[Mapbender-commits] r8687 - in trunk/mapbender: http/classes http/plugins http/print http/print/classes resources/db/pgsql/UTF-8/update
svn_mapbender at osgeo.org
Fri Aug 16 07:07:44 PDT 2013
Author: verenadiewald
Date: 2013-08-16 07:07:43 -0700 (Fri, 16 Aug 2013)
New Revision: 8687
trunk/mapbender/http/classes/class_weldMaps2PNG.php
trunk/mapbender/http/classes/class_weldMaps2PNG_rotate.php
trunk/mapbender/http/plugins/mb_print.php
trunk/mapbender/http/print/classes/mbLegendDecorator.php
trunk/mapbender/http/print/classes/mbMapDecorator.php
trunk/mapbender/http/print/classes/mbTemplatePdf.php
trunk/mapbender/http/print/printFactory.php
trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.7.3_to_2.7.4_pgsql_UTF-8.sql
http://trac.osgeo.org/mapbender/ticket/910
http://trac.osgeo.org/mapbender/ticket/911
Modified: trunk/mapbender/http/classes/class_weldMaps2PNG.php
--- trunk/mapbender/http/classes/class_weldMaps2PNG.php 2013-08-05 10:44:33 UTC (rev 8686)
+++ trunk/mapbender/http/classes/class_weldMaps2PNG.php 2013-08-16 14:07:43 UTC (rev 8687)
@@ -29,16 +29,18 @@
class weldMaps2PNG{
- function weldMaps2PNG($urls,$filename, $encode = true){
+ function weldMaps2PNG($urls,$filename, $encode = true, $opacities=""){
if(!$urls || $urls == ""){
$e = new mb_exception("weldMaps2PNG: no maprequests delivered");
$url = explode("___", $urls);
+ $opacities = explode("___",$opacities);
$obj1 = new stripRequest($url[0]);
$width = $obj1->get("width");
$height = $obj1->get("height");
$image = imagecreatetruecolor($width, $height );
+ imagealphablending($image,true);
$white = ImageColorAllocate($image,255,255,255);
ImageFilledRectangle($image,0,0,$width,$height,$white);
@@ -48,8 +50,16 @@
$url[$i] = $obj->setPNG();
$url[$i] = $obj->encodeGET($encode);
$img = $this->loadpng($url[$i]);
+ $opacity = $opacities[$i] *100;
if($img != false){
+ if(imagecolortransparent($img) > -1 ){
+ imagecopymerge($image, $img, 0, 0, 0, 0, $width, $height,$opacity);
+ }else{
+ $this->filter_opacity($img,$opacity);
imagecopy($image, $img, 0, 0, 0, 0, $width, $height);
@imagedestroy($img);
else{
@@ -77,6 +87,51 @@
+ function filter_opacity( &$img, $opacity ) //params: image resource id, opacity in percentage (eg. 80)
+ if( !isset( $opacity ) )
+ { return false; }
+ $opacity /= 100;
+ //get image width and height
+ $w = imagesx( $img );
+ $h = imagesy( $img );
+ //turn alpha blending off
+ imagealphablending( $img, false );
+ //find the most opaque pixel in the image (the one with the smallest alpha value)
+ $minalpha = 0;
+ for( $x = 0; $x < $w; $x++ )
+ for( $y = 0; $y < $h; $y++ )
+ $alpha = ( imagecolorat( $img, $x, $y ) >> 24 ) & 0xFF;
+ if( $alpha < $minalpha )
+ { $minalpha = $alpha; }
+ //loop through image pixels and modify alpha for each
+ //get current alpha value (represents the TANSPARENCY!)
