-			while (!feof($fp)) {
-		    	$content = fgets($fp,4096);
-//		    	if( strpos($content, '<?xml') === 0){
-		    	if( strpos($content, '<') === 0){
-		    		$xmlstr = true;
-		    	if($xmlstr == true){
-		    		$buf .= $content;
-		    fclose($fp);
-//		    new mb_notice("connector.http.response: ".$buf);
-		    return $buf;
-	private function getSOCKET($url){
-		$r = "";
-		$fp = fsockopen (CONNECTION_PROXY, CONNECTION_PORT, $errno, $errstr, 30);
-		if (!$fp) {
-			echo "$errstr ($errno)<br />\n";
-		else {
-			fputs ($fp, "GET ".$url." HTTP/1.0\r\n\r\n");
-				$r .= fgets($fp,4096);
-			fclose($fp);
-			return $r;
+<?php
+# $Id$
+# http://www.mapbender.org/index.php/class_connector
+# Copyright (C) 2002 CCGIS
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+require_once(dirname(__FILE__)."/../../core/globalSettings.php");
+ * Establishes a connection to a given URL (and loads the content).
+ * Supports HTTP (GET and POST), cURL and socket connections.
+ * @class
+class connector {
+	var $file;
+	private $connectionType;
+	private $timeOut = 20;
+	private $httpType = "get";
+	private $httpVersion = "1.0";
+	private $httpPostData;
+	private $httpContentType;
+	private $httpPostFieldsNumber;
+	private $curlSendCustomHeaders = true; //decide to send own headers or not
+	private $curlCookiesession = true;
+	 * @constructor
+	 * @param String url the URL that will be loaded (optional)
+	public function __construct() {
+		$this->set("connectionType", CONNECTION);
+		if (func_num_args() == 1) {
+			$url = func_get_arg(0);
+			if ($url) {
+				$this->load($url);
+		else if (func_num_args() == 2) {
+       		$auth = func_get_arg(1);
+			if ($url) {
+				$this->load($url,$auth);
+	 * Loads content from the given URL.
+	public function load($url) {
+		//some firewalls have problems to allow requests from a server behind it to the same server through
+		//an internet connection. It can be that some requests are done thru this class to the urls of
+		//HTTP_AUTH_PROXY or OWSPROXY. If some of those are part of the url they must be exchanged with 127.0.0.1 - 			//which hopefully should work.
+		//TODO: check if http is ok for all
+		$posPROXY = strpos($url,OWSPROXY);
+		//$e = new mb_exception('class_connector: old url: '.$url);
+ 		if($posPROXY !== false && OWSPROXY_USE_LOCALHOST == true){
+			$e = new mb_notice('class_connector: old url: '.$url);
+			$url = str_replace($_SERVER['HTTP_HOST'], "127.0.0.1", $url);
+			$url = str_replace("https", "http", $url);//localhost no https should needed - it will be faster without
+			$e = new mb_notice('class_connector: new url: '.$url);
+		$e = new mb_notice('class_connector: load url: '.$url);
+		if (!$url) {
+			$e = new mb_exception("connector: no URL given");
+			return false;
+		switch ($this->connectionType) {
+			case "curl":
+			    if (func_num_args() == 2) {
+						if (isset($auth)) {
+							$e = new mb_notice("connector: curl auth");
+							$this->file = $this->getCURL($url,$auth);
+				else {
+				$e = new mb_notice("connector: curl without auth");
+					$this->file = $this->getCURL($url);
+				break;
+			case "http":
+			$e = new mb_notice("connector: http");
+				$this->file = $this->getHTTP($url);
+				break;
+			case "socket":
+			$e = new mb_notice("connector: socket");
+				$this->file = $this->getSOCKET($url);
+				break;
+		if(!$this->file){
+			$e = new mb_exception("connector: unable to load: ".$url);
+			return false;
+		return $this->file;
+	 * Sets the environment variables. The following can be set:
+	 * - connectionType ("http", "curl", "socket")
+	 * - httpType ("get", "post")
+	 * - etc.
