[Mapbender-commits] r8689 - trunk/mapbender/resources/db/pgsql/UTF-8/update
svn_mapbender at osgeo.org
Thu Aug 22 06:33:25 PDT 2013
Author: armin11
Date: 2013-08-22 06:33:25 -0700 (Thu, 22 Aug 2013)
New Revision: 8689
trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.7.3_to_2.7.4_pgsql_UTF-8.sql
Update postgres functions for collecting categories because now categories relations may be multiple.
Modified: trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.7.3_to_2.7.4_pgsql_UTF-8.sql
--- trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.7.3_to_2.7.4_pgsql_UTF-8.sql 2013-08-22 05:56:12 UTC (rev 8688)
+++ trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.7.3_to_2.7.4_pgsql_UTF-8.sql 2013-08-22 13:33:25 UTC (rev 8689)
@@ -388,3 +388,167 @@
REFERENCES mb_metadata (metadata_id) MATCH SIMPLE
ON UPDATE CASCADE ON DELETE CASCADE;
+-- Function: f_collect_custom_cat_layer(integer)
+-- DROP FUNCTION f_collect_custom_cat_layer(integer);
+CREATE OR REPLACE FUNCTION f_collect_custom_cat_layer(integer)
+ RETURNS text AS
+$BODY$DECLARE
+ i_layer_id ALIAS FOR $1;
+ custom_cat_string TEXT;
+ custom_cat_record RECORD;
+BEGIN
+custom_cat_string := '';
+FOR custom_cat_record IN SELECT DISTINCT layer_custom_category.fkey_custom_category_id from layer_custom_category WHERE layer_custom_category.fkey_layer_id=$1 LOOP
+custom_cat_string := custom_cat_string || '{' ||custom_cat_record.fkey_custom_category_id || '}';
+END LOOP ;
+RETURN custom_cat_string;
+END;
+$BODY$
+ LANGUAGE plpgsql VOLATILE STRICT
+ COST 100;
+ALTER FUNCTION f_collect_custom_cat_layer(integer)
+ OWNER TO postgres;
+-- Function: f_collect_custom_cat_wfs_featuretype(integer)
+-- DROP FUNCTION f_collect_custom_cat_wfs_featuretype(integer);
+CREATE OR REPLACE FUNCTION f_collect_custom_cat_wfs_featuretype(integer)
+ RETURNS text AS
+$BODY$DECLARE
+ i_featuretype_id ALIAS FOR $1;
+BEGIN
+FOR custom_cat_record IN SELECT DISTINCT wfs_featuretype_custom_category.fkey_custom_category_id from wfs_featuretype_custom_category WHERE wfs_featuretype_custom_category.fkey_featuretype_id=$1 LOOP
+END LOOP ;
+END;
+$BODY$
+ COST 100;
+ALTER FUNCTION f_collect_custom_cat_wfs_featuretype(integer)
+-- Function: f_collect_inspire_cat_layer(integer)
+-- DROP FUNCTION f_collect_inspire_cat_layer(integer);
+CREATE OR REPLACE FUNCTION f_collect_inspire_cat_layer(integer)
+ RETURNS text AS
+$BODY$DECLARE
+ inspire_cat_string TEXT;
+ inspire_cat_record RECORD;
+BEGIN
+inspire_cat_string := '';
+FOR inspire_cat_record IN SELECT DISTINCT layer_inspire_category.fkey_inspire_category_id from layer_inspire_category WHERE layer_inspire_category.fkey_layer_id=$1 LOOP
+inspire_cat_string := inspire_cat_string || '{' ||inspire_cat_record.fkey_inspire_category_id || '}';
+END LOOP ;
+RETURN inspire_cat_string;
+END;
+$BODY$
+ COST 100;
+ALTER FUNCTION f_collect_inspire_cat_layer(integer)
+-- Function: f_collect_inspire_cat_wfs_featuretype(integer)
+-- DROP FUNCTION f_collect_inspire_cat_wfs_featuretype(integer);
+CREATE OR REPLACE FUNCTION f_collect_inspire_cat_wfs_featuretype(integer)
+ RETURNS text AS
+$BODY$DECLARE
+ i_wfs_featuretype_id ALIAS FOR $1;
+BEGIN
+FOR inspire_cat_record IN SELECT DISTINCT wfs_featuretype_inspire_category.fkey_inspire_category_id from wfs_featuretype_inspire_category WHERE wfs_featuretype_inspire_category.fkey_featuretype_id=$1 LOOP
+END LOOP ;
+END;
+$BODY$
+ COST 100;
+ALTER FUNCTION f_collect_inspire_cat_wfs_featuretype(integer)
+-- Function: f_collect_topic_cat_layer(integer)
+-- DROP FUNCTION f_collect_topic_cat_layer(integer);
+CREATE OR REPLACE FUNCTION f_collect_topic_cat_layer(integer)
+ RETURNS text AS
+$BODY$DECLARE
+ topic_cat_string TEXT;
+ topic_cat_record RECORD;
+BEGIN
+topic_cat_string := '';
+FOR topic_cat_record IN SELECT DISTINCT layer_md_topic_category.fkey_md_topic_category_id from layer_md_topic_category WHERE layer_md_topic_category.fkey_layer_id=$1 LOOP
+topic_cat_string := topic_cat_string || '{' ||topic_cat_record.fkey_md_topic_category_id || '}';
+END LOOP ;
+RETURN topic_cat_string;
+END;
+$BODY$
+ COST 100;
+ALTER FUNCTION f_collect_topic_cat_layer(integer)
+-- Function: f_collect_topic_cat_wfs_featuretype(integer)
+-- DROP FUNCTION f_collect_topic_cat_wfs_featuretype(integer);
+CREATE OR REPLACE FUNCTION f_collect_topic_cat_wfs_featuretype(integer)
+ RETURNS text AS
+$BODY$DECLARE
+BEGIN
+FOR topic_cat_record IN SELECT DISTINCT wfs_featuretype_md_topic_category.fkey_md_topic_category_id from wfs_featuretype_md_topic_category WHERE wfs_featuretype_md_topic_category.fkey_featuretype_id=$1 LOOP
+END LOOP ;
+END;
+$BODY$
+ COST 100;
+ALTER FUNCTION f_collect_topic_cat_wfs_featuretype(integer)
More information about the Mapbender_commits