+ $colorxy = imagecolorat( $img, $x, $y );
+ $alpha = ( $colorxy >> 24 ) & 0xFF;
+ //calculate new alpha
+ if( $minalpha !== 127 )
+ { $alpha = 127 + 127 * $opacity * ( $alpha - 127 ) / ( 127 - $minalpha ); }
+ else
+ { $alpha += 127 * $opacity; }
+ //get the color index with new alpha
+ $alphacolorxy = imagecolorallocatealpha( $img, ( $colorxy >> 16 ) & 0xFF, ( $colorxy >> 8 ) & 0xFF, $colorxy & 0xFF, $alpha );
+ //set pixel with the new color + opacity
+ if( !imagesetpixel( $img, $x, $y, $alphacolorxy ) )
+ { return false; }
+ return true;
Modified: trunk/mapbender/http/classes/class_weldMaps2PNG_rotate.php
--- trunk/mapbender/http/classes/class_weldMaps2PNG_rotate.php 2013-08-05 10:44:33 UTC (rev 8686)
+++ trunk/mapbender/http/classes/class_weldMaps2PNG_rotate.php 2013-08-16 14:07:43 UTC (rev 8687)
@@ -30,7 +30,7 @@
class weldMaps2PNG_rotate extends weldMaps2PNG{
- function weldMaps2PNG_rotate($urls,$filename, $angle, $encode = true){
+ function weldMaps2PNG_rotate($urls,$filename, $angle, $encode = true, $opacities = ""){
$e = new mb_exception("weldMaps2PNG_rotate: no maprequests delivered");
@@ -59,7 +59,7 @@
//get image
$urls = implode("___", $url);
- $this->weldMaps2PNG($urls, $filename, $encode);
+ $this->weldMaps2PNG($urls, $filename, $encode, $opacities);
//rotate image
Modified: trunk/mapbender/http/plugins/mb_print.php
--- trunk/mapbender/http/plugins/mb_print.php 2013-08-05 10:44:33 UTC (rev 8686)
+++ trunk/mapbender/http/plugins/mb_print.php 2013-08-16 14:07:43 UTC (rev 8687)
@@ -467,6 +467,7 @@
var ind = getMapObjIndexByName(myTarget);
var f = jqForm[0];
f.map_url.value = '';
+ f.opacity.value = "";
var scale = f.scale.value || mb_mapObj[ind].getScale();
scale = parseInt(scale, 10);
@@ -480,10 +481,14 @@
if(f.map_url.value != ""){
f.map_url.value += '___';
+ if(f.opacity.value != ""){
+ f.opacity.value += '___';
var currentMapUrl = mb_mapObj[ind].getMapUrl(i, mb_mapObj[ind].getExtentInfos(), scale);
currentMapUrl = replaceMapFileForHighQualityPrint(currentMapUrl, "map");
- f.map_url.value += currentMapUrl
+ f.map_url.value += currentMapUrl;
+ f.opacity.value += mb_mapObj[ind].wms[i].gui_wms_mapopacity;
var wmsLegendObj = [];
@@ -520,6 +525,7 @@
updateFormField(formData, "legend_url", legendUrlArrayJson);
updateFormField(formData, "map_url", f.map_url.value);
updateFormField(formData, "scale", scale);
+ updateFormField(formData, "opacity",f.opacity.value);
//overview_url
var ind_overview = getMapObjIndexByName('overview');
Modified: trunk/mapbender/http/print/classes/mbLegendDecorator.php
--- trunk/mapbender/http/print/classes/mbLegendDecorator.php 2013-08-05 10:44:33 UTC (rev 8686)
+++ trunk/mapbender/http/print/classes/mbLegendDecorator.php 2013-08-16 14:07:43 UTC (rev 8687)
@@ -24,6 +24,8 @@
$currentX = $this->conf->x_ul;
$currentY = $this->conf->y_ul;
+ $cols = $this->pdf->legendColumns;
+ $colWidth = $this->pdf->objPdf->w / $cols;
$json = new Mapbender_JSON();
$wmsLegendArray = $json->decode($_POST["legend_url"]);
@@ -46,7 +48,7 @@
$this->pdf->objPdf->Text($currentX, $currentY, html_entity_decode(utf8_decode($title)));
// $currentY += $mmPerPt * $this->conf->font_size;
$currentY += $titleFontSize;
$this->pdf->objPdf->setFont($this->conf->font_family, "", $this->conf->font_size);
