[Mapbender-commits] r8607 - trunk/mapbender/http/classes
svn_mapbender at osgeo.org
Mon Apr 22 22:46:52 PDT 2013
Author: armin11
Date: 2013-04-22 22:46:51 -0700 (Mon, 22 Apr 2013)
New Revision: 8607
trunk/mapbender/http/classes/class_wms.php
Bugfix: License information was lost when updating wms with update module.
Modified: trunk/mapbender/http/classes/class_wms.php
--- trunk/mapbender/http/classes/class_wms.php 2013-04-22 13:01:04 UTC (rev 8606)
+++ trunk/mapbender/http/classes/class_wms.php 2013-04-23 05:46:51 UTC (rev 8607)
@@ -2585,16 +2585,17 @@
db_rollback();
- # delete and refill wms_termsofuse
- $sql = "DELETE FROM wms_termsofuse WHERE fkey_wms_id = $1 ";
- $v = array($myWMS);
- $t = array('i');
- $res = db_prep_query($sql,$v,$t);
- if(!$res){
- db_rollback();
+ if ($updateMetadataOnly) {
+ # delete and refill wms_termsofuse
+ $sql = "DELETE FROM wms_termsofuse WHERE fkey_wms_id = $1 ";
+ $v = array($myWMS);
+ $t = array('i');
+ $res = db_prep_query($sql,$v,$t);
+ if(!$res){
+ db_rollback();
+ $this->insertTermsOfUse($myWMS);
- $this->insertTermsOfUse($myWMS);
//the following things should not be updated by using the metadata editor! Therefor
//if ($updateMetadataOnly) {
// die();
More information about the Mapbender_commits