+	public function set ($key, $value) {
+		switch ($key) {
+			case "connectionType":
+				if ($this->isValidConnectionType($value)) {
+					$this->connectionType = $value;
+				break;
+			case "httpVersion":
+				if (in_array($value, array("1.0", "1.1"))) {
+					$this->httpVersion = $value;
+				else {
+					$e = new mb_exception("class_connector.php: invalid http type '" . $value . "'");
+				break;
+			case "httpType":
+				if (in_array(mb_strtoupper($value), array("POST", "GET"))) {
+					$this->httpType = $value;
+				else {
+				break;
+			case "httpPostData":
+				$this->httpPostData = $value;
+				break;
+			case "httpPostFieldsNumber":
+				$this->httpPostFieldsNumber = $value;
+				break;
+			case "curlSendCustomHeaders":
+				$this->curlSendCustomHeaders = $value;
+				break;
+			case "timeOut":
+				$this->timeOut = (integer)$value;
+				break;
+			case "httpContentType":
+				if ($this->isValidHttpContentType($value)) {
+					$this->httpContentType = $value;
+				break;
+	private function isValidConnectionType ($value) {
+		if (in_array(mb_strtoupper($value), array("HTTP", "CURL", "SOCKET"))) {
+			return true;
+		else {
+			$e = new mb_exception("class_connector.php: invalid connection type '" . $value . "'");
+			return false;
+	private function isValidHttpContentType ($value) {
+		$validHttpContentTypeArray = array("XML","TEXT/XML","APPLICATION/XML","MULTIPART/FORM-DATA");
+		if (in_array(mb_strtoupper($value), $validHttpContentTypeArray)) {
+			switch (mb_strtoupper($value)) {
+				case "XML":
+					$this->httpContentType = "application/xml";
+					break;
+			return true;
+		else {
+			$e = new mb_exception("class_connector.php: invalid HTTP content type '" . $value . "'");
+			return false;
+	private function getCURL($url){
+		//urls should begin with http ;-)
+		$url=ltrim($url);
+		$url=Str_replace(" ","+",$url); //to have no problems with image/png; mode=24bit!
+		$url=str_replace(";","%3B",$url);
+		} //auth should be an array of ['username', 'realm', 'password', 'auth_type'] - or false - problem would be, that these are stored without hashing them!
+		$ch = curl_init ($url);
+		curl_setopt($ch, CURLOPT_BINARYTRANSFER, true); //for images
+		curl_setopt($ch, CURLOPT_FOLLOWLOCATION, true);
+		curl_setopt($ch, CURLOPT_RETURNTRANSFER, true);
+		//hold cookies on redirects (302) - http://stackoverflow.com/questions/1458683/how-do-i-pass-cookies-on-a-curl-redirect - needed for print via internal owsproxy!
+		curl_setopt($ch, CURLOPT_COOKIEFILE, "");
+		//allow https connections and handle certificates quite simply ;-)
+		curl_setopt($ch,CURLOPT_SSL_VERIFYHOST,0);
+		curl_setopt($ch, CURLOPT_SSL_VERIFYPEER, 0);
+		curl_setopt($ch, CURLOPT_CONNECTTIMEOUT, $this->timeOut);
+		//$e = new mb_notice("connector: test1:");
+		//get hostname/ip out of url
+		//$host = parse_url($url,PHP_URL_HOST);
+		$arURL = parse_url($url);
+		$host = $arURL["host"];
+		$port = $arURL["port"];
+		if($port == ''){
+			$port = 80;
+		$path = $arURL["path"];
+		// fill array (HOSTs not for Proxy)
+		$e = new mb_notice("class_connector.php: NOT_PROXY_HOSTS:".NOT_PROXY_HOSTS);
+ 	    	$NOT_PROXY_HOSTS_array = explode(",", NOT_PROXY_HOSTS);
+ 	    	//check if http_proxy is set as env, if yes, unset it for the curl action here, it will be reset somewhere below - normally not needed, cause it will be only available when at execution time of the script http://php.net/manual/en/function.putenv.php
+		if (getenv('http_proxy')) {
+			$e = new mb_notice("class_connector.php: current http_proxy: ".getenv('http_proxy')." will be unset by putenv('http_proxy')");
+			$tmpHttpProxy = getenv('http_proxy');
+			putenv("http_proxy"); //this should unset the variable???