for ($j = 0; $j < count($layerLegendArray); $j++) {
// Legend
@@ -71,7 +73,7 @@
$this->pdf->objPdf->Image(
$legendFilename,
$currentX,
- $currentY-3.5,
+ $currentY-7.5,
($width * $this->conf->scale)
}catch(Exception $E){
@@ -81,10 +83,33 @@
$currentY += ($height * $this->conf->scale) ;
+ if($currentY > ($this->pdf->objPdf->h)-40 AND $j < count($layerLegendArray)-1){
+ //$currentX += 50;
+ $currentX += $colWidth;
+ $currentY = $this->conf->y_ul;
+ if($currentX > ($this->pdf->objPdf->w)-30){
+ $tplidx = $this->pdf->objPdf->importPage(2);
+ $this->pdf->objPdf->addPage();
+ $this->pdf->objPdf->useTemplate($tplidx);
+ $currentX = $this->conf->x_ul;
$currentY += 5;
+ if($currentY > ($this->pdf->objPdf->h)-40 ){
+ if($currentX > ($this->pdf->objPdf->w)-30 AND $i < count($wmsLegendArray)-1){
$this->pdf->unlink($legendFilename);
Modified: trunk/mapbender/http/print/classes/mbMapDecorator.php
--- trunk/mapbender/http/print/classes/mbMapDecorator.php 2013-08-05 10:44:33 UTC (rev 8686)
+++ trunk/mapbender/http/print/classes/mbMapDecorator.php 2013-08-16 14:07:43 UTC (rev 8687)
@@ -58,6 +58,7 @@
public function decorate() {
$urls = $_REQUEST["map_url"];
+ $opacity = $_REQUEST["opacity"];
$array_urls = explode("___", $urls);
//problem with false in some map_urls see http/plugins/mb_metadata_wmcPreview.php
//exchange array_urls with array_urls without false entries
@@ -98,13 +99,13 @@
if ($this->angle != 0) {
if (class_exists('weldMaps2PNG_rotate')) {
- $i = new weldMaps2PNG_rotate(implode("___",$array_urls), $this->filename, $this->angle, false);
+ $i = new weldMaps2PNG_rotate(implode("___",$array_urls), $this->filename, $this->angle, false,$opacity);
} else {
- $i = new weldMaps2PNG(implode("___",$array_urls), $this->filename, false);
+ $i = new weldMaps2PNG(implode("___",$array_urls), $this->filename, false, $opacity);
$e = new mb_warning("mbMapDecorator: no rotation possible.");
} else {
+ $i = new weldMaps2PNG(implode("___",$array_urls), $this->filename, false,$opacity);
$this->pdf->objPdf->Image($this->filename, $this->conf->x_ul, $this->conf->y_ul, $width, $height,'png');
Modified: trunk/mapbender/http/print/classes/mbTemplatePdf.php
--- trunk/mapbender/http/print/classes/mbTemplatePdf.php 2013-08-05 10:44:33 UTC (rev 8686)
+++ trunk/mapbender/http/print/classes/mbTemplatePdf.php 2013-08-16 14:07:43 UTC (rev 8687)
@@ -59,13 +59,21 @@
public function render() {
foreach ($this->confPdf->pages as $pageConf) {
/* apply the template to the pdf page */
- $this->objPdf->addPage();
+ //$this->objPdf->addPage();
$pagecount = $this->objPdf->setSourceFile(dirname(__FILE__)."/../".$pageConf->tpl);
$tplidx = $this->objPdf->importPage($pageConf->useTplPage);
- $controls = $this->confPdf->controls;
- $this->objPdf->useTemplate($tplidx);
foreach ($pageConf->elements as $pageElementId => $pageElementConf) {
+ $elementType = $pageElementConf->type;
+ if ($elementType == 'legend' && $this->printLegend == 'false'){
+ break;
+ }else{
+ $this->objPdf->addPage();
+ $controls = $this->confPdf->controls;
+ $this->objPdf->useTemplate($tplidx);
+ foreach ($pageConf->elements as $pageElementId => $pageElementConf) {
switch ($pageElementConf->type) {
case "map":
@@ -87,9 +95,11 @@
$err = new mbImageDecorator($this, $pageElementId, $pageElementConf, $controls);