+		} else {
+			$e = new mb_notice("class_connector.php: http_proxy is not set as env variable!");
+ 	    	//$tmpHttpProxy = getenv('http_proxy')?getenv('http_proxy') : "";
+ 	    	//putenv("http_proxy");
+		//check if proxy is set and server not in NOT_PROXY_HOSTS
+ 	    	if(CONNECTION_PROXY != "" AND (in_array($host, $NOT_PROXY_HOSTS_array)!= true)){
+			curl_setopt($ch, CURLOPT_PROXY,CONNECTION_PROXY.":".CONNECTION_PORT);
+			$e = new mb_notice("class_connector.php: Proxy will be used!");
+			if(CONNECTION_PASSWORD != ""){
+				curl_setopt ($ch, CURLOPT_PROXYUSERPWD, CONNECTION_USER.':'.CONNECTION_PASSWORD);
+		} else {
+			$e = new mb_notice("class_connector.php: Proxy will not be used!");
+		//TODO maybe allow basic authentication for client, but this will store the passwords in plain text
+		//TODO: store the  passwords as digest hash. Therefor we have to handle the realm which is defined in the 401 header and return it back to the scripts like mod_loadwms.php to store the digest into the database - problem: curl cannot handle digest connection without clear username and password - we have to send our own headers
+		if(isset($auth) && $auth != false) {
+			curl_setopt($ch, CURLOPT_USERPWD, $auth['username'].':'.$auth['password']);
+			if ($auth['auth_type'] == 'digest') {
+				curl_setopt($ch, CURLOPT_HTTPAUTH, CURLAUTH_DIGEST);
+			if ($auth['auth_type'] == 'basic') {
+				curl_setopt($ch, CURLOPT_HTTPAUTH, CURLAUTH_BASIC);
+		//if httpType is POST, set CURLOPT_POST and CURLOPT_POSTFIELDS
+		//and set a usefull http header
+		if(strtoupper($this->httpType) == 'POST'){
+			$headers = array(
+					"POST ".$path." HTTP/1.1",
+            			 	"Content-type: ".$this->httpContentType."; charset=".CHARSET,
+           				"Cache-Control: no-cache",
+	           		 	"Pragma: no-cache",
+	           		 	"Content-length: ".strlen($this->httpPostData)
+			$e = new mb_notice("connector: CURL POST: ".$this->httpPostData);
+			$e = new mb_notice("connector: CURL POST length: ".strlen($this->httpPostData));
+			if ($this->curlSendCustomHeaders) {
+				curl_setopt($ch, CURLOPT_HTTPHEADER, $headers);
+			if ($this->httpPostFieldsNumber != 1){
+				curl_setopt($ch,CURLOPT_POST,$this->httpPostFieldsNumber);
+			} else {
+				curl_setopt($ch, CURLOPT_POST, 1);
+			curl_setopt($ch, CURLOPT_POSTFIELDS, $this->httpPostData);
+		$useragent=CONNECTION_USERAGENT;
+		//Build own headers for GET Requests - maybe needful?
+		if(strtoupper($this->httpType) == 'GET'){
+			$headers = array(
+					"GET ".$path." HTTP/1.1",
+					"User-Agent: ".$useragent,
+           				"Host: ".$host.":".$port,
+	           		 	"Accept: */*",
+					"Proxy-Connection: Keep-Alive"
+		#curl_setopt($ch, CURLOPT_HEADER, true);
+		$e = new mb_notice("class_connector.php: CURL connect to:".$url);
+		//curl_setopt ($ch,CURLOPT_USERAGENT,$useragent);
+		curl_setopt($ch,CURLOPT_DNS_USE_GLOBAL_CACHE, false);
+		curl_setopt($ch,CURLINFO_HEADER_OUT, true);
+		curl_setopt($ch, CURLOPT_FORBID_REUSE, false);
+		//curl_setopt ($ch,HTTPPROXYTUNNEL, 1);
+		//curl_setopt ($ch,CURLOPT_AUTOREFERER, 1);
+		//curl_setopt ($ch,CURLOPT_VERBOSE, true);
+		//$handle = fopen('/tmp/phpcurl_error.tmp', 'a'); //use this for debugging purposes
+		//curl_setopt ($ch,CURLOPT_STDERR, $handle);
+		$file = curl_exec ($ch);
+		//handle http authentication
+		$info = curl_getinfo($ch);
+		/*$error_log = "";
+		$error_log .= "http code: ".$info['http_code']."\n";
+		$error_log .= "sent header: ".$info['request_header']."\n";
+		$error_log .= "lookup time: ".$info['namelookup_time']."\n";
+		$error_log .= "redirect_time: ".$info['redirect_time']."\n";
+		$error_log .= "redirect_count: ".$info['redirect_count']."\n";*/
+		if ($info['http_code'] == '401') {
+			curl_close ($ch);
+			return $info['http_code'];
+		if ($info['http_code'] == '502') {
+			curl_close ($ch);
+			$e = new mb_exception("class_connector.php: Problem with connecting Gateway - maybe problem with the configuration of the security proxy (mod_proxy?).");
+			/*fwrite($handle,"HEADER: \n");
+			fwrite($handle,$error_log);
+			fwrite($handle,"502: ".$file."\n");*/
+		curl_close ($ch);
+		//fclose($handle);
+		//reset the env variable http_proxy to the former value
+		if ($tmpHttpProxy != '') {
+			putenv("http_proxy=$tmpHttpProxy");
+		$e = new mb_notice("class_connector.php: CURL give back: ".$file);
+		return $file;
+	private function getHTTP($url){
+		if ($this->httpType == "get") {
+			return @file_get_contents($url);
+		else {
+			$errno = 0;
+			$errstr = "";
+			$urlComponentArray = parse_url($url);
+			$scheme = $urlComponentArray["scheme"];
+			$host = $urlComponentArray["host"];
+			$port = $urlComponentArray["port"];
+			if ($port == "") {
+				if ($scheme == "https") {
+					$port = 443;
+				else {
+					$port = 80;
+			$path = $urlComponentArray["path"];
+			$query = $urlComponentArray["query"];
+			$buf = '';
+				$fp = fsockopen("ssl://". $host, $port, $errno, $errstr);
+			else {
+			    $fp = fsockopen($host, $port);
+			$postStr = "";
+			$postPath = "POST " . $path . "?" . $query . " HTTP/".$this->httpVersion . "\r\n";
+			$postStr .= $postPath;
+		    fputs($fp, $postPath);
+			$postHost = "Host: " . $host . "\r\n";
+			$postStr .= $postHost;
+		    fputs($fp, $postHost);
+		    if ($this->isValidHttpContentType($this->httpContentType)) {
+				$postContentType = "Content-type: " . $this->httpContentType . "\r\n";
+				$postStr .= $postContentType;
+		    	fputs($fp, $postContentType);
+			$postContentLength = "Content-length: " . strlen($this->httpPostData) . "\r\n";
+			$postStr .= $postContentLength;
+		    fputs($fp, $postContentLength);
+			$postClose = "Connection: close\r\n\r\n";
+			$postStr .= $postClose;
+		    fputs($fp, $postClose);
+		    $postStr .= $this->httpPostData;
+			fputs($fp, $this->httpPostData);
+			new mb_notice("connector.http.postData: ".$this->httpPostData);
+		    $xmlstr = false;
+		    //@TODO remove possibly infinite loop
+			while (!feof($fp)) {
+		    	$content = fgets($fp,4096);
+//		    	if( strpos($content, '<?xml') === 0){
+		    	if( strpos($content, '<') === 0){
+		    		$xmlstr = true;
+		    	if($xmlstr == true){
+		    		$buf .= $content;
+		    fclose($fp);
+//		    new mb_notice("connector.http.response: ".$buf);
+		    return $buf;
+	private function getSOCKET($url){
+		$r = "";
+		$fp = fsockopen (CONNECTION_PROXY, CONNECTION_PORT, $errno, $errstr, 30);
+		if (!$fp) {
+			echo "$errstr ($errno)<br />\n";
+		else {
+			fputs ($fp, "GET ".$url." HTTP/1.0\r\n\r\n");
+				$r .= fgets($fp,4096);
+			fclose($fp);
+			return $r;
More information about the Mapbender_commits mailing list