break;
case "legend":
- $err = new mbLegendDecorator($this, $pageElementId, $pageElementConf, $controls);
+ if($this->printLegend == 'true'){
+ $err = new mbLegendDecorator($this, $pageElementId, $pageElementConf, $controls);
break;
- case "permanentImage":
+ case "permanentImage":
$err = new mbPermanentImgDecorator($this, $pageElementId, $pageElementConf, $controls);
break;
Modified: trunk/mapbender/http/print/printFactory.php
--- trunk/mapbender/http/print/printFactory.php 2013-08-05 10:44:33 UTC (rev 8686)
+++ trunk/mapbender/http/print/printFactory.php 2013-08-16 14:07:43 UTC (rev 8687)
@@ -23,6 +23,18 @@
$pdf->logRequests = $logRequests;
$pdf->logType = $logType;
+if (isset($printLegend)){
+ $pdf->printLegend = $printLegend;
+}else{
+ $pdf->printLegend = 'true';
+if (isset($legendColumns)){
+ $pdf->legendColumns = $legendColumns;
+}else{
+ $pdf->legendColumns = '1';
$pdf->render();
try {
$pdf->save();
Modified: trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.7.3_to_2.7.4_pgsql_UTF-8.sql
--- trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.7.3_to_2.7.4_pgsql_UTF-8.sql 2013-08-05 10:44:33 UTC (rev 8686)
+++ trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.7.3_to_2.7.4_pgsql_UTF-8.sql 2013-08-16 14:07:43 UTC (rev 8687)
@@ -278,8 +278,27 @@
ALTER TABLE mb_group ADD COLUMN mb_group_address_location geometry;
+-- printPDF: legend_url and opacity fields in e_content for printPDF template print
+UPDATE gui_element SET e_content = '<div id="printPDF_working_bg"></div><div id="printPDF_working"><img src="../img/indicator_wheel.gif" style="padding:10px 0 0 10px">Generating PDF</div><div id="printPDF_input"><form id="printPDF_form" action="../print/printFactory.php"><div id="printPDF_selector"></div><div class="print_option"><input type="hidden" id="map_url" name="map_url" value=""/><input type="hidden" id="legend_url" name="legend_url" value=""/><input type="hidden" id="opacity" name="opacity" value=""/> <input type="hidden" id="overview_url" name="overview_url" value=""/><input type="hidden" id="map_scale" name="map_scale" value=""/><input type="hidden" name="measured_x_values" /><input type="hidden" name="measured_y_values" /><br /></div><div class="print_option" id="printPDF_formsubmit"><input id="submit" type="submit" value="Print"><br /></div></form><div id="printPDF_result"></div></div>'
+WHERE e_id = 'printPDF' and fkey_gui_id = 'template_print';
+-- printPDF: new element_var legendColumns for element printPDF
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type)
+SELECT gui_element.fkey_gui_id,
+'printPDF', 'legendColumns', '2', 'define number of columns on legendpage' ,'php_var' from gui_element
+WHERE
+gui_element.e_id = 'printPDF' AND
+gui_element.fkey_gui_id
+NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE fkey_e_id = 'printPDF' AND var_name = 'legendColumns');
+-- printPDF: new element_var printLegend for element printPDF
+SELECT gui_element.fkey_gui_id, 'printPDF', 'printLegend', 'true', 'define whether the legend should be printed or not' ,'php_var'
+from gui_element
+WHERE
+NOT IN (SELECT fkey_gui_id FROM gui_element_vars WHERE fkey_e_id = 'printPDF' AND var_name = 'printLegend');
More information about the Mapbender_commits
